Generated by Cython 3.0.11
Yellow lines hint at Python interaction.
Click on a line that starts with a "+
" to see the C code that Cython generated for it.
Raw output: dataframe.pxi
0001: # See: dataframe.md for technical overview.
0002:
0003: # Auto-flush settings.
0004: # The individual `interval`, `row_count` and `byte_count`
0005: # settings are set to `-1` when disabled.
0006: # If `.enabled`, then at least one of the settings are `!= -1`.
+0007: cdef struct auto_flush_mode_t:
struct __pyx_t_7questdb_7ingress_auto_flush_mode_t { int enabled; int64_t interval; int64_t row_count; int64_t byte_count; };
0008: bint enabled
0009: int64_t interval
0010: int64_t row_count
0011: int64_t byte_count
0012:
0013:
+0014: cdef struct auto_flush_t:
struct __pyx_t_7questdb_7ingress_auto_flush_t { struct line_sender *sender; struct __pyx_t_7questdb_7ingress_auto_flush_mode_t mode; int64_t *last_flush_ms; };
0015: line_sender* sender
0016: auto_flush_mode_t mode
0017: int64_t* last_flush_ms
0018:
0019:
+0020: cdef auto_flush_t auto_flush_blank() noexcept nogil:
static struct __pyx_t_7questdb_7ingress_auto_flush_t __pyx_f_7questdb_7ingress_auto_flush_blank(void) { struct __pyx_t_7questdb_7ingress_auto_flush_t __pyx_v_af; struct __pyx_t_7questdb_7ingress_auto_flush_t __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
0021: cdef auto_flush_t af
+0022: af.sender = NULL
__pyx_v_af.sender = NULL;
+0023: af.mode.enabled = False
__pyx_v_af.mode.enabled = 0;
+0024: af.mode.interval = -1
__pyx_v_af.mode.interval = -1L;
+0025: af.mode.row_count = -1
__pyx_v_af.mode.row_count = -1L;
+0026: af.mode.byte_count = -1
__pyx_v_af.mode.byte_count = -1L;
+0027: af.last_flush_ms = NULL
__pyx_v_af.last_flush_ms = NULL;
+0028: return af
__pyx_r = __pyx_v_af; goto __pyx_L0;
0029:
0030:
+0031: cdef bint should_auto_flush(
static int __pyx_f_7questdb_7ingress_should_auto_flush(struct __pyx_t_7questdb_7ingress_auto_flush_mode_t const *__pyx_v_af_mode, struct line_sender_buffer *__pyx_v_ls_buf, int64_t __pyx_v_last_flush_ms) { int __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
0032: const auto_flush_mode_t* af_mode,
0033: line_sender_buffer* ls_buf,
0034: int64_t last_flush_ms):
+0035: if not af_mode.enabled:
__pyx_t_1 = (!(__pyx_v_af_mode->enabled != 0)); if (__pyx_t_1) { /* … */ }
+0036: return False
__pyx_r = 0; goto __pyx_L0;
0037:
0038: # Check `auto_flush_rows` breach.
+0039: if (af_mode.row_count != -1) and \
__pyx_t_2 = (__pyx_v_af_mode->row_count != -1L); if (__pyx_t_2) { } else { __pyx_t_1 = __pyx_t_2; goto __pyx_L5_bool_binop_done; } /* … */ if (__pyx_t_1) { /* … */ }
+0040: (<int64_t>line_sender_buffer_row_count(ls_buf) >= af_mode.row_count):
__pyx_t_2 = (((int64_t)line_sender_buffer_row_count(__pyx_v_ls_buf)) >= __pyx_v_af_mode->row_count); __pyx_t_1 = __pyx_t_2; __pyx_L5_bool_binop_done:;
+0041: return True
__pyx_r = 1; goto __pyx_L0;
0042:
0043: # Check `auto_flush_bytes` breach.
+0044: if (af_mode.byte_count != -1) and \
__pyx_t_2 = (__pyx_v_af_mode->byte_count != -1L); if (__pyx_t_2) { } else { __pyx_t_1 = __pyx_t_2; goto __pyx_L8_bool_binop_done; } /* … */ if (__pyx_t_1) { /* … */ }
+0045: (<int64_t>line_sender_buffer_size(ls_buf) >= af_mode.byte_count):
__pyx_t_2 = (((int64_t)line_sender_buffer_size(__pyx_v_ls_buf)) >= __pyx_v_af_mode->byte_count); __pyx_t_1 = __pyx_t_2; __pyx_L8_bool_binop_done:;
+0046: return True
0047:
0048: # Check for interval breach.
+0049: if (af_mode.interval != -1) and \
__pyx_t_2 = (__pyx_v_af_mode->interval != -1L); if (__pyx_t_2) { } else { __pyx_t_1 = __pyx_t_2; goto __pyx_L11_bool_binop_done; } /* … */ if (__pyx_t_1) { /* … */ }
+0050: (((line_sender_now_micros() / 1000) - last_flush_ms) >= af_mode.interval):
__pyx_t_2 = (((((double)line_sender_now_micros()) / 1000.0) - __pyx_v_last_flush_ms) >= __pyx_v_af_mode->interval); __pyx_t_1 = __pyx_t_2; __pyx_L11_bool_binop_done:;
+0051: return True
0052:
+0053: return False
0054:
0055:
+0056: cdef struct col_chunks_t:
struct __pyx_t_7questdb_7ingress_col_chunks_t { size_t n_chunks; struct ArrowArray *chunks; };
0057: size_t n_chunks
0058: ArrowArray* chunks # We calloc `n_chunks + 1` of these.
0059:
0060:
+0061: cdef struct col_cursor_t:
struct __pyx_t_7questdb_7ingress_col_cursor_t { struct ArrowArray *chunk; size_t chunk_index; size_t offset; };
0062: ArrowArray* chunk # Current chunk.
0063: size_t chunk_index
0064: size_t offset # i.e. the element index (not byte offset)
0065:
0066:
+0067: cdef enum col_target_t:
enum __pyx_t_7questdb_7ingress_col_target_t { __pyx_e_7questdb_7ingress_col_target_skip = 0, __pyx_e_7questdb_7ingress_col_target_table = 1, __pyx_e_7questdb_7ingress_col_target_symbol = 2, __pyx_e_7questdb_7ingress_col_target_column_bool = 3, __pyx_e_7questdb_7ingress_col_target_column_i64 = 4, __pyx_e_7questdb_7ingress_col_target_column_f64 = 5, __pyx_e_7questdb_7ingress_col_target_column_str = 6, __pyx_e_7questdb_7ingress_col_target_column_ts = 7, __pyx_e_7questdb_7ingress_col_target_at = 8 };
0068: col_target_skip = 0
0069: col_target_table = 1
0070: col_target_symbol = 2
0071: col_target_column_bool = 3
0072: col_target_column_i64 = 4
0073: col_target_column_f64 = 5
0074: col_target_column_str = 6
0075: col_target_column_ts = 7
0076: col_target_at = 8
0077:
0078:
0079: cdef dict _TARGET_NAMES = {
+0080: col_target_t.col_target_skip: "skipped",
__pyx_t_2 = __Pyx_PyDict_NewPresized(9); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 80, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_skip); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 80, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); if (PyDict_SetItem(__pyx_t_2, __pyx_t_3, __pyx_n_u_skipped) < 0) __PYX_ERR(1, 80, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
+0081: col_target_t.col_target_table: "table name",
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_table); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 81, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); if (PyDict_SetItem(__pyx_t_2, __pyx_t_3, __pyx_kp_u_table_name_2) < 0) __PYX_ERR(1, 80, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
+0082: col_target_t.col_target_symbol: "symbol",
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_symbol); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 82, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); if (PyDict_SetItem(__pyx_t_2, __pyx_t_3, __pyx_n_u_symbol) < 0) __PYX_ERR(1, 80, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
+0083: col_target_t.col_target_column_bool: "boolean",
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_bool); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 83, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); if (PyDict_SetItem(__pyx_t_2, __pyx_t_3, __pyx_n_u_boolean) < 0) __PYX_ERR(1, 80, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
+0084: col_target_t.col_target_column_i64: "integer",
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_i64); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 84, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); if (PyDict_SetItem(__pyx_t_2, __pyx_t_3, __pyx_n_u_integer) < 0) __PYX_ERR(1, 80, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
+0085: col_target_t.col_target_column_f64: "float",
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_f64); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 85, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); if (PyDict_SetItem(__pyx_t_2, __pyx_t_3, __pyx_n_u_float) < 0) __PYX_ERR(1, 80, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
+0086: col_target_t.col_target_column_str: "string",
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_str); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 86, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); if (PyDict_SetItem(__pyx_t_2, __pyx_t_3, __pyx_n_u_string) < 0) __PYX_ERR(1, 80, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
+0087: col_target_t.col_target_column_ts: "timestamp",
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_ts); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 87, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); if (PyDict_SetItem(__pyx_t_2, __pyx_t_3, __pyx_n_u_timestamp) < 0) __PYX_ERR(1, 80, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
+0088: col_target_t.col_target_at: "designated timestamp",
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_at); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 88, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); if (PyDict_SetItem(__pyx_t_2, __pyx_t_3, __pyx_kp_u_designated_timestamp) < 0) __PYX_ERR(1, 80, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__TARGET_NAMES); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__TARGET_NAMES, ((PyObject*)__pyx_t_2)); __Pyx_GIVEREF(__pyx_t_2); __pyx_t_2 = 0;
0089: }
0090:
0091:
+0092: cdef enum col_source_t:
enum __pyx_t_7questdb_7ingress_col_source_t { __pyx_e_7questdb_7ingress_col_source_nulls = 0, __pyx_e_7questdb_7ingress_col_source_bool_pyobj = 0x18AEC, __pyx_e_7questdb_7ingress_col_source_bool_numpy = 0x18E70, __pyx_e_7questdb_7ingress_col_source_bool_arrow = 0x19258, __pyx_e_7questdb_7ingress_col_source_int_pyobj = 0x3118C, __pyx_e_7questdb_7ingress_col_source_u8_numpy = 0x31510, __pyx_e_7questdb_7ingress_col_source_i8_numpy = 0x318F8, __pyx_e_7questdb_7ingress_col_source_u16_numpy = 0x31CE0, __pyx_e_7questdb_7ingress_col_source_i16_numpy = 0x320C8, __pyx_e_7questdb_7ingress_col_source_u32_numpy = 0x324B0, __pyx_e_7questdb_7ingress_col_source_i32_numpy = 0x32898, __pyx_e_7questdb_7ingress_col_source_u64_numpy = 0x32C80, __pyx_e_7questdb_7ingress_col_source_i64_numpy = 0x33068, __pyx_e_7questdb_7ingress_col_source_u8_arrow = 0x33450, __pyx_e_7questdb_7ingress_col_source_i8_arrow = 0x33838, __pyx_e_7questdb_7ingress_col_source_u16_arrow = 0x33C20, __pyx_e_7questdb_7ingress_col_source_i16_arrow = 0x34008, __pyx_e_7questdb_7ingress_col_source_u32_arrow = 0x343F0, __pyx_e_7questdb_7ingress_col_source_i32_arrow = 0x347D8, __pyx_e_7questdb_7ingress_col_source_u64_arrow = 0x34BC0, __pyx_e_7questdb_7ingress_col_source_i64_arrow = 0x34FA8, __pyx_e_7questdb_7ingress_col_source_float_pyobj = 0x4982C, __pyx_e_7questdb_7ingress_col_source_f32_numpy = 0x49BB0, __pyx_e_7questdb_7ingress_col_source_f64_numpy = 0x49F98, __pyx_e_7questdb_7ingress_col_source_f32_arrow = 0x4A380, __pyx_e_7questdb_7ingress_col_source_f64_arrow = 0x4A768, __pyx_e_7questdb_7ingress_col_source_str_pyobj = 0x61ECC, __pyx_e_7questdb_7ingress_col_source_str_utf8_arrow = 0x62250, __pyx_e_7questdb_7ingress_col_source_str_i8_cat = 0x62638, __pyx_e_7questdb_7ingress_col_source_str_i16_cat = 0x62A20, __pyx_e_7questdb_7ingress_col_source_str_i32_cat = 0x62E08, __pyx_e_7questdb_7ingress_col_source_str_lrg_utf8_arrow = 0x631F0, __pyx_e_7questdb_7ingress_col_source_dt64ns_numpy = 0x7A508, __pyx_e_7questdb_7ingress_col_source_dt64ns_tz_arrow = 0x7A8F0 };
0093: # Note: Hundreds digit set to 1 if GIL is required.
0094: col_source_nulls = 0
0095: col_source_bool_pyobj = 101100
0096: col_source_bool_numpy = 102000
0097: col_source_bool_arrow = 103000
0098: col_source_int_pyobj = 201100
0099: col_source_u8_numpy = 202000
0100: col_source_i8_numpy = 203000
0101: col_source_u16_numpy = 204000
0102: col_source_i16_numpy = 205000
0103: col_source_u32_numpy = 206000
0104: col_source_i32_numpy = 207000
0105: col_source_u64_numpy = 208000
0106: col_source_i64_numpy = 209000
0107: col_source_u8_arrow = 210000
0108: col_source_i8_arrow = 211000
0109: col_source_u16_arrow = 212000
0110: col_source_i16_arrow = 213000
0111: col_source_u32_arrow = 214000
0112: col_source_i32_arrow = 215000
0113: col_source_u64_arrow = 216000
0114: col_source_i64_arrow = 217000
0115: col_source_float_pyobj = 301100
0116: col_source_f32_numpy = 302000
0117: col_source_f64_numpy = 303000
0118: col_source_f32_arrow = 304000
0119: col_source_f64_arrow = 305000
0120: col_source_str_pyobj = 401100
0121: col_source_str_utf8_arrow = 402000
0122: col_source_str_i8_cat = 403000
0123: col_source_str_i16_cat = 404000
0124: col_source_str_i32_cat = 405000
0125: col_source_str_lrg_utf8_arrow = 406000
0126: col_source_dt64ns_numpy = 501000
0127: col_source_dt64ns_tz_arrow = 502000
0128:
0129:
+0130: cdef bint col_source_needs_gil(col_source_t source) noexcept nogil:
static int __pyx_f_7questdb_7ingress_col_source_needs_gil(enum __pyx_t_7questdb_7ingress_col_source_t __pyx_v_source) { int __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
0131: # Check if hundreds digit is 1.
+0132: return <int>source // 100 % 10 == 1
__pyx_r = (__Pyx_mod_long(__Pyx_div_long(((int)__pyx_v_source), 0x64), 10) == 1); goto __pyx_L0;
0133:
0134:
0135: cdef set _STR_SOURCES = {
+0136: col_source_t.col_source_str_pyobj,
__pyx_t_2 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_pyobj); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 136, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2);
+0137: col_source_t.col_source_str_utf8_arrow,
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_utf8_arrow); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 137, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3);
+0138: col_source_t.col_source_str_lrg_utf8_arrow,
__pyx_t_4 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_lrg_utf8_arrow); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 138, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4);
+0139: col_source_t.col_source_str_i8_cat,
__pyx_t_5 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_i8_cat); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 139, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5);
+0140: col_source_t.col_source_str_i16_cat,
__pyx_t_6 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_i16_cat); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 140, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6);
+0141: col_source_t.col_source_str_i32_cat,
__pyx_t_7 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_i32_cat); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 141, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_8 = PySet_New(0); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 136, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); if (PySet_Add(__pyx_t_8, __pyx_t_2) < 0) __PYX_ERR(1, 136, __pyx_L1_error) __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; if (PySet_Add(__pyx_t_8, __pyx_t_3) < 0) __PYX_ERR(1, 136, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; if (PySet_Add(__pyx_t_8, __pyx_t_4) < 0) __PYX_ERR(1, 136, __pyx_L1_error) __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; if (PySet_Add(__pyx_t_8, __pyx_t_5) < 0) __PYX_ERR(1, 136, __pyx_L1_error) __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; if (PySet_Add(__pyx_t_8, __pyx_t_6) < 0) __PYX_ERR(1, 136, __pyx_L1_error) __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; if (PySet_Add(__pyx_t_8, __pyx_t_7) < 0) __PYX_ERR(1, 136, __pyx_L1_error) __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__STR_SOURCES); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__STR_SOURCES, ((PyObject*)__pyx_t_8)); __Pyx_GIVEREF(__pyx_t_8); __pyx_t_8 = 0;
0142: }
0143:
0144:
0145: cdef dict _PYOBJ_SOURCE_DESCR = {
+0146: col_source_t.col_source_bool_pyobj: "bool",
__pyx_t_8 = __Pyx_PyDict_NewPresized(4); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 146, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __pyx_t_7 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_bool_pyobj); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 146, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); if (PyDict_SetItem(__pyx_t_8, __pyx_t_7, __pyx_n_u_bool) < 0) __PYX_ERR(1, 146, __pyx_L1_error) __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0;
+0147: col_source_t.col_source_int_pyobj: "int",
__pyx_t_7 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_int_pyobj); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 147, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); if (PyDict_SetItem(__pyx_t_8, __pyx_t_7, __pyx_n_u_int) < 0) __PYX_ERR(1, 146, __pyx_L1_error) __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0;
+0148: col_source_t.col_source_float_pyobj: "float",
__pyx_t_7 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_float_pyobj); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 148, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); if (PyDict_SetItem(__pyx_t_8, __pyx_t_7, __pyx_n_u_float) < 0) __PYX_ERR(1, 146, __pyx_L1_error) __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0;
+0149: col_source_t.col_source_str_pyobj: "str",
__pyx_t_7 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_pyobj); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 149, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); if (PyDict_SetItem(__pyx_t_8, __pyx_t_7, __pyx_n_u_str) < 0) __PYX_ERR(1, 146, __pyx_L1_error) __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__PYOBJ_SOURCE_DESCR); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__PYOBJ_SOURCE_DESCR, ((PyObject*)__pyx_t_8)); __Pyx_GIVEREF(__pyx_t_8); __pyx_t_8 = 0;
0150: }
0151:
0152:
0153: cdef dict _TARGET_TO_SOURCES = {
+0154: col_target_t.col_target_skip: {
__pyx_t_8 = __Pyx_PyDict_NewPresized(9); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 154, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __pyx_t_7 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_skip); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 154, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7);
+0155: col_source_t.col_source_nulls,
__pyx_t_6 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_nulls); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 155, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_5 = PySet_New(0); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 155, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); if (PySet_Add(__pyx_t_5, __pyx_t_6) < 0) __PYX_ERR(1, 155, __pyx_L1_error) __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; if (PyDict_SetItem(__pyx_t_8, __pyx_t_7, __pyx_t_5) < 0) __PYX_ERR(1, 154, __pyx_L1_error) __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0;
0156: },
+0157: col_target_t.col_target_table: {
__pyx_t_5 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_table); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 157, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5);
+0158: col_source_t.col_source_str_pyobj,
__pyx_t_7 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_pyobj); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 158, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7);
+0159: col_source_t.col_source_str_utf8_arrow,
__pyx_t_6 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_utf8_arrow); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 159, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6);
+0160: col_source_t.col_source_str_lrg_utf8_arrow,
__pyx_t_4 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_lrg_utf8_arrow); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 160, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4);
+0161: col_source_t.col_source_str_i8_cat,
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_i8_cat); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 161, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3);
+0162: col_source_t.col_source_str_i16_cat,
__pyx_t_2 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_i16_cat); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 162, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2);
+0163: col_source_t.col_source_str_i32_cat,
__pyx_t_9 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_i32_cat); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 163, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_10 = PySet_New(0); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 158, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); if (PySet_Add(__pyx_t_10, __pyx_t_7) < 0) __PYX_ERR(1, 158, __pyx_L1_error) __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; if (PySet_Add(__pyx_t_10, __pyx_t_6) < 0) __PYX_ERR(1, 158, __pyx_L1_error) __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; if (PySet_Add(__pyx_t_10, __pyx_t_4) < 0) __PYX_ERR(1, 158, __pyx_L1_error) __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; if (PySet_Add(__pyx_t_10, __pyx_t_3) < 0) __PYX_ERR(1, 158, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; if (PySet_Add(__pyx_t_10, __pyx_t_2) < 0) __PYX_ERR(1, 158, __pyx_L1_error) __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; if (PySet_Add(__pyx_t_10, __pyx_t_9) < 0) __PYX_ERR(1, 158, __pyx_L1_error) __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; if (PyDict_SetItem(__pyx_t_8, __pyx_t_5, __pyx_t_10) < 0) __PYX_ERR(1, 154, __pyx_L1_error) __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0;
0164: },
+0165: col_target_t.col_target_symbol: {
__pyx_t_10 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_symbol); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 165, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10);
+0166: col_source_t.col_source_str_pyobj,
__pyx_t_5 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_pyobj); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 166, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5);
+0167: col_source_t.col_source_str_utf8_arrow,
__pyx_t_9 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_utf8_arrow); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 167, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9);
+0168: col_source_t.col_source_str_lrg_utf8_arrow,
__pyx_t_2 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_lrg_utf8_arrow); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 168, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2);
+0169: col_source_t.col_source_str_i8_cat,
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_i8_cat); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 169, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3);
+0170: col_source_t.col_source_str_i16_cat,
__pyx_t_4 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_i16_cat); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 170, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4);
+0171: col_source_t.col_source_str_i32_cat,
__pyx_t_6 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_i32_cat); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 171, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_7 = PySet_New(0); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 166, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); if (PySet_Add(__pyx_t_7, __pyx_t_5) < 0) __PYX_ERR(1, 166, __pyx_L1_error) __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; if (PySet_Add(__pyx_t_7, __pyx_t_9) < 0) __PYX_ERR(1, 166, __pyx_L1_error) __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; if (PySet_Add(__pyx_t_7, __pyx_t_2) < 0) __PYX_ERR(1, 166, __pyx_L1_error) __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; if (PySet_Add(__pyx_t_7, __pyx_t_3) < 0) __PYX_ERR(1, 166, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; if (PySet_Add(__pyx_t_7, __pyx_t_4) < 0) __PYX_ERR(1, 166, __pyx_L1_error) __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; if (PySet_Add(__pyx_t_7, __pyx_t_6) < 0) __PYX_ERR(1, 166, __pyx_L1_error) __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; if (PyDict_SetItem(__pyx_t_8, __pyx_t_10, __pyx_t_7) < 0) __PYX_ERR(1, 154, __pyx_L1_error) __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0;
0172: },
+0173: col_target_t.col_target_column_bool: {
__pyx_t_7 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_bool); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 173, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7);
+0174: col_source_t.col_source_bool_pyobj,
__pyx_t_10 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_bool_pyobj); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 174, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10);
+0175: col_source_t.col_source_bool_numpy,
__pyx_t_6 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_bool_numpy); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 175, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6);
+0176: col_source_t.col_source_bool_arrow,
__pyx_t_4 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_bool_arrow); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 176, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __pyx_t_3 = PySet_New(0); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 174, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); if (PySet_Add(__pyx_t_3, __pyx_t_10) < 0) __PYX_ERR(1, 174, __pyx_L1_error) __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; if (PySet_Add(__pyx_t_3, __pyx_t_6) < 0) __PYX_ERR(1, 174, __pyx_L1_error) __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; if (PySet_Add(__pyx_t_3, __pyx_t_4) < 0) __PYX_ERR(1, 174, __pyx_L1_error) __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; if (PyDict_SetItem(__pyx_t_8, __pyx_t_7, __pyx_t_3) < 0) __PYX_ERR(1, 154, __pyx_L1_error) __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
0177: },
+0178: col_target_t.col_target_column_i64: {
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_i64); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 178, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3);
+0179: col_source_t.col_source_int_pyobj,
__pyx_t_7 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_int_pyobj); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7);
+0180: col_source_t.col_source_u8_numpy,
__pyx_t_4 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_u8_numpy); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 180, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4);
+0181: col_source_t.col_source_i8_numpy,
__pyx_t_6 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_i8_numpy); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 181, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6);
+0182: col_source_t.col_source_u16_numpy,
__pyx_t_10 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_u16_numpy); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 182, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10);
+0183: col_source_t.col_source_i16_numpy,
__pyx_t_2 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_i16_numpy); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 183, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2);
+0184: col_source_t.col_source_u32_numpy,
__pyx_t_9 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_u32_numpy); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 184, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9);
+0185: col_source_t.col_source_i32_numpy,
__pyx_t_5 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_i32_numpy); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 185, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5);
+0186: col_source_t.col_source_u64_numpy,
__pyx_t_11 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_u64_numpy); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 186, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_11);
+0187: col_source_t.col_source_i64_numpy,
__pyx_t_12 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_i64_numpy); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 187, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12);
+0188: col_source_t.col_source_u8_arrow,
__pyx_t_13 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_u8_arrow); if (unlikely(!__pyx_t_13)) __PYX_ERR(1, 188, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_13);
+0189: col_source_t.col_source_i8_arrow,
__pyx_t_14 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_i8_arrow); if (unlikely(!__pyx_t_14)) __PYX_ERR(1, 189, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_14);
+0190: col_source_t.col_source_u16_arrow,
__pyx_t_15 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_u16_arrow); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 190, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_15);
+0191: col_source_t.col_source_i16_arrow,
__pyx_t_16 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_i16_arrow); if (unlikely(!__pyx_t_16)) __PYX_ERR(1, 191, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_16);
+0192: col_source_t.col_source_u32_arrow,
__pyx_t_17 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_u32_arrow); if (unlikely(!__pyx_t_17)) __PYX_ERR(1, 192, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_17);
+0193: col_source_t.col_source_i32_arrow,
__pyx_t_18 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_i32_arrow); if (unlikely(!__pyx_t_18)) __PYX_ERR(1, 193, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_18);
+0194: col_source_t.col_source_u64_arrow,
__pyx_t_19 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_u64_arrow); if (unlikely(!__pyx_t_19)) __PYX_ERR(1, 194, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_19);
+0195: col_source_t.col_source_i64_arrow,
__pyx_t_20 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_i64_arrow); if (unlikely(!__pyx_t_20)) __PYX_ERR(1, 195, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_20); __pyx_t_21 = PySet_New(0); if (unlikely(!__pyx_t_21)) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_21); if (PySet_Add(__pyx_t_21, __pyx_t_7) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_4) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_6) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_10) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_2) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_9) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_5) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_11) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_11); __pyx_t_11 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_12) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_13) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_13); __pyx_t_13 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_14) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_14); __pyx_t_14 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_15) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_15); __pyx_t_15 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_16) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_16); __pyx_t_16 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_17) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_17); __pyx_t_17 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_18) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_18); __pyx_t_18 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_19) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_19); __pyx_t_19 = 0; if (PySet_Add(__pyx_t_21, __pyx_t_20) < 0) __PYX_ERR(1, 179, __pyx_L1_error) __Pyx_DECREF(__pyx_t_20); __pyx_t_20 = 0; if (PyDict_SetItem(__pyx_t_8, __pyx_t_3, __pyx_t_21) < 0) __PYX_ERR(1, 154, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __Pyx_DECREF(__pyx_t_21); __pyx_t_21 = 0;
0196: },
+0197: col_target_t.col_target_column_f64: {
__pyx_t_21 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_f64); if (unlikely(!__pyx_t_21)) __PYX_ERR(1, 197, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_21);
+0198: col_source_t.col_source_float_pyobj,
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_float_pyobj); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 198, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3);
+0199: col_source_t.col_source_f32_numpy,
__pyx_t_20 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_f32_numpy); if (unlikely(!__pyx_t_20)) __PYX_ERR(1, 199, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_20);
+0200: col_source_t.col_source_f64_numpy,
__pyx_t_19 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_f64_numpy); if (unlikely(!__pyx_t_19)) __PYX_ERR(1, 200, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_19);
+0201: col_source_t.col_source_f32_arrow,
__pyx_t_18 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_f32_arrow); if (unlikely(!__pyx_t_18)) __PYX_ERR(1, 201, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_18);
+0202: col_source_t.col_source_f64_arrow,
__pyx_t_17 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_f64_arrow); if (unlikely(!__pyx_t_17)) __PYX_ERR(1, 202, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_17); __pyx_t_16 = PySet_New(0); if (unlikely(!__pyx_t_16)) __PYX_ERR(1, 198, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_16); if (PySet_Add(__pyx_t_16, __pyx_t_3) < 0) __PYX_ERR(1, 198, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; if (PySet_Add(__pyx_t_16, __pyx_t_20) < 0) __PYX_ERR(1, 198, __pyx_L1_error) __Pyx_DECREF(__pyx_t_20); __pyx_t_20 = 0; if (PySet_Add(__pyx_t_16, __pyx_t_19) < 0) __PYX_ERR(1, 198, __pyx_L1_error) __Pyx_DECREF(__pyx_t_19); __pyx_t_19 = 0; if (PySet_Add(__pyx_t_16, __pyx_t_18) < 0) __PYX_ERR(1, 198, __pyx_L1_error) __Pyx_DECREF(__pyx_t_18); __pyx_t_18 = 0; if (PySet_Add(__pyx_t_16, __pyx_t_17) < 0) __PYX_ERR(1, 198, __pyx_L1_error) __Pyx_DECREF(__pyx_t_17); __pyx_t_17 = 0; if (PyDict_SetItem(__pyx_t_8, __pyx_t_21, __pyx_t_16) < 0) __PYX_ERR(1, 154, __pyx_L1_error) __Pyx_DECREF(__pyx_t_21); __pyx_t_21 = 0; __Pyx_DECREF(__pyx_t_16); __pyx_t_16 = 0;
0203: },
+0204: col_target_t.col_target_column_str: {
__pyx_t_16 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_str); if (unlikely(!__pyx_t_16)) __PYX_ERR(1, 204, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_16);
+0205: col_source_t.col_source_str_pyobj,
__pyx_t_21 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_pyobj); if (unlikely(!__pyx_t_21)) __PYX_ERR(1, 205, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_21);
+0206: col_source_t.col_source_str_utf8_arrow,
__pyx_t_17 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_utf8_arrow); if (unlikely(!__pyx_t_17)) __PYX_ERR(1, 206, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_17);
+0207: col_source_t.col_source_str_lrg_utf8_arrow,
__pyx_t_18 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_lrg_utf8_arrow); if (unlikely(!__pyx_t_18)) __PYX_ERR(1, 207, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_18);
+0208: col_source_t.col_source_str_i8_cat,
__pyx_t_19 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_i8_cat); if (unlikely(!__pyx_t_19)) __PYX_ERR(1, 208, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_19);
+0209: col_source_t.col_source_str_i16_cat,
__pyx_t_20 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_i16_cat); if (unlikely(!__pyx_t_20)) __PYX_ERR(1, 209, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_20);
+0210: col_source_t.col_source_str_i32_cat,
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_str_i32_cat); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 210, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __pyx_t_15 = PySet_New(0); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 205, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_15); if (PySet_Add(__pyx_t_15, __pyx_t_21) < 0) __PYX_ERR(1, 205, __pyx_L1_error) __Pyx_DECREF(__pyx_t_21); __pyx_t_21 = 0; if (PySet_Add(__pyx_t_15, __pyx_t_17) < 0) __PYX_ERR(1, 205, __pyx_L1_error) __Pyx_DECREF(__pyx_t_17); __pyx_t_17 = 0; if (PySet_Add(__pyx_t_15, __pyx_t_18) < 0) __PYX_ERR(1, 205, __pyx_L1_error) __Pyx_DECREF(__pyx_t_18); __pyx_t_18 = 0; if (PySet_Add(__pyx_t_15, __pyx_t_19) < 0) __PYX_ERR(1, 205, __pyx_L1_error) __Pyx_DECREF(__pyx_t_19); __pyx_t_19 = 0; if (PySet_Add(__pyx_t_15, __pyx_t_20) < 0) __PYX_ERR(1, 205, __pyx_L1_error) __Pyx_DECREF(__pyx_t_20); __pyx_t_20 = 0; if (PySet_Add(__pyx_t_15, __pyx_t_3) < 0) __PYX_ERR(1, 205, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; if (PyDict_SetItem(__pyx_t_8, __pyx_t_16, __pyx_t_15) < 0) __PYX_ERR(1, 154, __pyx_L1_error) __Pyx_DECREF(__pyx_t_16); __pyx_t_16 = 0; __Pyx_DECREF(__pyx_t_15); __pyx_t_15 = 0;
0211: },
+0212: col_target_t.col_target_column_ts: {
__pyx_t_15 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_ts); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 212, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_15);
+0213: col_source_t.col_source_dt64ns_numpy,
__pyx_t_16 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_dt64ns_numpy); if (unlikely(!__pyx_t_16)) __PYX_ERR(1, 213, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_16);
+0214: col_source_t.col_source_dt64ns_tz_arrow,
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_dt64ns_tz_arrow); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 214, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __pyx_t_20 = PySet_New(0); if (unlikely(!__pyx_t_20)) __PYX_ERR(1, 213, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_20); if (PySet_Add(__pyx_t_20, __pyx_t_16) < 0) __PYX_ERR(1, 213, __pyx_L1_error) __Pyx_DECREF(__pyx_t_16); __pyx_t_16 = 0; if (PySet_Add(__pyx_t_20, __pyx_t_3) < 0) __PYX_ERR(1, 213, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; if (PyDict_SetItem(__pyx_t_8, __pyx_t_15, __pyx_t_20) < 0) __PYX_ERR(1, 154, __pyx_L1_error) __Pyx_DECREF(__pyx_t_15); __pyx_t_15 = 0; __Pyx_DECREF(__pyx_t_20); __pyx_t_20 = 0;
0215: },
+0216: col_target_t.col_target_at: {
__pyx_t_20 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_at); if (unlikely(!__pyx_t_20)) __PYX_ERR(1, 216, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_20);
+0217: col_source_t.col_source_dt64ns_numpy,
__pyx_t_15 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_dt64ns_numpy); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 217, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_15);
+0218: col_source_t.col_source_dt64ns_tz_arrow,
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_e_7questdb_7ingress_col_source_dt64ns_tz_arrow); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 218, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __pyx_t_16 = PySet_New(0); if (unlikely(!__pyx_t_16)) __PYX_ERR(1, 217, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_16); if (PySet_Add(__pyx_t_16, __pyx_t_15) < 0) __PYX_ERR(1, 217, __pyx_L1_error) __Pyx_DECREF(__pyx_t_15); __pyx_t_15 = 0; if (PySet_Add(__pyx_t_16, __pyx_t_3) < 0) __PYX_ERR(1, 217, __pyx_L1_error) __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; if (PyDict_SetItem(__pyx_t_8, __pyx_t_20, __pyx_t_16) < 0) __PYX_ERR(1, 154, __pyx_L1_error) __Pyx_DECREF(__pyx_t_20); __pyx_t_20 = 0; __Pyx_DECREF(__pyx_t_16); __pyx_t_16 = 0; __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__TARGET_TO_SOURCES); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__TARGET_TO_SOURCES, ((PyObject*)__pyx_t_8)); __Pyx_GIVEREF(__pyx_t_8); __pyx_t_8 = 0;
0219: },
0220: }
0221:
0222:
0223: # Targets associated with col_meta_target.field.
0224: cdef tuple _FIELD_TARGETS = (
+0225: col_target_t.col_target_skip,
__pyx_t_8 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_skip); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 225, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); /* … */ __pyx_t_18 = PyTuple_New(6); if (unlikely(!__pyx_t_18)) __PYX_ERR(1, 225, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_18); __Pyx_GIVEREF(__pyx_t_8); if (__Pyx_PyTuple_SET_ITEM(__pyx_t_18, 0, __pyx_t_8)) __PYX_ERR(1, 225, __pyx_L1_error); __Pyx_GIVEREF(__pyx_t_16); if (__Pyx_PyTuple_SET_ITEM(__pyx_t_18, 1, __pyx_t_16)) __PYX_ERR(1, 225, __pyx_L1_error); __Pyx_GIVEREF(__pyx_t_20); if (__Pyx_PyTuple_SET_ITEM(__pyx_t_18, 2, __pyx_t_20)) __PYX_ERR(1, 225, __pyx_L1_error); __Pyx_GIVEREF(__pyx_t_3); if (__Pyx_PyTuple_SET_ITEM(__pyx_t_18, 3, __pyx_t_3)) __PYX_ERR(1, 225, __pyx_L1_error); __Pyx_GIVEREF(__pyx_t_15); if (__Pyx_PyTuple_SET_ITEM(__pyx_t_18, 4, __pyx_t_15)) __PYX_ERR(1, 225, __pyx_L1_error); __Pyx_GIVEREF(__pyx_t_19); if (__Pyx_PyTuple_SET_ITEM(__pyx_t_18, 5, __pyx_t_19)) __PYX_ERR(1, 225, __pyx_L1_error); __pyx_t_8 = 0; __pyx_t_16 = 0; __pyx_t_20 = 0; __pyx_t_3 = 0; __pyx_t_15 = 0; __pyx_t_19 = 0; __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__FIELD_TARGETS); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__FIELD_TARGETS, ((PyObject*)__pyx_t_18)); __Pyx_GIVEREF(__pyx_t_18); __pyx_t_18 = 0;
+0226: col_target_t.col_target_column_bool,
__pyx_t_16 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_bool); if (unlikely(!__pyx_t_16)) __PYX_ERR(1, 226, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_16);
+0227: col_target_t.col_target_column_i64,
__pyx_t_20 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_i64); if (unlikely(!__pyx_t_20)) __PYX_ERR(1, 227, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_20);
+0228: col_target_t.col_target_column_f64,
__pyx_t_3 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_f64); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 228, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3);
+0229: col_target_t.col_target_column_str,
__pyx_t_15 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_str); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 229, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_15);
+0230: col_target_t.col_target_column_ts)
__pyx_t_19 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_column_ts); if (unlikely(!__pyx_t_19)) __PYX_ERR(1, 230, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_19);
0231:
0232:
0233: # Targets that map directly from a meta target.
0234: cdef set _DIRECT_META_TARGETS = {
+0235: col_target_t.col_target_table,
__pyx_t_18 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_table); if (unlikely(!__pyx_t_18)) __PYX_ERR(1, 235, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_18);
+0236: col_target_t.col_target_symbol,
__pyx_t_19 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_symbol); if (unlikely(!__pyx_t_19)) __PYX_ERR(1, 236, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_19);
+0237: col_target_t.col_target_at,
__pyx_t_15 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_e_7questdb_7ingress_col_target_at); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 237, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_15); __pyx_t_3 = PySet_New(0); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 235, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); if (PySet_Add(__pyx_t_3, __pyx_t_18) < 0) __PYX_ERR(1, 235, __pyx_L1_error) __Pyx_DECREF(__pyx_t_18); __pyx_t_18 = 0; if (PySet_Add(__pyx_t_3, __pyx_t_19) < 0) __PYX_ERR(1, 235, __pyx_L1_error) __Pyx_DECREF(__pyx_t_19); __pyx_t_19 = 0; if (PySet_Add(__pyx_t_3, __pyx_t_15) < 0) __PYX_ERR(1, 235, __pyx_L1_error) __Pyx_DECREF(__pyx_t_15); __pyx_t_15 = 0; __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__DIRECT_META_TARGETS); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__DIRECT_META_TARGETS, ((PyObject*)__pyx_t_3)); __Pyx_GIVEREF(__pyx_t_3); __pyx_t_3 = 0;
0238: }
0239:
0240:
0241: # This is verbose, but..
0242: # * Enums give us constants.
0243: # * Constants allow unfolding `if` statements into `switch`
0244: # * Switch statements can be more heavily optimized by the C compiler.
+0245: cdef enum col_dispatch_code_t:
enum __pyx_t_7questdb_7ingress_col_dispatch_code_t {
0246: col_dispatch_code_skip_nulls = \
0247: col_target_t.col_target_skip + col_source_t.col_source_nulls
0248:
0249: col_dispatch_code_table__str_pyobj = \
0250: col_target_t.col_target_table + col_source_t.col_source_str_pyobj
0251: col_dispatch_code_table__str_utf8_arrow = \
0252: col_target_t.col_target_table + col_source_t.col_source_str_utf8_arrow
0253: col_dispatch_code_table__str_lrg_utf8_arrow = \
0254: col_target_t.col_target_table + col_source_t.col_source_str_lrg_utf8_arrow
0255: col_dispatch_code_table__str_i8_cat = \
0256: col_target_t.col_target_table + col_source_t.col_source_str_i8_cat
0257: col_dispatch_code_table__str_i16_cat = \
0258: col_target_t.col_target_table + col_source_t.col_source_str_i16_cat
0259: col_dispatch_code_table__str_i32_cat = \
0260: col_target_t.col_target_table + col_source_t.col_source_str_i32_cat
0261:
0262: col_dispatch_code_symbol__str_pyobj = \
0263: col_target_t.col_target_symbol + col_source_t.col_source_str_pyobj
0264: col_dispatch_code_symbol__str_utf8_arrow = \
0265: col_target_t.col_target_symbol + col_source_t.col_source_str_utf8_arrow
0266: col_dispatch_code_symbol__str_lrg_utf8_arrow = \
0267: col_target_t.col_target_symbol + col_source_t.col_source_str_lrg_utf8_arrow
0268: col_dispatch_code_symbol__str_i8_cat = \
0269: col_target_t.col_target_symbol + col_source_t.col_source_str_i8_cat
0270: col_dispatch_code_symbol__str_i16_cat = \
0271: col_target_t.col_target_symbol + col_source_t.col_source_str_i16_cat
0272: col_dispatch_code_symbol__str_i32_cat = \
0273: col_target_t.col_target_symbol + col_source_t.col_source_str_i32_cat
0274:
0275: col_dispatch_code_column_bool__bool_pyobj = \
0276: col_target_t.col_target_column_bool + col_source_t.col_source_bool_pyobj
0277: col_dispatch_code_column_bool__bool_numpy = \
0278: col_target_t.col_target_column_bool + col_source_t.col_source_bool_numpy
0279: col_dispatch_code_column_bool__bool_arrow = \
0280: col_target_t.col_target_column_bool + col_source_t.col_source_bool_arrow
0281:
0282: col_dispatch_code_column_i64__int_pyobj = \
0283: col_target_t.col_target_column_i64 + col_source_t.col_source_int_pyobj
0284: col_dispatch_code_column_i64__u8_numpy = \
0285: col_target_t.col_target_column_i64 + col_source_t.col_source_u8_numpy
0286: col_dispatch_code_column_i64__i8_numpy = \
0287: col_target_t.col_target_column_i64 + col_source_t.col_source_i8_numpy
0288: col_dispatch_code_column_i64__u16_numpy = \
0289: col_target_t.col_target_column_i64 + col_source_t.col_source_u16_numpy
0290: col_dispatch_code_column_i64__i16_numpy = \
0291: col_target_t.col_target_column_i64 + col_source_t.col_source_i16_numpy
0292: col_dispatch_code_column_i64__u32_numpy = \
0293: col_target_t.col_target_column_i64 + col_source_t.col_source_u32_numpy
0294: col_dispatch_code_column_i64__i32_numpy = \
0295: col_target_t.col_target_column_i64 + col_source_t.col_source_i32_numpy
0296: col_dispatch_code_column_i64__u64_numpy = \
0297: col_target_t.col_target_column_i64 + col_source_t.col_source_u64_numpy
0298: col_dispatch_code_column_i64__i64_numpy = \
0299: col_target_t.col_target_column_i64 + col_source_t.col_source_i64_numpy
0300: col_dispatch_code_column_i64__u8_arrow = \
0301: col_target_t.col_target_column_i64 + col_source_t.col_source_u8_arrow
0302: col_dispatch_code_column_i64__i8_arrow = \
0303: col_target_t.col_target_column_i64 + col_source_t.col_source_i8_arrow
0304: col_dispatch_code_column_i64__u16_arrow = \
0305: col_target_t.col_target_column_i64 + col_source_t.col_source_u16_arrow
0306: col_dispatch_code_column_i64__i16_arrow = \
0307: col_target_t.col_target_column_i64 + col_source_t.col_source_i16_arrow
0308: col_dispatch_code_column_i64__u32_arrow = \
0309: col_target_t.col_target_column_i64 + col_source_t.col_source_u32_arrow
0310: col_dispatch_code_column_i64__i32_arrow = \
0311: col_target_t.col_target_column_i64 + col_source_t.col_source_i32_arrow
0312: col_dispatch_code_column_i64__u64_arrow = \
0313: col_target_t.col_target_column_i64 + col_source_t.col_source_u64_arrow
0314: col_dispatch_code_column_i64__i64_arrow = \
0315: col_target_t.col_target_column_i64 + col_source_t.col_source_i64_arrow
0316:
0317: col_dispatch_code_column_f64__float_pyobj = \
0318: col_target_t.col_target_column_f64 + col_source_t.col_source_float_pyobj
0319: col_dispatch_code_column_f64__f32_numpy = \
0320: col_target_t.col_target_column_f64 + col_source_t.col_source_f32_numpy
0321: col_dispatch_code_column_f64__f64_numpy = \
0322: col_target_t.col_target_column_f64 + col_source_t.col_source_f64_numpy
0323: col_dispatch_code_column_f64__f32_arrow = \
0324: col_target_t.col_target_column_f64 + col_source_t.col_source_f32_arrow
0325: col_dispatch_code_column_f64__f64_arrow = \
0326: col_target_t.col_target_column_f64 + col_source_t.col_source_f64_arrow
0327:
0328: col_dispatch_code_column_str__str_pyobj = \
0329: col_target_t.col_target_column_str + col_source_t.col_source_str_pyobj
0330: col_dispatch_code_column_str__str_utf8_arrow = \
0331: col_target_t.col_target_column_str + col_source_t.col_source_str_utf8_arrow
0332: col_dispatch_code_column_str__str_lrg_utf8_arrow = \
0333: col_target_t.col_target_column_str + col_source_t.col_source_str_lrg_utf8_arrow
0334: col_dispatch_code_column_str__str_i8_cat = \
0335: col_target_t.col_target_column_str + col_source_t.col_source_str_i8_cat
0336: col_dispatch_code_column_str__str_i16_cat = \
0337: col_target_t.col_target_column_str + col_source_t.col_source_str_i16_cat
0338: col_dispatch_code_column_str__str_i32_cat = \
0339: col_target_t.col_target_column_str + col_source_t.col_source_str_i32_cat
0340:
0341: col_dispatch_code_column_ts__dt64ns_numpy = \
0342: col_target_t.col_target_column_ts + col_source_t.col_source_dt64ns_numpy
0343: col_dispatch_code_column_ts__dt64ns_tz_arrow = \
0344: col_target_t.col_target_column_ts + \
0345: col_source_t.col_source_dt64ns_tz_arrow
0346:
0347: col_dispatch_code_at__dt64ns_numpy = \
0348: col_target_t.col_target_at + col_source_t.col_source_dt64ns_numpy
0349: col_dispatch_code_at__dt64ns_tz_arrow = \
+0350: col_target_t.col_target_at + col_source_t.col_source_dt64ns_tz_arrow
__pyx_e_7questdb_7ingress_col_dispatch_code_skip_nulls = (__pyx_e_7questdb_7ingress_col_target_skip + __pyx_e_7questdb_7ingress_col_source_nulls), __pyx_e_7questdb_7ingress_col_dispatch_code_table__str_pyobj = (__pyx_e_7questdb_7ingress_col_target_table + __pyx_e_7questdb_7ingress_col_source_str_pyobj), __pyx_e_7questdb_7ingress_col_dispatch_code_table__str_utf8_arrow = (__pyx_e_7questdb_7ingress_col_target_table + __pyx_e_7questdb_7ingress_col_source_str_utf8_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_table__str_lrg_utf8_arrow = (__pyx_e_7questdb_7ingress_col_target_table + __pyx_e_7questdb_7ingress_col_source_str_lrg_utf8_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_table__str_i8_cat = (__pyx_e_7questdb_7ingress_col_target_table + __pyx_e_7questdb_7ingress_col_source_str_i8_cat), __pyx_e_7questdb_7ingress_col_dispatch_code_table__str_i16_cat = (__pyx_e_7questdb_7ingress_col_target_table + __pyx_e_7questdb_7ingress_col_source_str_i16_cat), __pyx_e_7questdb_7ingress_col_dispatch_code_table__str_i32_cat = (__pyx_e_7questdb_7ingress_col_target_table + __pyx_e_7questdb_7ingress_col_source_str_i32_cat), __pyx_e_7questdb_7ingress_col_dispatch_code_symbol__str_pyobj = (__pyx_e_7questdb_7ingress_col_target_symbol + __pyx_e_7questdb_7ingress_col_source_str_pyobj), __pyx_e_7questdb_7ingress_col_dispatch_code_symbol__str_utf8_arrow = (__pyx_e_7questdb_7ingress_col_target_symbol + __pyx_e_7questdb_7ingress_col_source_str_utf8_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_symbol__str_lrg_utf8_arrow = (__pyx_e_7questdb_7ingress_col_target_symbol + __pyx_e_7questdb_7ingress_col_source_str_lrg_utf8_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_symbol__str_i8_cat = (__pyx_e_7questdb_7ingress_col_target_symbol + __pyx_e_7questdb_7ingress_col_source_str_i8_cat), __pyx_e_7questdb_7ingress_col_dispatch_code_symbol__str_i16_cat = (__pyx_e_7questdb_7ingress_col_target_symbol + __pyx_e_7questdb_7ingress_col_source_str_i16_cat), __pyx_e_7questdb_7ingress_col_dispatch_code_symbol__str_i32_cat = (__pyx_e_7questdb_7ingress_col_target_symbol + __pyx_e_7questdb_7ingress_col_source_str_i32_cat), __pyx_e_7questdb_7ingress_col_dispatch_code_column_bool__bool_pyobj = (__pyx_e_7questdb_7ingress_col_target_column_bool + __pyx_e_7questdb_7ingress_col_source_bool_pyobj), __pyx_e_7questdb_7ingress_col_dispatch_code_column_bool__bool_numpy = (__pyx_e_7questdb_7ingress_col_target_column_bool + __pyx_e_7questdb_7ingress_col_source_bool_numpy), __pyx_e_7questdb_7ingress_col_dispatch_code_column_bool__bool_arrow = (__pyx_e_7questdb_7ingress_col_target_column_bool + __pyx_e_7questdb_7ingress_col_source_bool_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__int_pyobj = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_int_pyobj), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u8_numpy = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_u8_numpy), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i8_numpy = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_i8_numpy), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u16_numpy = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_u16_numpy), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i16_numpy = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_i16_numpy), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u32_numpy = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_u32_numpy), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i32_numpy = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_i32_numpy), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u64_numpy = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_u64_numpy), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i64_numpy = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_i64_numpy), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u8_arrow = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_u8_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i8_arrow = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_i8_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u16_arrow = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_u16_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i16_arrow = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_i16_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u32_arrow = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_u32_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i32_arrow = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_i32_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u64_arrow = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_u64_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i64_arrow = (__pyx_e_7questdb_7ingress_col_target_column_i64 + __pyx_e_7questdb_7ingress_col_source_i64_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_column_f64__float_pyobj = (__pyx_e_7questdb_7ingress_col_target_column_f64 + __pyx_e_7questdb_7ingress_col_source_float_pyobj), __pyx_e_7questdb_7ingress_col_dispatch_code_column_f64__f32_numpy = (__pyx_e_7questdb_7ingress_col_target_column_f64 + __pyx_e_7questdb_7ingress_col_source_f32_numpy), __pyx_e_7questdb_7ingress_col_dispatch_code_column_f64__f64_numpy = (__pyx_e_7questdb_7ingress_col_target_column_f64 + __pyx_e_7questdb_7ingress_col_source_f64_numpy), __pyx_e_7questdb_7ingress_col_dispatch_code_column_f64__f32_arrow = (__pyx_e_7questdb_7ingress_col_target_column_f64 + __pyx_e_7questdb_7ingress_col_source_f32_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_column_f64__f64_arrow = (__pyx_e_7questdb_7ingress_col_target_column_f64 + __pyx_e_7questdb_7ingress_col_source_f64_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_column_str__str_pyobj = (__pyx_e_7questdb_7ingress_col_target_column_str + __pyx_e_7questdb_7ingress_col_source_str_pyobj), __pyx_e_7questdb_7ingress_col_dispatch_code_column_str__str_utf8_arrow = (__pyx_e_7questdb_7ingress_col_target_column_str + __pyx_e_7questdb_7ingress_col_source_str_utf8_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_column_str__str_lrg_utf8_arrow = (__pyx_e_7questdb_7ingress_col_target_column_str + __pyx_e_7questdb_7ingress_col_source_str_lrg_utf8_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_column_str__str_i8_cat = (__pyx_e_7questdb_7ingress_col_target_column_str + __pyx_e_7questdb_7ingress_col_source_str_i8_cat), __pyx_e_7questdb_7ingress_col_dispatch_code_column_str__str_i16_cat = (__pyx_e_7questdb_7ingress_col_target_column_str + __pyx_e_7questdb_7ingress_col_source_str_i16_cat), __pyx_e_7questdb_7ingress_col_dispatch_code_column_str__str_i32_cat = (__pyx_e_7questdb_7ingress_col_target_column_str + __pyx_e_7questdb_7ingress_col_source_str_i32_cat), __pyx_e_7questdb_7ingress_col_dispatch_code_column_ts__dt64ns_numpy = (__pyx_e_7questdb_7ingress_col_target_column_ts + __pyx_e_7questdb_7ingress_col_source_dt64ns_numpy), __pyx_e_7questdb_7ingress_col_dispatch_code_column_ts__dt64ns_tz_arrow = (__pyx_e_7questdb_7ingress_col_target_column_ts + __pyx_e_7questdb_7ingress_col_source_dt64ns_tz_arrow), __pyx_e_7questdb_7ingress_col_dispatch_code_at__dt64ns_numpy = (__pyx_e_7questdb_7ingress_col_target_at + __pyx_e_7questdb_7ingress_col_source_dt64ns_numpy), __pyx_e_7questdb_7ingress_col_dispatch_code_at__dt64ns_tz_arrow = (__pyx_e_7questdb_7ingress_col_target_at + __pyx_e_7questdb_7ingress_col_source_dt64ns_tz_arrow) };
0351:
0352:
0353: # Int values in order for sorting (as needed for API's sequential coupling).
+0354: cdef enum meta_target_t:
enum __pyx_t_7questdb_7ingress_meta_target_t {
0355: meta_target_table = <int>col_target_t.col_target_table
0356: meta_target_symbol = <int>col_target_t.col_target_symbol
0357: meta_target_field = <int>col_target_t.col_target_column_bool
+0358: meta_target_at = <int>col_target_t.col_target_at
__pyx_e_7questdb_7ingress_meta_target_table = ((int)__pyx_e_7questdb_7ingress_col_target_table), __pyx_e_7questdb_7ingress_meta_target_symbol = ((int)__pyx_e_7questdb_7ingress_col_target_symbol), __pyx_e_7questdb_7ingress_meta_target_field = ((int)__pyx_e_7questdb_7ingress_col_target_column_bool), __pyx_e_7questdb_7ingress_meta_target_at = ((int)__pyx_e_7questdb_7ingress_col_target_at) };
0359:
0360:
+0361: cdef struct col_setup_t:
struct __pyx_t_7questdb_7ingress_col_setup_t { struct __pyx_t_7questdb_7ingress_col_chunks_t chunks; size_t orig_index; Py_buffer pybuf; struct ArrowSchema arrow_schema; enum __pyx_t_7questdb_7ingress_col_source_t source; enum __pyx_t_7questdb_7ingress_meta_target_t meta_target; enum __pyx_t_7questdb_7ingress_col_target_t target; };
0362: col_chunks_t chunks
0363: size_t orig_index
0364: Py_buffer pybuf
0365: ArrowSchema arrow_schema # Schema of first chunk.
0366: col_source_t source
0367: meta_target_t meta_target
0368: col_target_t target
0369:
0370:
+0371: cdef struct col_t:
struct __pyx_t_7questdb_7ingress_col_t { enum __pyx_t_7questdb_7ingress_col_dispatch_code_t dispatch_code; struct line_sender_column_name name; struct __pyx_t_7questdb_7ingress_col_cursor_t cursor; struct __pyx_t_7questdb_7ingress_col_setup_t *setup; };
0372: col_dispatch_code_t dispatch_code # source + target. Determines serializer.
0373: line_sender_column_name name
0374: col_cursor_t cursor
0375: col_setup_t* setup # Grouping to reduce size of struct.
0376:
0377:
+0378: cdef void col_t_release(col_t* col) noexcept:
static void __pyx_f_7questdb_7ingress_col_t_release(struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { size_t __pyx_v_chunk_index; struct ArrowArray *__pyx_v_chunk; /* … */ /* function exit code */ }
0379: """
0380: Release a (possibly) initialized column.
0381:
0382: col_t objects are `calloc`ed, so uninitialized (or partially) initialized
0383: objects will have their pointers and other values set to 0.
0384: """
0385: cdef size_t chunk_index
0386: cdef ArrowArray* chunk
0387:
+0388: if Py_buffer_obj_is_set(&col.setup.pybuf):
__pyx_t_1 = Py_buffer_obj_is_set((&__pyx_v_col->setup->pybuf)); if (__pyx_t_1) { /* … */ }
+0389: PyBuffer_Release(&col.setup.pybuf) # Note: Sets `.pybuf.obj` to NULL.
PyBuffer_Release((&__pyx_v_col->setup->pybuf));
0390:
+0391: for chunk_index in range(col.setup.chunks.n_chunks):
__pyx_t_2 = __pyx_v_col->setup->chunks.n_chunks; __pyx_t_3 = __pyx_t_2; for (__pyx_t_4 = 0; __pyx_t_4 < __pyx_t_3; __pyx_t_4+=1) { __pyx_v_chunk_index = __pyx_t_4;
+0392: chunk = &col.setup.chunks.chunks[chunk_index]
__pyx_v_chunk = (&(__pyx_v_col->setup->chunks.chunks[__pyx_v_chunk_index]));
+0393: if chunk.release != NULL:
__pyx_t_1 = (__pyx_v_chunk->release != NULL); if (__pyx_t_1) { /* … */ }
+0394: chunk.release(chunk)
__pyx_v_chunk->release(__pyx_v_chunk);
+0395: memset(chunk, 0, sizeof(ArrowArray))
(void)(memset(__pyx_v_chunk, 0, (sizeof(struct ArrowArray)))); }
0396:
+0397: if col.setup.arrow_schema.release != NULL:
__pyx_t_1 = (__pyx_v_col->setup->arrow_schema.release != NULL); if (__pyx_t_1) { /* … */ }
+0398: col.setup.arrow_schema.release(&col.setup.arrow_schema)
__pyx_v_col->setup->arrow_schema.release((&__pyx_v_col->setup->arrow_schema));
0399:
+0400: free(col.setup.chunks.chunks)
free(__pyx_v_col->setup->chunks.chunks);
+0401: col.setup.chunks.chunks = NULL
__pyx_v_col->setup->chunks.chunks = NULL;
+0402: col.setup.chunks.n_chunks = 0
__pyx_v_col->setup->chunks.n_chunks = 0;
0403:
+0404: free(col.setup)
free(__pyx_v_col->setup);
+0405: col.setup = NULL
__pyx_v_col->setup = NULL;
0406:
0407:
0408: # Calloc'd array of col_t.
+0409: cdef struct col_t_arr:
struct __pyx_t_7questdb_7ingress_col_t_arr { size_t size; struct __pyx_t_7questdb_7ingress_col_t *d; };
0410: size_t size
0411: col_t* d
0412:
0413:
+0414: cdef col_t_arr col_t_arr_blank() noexcept nogil:
static struct __pyx_t_7questdb_7ingress_col_t_arr __pyx_f_7questdb_7ingress_col_t_arr_blank(void) { struct __pyx_t_7questdb_7ingress_col_t_arr __pyx_v_arr; struct __pyx_t_7questdb_7ingress_col_t_arr __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
0415: cdef col_t_arr arr
+0416: arr.size = 0
__pyx_v_arr.size = 0;
+0417: arr.d = NULL
__pyx_v_arr.d = NULL;
+0418: return arr
__pyx_r = __pyx_v_arr; goto __pyx_L0;
0419:
0420:
+0421: cdef col_t_arr col_t_arr_new(size_t size) noexcept nogil:
static struct __pyx_t_7questdb_7ingress_col_t_arr __pyx_f_7questdb_7ingress_col_t_arr_new(size_t __pyx_v_size) { struct __pyx_t_7questdb_7ingress_col_t_arr __pyx_v_arr; size_t __pyx_v_index; struct __pyx_t_7questdb_7ingress_col_t_arr __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
0422: cdef col_t_arr arr
0423: cdef size_t index
+0424: arr.size = size
__pyx_v_arr.size = __pyx_v_size;
+0425: arr.d = <col_t*>calloc(size, sizeof(col_t))
__pyx_v_arr.d = ((struct __pyx_t_7questdb_7ingress_col_t *)calloc(__pyx_v_size, (sizeof(struct __pyx_t_7questdb_7ingress_col_t))));
+0426: for index in range(size):
__pyx_t_1 = __pyx_v_size; __pyx_t_2 = __pyx_t_1; for (__pyx_t_3 = 0; __pyx_t_3 < __pyx_t_2; __pyx_t_3+=1) { __pyx_v_index = __pyx_t_3;
+0427: arr.d[index].setup = <col_setup_t*>calloc(1, sizeof(col_setup_t))
(__pyx_v_arr.d[__pyx_v_index]).setup = ((struct __pyx_t_7questdb_7ingress_col_setup_t *)calloc(1, (sizeof(struct __pyx_t_7questdb_7ingress_col_setup_t)))); }
+0428: return arr
0429:
0430:
+0431: cdef void col_t_arr_release(col_t_arr* arr) noexcept:
static void __pyx_f_7questdb_7ingress_col_t_arr_release(struct __pyx_t_7questdb_7ingress_col_t_arr *__pyx_v_arr) { size_t __pyx_v_index; /* … */ /* function exit code */ }
0432: cdef size_t index
+0433: if arr.d:
__pyx_t_1 = (__pyx_v_arr->d != 0); if (__pyx_t_1) { /* … */ }
+0434: for index in range(arr.size):
__pyx_t_2 = __pyx_v_arr->size; __pyx_t_3 = __pyx_t_2; for (__pyx_t_4 = 0; __pyx_t_4 < __pyx_t_3; __pyx_t_4+=1) { __pyx_v_index = __pyx_t_4;
+0435: col_t_release(&arr.d[index])
__pyx_f_7questdb_7ingress_col_t_release((&(__pyx_v_arr->d[__pyx_v_index]))); }
+0436: free(arr.d)
free(__pyx_v_arr->d);
+0437: arr.size = 0
__pyx_v_arr->size = 0;
+0438: arr.d = NULL
__pyx_v_arr->d = NULL;
0439:
0440:
+0441: cdef object _NUMPY = None # module object
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY, Py_None); __Pyx_GIVEREF(Py_None);
+0442: cdef object _NUMPY_BOOL = None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_BOOL); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_BOOL, Py_None); __Pyx_GIVEREF(Py_None);
+0443: cdef object _NUMPY_UINT8 = None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_UINT8); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_UINT8, Py_None); __Pyx_GIVEREF(Py_None);
+0444: cdef object _NUMPY_INT8 = None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_INT8); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_INT8, Py_None); __Pyx_GIVEREF(Py_None);
+0445: cdef object _NUMPY_UINT16 = None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_UINT16); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_UINT16, Py_None); __Pyx_GIVEREF(Py_None);
+0446: cdef object _NUMPY_INT16 = None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_INT16); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_INT16, Py_None); __Pyx_GIVEREF(Py_None);
+0447: cdef object _NUMPY_UINT32 = None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_UINT32); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_UINT32, Py_None); __Pyx_GIVEREF(Py_None);
+0448: cdef object _NUMPY_INT32 = None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_INT32); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_INT32, Py_None); __Pyx_GIVEREF(Py_None);
+0449: cdef object _NUMPY_UINT64 = None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_UINT64); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_UINT64, Py_None); __Pyx_GIVEREF(Py_None);
+0450: cdef object _NUMPY_INT64 = None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_INT64); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_INT64, Py_None); __Pyx_GIVEREF(Py_None);
+0451: cdef object _NUMPY_FLOAT32 = None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_FLOAT32); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_FLOAT32, Py_None); __Pyx_GIVEREF(Py_None);
+0452: cdef object _NUMPY_FLOAT64 = None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_FLOAT64); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_FLOAT64, Py_None); __Pyx_GIVEREF(Py_None);
+0453: cdef object _NUMPY_DATETIME64_NS = None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_DATETIME64_NS); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_DATETIME64_NS, Py_None); __Pyx_GIVEREF(Py_None);
+0454: cdef object _NUMPY_OBJECT = None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_OBJECT); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_OBJECT, Py_None); __Pyx_GIVEREF(Py_None);
+0455: cdef object _PANDAS = None # module object
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__PANDAS); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__PANDAS, Py_None); __Pyx_GIVEREF(Py_None);
+0456: cdef object _PANDAS_NA = None # pandas.NA
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__PANDAS_NA); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__PANDAS_NA, Py_None); __Pyx_GIVEREF(Py_None);
+0457: cdef object _PYARROW = None # module object, if available or None
__Pyx_INCREF(Py_None); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__PYARROW); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__PYARROW, Py_None); __Pyx_GIVEREF(Py_None);
0458:
+0459: cdef int64_t _NAT = INT64_MIN # pandas NaT
__pyx_v_7questdb_7ingress__NAT = INT64_MIN;
0460:
0461:
+0462: cdef object _dataframe_may_import_deps():
static PyObject *__pyx_f_7questdb_7ingress__dataframe_may_import_deps(void) { PyObject *__pyx_v_pandas = NULL; PyObject *__pyx_v_numpy = NULL; PyObject *__pyx_v_pyarrow = NULL; PyObject *__pyx_v_ie = NULL; PyObject *__pyx_r = NULL; /* … */ /* function exit code */ __pyx_r = Py_None; __Pyx_INCREF(Py_None); goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_5); __Pyx_XDECREF(__pyx_t_7); __Pyx_XDECREF(__pyx_t_8); __Pyx_XDECREF(__pyx_t_9); __Pyx_AddTraceback("questdb.ingress._dataframe_may_import_deps", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = 0; __pyx_L0:; __Pyx_XDECREF(__pyx_v_pandas); __Pyx_XDECREF(__pyx_v_numpy); __Pyx_XDECREF(__pyx_v_pyarrow); __Pyx_XDECREF(__pyx_v_ie); __Pyx_XGIVEREF(__pyx_r); __Pyx_RefNannyFinishContext(); return __pyx_r; }
0463: """"
0464: Lazily import module dependencies on first use to avoid startup overhead.
0465:
0466: $ cat imp_test.py
0467: import numpy
0468: import pandas
0469: import pyarrow
0470:
0471: $ time python3 ./imp_test.py
0472: python3 ./imp_test.py 0.56s user 1.60s system 852% cpu 0.254 total
0473: """
0474: global _NUMPY, _PANDAS, _PYARROW, _PANDAS_NA
0475: global _NUMPY_BOOL
0476: global _NUMPY_UINT8
0477: global _NUMPY_INT8
0478: global _NUMPY_UINT16
0479: global _NUMPY_INT16
0480: global _NUMPY_UINT32
0481: global _NUMPY_INT32
0482: global _NUMPY_UINT64
0483: global _NUMPY_INT64
0484: global _NUMPY_FLOAT32
0485: global _NUMPY_FLOAT64
0486: global _NUMPY_DATETIME64_NS
0487: global _NUMPY_OBJECT
+0488: if _NUMPY is not None:
__pyx_t_1 = (__pyx_v_7questdb_7ingress__NUMPY != Py_None); if (__pyx_t_1) { /* … */ }
+0489: return
__Pyx_XDECREF(__pyx_r); __pyx_r = Py_None; __Pyx_INCREF(Py_None); goto __pyx_L0;
+0490: try:
{ /*try:*/ { /* … */ } __Pyx_XDECREF(__pyx_t_2); __pyx_t_2 = 0; __Pyx_XDECREF(__pyx_t_3); __pyx_t_3 = 0; __Pyx_XDECREF(__pyx_t_4); __pyx_t_4 = 0; goto __pyx_L9_try_end; __pyx_L4_error:; __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; /* … */ __pyx_L6_except_error:; __Pyx_XGIVEREF(__pyx_t_2); __Pyx_XGIVEREF(__pyx_t_3); __Pyx_XGIVEREF(__pyx_t_4); __Pyx_ExceptionReset(__pyx_t_2, __pyx_t_3, __pyx_t_4); goto __pyx_L1_error; __pyx_L9_try_end:; }
+0491: import pandas
__pyx_t_5 = __Pyx_ImportDottedModule(__pyx_n_s_pandas, NULL); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 491, __pyx_L4_error) __Pyx_GOTREF(__pyx_t_5); __pyx_v_pandas = __pyx_t_5; __pyx_t_5 = 0;
+0492: import numpy
__pyx_t_5 = __Pyx_ImportDottedModule(__pyx_n_s_numpy, NULL); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 492, __pyx_L4_error) __Pyx_GOTREF(__pyx_t_5); __pyx_v_numpy = __pyx_t_5; __pyx_t_5 = 0;
+0493: import pyarrow
__pyx_t_5 = __Pyx_ImportDottedModule(__pyx_n_s_pyarrow, NULL); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 493, __pyx_L4_error) __Pyx_GOTREF(__pyx_t_5); __pyx_v_pyarrow = __pyx_t_5; __pyx_t_5 = 0;
+0494: except ImportError as ie:
__pyx_t_6 = __Pyx_PyErr_ExceptionMatches(__pyx_builtin_ImportError); if (__pyx_t_6) { __Pyx_AddTraceback("questdb.ingress._dataframe_may_import_deps", __pyx_clineno, __pyx_lineno, __pyx_filename); if (__Pyx_GetException(&__pyx_t_5, &__pyx_t_7, &__pyx_t_8) < 0) __PYX_ERR(1, 494, __pyx_L6_except_error) __Pyx_XGOTREF(__pyx_t_5); __Pyx_XGOTREF(__pyx_t_7); __Pyx_XGOTREF(__pyx_t_8); __Pyx_INCREF(__pyx_t_7); __pyx_v_ie = __pyx_t_7; /*try:*/ { /* … */ /*finally:*/ { __pyx_L15_error:; /*exception exit:*/{ __Pyx_PyThreadState_declare __Pyx_PyThreadState_assign __pyx_t_12 = 0; __pyx_t_13 = 0; __pyx_t_14 = 0; __pyx_t_15 = 0; __pyx_t_16 = 0; __pyx_t_17 = 0; __Pyx_XDECREF(__pyx_t_9); __pyx_t_9 = 0; if (PY_MAJOR_VERSION >= 3) __Pyx_ExceptionSwap(&__pyx_t_15, &__pyx_t_16, &__pyx_t_17); if ((PY_MAJOR_VERSION < 3) || unlikely(__Pyx_GetException(&__pyx_t_12, &__pyx_t_13, &__pyx_t_14) < 0)) __Pyx_ErrFetch(&__pyx_t_12, &__pyx_t_13, &__pyx_t_14); __Pyx_XGOTREF(__pyx_t_12); __Pyx_XGOTREF(__pyx_t_13); __Pyx_XGOTREF(__pyx_t_14); __Pyx_XGOTREF(__pyx_t_15); __Pyx_XGOTREF(__pyx_t_16); __Pyx_XGOTREF(__pyx_t_17); __pyx_t_6 = __pyx_lineno; __pyx_t_10 = __pyx_clineno; __pyx_t_11 = __pyx_filename; { __Pyx_DECREF(__pyx_v_ie); __pyx_v_ie = 0; } if (PY_MAJOR_VERSION >= 3) { __Pyx_XGIVEREF(__pyx_t_15); __Pyx_XGIVEREF(__pyx_t_16); __Pyx_XGIVEREF(__pyx_t_17); __Pyx_ExceptionReset(__pyx_t_15, __pyx_t_16, __pyx_t_17); } __Pyx_XGIVEREF(__pyx_t_12); __Pyx_XGIVEREF(__pyx_t_13); __Pyx_XGIVEREF(__pyx_t_14); __Pyx_ErrRestore(__pyx_t_12, __pyx_t_13, __pyx_t_14); __pyx_t_12 = 0; __pyx_t_13 = 0; __pyx_t_14 = 0; __pyx_t_15 = 0; __pyx_t_16 = 0; __pyx_t_17 = 0; __pyx_lineno = __pyx_t_6; __pyx_clineno = __pyx_t_10; __pyx_filename = __pyx_t_11; goto __pyx_L6_except_error; } } } goto __pyx_L6_except_error;
+0495: raise ImportError(
__pyx_t_9 = __Pyx_PyObject_Call(__pyx_builtin_ImportError, __pyx_tuple__3, NULL); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 495, __pyx_L15_error) __Pyx_GOTREF(__pyx_t_9); /* … */ __pyx_tuple__3 = PyTuple_Pack(1, __pyx_kp_u_Missing_dependencies_pandas_nump); if (unlikely(!__pyx_tuple__3)) __PYX_ERR(1, 495, __pyx_L1_error) __Pyx_GOTREF(__pyx_tuple__3); __Pyx_GIVEREF(__pyx_tuple__3);
0496: 'Missing dependencies: `pandas`, `numpy` and `pyarrow` must all ' +
0497: 'be installed to use the `.dataframe()` method. ' +
0498: 'See: https://py-questdb-client.readthedocs.io/' +
+0499: 'en/latest/installation.html.') from ie
__Pyx_Raise(__pyx_t_9, 0, 0, __pyx_v_ie); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __PYX_ERR(1, 495, __pyx_L15_error) }
+0500: _NUMPY = numpy
__Pyx_INCREF(__pyx_v_numpy); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY, __pyx_v_numpy); __Pyx_GIVEREF(__pyx_v_numpy);
+0501: _NUMPY_BOOL = type(_NUMPY.dtype('bool'))
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__NUMPY, __pyx_n_s_dtype); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 501, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_5 = NULL; __pyx_t_18 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_7))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_7); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_7); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_7, function); __pyx_t_18 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_n_u_bool}; __pyx_t_8 = __Pyx_PyObject_FastCall(__pyx_t_7, __pyx_callargs+1-__pyx_t_18, 1+__pyx_t_18); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 501, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; } __Pyx_INCREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_BOOL); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_BOOL, ((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_GIVEREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0502: _NUMPY_UINT8 = type(_NUMPY.dtype('uint8'))
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__NUMPY, __pyx_n_s_dtype); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 502, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_5 = NULL; __pyx_t_18 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_7))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_7); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_7); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_7, function); __pyx_t_18 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_n_u_uint8}; __pyx_t_8 = __Pyx_PyObject_FastCall(__pyx_t_7, __pyx_callargs+1-__pyx_t_18, 1+__pyx_t_18); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 502, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; } __Pyx_INCREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_UINT8); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_UINT8, ((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_GIVEREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0503: _NUMPY_INT8 = type(_NUMPY.dtype('int8'))
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__NUMPY, __pyx_n_s_dtype); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 503, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_5 = NULL; __pyx_t_18 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_7))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_7); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_7); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_7, function); __pyx_t_18 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_n_u_int8}; __pyx_t_8 = __Pyx_PyObject_FastCall(__pyx_t_7, __pyx_callargs+1-__pyx_t_18, 1+__pyx_t_18); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 503, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; } __Pyx_INCREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_INT8); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_INT8, ((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_GIVEREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0504: _NUMPY_UINT16 = type(_NUMPY.dtype('uint16'))
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__NUMPY, __pyx_n_s_dtype); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 504, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_5 = NULL; __pyx_t_18 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_7))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_7); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_7); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_7, function); __pyx_t_18 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_n_u_uint16}; __pyx_t_8 = __Pyx_PyObject_FastCall(__pyx_t_7, __pyx_callargs+1-__pyx_t_18, 1+__pyx_t_18); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 504, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; } __Pyx_INCREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_UINT16); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_UINT16, ((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_GIVEREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0505: _NUMPY_INT16 = type(_NUMPY.dtype('int16'))
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__NUMPY, __pyx_n_s_dtype); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 505, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_5 = NULL; __pyx_t_18 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_7))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_7); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_7); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_7, function); __pyx_t_18 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_n_u_int16}; __pyx_t_8 = __Pyx_PyObject_FastCall(__pyx_t_7, __pyx_callargs+1-__pyx_t_18, 1+__pyx_t_18); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 505, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; } __Pyx_INCREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_INT16); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_INT16, ((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_GIVEREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0506: _NUMPY_UINT32 = type(_NUMPY.dtype('uint32'))
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__NUMPY, __pyx_n_s_dtype); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 506, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_5 = NULL; __pyx_t_18 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_7))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_7); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_7); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_7, function); __pyx_t_18 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_n_u_uint32}; __pyx_t_8 = __Pyx_PyObject_FastCall(__pyx_t_7, __pyx_callargs+1-__pyx_t_18, 1+__pyx_t_18); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 506, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; } __Pyx_INCREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_UINT32); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_UINT32, ((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_GIVEREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0507: _NUMPY_INT32 = type(_NUMPY.dtype('int32'))
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__NUMPY, __pyx_n_s_dtype); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 507, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_5 = NULL; __pyx_t_18 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_7))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_7); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_7); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_7, function); __pyx_t_18 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_n_u_int32}; __pyx_t_8 = __Pyx_PyObject_FastCall(__pyx_t_7, __pyx_callargs+1-__pyx_t_18, 1+__pyx_t_18); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 507, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; } __Pyx_INCREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_INT32); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_INT32, ((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_GIVEREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0508: _NUMPY_UINT64 = type(_NUMPY.dtype('uint64'))
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__NUMPY, __pyx_n_s_dtype); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 508, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_5 = NULL; __pyx_t_18 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_7))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_7); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_7); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_7, function); __pyx_t_18 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_n_u_uint64}; __pyx_t_8 = __Pyx_PyObject_FastCall(__pyx_t_7, __pyx_callargs+1-__pyx_t_18, 1+__pyx_t_18); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 508, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; } __Pyx_INCREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_UINT64); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_UINT64, ((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_GIVEREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0509: _NUMPY_INT64 = type(_NUMPY.dtype('int64'))
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__NUMPY, __pyx_n_s_dtype); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 509, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_5 = NULL; __pyx_t_18 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_7))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_7); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_7); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_7, function); __pyx_t_18 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_n_u_int64}; __pyx_t_8 = __Pyx_PyObject_FastCall(__pyx_t_7, __pyx_callargs+1-__pyx_t_18, 1+__pyx_t_18); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 509, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; } __Pyx_INCREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_INT64); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_INT64, ((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_GIVEREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0510: _NUMPY_FLOAT32 = type(_NUMPY.dtype('float32'))
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__NUMPY, __pyx_n_s_dtype); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 510, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_5 = NULL; __pyx_t_18 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_7))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_7); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_7); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_7, function); __pyx_t_18 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_n_u_float32}; __pyx_t_8 = __Pyx_PyObject_FastCall(__pyx_t_7, __pyx_callargs+1-__pyx_t_18, 1+__pyx_t_18); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 510, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; } __Pyx_INCREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_FLOAT32); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_FLOAT32, ((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_GIVEREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0511: _NUMPY_FLOAT64 = type(_NUMPY.dtype('float64'))
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__NUMPY, __pyx_n_s_dtype); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 511, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_5 = NULL; __pyx_t_18 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_7))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_7); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_7); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_7, function); __pyx_t_18 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_n_u_float64}; __pyx_t_8 = __Pyx_PyObject_FastCall(__pyx_t_7, __pyx_callargs+1-__pyx_t_18, 1+__pyx_t_18); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 511, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; } __Pyx_INCREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_FLOAT64); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_FLOAT64, ((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_GIVEREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0512: _NUMPY_DATETIME64_NS = type(_NUMPY.dtype('datetime64[ns]'))
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__NUMPY, __pyx_n_s_dtype); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 512, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_5 = NULL; __pyx_t_18 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_7))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_7); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_7); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_7, function); __pyx_t_18 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_kp_u_datetime64_ns}; __pyx_t_8 = __Pyx_PyObject_FastCall(__pyx_t_7, __pyx_callargs+1-__pyx_t_18, 1+__pyx_t_18); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 512, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; } __Pyx_INCREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_DATETIME64_NS); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_DATETIME64_NS, ((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_GIVEREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0513: _NUMPY_OBJECT = type(_NUMPY.dtype('object'))
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__NUMPY, __pyx_n_s_dtype); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 513, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_5 = NULL; __pyx_t_18 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_7))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_7); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_7); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_7, function); __pyx_t_18 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_n_u_object}; __pyx_t_8 = __Pyx_PyObject_FastCall(__pyx_t_7, __pyx_callargs+1-__pyx_t_18, 1+__pyx_t_18); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 513, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; } __Pyx_INCREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__NUMPY_OBJECT); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__NUMPY_OBJECT, ((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_GIVEREF(((PyObject *)Py_TYPE(__pyx_t_8))); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0514: _PANDAS = pandas
__Pyx_INCREF(__pyx_v_pandas); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__PANDAS); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__PANDAS, __pyx_v_pandas); __Pyx_GIVEREF(__pyx_v_pandas);
+0515: _PANDAS_NA = pandas.NA
__pyx_t_8 = __Pyx_PyObject_GetAttrStr(__pyx_v_pandas, __pyx_n_s_NA); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 515, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__PANDAS_NA); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__PANDAS_NA, __pyx_t_8); __Pyx_GIVEREF(__pyx_t_8); __pyx_t_8 = 0;
+0516: _PYARROW = pyarrow
__Pyx_INCREF(__pyx_v_pyarrow); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__PYARROW); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__PYARROW, __pyx_v_pyarrow); __Pyx_GIVEREF(__pyx_v_pyarrow);
0517:
0518:
+0519: cdef object _dataframe_check_is_dataframe(object df):
static PyObject *__pyx_f_7questdb_7ingress__dataframe_check_is_dataframe(PyObject *__pyx_v_df) { PyObject *__pyx_r = NULL; /* … */ /* function exit code */ __pyx_r = Py_None; __Pyx_INCREF(Py_None); goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_1); __Pyx_XDECREF(__pyx_t_4); __Pyx_XDECREF(__pyx_t_5); __Pyx_XDECREF(__pyx_t_6); __Pyx_XDECREF(__pyx_t_9); __Pyx_XDECREF(__pyx_t_10); __Pyx_XDECREF(__pyx_t_11); __Pyx_AddTraceback("questdb.ingress._dataframe_check_is_dataframe", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = 0; __pyx_L0:; __Pyx_XGIVEREF(__pyx_r); __Pyx_RefNannyFinishContext(); return __pyx_r; }
+0520: if not isinstance(df, _PANDAS.DataFrame):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_DataFrame); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 520, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_df, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 520, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __pyx_t_3 = (!__pyx_t_2); if (unlikely(__pyx_t_3)) { /* … */ }
+0521: raise IngressError(
__Pyx_GetModuleGlobalName(__pyx_t_4, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 521, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4);
+0522: IngressErrorCode.InvalidApiCall,
__Pyx_GetModuleGlobalName(__pyx_t_5, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 522, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_6 = __Pyx_PyObject_GetAttrStr(__pyx_t_5, __pyx_n_s_InvalidApiCall); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 522, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0;
+0523: f'Bad argument `df`: Expected {_fqn(_PANDAS.DataFrame)}, ' +
__pyx_t_5 = PyTuple_New(3); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 523, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_7 = 0; __pyx_t_8 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_argument_df_Expected); __pyx_t_7 += 28; __Pyx_GIVEREF(__pyx_kp_u_Bad_argument_df_Expected); PyTuple_SET_ITEM(__pyx_t_5, 0, __pyx_kp_u_Bad_argument_df_Expected); __pyx_t_9 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_DataFrame); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 523, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); if (!(likely(PyType_CheckExact(__pyx_t_9))||((__pyx_t_9) == Py_None) || __Pyx_RaiseUnexpectedTypeError("type", __pyx_t_9))) __PYX_ERR(1, 523, __pyx_L1_error) __pyx_t_10 = __pyx_f_7questdb_7ingress__fqn(((PyTypeObject*)__pyx_t_9)); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 523, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __pyx_t_9 = __Pyx_PyUnicode_Unicode(__pyx_t_10); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 523, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; __pyx_t_8 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_9) > __pyx_t_8) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_9) : __pyx_t_8; __pyx_t_7 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_9); __Pyx_GIVEREF(__pyx_t_9); PyTuple_SET_ITEM(__pyx_t_5, 1, __pyx_t_9); __pyx_t_9 = 0; __Pyx_INCREF(__pyx_kp_u__4); __pyx_t_7 += 2; __Pyx_GIVEREF(__pyx_kp_u__4); PyTuple_SET_ITEM(__pyx_t_5, 2, __pyx_kp_u__4); __pyx_t_9 = __Pyx_PyUnicode_Join(__pyx_t_5, 3, __pyx_t_7, __pyx_t_8); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 523, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; /* … */ __pyx_t_5 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_9, __pyx_t_11); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 523, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __Pyx_DECREF(__pyx_t_11); __pyx_t_11 = 0; __pyx_t_11 = NULL; __pyx_t_12 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_4))) { __pyx_t_11 = PyMethod_GET_SELF(__pyx_t_4); if (likely(__pyx_t_11)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_4); __Pyx_INCREF(__pyx_t_11); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_4, function); __pyx_t_12 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_11, __pyx_t_6, __pyx_t_5}; __pyx_t_1 = __Pyx_PyObject_FastCall(__pyx_t_4, __pyx_callargs+1-__pyx_t_12, 2+__pyx_t_12); __Pyx_XDECREF(__pyx_t_11); __pyx_t_11 = 0; __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 521, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; } __Pyx_Raise(__pyx_t_1, 0, 0, 0); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 521, __pyx_L1_error)
+0524: f'not an object of type {_fqn(type(df))}.')
__pyx_t_5 = PyTuple_New(3); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 524, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_7 = 0; __pyx_t_8 = 127; __Pyx_INCREF(__pyx_kp_u_not_an_object_of_type); __pyx_t_7 += 22; __Pyx_GIVEREF(__pyx_kp_u_not_an_object_of_type); PyTuple_SET_ITEM(__pyx_t_5, 0, __pyx_kp_u_not_an_object_of_type); __pyx_t_10 = __pyx_f_7questdb_7ingress__fqn(((PyTypeObject*)((PyObject *)Py_TYPE(__pyx_v_df)))); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 524, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_11 = __Pyx_PyUnicode_Unicode(__pyx_t_10); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 524, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_11); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; __pyx_t_8 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_11) > __pyx_t_8) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_11) : __pyx_t_8; __pyx_t_7 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_11); __Pyx_GIVEREF(__pyx_t_11); PyTuple_SET_ITEM(__pyx_t_5, 1, __pyx_t_11); __pyx_t_11 = 0; __Pyx_INCREF(__pyx_kp_u__5); __pyx_t_7 += 1; __Pyx_GIVEREF(__pyx_kp_u__5); PyTuple_SET_ITEM(__pyx_t_5, 2, __pyx_kp_u__5); __pyx_t_11 = __Pyx_PyUnicode_Join(__pyx_t_5, 3, __pyx_t_7, __pyx_t_8); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 524, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_11); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0;
0525:
0526:
+0527: cdef ssize_t _dataframe_resolve_table_name(
static Py_ssize_t __pyx_f_7questdb_7ingress__dataframe_resolve_table_name(struct qdb_pystr_buf *__pyx_v_b, PyObject *__pyx_v_df, PyObject *__pyx_v_pandas_cols, struct __pyx_t_7questdb_7ingress_col_t_arr *__pyx_v_cols, PyObject *__pyx_v_table_name, PyObject *__pyx_v_table_name_col, size_t __pyx_v_col_count, struct line_sender_table_name *__pyx_v_name_out) { size_t __pyx_v_col_index; struct __pyx_obj_7questdb_7ingress_PandasCol *__pyx_v_pandas_col = 0; struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col; PyObject *__pyx_v_ie = NULL; Py_ssize_t __pyx_r; /* … */ /* function exit code */ __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_XDECREF(__pyx_t_7); __Pyx_XDECREF(__pyx_t_8); __Pyx_XDECREF(__pyx_t_9); __Pyx_XDECREF(__pyx_t_11); __Pyx_AddTraceback("questdb.ingress._dataframe_resolve_table_name", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -2L; __pyx_L0:; __Pyx_XDECREF((PyObject *)__pyx_v_pandas_col); __Pyx_XDECREF(__pyx_v_ie); __Pyx_RefNannyFinishContext(); return __pyx_r; }
0528: qdb_pystr_buf* b,
0529: object df,
0530: list pandas_cols,
0531: col_t_arr* cols,
0532: object table_name,
0533: object table_name_col,
0534: size_t col_count,
0535: line_sender_table_name* name_out) except -2:
0536: """
0537: Resolve the table name string or column.
0538:
0539: Returns -1 if the table name is a string, otherwise the column index.
0540: """
+0541: cdef size_t col_index = 0
__pyx_v_col_index = 0;
0542: cdef PandasCol pandas_col
0543: cdef col_t* col
+0544: if table_name is not None:
__pyx_t_1 = (__pyx_v_table_name != Py_None); if (__pyx_t_1) { /* … */ }
+0545: if table_name_col is not None:
__pyx_t_1 = (__pyx_v_table_name_col != Py_None); if (unlikely(__pyx_t_1)) { /* … */ }
+0546: raise ValueError(
__pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_ValueError, __pyx_tuple__6, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 546, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 546, __pyx_L1_error) /* … */ __pyx_tuple__6 = PyTuple_Pack(1, __pyx_kp_u_Can_specify_only_one_of_table_na); if (unlikely(!__pyx_tuple__6)) __PYX_ERR(1, 546, __pyx_L1_error) __Pyx_GOTREF(__pyx_tuple__6); __Pyx_GIVEREF(__pyx_tuple__6);
0547: 'Can specify only one of `table_name` or `table_name_col`.')
+0548: if isinstance(table_name, str):
__pyx_t_1 = PyUnicode_Check(__pyx_v_table_name);
if (likely(__pyx_t_1)) {
+0549: try:
{ /*try:*/ { /* … */ } __pyx_L6_error:; __Pyx_XDECREF(__pyx_t_2); __pyx_t_2 = 0; /* … */ __pyx_L8_except_error:; __Pyx_XGIVEREF(__pyx_t_3); __Pyx_XGIVEREF(__pyx_t_4); __Pyx_XGIVEREF(__pyx_t_5); __Pyx_ExceptionReset(__pyx_t_3, __pyx_t_4, __pyx_t_5); goto __pyx_L1_error; __pyx_L10_try_return:; __Pyx_XGIVEREF(__pyx_t_3); __Pyx_XGIVEREF(__pyx_t_4); __Pyx_XGIVEREF(__pyx_t_5); __Pyx_ExceptionReset(__pyx_t_3, __pyx_t_4, __pyx_t_5); goto __pyx_L0; }
+0550: str_to_table_name_copy(b, <PyObject*>table_name, name_out)
__pyx_t_6 = __pyx_f_7questdb_7ingress_str_to_table_name_copy(__pyx_v_b, ((PyObject *)__pyx_v_table_name), __pyx_v_name_out); if (unlikely(__pyx_t_6 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 550, __pyx_L6_error)
+0551: return -1 # Magic value for "no column index".
__pyx_r = -1L; goto __pyx_L10_try_return;
+0552: except IngressError as ie:
__Pyx_ErrFetch(&__pyx_t_2, &__pyx_t_7, &__pyx_t_8); __Pyx_GetModuleGlobalName(__pyx_t_9, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 552, __pyx_L8_except_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_10 = __Pyx_PyErr_GivenExceptionMatches(__pyx_t_2, __pyx_t_9); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __Pyx_ErrRestore(__pyx_t_2, __pyx_t_7, __pyx_t_8); __pyx_t_2 = 0; __pyx_t_7 = 0; __pyx_t_8 = 0; if (__pyx_t_10) { __Pyx_AddTraceback("questdb.ingress._dataframe_resolve_table_name", __pyx_clineno, __pyx_lineno, __pyx_filename); if (__Pyx_GetException(&__pyx_t_8, &__pyx_t_7, &__pyx_t_2) < 0) __PYX_ERR(1, 552, __pyx_L8_except_error) __Pyx_XGOTREF(__pyx_t_8); __Pyx_XGOTREF(__pyx_t_7); __Pyx_XGOTREF(__pyx_t_2); __Pyx_INCREF(__pyx_t_7); __pyx_v_ie = __pyx_t_7; /*try:*/ { /* … */ /*finally:*/ { __pyx_L17_error:; /*exception exit:*/{ __Pyx_PyThreadState_declare __Pyx_PyThreadState_assign __pyx_t_14 = 0; __pyx_t_15 = 0; __pyx_t_16 = 0; __pyx_t_17 = 0; __pyx_t_18 = 0; __pyx_t_19 = 0; __Pyx_XDECREF(__pyx_t_11); __pyx_t_11 = 0; __Pyx_XDECREF(__pyx_t_9); __pyx_t_9 = 0; if (PY_MAJOR_VERSION >= 3) __Pyx_ExceptionSwap(&__pyx_t_17, &__pyx_t_18, &__pyx_t_19); if ((PY_MAJOR_VERSION < 3) || unlikely(__Pyx_GetException(&__pyx_t_14, &__pyx_t_15, &__pyx_t_16) < 0)) __Pyx_ErrFetch(&__pyx_t_14, &__pyx_t_15, &__pyx_t_16); __Pyx_XGOTREF(__pyx_t_14); __Pyx_XGOTREF(__pyx_t_15); __Pyx_XGOTREF(__pyx_t_16); __Pyx_XGOTREF(__pyx_t_17); __Pyx_XGOTREF(__pyx_t_18); __Pyx_XGOTREF(__pyx_t_19); __pyx_t_10 = __pyx_lineno; __pyx_t_12 = __pyx_clineno; __pyx_t_13 = __pyx_filename; { __Pyx_DECREF(__pyx_v_ie); __pyx_v_ie = 0; } if (PY_MAJOR_VERSION >= 3) { __Pyx_XGIVEREF(__pyx_t_17); __Pyx_XGIVEREF(__pyx_t_18); __Pyx_XGIVEREF(__pyx_t_19); __Pyx_ExceptionReset(__pyx_t_17, __pyx_t_18, __pyx_t_19); } __Pyx_XGIVEREF(__pyx_t_14); __Pyx_XGIVEREF(__pyx_t_15); __Pyx_XGIVEREF(__pyx_t_16); __Pyx_ErrRestore(__pyx_t_14, __pyx_t_15, __pyx_t_16); __pyx_t_14 = 0; __pyx_t_15 = 0; __pyx_t_16 = 0; __pyx_t_17 = 0; __pyx_t_18 = 0; __pyx_t_19 = 0; __pyx_lineno = __pyx_t_10; __pyx_clineno = __pyx_t_12; __pyx_filename = __pyx_t_13; goto __pyx_L8_except_error; } } } goto __pyx_L8_except_error;
+0553: raise ValueError(
__pyx_t_9 = __Pyx_PyObject_CallOneArg(__pyx_builtin_ValueError, __pyx_t_11); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 553, __pyx_L17_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_11); __pyx_t_11 = 0; __Pyx_Raise(__pyx_t_9, 0, 0, 0); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __PYX_ERR(1, 553, __pyx_L17_error) }
+0554: f'Bad argument `table_name`: {ie}')
__pyx_t_9 = __Pyx_PyObject_FormatSimple(__pyx_v_ie, __pyx_empty_unicode); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 554, __pyx_L17_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_11 = __Pyx_PyUnicode_Concat(__pyx_kp_u_Bad_argument_table_name, __pyx_t_9); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 554, __pyx_L17_error) __Pyx_GOTREF(__pyx_t_11); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0;
0555: else:
+0556: raise TypeError('Bad argument `table_name`: Must be str.')
/*else*/ { __pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_TypeError, __pyx_tuple__7, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 556, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 556, __pyx_L1_error) } /* … */ __pyx_tuple__7 = PyTuple_Pack(1, __pyx_kp_u_Bad_argument_table_name_Must_be); if (unlikely(!__pyx_tuple__7)) __PYX_ERR(1, 556, __pyx_L1_error) __Pyx_GOTREF(__pyx_tuple__7); __Pyx_GIVEREF(__pyx_tuple__7);
+0557: elif table_name_col is not None:
__pyx_t_1 = (__pyx_v_table_name_col != Py_None); if (__pyx_t_1) { /* … */ }
+0558: if isinstance(table_name_col, str):
__pyx_t_1 = PyUnicode_Check(__pyx_v_table_name_col);
if (__pyx_t_1) {
goto __pyx_L23;
+0559: _dataframe_get_loc(df, table_name_col, 'table_name_col', &col_index)
if (!(likely(PyUnicode_CheckExact(__pyx_v_table_name_col))||((__pyx_v_table_name_col) == Py_None) || __Pyx_RaiseUnexpectedTypeError("unicode", __pyx_v_table_name_col))) __PYX_ERR(1, 559, __pyx_L1_error) __pyx_t_6 = __pyx_f_7questdb_7ingress__dataframe_get_loc(__pyx_v_df, ((PyObject*)__pyx_v_table_name_col), __pyx_n_u_table_name_col, (&__pyx_v_col_index)); if (unlikely(__pyx_t_6 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 559, __pyx_L1_error)
+0560: elif isinstance(table_name_col, int):
__pyx_t_1 = PyInt_Check(__pyx_v_table_name_col);
goto __pyx_L23;
+0561: _bind_col_index(
__pyx_t_6 = __pyx_f_7questdb_7ingress__bind_col_index(__pyx_n_u_table_name_col, __pyx_t_12, __pyx_v_col_count, (&__pyx_v_col_index)); if (unlikely(__pyx_t_6 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 561, __pyx_L1_error)
+0562: 'table_name_col', table_name_col, col_count, &col_index)
__pyx_t_12 = __Pyx_PyInt_As_int(__pyx_v_table_name_col); if (unlikely((__pyx_t_12 == (int)-1) && PyErr_Occurred())) __PYX_ERR(1, 562, __pyx_L1_error)
0563: else:
+0564: raise TypeError(
/*else*/ { __pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_TypeError, __pyx_tuple__8, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 564, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 564, __pyx_L1_error) } __pyx_L23:; /* … */ __pyx_tuple__8 = PyTuple_Pack(1, __pyx_kp_u_Bad_argument_table_name_col_must); if (unlikely(!__pyx_tuple__8)) __PYX_ERR(1, 564, __pyx_L1_error) __Pyx_GOTREF(__pyx_tuple__8); __Pyx_GIVEREF(__pyx_tuple__8);
0565: 'Bad argument `table_name_col`: ' +
0566: 'must be a column name (str) or index (int).')
+0567: pandas_col = pandas_cols[col_index]
if (unlikely(__pyx_v_pandas_cols == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not subscriptable"); __PYX_ERR(1, 567, __pyx_L1_error) } __pyx_t_2 = __Pyx_GetItemInt_List(__pyx_v_pandas_cols, __pyx_v_col_index, size_t, 0, __Pyx_PyInt_FromSize_t, 1, 0, 1); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 567, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); if (!(likely(((__pyx_t_2) == Py_None) || likely(__Pyx_TypeTest(__pyx_t_2, __pyx_ptype_7questdb_7ingress_PandasCol))))) __PYX_ERR(1, 567, __pyx_L1_error) __pyx_v_pandas_col = ((struct __pyx_obj_7questdb_7ingress_PandasCol *)__pyx_t_2); __pyx_t_2 = 0;
+0568: col = &cols.d[col_index]
__pyx_v_col = (&(__pyx_v_cols->d[__pyx_v_col_index]));
+0569: _dataframe_check_column_is_str(
__pyx_t_6 = __pyx_f_7questdb_7ingress__dataframe_check_column_is_str(__pyx_kp_u_Bad_argument_table_name_col, __pyx_v_pandas_col, __pyx_v_col->setup->source); if (unlikely(__pyx_t_6 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 569, __pyx_L1_error)
0570: 'Bad argument `table_name_col`: ',
0571: pandas_col,
0572: col.setup.source)
+0573: col.setup.meta_target = meta_target_t.meta_target_table
__pyx_v_col->setup->meta_target = __pyx_e_7questdb_7ingress_meta_target_table;
+0574: name_out.len = 0
__pyx_v_name_out->len = 0;
+0575: name_out.buf = NULL
__pyx_v_name_out->buf = NULL;
+0576: return col_index
__pyx_r = __pyx_v_col_index; goto __pyx_L0;
+0577: elif df.index.name:
__pyx_t_2 = __Pyx_PyObject_GetAttrStr(__pyx_v_df, __pyx_n_s_index); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 577, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_t_2, __pyx_n_s_name); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 577, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __pyx_t_1 = __Pyx_PyObject_IsTrue(__pyx_t_7); if (unlikely((__pyx_t_1 < 0))) __PYX_ERR(1, 577, __pyx_L1_error) __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; if (likely(__pyx_t_1)) { /* … */ }
+0578: if not isinstance(df.index.name, str):
__pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_df, __pyx_n_s_index); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 578, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_2 = __Pyx_PyObject_GetAttrStr(__pyx_t_7, __pyx_n_s_name); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 578, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __pyx_t_1 = PyUnicode_Check(__pyx_t_2); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __pyx_t_20 = (!__pyx_t_1); if (unlikely(__pyx_t_20)) { /* … */ }
+0579: raise TypeError(
__pyx_t_8 = __Pyx_PyObject_CallOneArg(__pyx_builtin_TypeError, __pyx_t_2); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 579, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __Pyx_Raise(__pyx_t_8, 0, 0, 0); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0; __PYX_ERR(1, 579, __pyx_L1_error)
+0580: 'Bad dataframe index name as table name: Expected str, ' +
__pyx_t_2 = __Pyx_PyUnicode_Concat(__pyx_kp_u_Bad_dataframe_index_name_as_tabl, __pyx_t_8); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 580, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0581: f'not an object of type {_fqn(type(df.index.name))}.')
__pyx_t_2 = PyTuple_New(3); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 581, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_21 = 0; __pyx_t_22 = 127; __Pyx_INCREF(__pyx_kp_u_not_an_object_of_type); __pyx_t_21 += 22; __Pyx_GIVEREF(__pyx_kp_u_not_an_object_of_type); PyTuple_SET_ITEM(__pyx_t_2, 0, __pyx_kp_u_not_an_object_of_type); __pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_v_df, __pyx_n_s_index); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 581, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_8 = __Pyx_PyObject_GetAttrStr(__pyx_t_7, __pyx_n_s_name); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 581, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __pyx_t_7 = __pyx_f_7questdb_7ingress__fqn(((PyTypeObject*)((PyObject *)Py_TYPE(__pyx_t_8)))); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 581, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0; __pyx_t_8 = __Pyx_PyUnicode_Unicode(__pyx_t_7); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 581, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __pyx_t_22 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_8) > __pyx_t_22) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_8) : __pyx_t_22; __pyx_t_21 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_8); __Pyx_GIVEREF(__pyx_t_8); PyTuple_SET_ITEM(__pyx_t_2, 1, __pyx_t_8); __pyx_t_8 = 0; __Pyx_INCREF(__pyx_kp_u__5); __pyx_t_21 += 1; __Pyx_GIVEREF(__pyx_kp_u__5); PyTuple_SET_ITEM(__pyx_t_2, 2, __pyx_kp_u__5); __pyx_t_8 = __Pyx_PyUnicode_Join(__pyx_t_2, 3, __pyx_t_21, __pyx_t_22); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 581, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0;
0582:
0583: # If the index has a name, use that as the table name.
+0584: try:
{ /*try:*/ { /* … */ } __pyx_L25_error:; __Pyx_XDECREF(__pyx_t_11); __pyx_t_11 = 0; __Pyx_XDECREF(__pyx_t_2); __pyx_t_2 = 0; __Pyx_XDECREF(__pyx_t_7); __pyx_t_7 = 0; __Pyx_XDECREF(__pyx_t_8); __pyx_t_8 = 0; __Pyx_XDECREF(__pyx_t_9); __pyx_t_9 = 0; /* … */ __pyx_L27_except_error:; __Pyx_XGIVEREF(__pyx_t_5); __Pyx_XGIVEREF(__pyx_t_4); __Pyx_XGIVEREF(__pyx_t_3); __Pyx_ExceptionReset(__pyx_t_5, __pyx_t_4, __pyx_t_3); goto __pyx_L1_error; __pyx_L29_try_return:; __Pyx_XGIVEREF(__pyx_t_5); __Pyx_XGIVEREF(__pyx_t_4); __Pyx_XGIVEREF(__pyx_t_3); __Pyx_ExceptionReset(__pyx_t_5, __pyx_t_4, __pyx_t_3); goto __pyx_L0; }
+0585: str_to_table_name_copy(b, <PyObject*>df.index.name, name_out)
__pyx_t_8 = __Pyx_PyObject_GetAttrStr(__pyx_v_df, __pyx_n_s_index); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 585, __pyx_L25_error) __Pyx_GOTREF(__pyx_t_8); __pyx_t_2 = __Pyx_PyObject_GetAttrStr(__pyx_t_8, __pyx_n_s_name); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 585, __pyx_L25_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0; __pyx_t_6 = __pyx_f_7questdb_7ingress_str_to_table_name_copy(__pyx_v_b, ((PyObject *)__pyx_t_2), __pyx_v_name_out); if (unlikely(__pyx_t_6 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 585, __pyx_L25_error) __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0;
+0586: return -1 # Magic value for "no column index".
__pyx_r = -1L; goto __pyx_L29_try_return;
+0587: except IngressError as ie:
__Pyx_ErrFetch(&__pyx_t_2, &__pyx_t_8, &__pyx_t_7); __Pyx_GetModuleGlobalName(__pyx_t_9, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 587, __pyx_L27_except_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_12 = __Pyx_PyErr_GivenExceptionMatches(__pyx_t_2, __pyx_t_9); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __Pyx_ErrRestore(__pyx_t_2, __pyx_t_8, __pyx_t_7); __pyx_t_2 = 0; __pyx_t_8 = 0; __pyx_t_7 = 0; if (__pyx_t_12) { __Pyx_AddTraceback("questdb.ingress._dataframe_resolve_table_name", __pyx_clineno, __pyx_lineno, __pyx_filename); if (__Pyx_GetException(&__pyx_t_7, &__pyx_t_8, &__pyx_t_2) < 0) __PYX_ERR(1, 587, __pyx_L27_except_error) __Pyx_XGOTREF(__pyx_t_7); __Pyx_XGOTREF(__pyx_t_8); __Pyx_XGOTREF(__pyx_t_2); __Pyx_INCREF(__pyx_t_8); __pyx_v_ie = __pyx_t_8; /*try:*/ { /* … */ /*finally:*/ { __pyx_L36_error:; /*exception exit:*/{ __Pyx_PyThreadState_declare __Pyx_PyThreadState_assign __pyx_t_19 = 0; __pyx_t_18 = 0; __pyx_t_17 = 0; __pyx_t_16 = 0; __pyx_t_15 = 0; __pyx_t_14 = 0; __Pyx_XDECREF(__pyx_t_11); __pyx_t_11 = 0; __Pyx_XDECREF(__pyx_t_9); __pyx_t_9 = 0; if (PY_MAJOR_VERSION >= 3) __Pyx_ExceptionSwap(&__pyx_t_16, &__pyx_t_15, &__pyx_t_14); if ((PY_MAJOR_VERSION < 3) || unlikely(__Pyx_GetException(&__pyx_t_19, &__pyx_t_18, &__pyx_t_17) < 0)) __Pyx_ErrFetch(&__pyx_t_19, &__pyx_t_18, &__pyx_t_17); __Pyx_XGOTREF(__pyx_t_19); __Pyx_XGOTREF(__pyx_t_18); __Pyx_XGOTREF(__pyx_t_17); __Pyx_XGOTREF(__pyx_t_16); __Pyx_XGOTREF(__pyx_t_15); __Pyx_XGOTREF(__pyx_t_14); __pyx_t_12 = __pyx_lineno; __pyx_t_10 = __pyx_clineno; __pyx_t_23 = __pyx_filename; { __Pyx_DECREF(__pyx_v_ie); __pyx_v_ie = 0; } if (PY_MAJOR_VERSION >= 3) { __Pyx_XGIVEREF(__pyx_t_16); __Pyx_XGIVEREF(__pyx_t_15); __Pyx_XGIVEREF(__pyx_t_14); __Pyx_ExceptionReset(__pyx_t_16, __pyx_t_15, __pyx_t_14); } __Pyx_XGIVEREF(__pyx_t_19); __Pyx_XGIVEREF(__pyx_t_18); __Pyx_XGIVEREF(__pyx_t_17); __Pyx_ErrRestore(__pyx_t_19, __pyx_t_18, __pyx_t_17); __pyx_t_19 = 0; __pyx_t_18 = 0; __pyx_t_17 = 0; __pyx_t_16 = 0; __pyx_t_15 = 0; __pyx_t_14 = 0; __pyx_lineno = __pyx_t_12; __pyx_clineno = __pyx_t_10; __pyx_filename = __pyx_t_23; goto __pyx_L27_except_error; } } } goto __pyx_L27_except_error;
+0588: raise ValueError(
__pyx_t_9 = __Pyx_PyObject_CallOneArg(__pyx_builtin_ValueError, __pyx_t_11); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 588, __pyx_L36_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_11); __pyx_t_11 = 0; __Pyx_Raise(__pyx_t_9, 0, 0, 0); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __PYX_ERR(1, 588, __pyx_L36_error) }
+0589: f'Bad dataframe index name as table name: {ie}')
__pyx_t_9 = __Pyx_PyObject_FormatSimple(__pyx_v_ie, __pyx_empty_unicode); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 589, __pyx_L36_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_11 = __Pyx_PyUnicode_Concat(__pyx_kp_u_Bad_dataframe_index_name_as_tabl_2, __pyx_t_9); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 589, __pyx_L36_error) __Pyx_GOTREF(__pyx_t_11); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0;
0590: else:
+0591: raise ValueError(
/*else*/ { __pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_ValueError, __pyx_tuple__9, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 591, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 591, __pyx_L1_error) } /* … */ __pyx_tuple__9 = PyTuple_Pack(1, __pyx_kp_u_Must_specify_at_least_one_of_tab); if (unlikely(!__pyx_tuple__9)) __PYX_ERR(1, 591, __pyx_L1_error) __Pyx_GOTREF(__pyx_tuple__9); __Pyx_GIVEREF(__pyx_tuple__9);
0592: 'Must specify at least one of `table_name` or `table_name_col`, ' +
0593: 'or set the dataframe index name (df.index.name = \'tbl_name\').')
0594:
0595:
+0596: cdef void_int _bind_col_index(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__bind_col_index(PyObject *__pyx_v_arg_name, int __pyx_v_col_num, size_t __pyx_v_col_count, size_t *__pyx_v_col_index) { int __pyx_v_bad; int __pyx_v_orig_col_num; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_3); __Pyx_XDECREF(__pyx_t_6); __Pyx_AddTraceback("questdb.ingress._bind_col_index", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
0597: str arg_name, int col_num, size_t col_count,
0598: size_t* col_index) except -1:
0599: """
0600: Validate that `col_index` is in bounds for `col_count`.
0601: This function also converts negative indicies (e.g. -1 for last column) to
0602: positive indicies.
0603: """
+0604: cdef bint bad = False
__pyx_v_bad = 0;
+0605: cdef int orig_col_num = col_num
__pyx_v_orig_col_num = __pyx_v_col_num;
+0606: if col_num < 0:
__pyx_t_1 = (__pyx_v_col_num < 0); if (__pyx_t_1) { /* … */ }
+0607: col_num += col_count # Try convert negative offsets to positive ones.
__pyx_v_col_num = (__pyx_v_col_num + __pyx_v_col_count);
+0608: if col_num < 0:
+0609: bad = True
__pyx_v_bad = 1;
+0610: if (not bad) and (<size_t>col_num >= col_count):
__pyx_t_2 = (!__pyx_v_bad); if (__pyx_t_2) { } else { __pyx_t_1 = __pyx_t_2; goto __pyx_L6_bool_binop_done; } __pyx_t_2 = (((size_t)__pyx_v_col_num) >= __pyx_v_col_count); __pyx_t_1 = __pyx_t_2; __pyx_L6_bool_binop_done:; if (__pyx_t_1) { /* … */ }
+0611: bad = True
__pyx_v_bad = 1;
+0612: if bad:
if (unlikely(__pyx_v_bad)) { /* … */ }
+0613: raise IndexError(
__pyx_t_3 = __Pyx_PyObject_CallOneArg(__pyx_builtin_IndexError, __pyx_t_6); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 613, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __Pyx_Raise(__pyx_t_3, 0, 0, 0); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __PYX_ERR(1, 613, __pyx_L1_error)
+0614: f'Bad argument `{arg_name}`: {orig_col_num} index out of range')
__pyx_t_3 = PyTuple_New(5); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 614, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __pyx_t_4 = 0; __pyx_t_5 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_argument); __pyx_t_4 += 14; __Pyx_GIVEREF(__pyx_kp_u_Bad_argument); PyTuple_SET_ITEM(__pyx_t_3, 0, __pyx_kp_u_Bad_argument); __pyx_t_6 = __Pyx_PyUnicode_Unicode(__pyx_v_arg_name); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 614, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_5 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_6) > __pyx_t_5) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_6) : __pyx_t_5; __pyx_t_4 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_6); __Pyx_GIVEREF(__pyx_t_6); PyTuple_SET_ITEM(__pyx_t_3, 1, __pyx_t_6); __pyx_t_6 = 0; __Pyx_INCREF(__pyx_kp_u__10); __pyx_t_4 += 3; __Pyx_GIVEREF(__pyx_kp_u__10); PyTuple_SET_ITEM(__pyx_t_3, 2, __pyx_kp_u__10); __pyx_t_6 = __Pyx_PyUnicode_From_int(__pyx_v_orig_col_num, 0, ' ', 'd'); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 614, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_4 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_6); __Pyx_GIVEREF(__pyx_t_6); PyTuple_SET_ITEM(__pyx_t_3, 3, __pyx_t_6); __pyx_t_6 = 0; __Pyx_INCREF(__pyx_kp_u_index_out_of_range); __pyx_t_4 += 19; __Pyx_GIVEREF(__pyx_kp_u_index_out_of_range); PyTuple_SET_ITEM(__pyx_t_3, 4, __pyx_kp_u_index_out_of_range); __pyx_t_6 = __Pyx_PyUnicode_Join(__pyx_t_3, 5, __pyx_t_4, __pyx_t_5); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 614, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
+0615: col_index[0] = <size_t>col_num
(__pyx_v_col_index[0]) = ((size_t)__pyx_v_col_num);
0616:
0617:
+0618: cdef void_int _dataframe_check_column_is_str(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_check_column_is_str(PyObject *__pyx_v_err_msg_prefix, struct __pyx_obj_7questdb_7ingress_PandasCol *__pyx_v_pandas_col, enum __pyx_t_7questdb_7ingress_col_source_t __pyx_v_source) { PyObject *__pyx_v_inferred_descr = 0; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_1); __Pyx_XDECREF(__pyx_t_3); __Pyx_XDECREF(__pyx_t_6); __Pyx_XDECREF(__pyx_t_7); __Pyx_XDECREF(__pyx_t_8); __Pyx_XDECREF(__pyx_t_9); __Pyx_AddTraceback("questdb.ingress._dataframe_check_column_is_str", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_XDECREF(__pyx_v_inferred_descr); __Pyx_RefNannyFinishContext(); return __pyx_r; }
0619: str err_msg_prefix,
0620: PandasCol pandas_col,
0621: col_source_t source) except -1:
+0622: cdef str inferred_descr = ""
__Pyx_INCREF(__pyx_kp_u__11);
__pyx_v_inferred_descr = __pyx_kp_u__11;
+0623: if not source in _STR_SOURCES:
__pyx_t_1 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_v_source); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 623, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); if (unlikely(__pyx_v_7questdb_7ingress__STR_SOURCES == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not iterable"); __PYX_ERR(1, 623, __pyx_L1_error) } __pyx_t_2 = (__Pyx_PySet_ContainsTF(__pyx_t_1, __pyx_v_7questdb_7ingress__STR_SOURCES, Py_NE)); if (unlikely((__pyx_t_2 < 0))) __PYX_ERR(1, 623, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ }
+0624: if isinstance(pandas_col.dtype, _NUMPY_OBJECT):
__pyx_t_1 = __pyx_v_pandas_col->dtype; __Pyx_INCREF(__pyx_t_1); __pyx_t_3 = __pyx_v_7questdb_7ingress__NUMPY_OBJECT; __Pyx_INCREF(__pyx_t_3); __pyx_t_2 = PyObject_IsInstance(__pyx_t_1, __pyx_t_3); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 624, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; if (__pyx_t_2) { /* … */ }
+0625: inferred_descr = f' (inferred type: {_PYOBJ_SOURCE_DESCR[source]})'
__pyx_t_3 = PyTuple_New(3); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 625, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __pyx_t_4 = 0; __pyx_t_5 = 127; __Pyx_INCREF(__pyx_kp_u_inferred_type); __pyx_t_4 += 17; __Pyx_GIVEREF(__pyx_kp_u_inferred_type); PyTuple_SET_ITEM(__pyx_t_3, 0, __pyx_kp_u_inferred_type); if (unlikely(__pyx_v_7questdb_7ingress__PYOBJ_SOURCE_DESCR == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not subscriptable"); __PYX_ERR(1, 625, __pyx_L1_error) } __pyx_t_1 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_v_source); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 625, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_6 = __Pyx_PyDict_GetItem(__pyx_v_7questdb_7ingress__PYOBJ_SOURCE_DESCR, __pyx_t_1); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 625, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __pyx_t_1 = __Pyx_PyObject_FormatSimple(__pyx_t_6, __pyx_empty_unicode); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 625, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __pyx_t_5 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_1) > __pyx_t_5) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_1) : __pyx_t_5; __pyx_t_4 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_1); __Pyx_GIVEREF(__pyx_t_1); PyTuple_SET_ITEM(__pyx_t_3, 1, __pyx_t_1); __pyx_t_1 = 0; __Pyx_INCREF(__pyx_kp_u__12); __pyx_t_4 += 1; __Pyx_GIVEREF(__pyx_kp_u__12); PyTuple_SET_ITEM(__pyx_t_3, 2, __pyx_kp_u__12); __pyx_t_1 = __Pyx_PyUnicode_Join(__pyx_t_3, 3, __pyx_t_4, __pyx_t_5); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 625, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __Pyx_DECREF_SET(__pyx_v_inferred_descr, ((PyObject*)__pyx_t_1)); __pyx_t_1 = 0;
+0626: raise IngressError(
__Pyx_GetModuleGlobalName(__pyx_t_3, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 626, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3);
+0627: IngressErrorCode.BadDataFrame,
__Pyx_GetModuleGlobalName(__pyx_t_6, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 627, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_t_6, __pyx_n_s_BadDataFrame); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 627, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0;
+0628: err_msg_prefix +
__pyx_t_6 = __Pyx_PyUnicode_ConcatSafe(__pyx_v_err_msg_prefix, __pyx_t_8); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 628, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
+0629: f'Bad dtype `{pandas_col.dtype}`{inferred_descr} for the ' +
__pyx_t_6 = PyTuple_New(5); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 629, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_4 = 0; __pyx_t_5 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_dtype); __pyx_t_4 += 11; __Pyx_GIVEREF(__pyx_kp_u_Bad_dtype); PyTuple_SET_ITEM(__pyx_t_6, 0, __pyx_kp_u_Bad_dtype); __pyx_t_8 = __Pyx_PyObject_FormatSimple(__pyx_v_pandas_col->dtype, __pyx_empty_unicode); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 629, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __pyx_t_5 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_8) > __pyx_t_5) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_8) : __pyx_t_5; __pyx_t_4 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_8); __Pyx_GIVEREF(__pyx_t_8); PyTuple_SET_ITEM(__pyx_t_6, 1, __pyx_t_8); __pyx_t_8 = 0; __Pyx_INCREF(__pyx_kp_u__13); __pyx_t_4 += 1; __Pyx_GIVEREF(__pyx_kp_u__13); PyTuple_SET_ITEM(__pyx_t_6, 2, __pyx_kp_u__13); __Pyx_INCREF(__pyx_v_inferred_descr); __pyx_t_5 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_v_inferred_descr) > __pyx_t_5) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_v_inferred_descr) : __pyx_t_5; __pyx_t_4 += __Pyx_PyUnicode_GET_LENGTH(__pyx_v_inferred_descr); __Pyx_GIVEREF(__pyx_v_inferred_descr); PyTuple_SET_ITEM(__pyx_t_6, 3, __pyx_v_inferred_descr); __Pyx_INCREF(__pyx_kp_u_for_the); __pyx_t_4 += 9; __Pyx_GIVEREF(__pyx_kp_u_for_the); PyTuple_SET_ITEM(__pyx_t_6, 4, __pyx_kp_u_for_the); __pyx_t_8 = __Pyx_PyUnicode_Join(__pyx_t_6, 5, __pyx_t_4, __pyx_t_5); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 629, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; /* … */ __pyx_t_8 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_6, __pyx_t_9); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 629, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __pyx_t_9 = NULL; __pyx_t_10 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_3))) { __pyx_t_9 = PyMethod_GET_SELF(__pyx_t_3); if (likely(__pyx_t_9)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_3); __Pyx_INCREF(__pyx_t_9); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_3, function); __pyx_t_10 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_9, __pyx_t_7, __pyx_t_8}; __pyx_t_1 = __Pyx_PyObject_FastCall(__pyx_t_3, __pyx_callargs+1-__pyx_t_10, 2+__pyx_t_10); __Pyx_XDECREF(__pyx_t_9); __pyx_t_9 = 0; __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0; if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 626, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; } __Pyx_Raise(__pyx_t_1, 0, 0, 0); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 626, __pyx_L1_error)
+0630: f'{pandas_col.name!r} column: Must be a strings column.')
__pyx_t_8 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_pandas_col->name), __pyx_empty_unicode); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 630, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8); __pyx_t_9 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_8, __pyx_kp_u_column_Must_be_a_strings_column); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 630, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0;
0631:
0632:
0633: @cython.internal
+0634: cdef class PandasCol:
struct __pyx_obj_7questdb_7ingress_PandasCol { PyObject_HEAD PyObject *name; PyObject *dtype; PyObject *series; };
0635: """Python object representing a column to parse .dataframe() arguments."""
0636: cdef str name
0637: cdef object dtype
0638: cdef object series
0639:
+0640: def __init__(
/* Python wrapper */ static int __pyx_pw_7questdb_7ingress_9PandasCol_1__init__(PyObject *__pyx_v_self, PyObject *__pyx_args, PyObject *__pyx_kwds); /*proto*/ static int __pyx_pw_7questdb_7ingress_9PandasCol_1__init__(PyObject *__pyx_v_self, PyObject *__pyx_args, PyObject *__pyx_kwds) { PyObject *__pyx_v_name = 0; PyObject *__pyx_v_dtype = 0; PyObject *__pyx_v_series = 0; CYTHON_UNUSED Py_ssize_t __pyx_nargs; CYTHON_UNUSED PyObject *const *__pyx_kwvalues; int __pyx_r; __Pyx_RefNannyDeclarations __Pyx_RefNannySetupContext("__init__ (wrapper)", 0); #if CYTHON_ASSUME_SAFE_MACROS __pyx_nargs = PyTuple_GET_SIZE(__pyx_args); #else __pyx_nargs = PyTuple_Size(__pyx_args); if (unlikely(__pyx_nargs < 0)) return -1; #endif __pyx_kwvalues = __Pyx_KwValues_VARARGS(__pyx_args, __pyx_nargs); { PyObject **__pyx_pyargnames[] = {&__pyx_n_s_name,&__pyx_n_s_dtype,&__pyx_n_s_series,0}; PyObject* values[3] = {0,0,0}; if (__pyx_kwds) { Py_ssize_t kw_args; switch (__pyx_nargs) { case 3: values[2] = __Pyx_Arg_VARARGS(__pyx_args, 2); CYTHON_FALLTHROUGH; case 2: values[1] = __Pyx_Arg_VARARGS(__pyx_args, 1); CYTHON_FALLTHROUGH; case 1: values[0] = __Pyx_Arg_VARARGS(__pyx_args, 0); CYTHON_FALLTHROUGH; case 0: break; default: goto __pyx_L5_argtuple_error; } kw_args = __Pyx_NumKwargs_VARARGS(__pyx_kwds); switch (__pyx_nargs) { case 0: if (likely((values[0] = __Pyx_GetKwValue_VARARGS(__pyx_kwds, __pyx_kwvalues, __pyx_n_s_name)) != 0)) { (void)__Pyx_Arg_NewRef_VARARGS(values[0]); kw_args--; } else if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 640, __pyx_L3_error) else goto __pyx_L5_argtuple_error; CYTHON_FALLTHROUGH; case 1: if (likely((values[1] = __Pyx_GetKwValue_VARARGS(__pyx_kwds, __pyx_kwvalues, __pyx_n_s_dtype)) != 0)) { (void)__Pyx_Arg_NewRef_VARARGS(values[1]); kw_args--; } else if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 640, __pyx_L3_error) else { __Pyx_RaiseArgtupleInvalid("__init__", 1, 3, 3, 1); __PYX_ERR(1, 640, __pyx_L3_error) } CYTHON_FALLTHROUGH; case 2: if (likely((values[2] = __Pyx_GetKwValue_VARARGS(__pyx_kwds, __pyx_kwvalues, __pyx_n_s_series)) != 0)) { (void)__Pyx_Arg_NewRef_VARARGS(values[2]); kw_args--; } else if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 640, __pyx_L3_error) else { __Pyx_RaiseArgtupleInvalid("__init__", 1, 3, 3, 2); __PYX_ERR(1, 640, __pyx_L3_error) } } if (unlikely(kw_args > 0)) { const Py_ssize_t kwd_pos_args = __pyx_nargs; if (unlikely(__Pyx_ParseOptionalKeywords(__pyx_kwds, __pyx_kwvalues, __pyx_pyargnames, 0, values + 0, kwd_pos_args, "__init__") < 0)) __PYX_ERR(1, 640, __pyx_L3_error) } } else if (unlikely(__pyx_nargs != 3)) { goto __pyx_L5_argtuple_error; } else { values[0] = __Pyx_Arg_VARARGS(__pyx_args, 0); values[1] = __Pyx_Arg_VARARGS(__pyx_args, 1); values[2] = __Pyx_Arg_VARARGS(__pyx_args, 2); } __pyx_v_name = ((PyObject*)values[0]); __pyx_v_dtype = values[1]; __pyx_v_series = values[2]; } goto __pyx_L6_skip; __pyx_L5_argtuple_error:; __Pyx_RaiseArgtupleInvalid("__init__", 1, 3, 3, __pyx_nargs); __PYX_ERR(1, 640, __pyx_L3_error) __pyx_L6_skip:; goto __pyx_L4_argument_unpacking_done; __pyx_L3_error:; { Py_ssize_t __pyx_temp; for (__pyx_temp=0; __pyx_temp < (Py_ssize_t)(sizeof(values)/sizeof(values[0])); ++__pyx_temp) { __Pyx_Arg_XDECREF_VARARGS(values[__pyx_temp]); } } __Pyx_AddTraceback("questdb.ingress.PandasCol.__init__", __pyx_clineno, __pyx_lineno, __pyx_filename); __Pyx_RefNannyFinishContext(); return -1; __pyx_L4_argument_unpacking_done:; if (unlikely(!__Pyx_ArgTypeTest(((PyObject *)__pyx_v_name), (&PyUnicode_Type), 1, "name", 1))) __PYX_ERR(1, 642, __pyx_L1_error) __pyx_r = __pyx_pf_7questdb_7ingress_9PandasCol___init__(((struct __pyx_obj_7questdb_7ingress_PandasCol *)__pyx_v_self), __pyx_v_name, __pyx_v_dtype, __pyx_v_series); int __pyx_lineno = 0; const char *__pyx_filename = NULL; int __pyx_clineno = 0; /* function exit code */ goto __pyx_L0; __pyx_L1_error:; __pyx_r = -1; __pyx_L0:; { Py_ssize_t __pyx_temp; for (__pyx_temp=0; __pyx_temp < (Py_ssize_t)(sizeof(values)/sizeof(values[0])); ++__pyx_temp) { __Pyx_Arg_XDECREF_VARARGS(values[__pyx_temp]); } } __Pyx_RefNannyFinishContext(); return __pyx_r; } static int __pyx_pf_7questdb_7ingress_9PandasCol___init__(struct __pyx_obj_7questdb_7ingress_PandasCol *__pyx_v_self, PyObject *__pyx_v_name, PyObject *__pyx_v_dtype, PyObject *__pyx_v_series) { int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; __Pyx_RefNannyFinishContext(); return __pyx_r; }
0641: self,
0642: str name,
0643: object dtype,
0644: object series):
+0645: self.name = name
__Pyx_INCREF(__pyx_v_name); __Pyx_GIVEREF(__pyx_v_name); __Pyx_GOTREF(__pyx_v_self->name); __Pyx_DECREF(__pyx_v_self->name); __pyx_v_self->name = __pyx_v_name;
+0646: self.dtype = dtype
__Pyx_INCREF(__pyx_v_dtype); __Pyx_GIVEREF(__pyx_v_dtype); __Pyx_GOTREF(__pyx_v_self->dtype); __Pyx_DECREF(__pyx_v_self->dtype); __pyx_v_self->dtype = __pyx_v_dtype;
+0647: self.series = series
__Pyx_INCREF(__pyx_v_series); __Pyx_GIVEREF(__pyx_v_series); __Pyx_GOTREF(__pyx_v_self->series); __Pyx_DECREF(__pyx_v_self->series); __pyx_v_self->series = __pyx_v_series;
0648:
+0649: cdef void_int _dataframe_resolve_symbols(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_resolve_symbols(PyObject *__pyx_v_df, PyObject *__pyx_v_pandas_cols, struct __pyx_t_7questdb_7ingress_col_t_arr *__pyx_v_cols, Py_ssize_t __pyx_v_table_name_col, Py_ssize_t __pyx_v_at_col, PyObject *__pyx_v_symbols) { size_t __pyx_v_col_index; PyObject *__pyx_v_symbol = 0; struct __pyx_obj_7questdb_7ingress_PandasCol *__pyx_v_pandas_col = 0; struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_5); __Pyx_XDECREF(__pyx_t_6); __Pyx_XDECREF(__pyx_t_12); __Pyx_XDECREF(__pyx_t_15); __Pyx_AddTraceback("questdb.ingress._dataframe_resolve_symbols", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_XDECREF(__pyx_v_symbol); __Pyx_XDECREF((PyObject *)__pyx_v_pandas_col); __Pyx_RefNannyFinishContext(); return __pyx_r; }
0650: object df,
0651: list pandas_cols,
0652: col_t_arr* cols,
0653: ssize_t table_name_col,
0654: ssize_t at_col,
0655: object symbols) except -1:
+0656: cdef size_t col_index = 0
0657: cdef object symbol
0658: cdef PandasCol pandas_col
0659: cdef col_t* col
+0660: if symbols == 'auto':
__pyx_t_1 = (__Pyx_PyUnicode_Equals(__pyx_v_symbols, __pyx_n_u_auto, Py_EQ)); if (unlikely((__pyx_t_1 < 0))) __PYX_ERR(1, 660, __pyx_L1_error) if (__pyx_t_1) { /* … */ goto __pyx_L3; }
+0661: for col_index in range(cols.size):
__pyx_t_2 = __pyx_v_cols->size; __pyx_t_3 = __pyx_t_2; for (__pyx_t_4 = 0; __pyx_t_4 < __pyx_t_3; __pyx_t_4+=1) { __pyx_v_col_index = __pyx_t_4;
+0662: pandas_col = pandas_cols[col_index]
if (unlikely(__pyx_v_pandas_cols == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not subscriptable"); __PYX_ERR(1, 662, __pyx_L1_error) } __pyx_t_5 = __Pyx_GetItemInt_List(__pyx_v_pandas_cols, __pyx_v_col_index, size_t, 0, __Pyx_PyInt_FromSize_t, 1, 0, 1); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 662, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); if (!(likely(((__pyx_t_5) == Py_None) || likely(__Pyx_TypeTest(__pyx_t_5, __pyx_ptype_7questdb_7ingress_PandasCol))))) __PYX_ERR(1, 662, __pyx_L1_error) __Pyx_XDECREF_SET(__pyx_v_pandas_col, ((struct __pyx_obj_7questdb_7ingress_PandasCol *)__pyx_t_5)); __pyx_t_5 = 0;
+0663: col = &cols.d[col_index]
+0664: if col.setup.meta_target == meta_target_t.meta_target_field:
__pyx_t_1 = (__pyx_v_col->setup->meta_target == __pyx_e_7questdb_7ingress_meta_target_field); if (__pyx_t_1) { /* … */ } }
+0665: if isinstance(pandas_col.dtype, _PANDAS.CategoricalDtype):
__pyx_t_5 = __pyx_v_pandas_col->dtype; __Pyx_INCREF(__pyx_t_5); __pyx_t_6 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_CategoricalDtype); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 665, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_1 = PyObject_IsInstance(__pyx_t_5, __pyx_t_6); if (unlikely(__pyx_t_1 == ((int)-1))) __PYX_ERR(1, 665, __pyx_L1_error) __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; if (__pyx_t_1) { /* … */ }
+0666: col.setup.meta_target = meta_target_t.meta_target_symbol
__pyx_v_col->setup->meta_target = __pyx_e_7questdb_7ingress_meta_target_symbol;
+0667: elif symbols is False:
__pyx_t_1 = (__pyx_v_symbols == Py_False); if (__pyx_t_1) { goto __pyx_L3; }
0668: pass
+0669: elif symbols is True:
__pyx_t_1 = (__pyx_v_symbols == Py_True); if (__pyx_t_1) { /* … */ goto __pyx_L3; }
+0670: for col_index in range(cols.size):
+0671: col = &cols.d[col_index]
+0672: if col.setup.source in _STR_SOURCES:
__pyx_t_6 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_v_col->setup->source); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 672, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); if (unlikely(__pyx_v_7questdb_7ingress__STR_SOURCES == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not iterable"); __PYX_ERR(1, 672, __pyx_L1_error) } __pyx_t_1 = (__Pyx_PySet_ContainsTF(__pyx_t_6, __pyx_v_7questdb_7ingress__STR_SOURCES, Py_EQ)); if (unlikely((__pyx_t_1 < 0))) __PYX_ERR(1, 672, __pyx_L1_error) __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; if (__pyx_t_1) { /* … */ } }
+0673: pandas_col = pandas_cols[col_index]
if (unlikely(__pyx_v_pandas_cols == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not subscriptable"); __PYX_ERR(1, 673, __pyx_L1_error) } __pyx_t_6 = __Pyx_GetItemInt_List(__pyx_v_pandas_cols, __pyx_v_col_index, size_t, 0, __Pyx_PyInt_FromSize_t, 1, 0, 1); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 673, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); if (!(likely(((__pyx_t_6) == Py_None) || likely(__Pyx_TypeTest(__pyx_t_6, __pyx_ptype_7questdb_7ingress_PandasCol))))) __PYX_ERR(1, 673, __pyx_L1_error) __Pyx_XDECREF_SET(__pyx_v_pandas_col, ((struct __pyx_obj_7questdb_7ingress_PandasCol *)__pyx_t_6)); __pyx_t_6 = 0;
+0674: if col.setup.meta_target == meta_target_t.meta_target_field:
+0675: col.setup.meta_target = meta_target_t.meta_target_symbol
0676: else:
+0677: if not isinstance(symbols, (tuple, list)):
/*else*/ { __pyx_t_7 = PyTuple_Check(__pyx_v_symbols); if (!__pyx_t_7) { } else { __pyx_t_1 = __pyx_t_7; goto __pyx_L13_bool_binop_done; } __pyx_t_7 = PyList_Check(__pyx_v_symbols); __pyx_t_1 = __pyx_t_7; __pyx_L13_bool_binop_done:; __pyx_t_7 = (!__pyx_t_1); if (unlikely(__pyx_t_7)) { /* … */ }
+0678: raise TypeError(
__pyx_t_6 = __Pyx_PyObject_Call(__pyx_builtin_TypeError, __pyx_tuple__14, NULL); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 678, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_Raise(__pyx_t_6, 0, 0, 0); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __PYX_ERR(1, 678, __pyx_L1_error) /* … */ __pyx_tuple__14 = PyTuple_Pack(1, __pyx_kp_u_Bad_argument_symbols_Must_be_a_b); if (unlikely(!__pyx_tuple__14)) __PYX_ERR(1, 678, __pyx_L1_error) __Pyx_GOTREF(__pyx_tuple__14); __Pyx_GIVEREF(__pyx_tuple__14);
0679: f'Bad argument `symbols`: Must be a bool or a tuple or list '+
0680: 'of column names (str) or indices (int).')
+0681: for symbol in symbols:
if (likely(PyList_CheckExact(__pyx_v_symbols)) || PyTuple_CheckExact(__pyx_v_symbols)) { __pyx_t_6 = __pyx_v_symbols; __Pyx_INCREF(__pyx_t_6); __pyx_t_8 = 0; __pyx_t_9 = NULL; } else { __pyx_t_8 = -1; __pyx_t_6 = PyObject_GetIter(__pyx_v_symbols); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 681, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_9 = __Pyx_PyObject_GetIterNextFunc(__pyx_t_6); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 681, __pyx_L1_error) } for (;;) { if (likely(!__pyx_t_9)) { if (likely(PyList_CheckExact(__pyx_t_6))) { { Py_ssize_t __pyx_temp = __Pyx_PyList_GET_SIZE(__pyx_t_6); #if !CYTHON_ASSUME_SAFE_MACROS if (unlikely((__pyx_temp < 0))) __PYX_ERR(1, 681, __pyx_L1_error) #endif if (__pyx_t_8 >= __pyx_temp) break; } #if CYTHON_ASSUME_SAFE_MACROS && !CYTHON_AVOID_BORROWED_REFS __pyx_t_5 = PyList_GET_ITEM(__pyx_t_6, __pyx_t_8); __Pyx_INCREF(__pyx_t_5); __pyx_t_8++; if (unlikely((0 < 0))) __PYX_ERR(1, 681, __pyx_L1_error) #else __pyx_t_5 = __Pyx_PySequence_ITEM(__pyx_t_6, __pyx_t_8); __pyx_t_8++; if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 681, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); #endif } else { { Py_ssize_t __pyx_temp = __Pyx_PyTuple_GET_SIZE(__pyx_t_6); #if !CYTHON_ASSUME_SAFE_MACROS if (unlikely((__pyx_temp < 0))) __PYX_ERR(1, 681, __pyx_L1_error) #endif if (__pyx_t_8 >= __pyx_temp) break; } #if CYTHON_ASSUME_SAFE_MACROS && !CYTHON_AVOID_BORROWED_REFS __pyx_t_5 = PyTuple_GET_ITEM(__pyx_t_6, __pyx_t_8); __Pyx_INCREF(__pyx_t_5); __pyx_t_8++; if (unlikely((0 < 0))) __PYX_ERR(1, 681, __pyx_L1_error) #else __pyx_t_5 = __Pyx_PySequence_ITEM(__pyx_t_6, __pyx_t_8); __pyx_t_8++; if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 681, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); #endif } } else { __pyx_t_5 = __pyx_t_9(__pyx_t_6); if (unlikely(!__pyx_t_5)) { PyObject* exc_type = PyErr_Occurred(); if (exc_type) { if (likely(__Pyx_PyErr_GivenExceptionMatches(exc_type, PyExc_StopIteration))) PyErr_Clear(); else __PYX_ERR(1, 681, __pyx_L1_error) } break; } __Pyx_GOTREF(__pyx_t_5); } __Pyx_XDECREF_SET(__pyx_v_symbol, __pyx_t_5); __pyx_t_5 = 0; /* … */ } __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; } __pyx_L3:;
+0682: if isinstance(symbol, str):
__pyx_t_7 = PyUnicode_Check(__pyx_v_symbol);
if (__pyx_t_7) {
goto __pyx_L17;
+0683: _dataframe_get_loc(df, symbol, 'symbols', &col_index)
if (!(likely(PyUnicode_CheckExact(__pyx_v_symbol))||((__pyx_v_symbol) == Py_None) || __Pyx_RaiseUnexpectedTypeError("unicode", __pyx_v_symbol))) __PYX_ERR(1, 683, __pyx_L1_error) __pyx_t_10 = __pyx_f_7questdb_7ingress__dataframe_get_loc(__pyx_v_df, ((PyObject*)__pyx_v_symbol), __pyx_n_u_symbols, (&__pyx_v_col_index)); if (unlikely(__pyx_t_10 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 683, __pyx_L1_error)
+0684: elif isinstance(symbol, int):
__pyx_t_7 = PyInt_Check(__pyx_v_symbol);
if (likely(__pyx_t_7)) {
goto __pyx_L17;
+0685: _bind_col_index('symbol', symbol, cols.size, &col_index)
__pyx_t_11 = __Pyx_PyInt_As_int(__pyx_v_symbol); if (unlikely((__pyx_t_11 == (int)-1) && PyErr_Occurred())) __PYX_ERR(1, 685, __pyx_L1_error) __pyx_t_10 = __pyx_f_7questdb_7ingress__bind_col_index(__pyx_n_u_symbol, __pyx_t_11, __pyx_v_cols->size, (&__pyx_v_col_index)); if (unlikely(__pyx_t_10 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 685, __pyx_L1_error)
0686: else:
+0687: raise TypeError(
/*else*/ { __pyx_t_5 = __Pyx_PyObject_Call(__pyx_builtin_TypeError, __pyx_tuple__15, NULL); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 687, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_Raise(__pyx_t_5, 0, 0, 0); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __PYX_ERR(1, 687, __pyx_L1_error) } __pyx_L17:; /* … */ __pyx_tuple__15 = PyTuple_Pack(1, __pyx_kp_u_Bad_argument_symbols_Elements_mu); if (unlikely(!__pyx_tuple__15)) __PYX_ERR(1, 687, __pyx_L1_error) __Pyx_GOTREF(__pyx_tuple__15); __Pyx_GIVEREF(__pyx_tuple__15);
0688: f'Bad argument `symbols`: Elements must ' +
0689: 'be a column name (str) or index (int).')
+0690: if (table_name_col >= 0) and (col_index == <size_t>table_name_col):
__pyx_t_1 = (__pyx_v_table_name_col >= 0); if (__pyx_t_1) { } else { __pyx_t_7 = __pyx_t_1; goto __pyx_L19_bool_binop_done; } __pyx_t_1 = (__pyx_v_col_index == ((size_t)__pyx_v_table_name_col)); __pyx_t_7 = __pyx_t_1; __pyx_L19_bool_binop_done:; if (unlikely(__pyx_t_7)) { /* … */ }
+0691: raise ValueError(
__pyx_t_12 = __Pyx_PyObject_CallOneArg(__pyx_builtin_ValueError, __pyx_t_5); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 691, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __Pyx_Raise(__pyx_t_12, 0, 0, 0); __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0; __PYX_ERR(1, 691, __pyx_L1_error)
+0692: f'Bad argument `symbols`: Cannot use the same column ' +
__pyx_t_5 = __Pyx_PyUnicode_Concat(__pyx_kp_u_Bad_argument_symbols_Cannot_use, __pyx_t_12); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 692, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0;
+0693: f'{symbol!r} as both the table_name and as a symbol.')
__pyx_t_5 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_symbol), __pyx_empty_unicode); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 693, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_12 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_5, __pyx_kp_u_as_both_the_table_name_and_as_a); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 693, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0;
+0694: if (at_col >= 0) and (col_index == <size_t>at_col):
__pyx_t_1 = (__pyx_v_at_col >= 0); if (__pyx_t_1) { } else { __pyx_t_7 = __pyx_t_1; goto __pyx_L22_bool_binop_done; } __pyx_t_1 = (__pyx_v_col_index == ((size_t)__pyx_v_at_col)); __pyx_t_7 = __pyx_t_1; __pyx_L22_bool_binop_done:; if (unlikely(__pyx_t_7)) { /* … */ }
+0695: raise ValueError(
__pyx_t_5 = __Pyx_PyObject_CallOneArg(__pyx_builtin_ValueError, __pyx_t_12); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 695, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0; __Pyx_Raise(__pyx_t_5, 0, 0, 0); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __PYX_ERR(1, 695, __pyx_L1_error)
+0696: f'Bad argument `symbols`: Cannot use the `at` column ' +
__pyx_t_12 = __Pyx_PyUnicode_Concat(__pyx_kp_u_Bad_argument_symbols_Cannot_use_2, __pyx_t_5); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 696, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0;
+0697: f'({df.columns[at_col]!r}) as a symbol column.')
__pyx_t_12 = PyTuple_New(3); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 697, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __pyx_t_13 = 0; __pyx_t_14 = 127; __Pyx_INCREF(__pyx_kp_u__16); __pyx_t_13 += 1; __Pyx_GIVEREF(__pyx_kp_u__16); PyTuple_SET_ITEM(__pyx_t_12, 0, __pyx_kp_u__16); __pyx_t_5 = __Pyx_PyObject_GetAttrStr(__pyx_v_df, __pyx_n_s_columns); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 697, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_15 = __Pyx_GetItemInt(__pyx_t_5, __pyx_v_at_col, Py_ssize_t, 1, PyInt_FromSsize_t, 0, 1, 1); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 697, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_15); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __pyx_t_5 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_t_15), __pyx_empty_unicode); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 697, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_15); __pyx_t_15 = 0; __pyx_t_14 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_5) > __pyx_t_14) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_5) : __pyx_t_14; __pyx_t_13 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_5); __Pyx_GIVEREF(__pyx_t_5); PyTuple_SET_ITEM(__pyx_t_12, 1, __pyx_t_5); __pyx_t_5 = 0; __Pyx_INCREF(__pyx_kp_u_as_a_symbol_column); __pyx_t_13 += 21; __Pyx_GIVEREF(__pyx_kp_u_as_a_symbol_column); PyTuple_SET_ITEM(__pyx_t_12, 2, __pyx_kp_u_as_a_symbol_column); __pyx_t_5 = __Pyx_PyUnicode_Join(__pyx_t_12, 3, __pyx_t_13, __pyx_t_14); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 697, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0;
+0698: pandas_col = pandas_cols[col_index]
if (unlikely(__pyx_v_pandas_cols == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not subscriptable"); __PYX_ERR(1, 698, __pyx_L1_error) } __pyx_t_5 = __Pyx_GetItemInt_List(__pyx_v_pandas_cols, __pyx_v_col_index, size_t, 0, __Pyx_PyInt_FromSize_t, 1, 0, 1); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 698, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); if (!(likely(((__pyx_t_5) == Py_None) || likely(__Pyx_TypeTest(__pyx_t_5, __pyx_ptype_7questdb_7ingress_PandasCol))))) __PYX_ERR(1, 698, __pyx_L1_error) __Pyx_XDECREF_SET(__pyx_v_pandas_col, ((struct __pyx_obj_7questdb_7ingress_PandasCol *)__pyx_t_5)); __pyx_t_5 = 0;
+0699: col = &cols.d[col_index]
+0700: _dataframe_check_column_is_str(
__pyx_t_10 = __pyx_f_7questdb_7ingress__dataframe_check_column_is_str(__pyx_kp_u_Bad_argument_symbols, __pyx_v_pandas_col, __pyx_v_col->setup->source); if (unlikely(__pyx_t_10 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 700, __pyx_L1_error)
0701: 'Bad argument `symbols`: ',
0702: pandas_col,
0703: col.setup.source)
+0704: col.setup.meta_target = meta_target_t.meta_target_symbol
0705:
0706:
+0707: cdef void_int _dataframe_get_loc(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_get_loc(PyObject *__pyx_v_df, PyObject *__pyx_v_col_name, PyObject *__pyx_v_arg_name, size_t *__pyx_v_col_index_out) { __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_4); __Pyx_XDECREF(__pyx_t_5); __Pyx_XDECREF(__pyx_t_6); __Pyx_XDECREF(__pyx_t_10); __Pyx_XDECREF(__pyx_t_13); __Pyx_XDECREF(__pyx_t_14); __Pyx_AddTraceback("questdb.ingress._dataframe_get_loc", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
0708: object df, str col_name, str arg_name,
0709: size_t* col_index_out) except -1:
0710: """
0711: Return the column index for `col_name`.
0712: """
+0713: try:
{ /*try:*/ { /* … */ } __Pyx_XDECREF(__pyx_t_1); __pyx_t_1 = 0; __Pyx_XDECREF(__pyx_t_2); __pyx_t_2 = 0; __Pyx_XDECREF(__pyx_t_3); __pyx_t_3 = 0; goto __pyx_L8_try_end; __pyx_L3_error:; __Pyx_XDECREF(__pyx_t_4); __pyx_t_4 = 0; __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; __Pyx_XDECREF(__pyx_t_6); __pyx_t_6 = 0; /* … */ __pyx_L5_except_error:; __Pyx_XGIVEREF(__pyx_t_1); __Pyx_XGIVEREF(__pyx_t_2); __Pyx_XGIVEREF(__pyx_t_3); __Pyx_ExceptionReset(__pyx_t_1, __pyx_t_2, __pyx_t_3); goto __pyx_L1_error; __pyx_L8_try_end:; }
+0714: col_index_out[0] = df.columns.get_loc(col_name)
__pyx_t_5 = __Pyx_PyObject_GetAttrStr(__pyx_v_df, __pyx_n_s_columns); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 714, __pyx_L3_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_6 = __Pyx_PyObject_GetAttrStr(__pyx_t_5, __pyx_n_s_get_loc); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 714, __pyx_L3_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __pyx_t_5 = NULL; __pyx_t_7 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_6))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_6); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_6); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_6, function); __pyx_t_7 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, __pyx_v_col_name}; __pyx_t_4 = __Pyx_PyObject_FastCall(__pyx_t_6, __pyx_callargs+1-__pyx_t_7, 1+__pyx_t_7); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 714, __pyx_L3_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; } __pyx_t_8 = __Pyx_PyInt_As_size_t(__pyx_t_4); if (unlikely((__pyx_t_8 == (size_t)-1) && PyErr_Occurred())) __PYX_ERR(1, 714, __pyx_L3_error) __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; (__pyx_v_col_index_out[0]) = __pyx_t_8;
+0715: except KeyError:
__pyx_t_9 = __Pyx_PyErr_ExceptionMatches(__pyx_builtin_KeyError); if (__pyx_t_9) { __Pyx_AddTraceback("questdb.ingress._dataframe_get_loc", __pyx_clineno, __pyx_lineno, __pyx_filename); if (__Pyx_GetException(&__pyx_t_4, &__pyx_t_6, &__pyx_t_5) < 0) __PYX_ERR(1, 715, __pyx_L5_except_error) __Pyx_XGOTREF(__pyx_t_4); __Pyx_XGOTREF(__pyx_t_6); __Pyx_XGOTREF(__pyx_t_5);
+0716: raise KeyError(
__pyx_t_14 = __Pyx_PyObject_CallOneArg(__pyx_builtin_KeyError, __pyx_t_10); if (unlikely(!__pyx_t_14)) __PYX_ERR(1, 716, __pyx_L5_except_error) __Pyx_GOTREF(__pyx_t_14); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; __Pyx_Raise(__pyx_t_14, 0, 0, 0); __Pyx_DECREF(__pyx_t_14); __pyx_t_14 = 0; __PYX_ERR(1, 716, __pyx_L5_except_error) } goto __pyx_L5_except_error;
+0717: f'Bad argument `{arg_name}`: ' +
__pyx_t_10 = PyTuple_New(3); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 717, __pyx_L5_except_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_11 = 0; __pyx_t_12 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_argument); __pyx_t_11 += 14; __Pyx_GIVEREF(__pyx_kp_u_Bad_argument); PyTuple_SET_ITEM(__pyx_t_10, 0, __pyx_kp_u_Bad_argument); __pyx_t_13 = __Pyx_PyUnicode_Unicode(__pyx_v_arg_name); if (unlikely(!__pyx_t_13)) __PYX_ERR(1, 717, __pyx_L5_except_error) __Pyx_GOTREF(__pyx_t_13); __pyx_t_12 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_13) > __pyx_t_12) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_13) : __pyx_t_12; __pyx_t_11 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_13); __Pyx_GIVEREF(__pyx_t_13); PyTuple_SET_ITEM(__pyx_t_10, 1, __pyx_t_13); __pyx_t_13 = 0; __Pyx_INCREF(__pyx_kp_u__10); __pyx_t_11 += 3; __Pyx_GIVEREF(__pyx_kp_u__10); PyTuple_SET_ITEM(__pyx_t_10, 2, __pyx_kp_u__10); __pyx_t_13 = __Pyx_PyUnicode_Join(__pyx_t_10, 3, __pyx_t_11, __pyx_t_12); if (unlikely(!__pyx_t_13)) __PYX_ERR(1, 717, __pyx_L5_except_error) __Pyx_GOTREF(__pyx_t_13); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; /* … */ __pyx_t_10 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_13, __pyx_t_14); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 717, __pyx_L5_except_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_13); __pyx_t_13 = 0; __Pyx_DECREF(__pyx_t_14); __pyx_t_14 = 0;
+0718: f'Column {col_name!r} not found in the dataframe.')
__pyx_t_10 = PyTuple_New(3); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 718, __pyx_L5_except_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_11 = 0; __pyx_t_12 = 127; __Pyx_INCREF(__pyx_kp_u_Column); __pyx_t_11 += 7; __Pyx_GIVEREF(__pyx_kp_u_Column); PyTuple_SET_ITEM(__pyx_t_10, 0, __pyx_kp_u_Column); __pyx_t_14 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_col_name), __pyx_empty_unicode); if (unlikely(!__pyx_t_14)) __PYX_ERR(1, 718, __pyx_L5_except_error) __Pyx_GOTREF(__pyx_t_14); __pyx_t_12 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_14) > __pyx_t_12) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_14) : __pyx_t_12; __pyx_t_11 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_14); __Pyx_GIVEREF(__pyx_t_14); PyTuple_SET_ITEM(__pyx_t_10, 1, __pyx_t_14); __pyx_t_14 = 0; __Pyx_INCREF(__pyx_kp_u_not_found_in_the_dataframe); __pyx_t_11 += 28; __Pyx_GIVEREF(__pyx_kp_u_not_found_in_the_dataframe); PyTuple_SET_ITEM(__pyx_t_10, 2, __pyx_kp_u_not_found_in_the_dataframe); __pyx_t_14 = __Pyx_PyUnicode_Join(__pyx_t_10, 3, __pyx_t_11, __pyx_t_12); if (unlikely(!__pyx_t_14)) __PYX_ERR(1, 718, __pyx_L5_except_error) __Pyx_GOTREF(__pyx_t_14); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0;
0719:
0720:
0721: # The values -2 and -1 are safe to use as a sentinel because the TimestampNanos
0722: # type already validates that the value is >= 0.
+0723: cdef int64_t _AT_IS_SERVER_NOW = -2
__pyx_v_7questdb_7ingress__AT_IS_SERVER_NOW = -2L;
+0724: cdef int64_t _AT_IS_SET_BY_COLUMN = -1
__pyx_v_7questdb_7ingress__AT_IS_SET_BY_COLUMN = -1L;
0725:
0726:
+0727: cdef str _SUPPORTED_DATETIMES = 'datetime64[ns] or datetime64[ns, tz]'
__Pyx_INCREF(__pyx_kp_u_datetime64_ns_or_datetime64_ns_t); __Pyx_XGOTREF(__pyx_v_7questdb_7ingress__SUPPORTED_DATETIMES); __Pyx_DECREF_SET(__pyx_v_7questdb_7ingress__SUPPORTED_DATETIMES, __pyx_kp_u_datetime64_ns_or_datetime64_ns_t); __Pyx_GIVEREF(__pyx_kp_u_datetime64_ns_or_datetime64_ns_t);
0728:
0729:
+0730: cdef object _dataframe_is_supported_datetime(object dtype):
static PyObject *__pyx_f_7questdb_7ingress__dataframe_is_supported_datetime(PyObject *__pyx_v_dtype) { PyObject *__pyx_r = NULL; /* … */ /* function exit code */ __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_XDECREF(__pyx_t_4); __Pyx_AddTraceback("questdb.ingress._dataframe_is_supported_datetime", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = 0; __pyx_L0:; __Pyx_XGIVEREF(__pyx_r); __Pyx_RefNannyFinishContext(); return __pyx_r; }
+0731: if (isinstance(dtype, _NUMPY_DATETIME64_NS) and
__pyx_t_2 = __pyx_v_7questdb_7ingress__NUMPY_DATETIME64_NS; __Pyx_INCREF(__pyx_t_2); __pyx_t_3 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_2); if (unlikely(__pyx_t_3 == ((int)-1))) __PYX_ERR(1, 731, __pyx_L1_error) __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; if (__pyx_t_3) { } else { __pyx_t_1 = __pyx_t_3; goto __pyx_L4_bool_binop_done; } /* … */ if (__pyx_t_1) { /* … */ }
+0732: (str(dtype) == 'datetime64[ns]')):
__pyx_t_2 = __Pyx_PyObject_Unicode(__pyx_v_dtype); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 732, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_3 = (__Pyx_PyUnicode_Equals(__pyx_t_2, __pyx_kp_u_datetime64_ns, Py_EQ)); if (unlikely((__pyx_t_3 < 0))) __PYX_ERR(1, 732, __pyx_L1_error) __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __pyx_t_1 = __pyx_t_3; __pyx_L4_bool_binop_done:;
+0733: return True
__Pyx_XDECREF(__pyx_r); __Pyx_INCREF(Py_True); __pyx_r = Py_True; goto __pyx_L0;
+0734: if isinstance(dtype, _PANDAS.DatetimeTZDtype):
__pyx_t_2 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_DatetimeTZDtype); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 734, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_1 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_2); if (unlikely(__pyx_t_1 == ((int)-1))) __PYX_ERR(1, 734, __pyx_L1_error) __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; if (__pyx_t_1) { /* … */ }
+0735: return dtype.unit == 'ns'
__Pyx_XDECREF(__pyx_r); __pyx_t_2 = __Pyx_PyObject_GetAttrStr(__pyx_v_dtype, __pyx_n_s_unit); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 735, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_4 = PyObject_RichCompare(__pyx_t_2, __pyx_n_u_ns, Py_EQ); __Pyx_XGOTREF(__pyx_t_4); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 735, __pyx_L1_error) __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __pyx_r = __pyx_t_4; __pyx_t_4 = 0; goto __pyx_L0;
+0736: return False
__Pyx_XDECREF(__pyx_r); __Pyx_INCREF(Py_False); __pyx_r = Py_False; goto __pyx_L0;
0737:
0738:
+0739: cdef ssize_t _dataframe_resolve_at(
static Py_ssize_t __pyx_f_7questdb_7ingress__dataframe_resolve_at(PyObject *__pyx_v_df, struct __pyx_t_7questdb_7ingress_col_t_arr *__pyx_v_cols, PyObject *__pyx_v_at, size_t __pyx_v_col_count, int64_t *__pyx_v_at_value_out) { size_t __pyx_v_col_index; PyObject *__pyx_v_dtype = 0; struct __pyx_obj_7questdb_7ingress_TimestampNanos *__pyx_v_at_nanos = 0; struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col; Py_ssize_t __pyx_r; /* … */ /* function exit code */ __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_XDECREF(__pyx_t_4); __Pyx_XDECREF(__pyx_t_5); __Pyx_AddTraceback("questdb.ingress._dataframe_resolve_at", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -2L; __pyx_L0:; __Pyx_XDECREF(__pyx_v_dtype); __Pyx_XDECREF((PyObject *)__pyx_v_at_nanos); __Pyx_RefNannyFinishContext(); return __pyx_r; }
0740: object df,
0741: col_t_arr* cols,
0742: object at,
0743: size_t col_count,
0744: int64_t* at_value_out) except -2:
0745: cdef size_t col_index
0746: cdef object dtype
0747: cdef PandasCol pandas_col
0748: cdef TimestampNanos at_nanos
+0749: if at is None:
__pyx_t_1 = (__pyx_v_at == Py_None); if (__pyx_t_1) { /* … */ }
+0750: at_value_out[0] = _AT_IS_SERVER_NOW
(__pyx_v_at_value_out[0]) = __pyx_v_7questdb_7ingress__AT_IS_SERVER_NOW;
+0751: return -1
__pyx_r = -1L; goto __pyx_L0;
+0752: elif isinstance(at, TimestampNanos):
__pyx_t_1 = __Pyx_TypeCheck(__pyx_v_at, __pyx_ptype_7questdb_7ingress_TimestampNanos);
if (__pyx_t_1) {
+0753: at_nanos = at
if (!(likely(((__pyx_v_at) == Py_None) || likely(__Pyx_TypeTest(__pyx_v_at, __pyx_ptype_7questdb_7ingress_TimestampNanos))))) __PYX_ERR(1, 753, __pyx_L1_error) __pyx_t_2 = __pyx_v_at; __Pyx_INCREF(__pyx_t_2); __pyx_v_at_nanos = ((struct __pyx_obj_7questdb_7ingress_TimestampNanos *)__pyx_t_2); __pyx_t_2 = 0;
+0754: at_value_out[0] = at_nanos._value
__pyx_t_3 = __pyx_v_at_nanos->_value; (__pyx_v_at_value_out[0]) = __pyx_t_3;
+0755: return -1
+0756: elif isinstance(at, datetime):
__pyx_t_1 = __Pyx_TypeCheck(__pyx_v_at, __pyx_ptype_7cpython_8datetime_datetime);
if (__pyx_t_1) {
+0757: if at.timestamp() < 0:
__pyx_t_4 = __Pyx_PyObject_GetAttrStr(__pyx_v_at, __pyx_n_s_timestamp); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 757, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __pyx_t_5 = NULL; __pyx_t_6 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_4))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_4); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_4); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_4, function); __pyx_t_6 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_5, NULL}; __pyx_t_2 = __Pyx_PyObject_FastCall(__pyx_t_4, __pyx_callargs+1-__pyx_t_6, 0+__pyx_t_6); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 757, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; } __pyx_t_4 = PyObject_RichCompare(__pyx_t_2, __pyx_int_0, Py_LT); __Pyx_XGOTREF(__pyx_t_4); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 757, __pyx_L1_error) __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __pyx_t_1 = __Pyx_PyObject_IsTrue(__pyx_t_4); if (unlikely((__pyx_t_1 < 0))) __PYX_ERR(1, 757, __pyx_L1_error) __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; if (unlikely(__pyx_t_1)) { /* … */ }
+0758: raise ValueError(
__pyx_t_4 = __Pyx_PyObject_Call(__pyx_builtin_ValueError, __pyx_tuple__17, NULL); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 758, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_Raise(__pyx_t_4, 0, 0, 0); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __PYX_ERR(1, 758, __pyx_L1_error) /* … */ __pyx_tuple__17 = PyTuple_Pack(1, __pyx_kp_u_Bad_argument_at_Cannot_use_a_dat); if (unlikely(!__pyx_tuple__17)) __PYX_ERR(1, 758, __pyx_L1_error) __Pyx_GOTREF(__pyx_tuple__17); __Pyx_GIVEREF(__pyx_tuple__17);
0759: 'Bad argument `at`: Cannot use a datetime before the ' +
0760: 'Unix epoch (1970-01-01 00:00:00).')
+0761: at_value_out[0] = datetime_to_nanos(at)
if (!(likely(((__pyx_v_at) == Py_None) || likely(__Pyx_TypeTest(__pyx_v_at, __pyx_ptype_7cpython_8datetime_datetime))))) __PYX_ERR(1, 761, __pyx_L1_error) __pyx_t_3 = __pyx_f_7questdb_7ingress_datetime_to_nanos(((PyDateTime_DateTime *)__pyx_v_at)); if (unlikely(__pyx_t_3 == ((int64_t)-1) && PyErr_Occurred())) __PYX_ERR(1, 761, __pyx_L1_error) (__pyx_v_at_value_out[0]) = __pyx_t_3;
+0762: return -1
+0763: elif isinstance(at, str):
__pyx_t_1 = PyUnicode_Check(__pyx_v_at);
if (__pyx_t_1) {
goto __pyx_L3;
+0764: _dataframe_get_loc(df, at, 'at', &col_index)
if (!(likely(PyUnicode_CheckExact(__pyx_v_at))||((__pyx_v_at) == Py_None) || __Pyx_RaiseUnexpectedTypeError("unicode", __pyx_v_at))) __PYX_ERR(1, 764, __pyx_L1_error) __pyx_t_7 = __pyx_f_7questdb_7ingress__dataframe_get_loc(__pyx_v_df, ((PyObject*)__pyx_v_at), __pyx_n_u_at, (&__pyx_v_col_index)); if (unlikely(__pyx_t_7 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 764, __pyx_L1_error)
+0765: elif isinstance(at, int):
__pyx_t_1 = PyInt_Check(__pyx_v_at);
goto __pyx_L3;
+0766: _bind_col_index('at', at, col_count, &col_index)
__pyx_t_8 = __Pyx_PyInt_As_int(__pyx_v_at); if (unlikely((__pyx_t_8 == (int)-1) && PyErr_Occurred())) __PYX_ERR(1, 766, __pyx_L1_error) __pyx_t_7 = __pyx_f_7questdb_7ingress__bind_col_index(__pyx_n_u_at, __pyx_t_8, __pyx_v_col_count, (&__pyx_v_col_index)); if (unlikely(__pyx_t_7 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 766, __pyx_L1_error)
0767: else:
+0768: raise TypeError(
/*else*/ { /* … */ __pyx_t_4 = __Pyx_PyObject_CallOneArg(__pyx_builtin_TypeError, __pyx_t_5); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 768, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __Pyx_Raise(__pyx_t_4, 0, 0, 0); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __PYX_ERR(1, 768, __pyx_L1_error) } __pyx_L3:;
+0769: f'Bad argument `at`: Unsupported type {_fqn(type(at))}. ' +
__pyx_t_4 = PyTuple_New(3); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 769, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __pyx_t_9 = 0; __pyx_t_10 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_argument_at_Unsupported_type); __pyx_t_9 += 36; __Pyx_GIVEREF(__pyx_kp_u_Bad_argument_at_Unsupported_type); PyTuple_SET_ITEM(__pyx_t_4, 0, __pyx_kp_u_Bad_argument_at_Unsupported_type); __pyx_t_2 = __pyx_f_7questdb_7ingress__fqn(((PyTypeObject*)((PyObject *)Py_TYPE(__pyx_v_at)))); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 769, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_5 = __Pyx_PyUnicode_Unicode(__pyx_t_2); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 769, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __pyx_t_10 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_5) > __pyx_t_10) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_5) : __pyx_t_10; __pyx_t_9 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_5); __Pyx_GIVEREF(__pyx_t_5); PyTuple_SET_ITEM(__pyx_t_4, 1, __pyx_t_5); __pyx_t_5 = 0; __Pyx_INCREF(__pyx_kp_u__18); __pyx_t_9 += 2; __Pyx_GIVEREF(__pyx_kp_u__18); PyTuple_SET_ITEM(__pyx_t_4, 2, __pyx_kp_u__18); __pyx_t_5 = __Pyx_PyUnicode_Join(__pyx_t_4, 3, __pyx_t_9, __pyx_t_10); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 769, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __pyx_t_4 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_5, __pyx_kp_u_Must_be_one_of_None_TimestampNan); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 769, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0;
+0770: 'Must be one of: None, TimestampNanos, datetime, ' +
__pyx_t_5 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_4, __pyx_kp_u_int_column_index_str_colum_name); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 770, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0;
0771: 'int (column index), str (colum name)')
+0772: dtype = df.dtypes.iloc[col_index]
__pyx_t_4 = __Pyx_PyObject_GetAttrStr(__pyx_v_df, __pyx_n_s_dtypes); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 772, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __pyx_t_5 = __Pyx_PyObject_GetAttrStr(__pyx_t_4, __pyx_n_s_iloc); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 772, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __pyx_t_4 = __Pyx_GetItemInt(__pyx_t_5, __pyx_v_col_index, size_t, 0, __Pyx_PyInt_FromSize_t, 0, 0, 1); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 772, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __pyx_v_dtype = __pyx_t_4; __pyx_t_4 = 0;
+0773: if _dataframe_is_supported_datetime(dtype):
__pyx_t_4 = __pyx_f_7questdb_7ingress__dataframe_is_supported_datetime(__pyx_v_dtype); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 773, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __pyx_t_1 = __Pyx_PyObject_IsTrue(__pyx_t_4); if (unlikely((__pyx_t_1 < 0))) __PYX_ERR(1, 773, __pyx_L1_error) __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; if (likely(__pyx_t_1)) { /* … */ }
+0774: at_value_out[0] = _AT_IS_SET_BY_COLUMN
(__pyx_v_at_value_out[0]) = __pyx_v_7questdb_7ingress__AT_IS_SET_BY_COLUMN;
+0775: col = &cols.d[col_index]
+0776: col.setup.meta_target = meta_target_t.meta_target_at
__pyx_v_col->setup->meta_target = __pyx_e_7questdb_7ingress_meta_target_at;
+0777: return col_index
0778: else:
+0779: raise TypeError(
/*else*/ { /* … */ __pyx_t_2 = __Pyx_PyObject_CallOneArg(__pyx_builtin_TypeError, __pyx_t_4); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 779, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 779, __pyx_L1_error) }
+0780: f'Bad argument `at`: Bad dtype `{dtype}` ' +
__pyx_t_4 = PyTuple_New(3); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 780, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __pyx_t_9 = 0; __pyx_t_10 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_argument_at_Bad_dtype); __pyx_t_9 += 30; __Pyx_GIVEREF(__pyx_kp_u_Bad_argument_at_Bad_dtype); PyTuple_SET_ITEM(__pyx_t_4, 0, __pyx_kp_u_Bad_argument_at_Bad_dtype); __pyx_t_5 = __Pyx_PyObject_FormatSimple(__pyx_v_dtype, __pyx_empty_unicode); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 780, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_10 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_5) > __pyx_t_10) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_5) : __pyx_t_10; __pyx_t_9 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_5); __Pyx_GIVEREF(__pyx_t_5); PyTuple_SET_ITEM(__pyx_t_4, 1, __pyx_t_5); __pyx_t_5 = 0; __Pyx_INCREF(__pyx_kp_u__19); __pyx_t_9 += 2; __Pyx_GIVEREF(__pyx_kp_u__19); PyTuple_SET_ITEM(__pyx_t_4, 2, __pyx_kp_u__19); __pyx_t_5 = __Pyx_PyUnicode_Join(__pyx_t_4, 3, __pyx_t_9, __pyx_t_10); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 780, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; /* … */ __pyx_t_4 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_5, __pyx_t_2); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 780, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0;
+0781: f'for the {at!r} column: Must be a {_SUPPORTED_DATETIMES} column.')
__pyx_t_4 = PyTuple_New(5); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 781, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __pyx_t_9 = 0; __pyx_t_10 = 127; __Pyx_INCREF(__pyx_kp_u_for_the_2); __pyx_t_9 += 8; __Pyx_GIVEREF(__pyx_kp_u_for_the_2); PyTuple_SET_ITEM(__pyx_t_4, 0, __pyx_kp_u_for_the_2); __pyx_t_2 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_at), __pyx_empty_unicode); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 781, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_10 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_2) > __pyx_t_10) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_2) : __pyx_t_10; __pyx_t_9 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_2); __Pyx_GIVEREF(__pyx_t_2); PyTuple_SET_ITEM(__pyx_t_4, 1, __pyx_t_2); __pyx_t_2 = 0; __Pyx_INCREF(__pyx_kp_u_column_Must_be_a); __pyx_t_9 += 19; __Pyx_GIVEREF(__pyx_kp_u_column_Must_be_a); PyTuple_SET_ITEM(__pyx_t_4, 2, __pyx_kp_u_column_Must_be_a); __pyx_t_2 = __Pyx_PyUnicode_Unicode(__pyx_v_7questdb_7ingress__SUPPORTED_DATETIMES); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 781, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_10 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_2) > __pyx_t_10) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_2) : __pyx_t_10; __pyx_t_9 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_2); __Pyx_GIVEREF(__pyx_t_2); PyTuple_SET_ITEM(__pyx_t_4, 3, __pyx_t_2); __pyx_t_2 = 0; __Pyx_INCREF(__pyx_kp_u_column); __pyx_t_9 += 8; __Pyx_GIVEREF(__pyx_kp_u_column); PyTuple_SET_ITEM(__pyx_t_4, 4, __pyx_kp_u_column); __pyx_t_2 = __Pyx_PyUnicode_Join(__pyx_t_4, 5, __pyx_t_9, __pyx_t_10); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 781, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0;
0782:
0783:
+0784: cdef void_int _dataframe_alloc_chunks(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_alloc_chunks(size_t __pyx_v_n_chunks, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) {
__pyx_r = 0;
goto __pyx_L0;
__pyx_L1_error:;
__Pyx_AddTraceback("questdb.ingress._dataframe_alloc_chunks", __pyx_clineno, __pyx_lineno, __pyx_filename);
__pyx_r = -1;
__pyx_L0:;
return __pyx_r;
0785: size_t n_chunks, col_t* col) except -1:
+0786: col.setup.chunks.n_chunks = n_chunks
__pyx_v_col->setup->chunks.n_chunks = __pyx_v_n_chunks;
+0787: col.setup.chunks.chunks = <ArrowArray*>calloc(
__pyx_v_col->setup->chunks.chunks = ((struct ArrowArray *)calloc((__pyx_v_col->setup->chunks.n_chunks + 1), (sizeof(struct ArrowArray))));
0788: col.setup.chunks.n_chunks + 1, # See `_dataframe_col_advance` on why +1.
0789: sizeof(ArrowArray))
+0790: if col.setup.chunks.chunks == NULL:
__pyx_t_1 = (__pyx_v_col->setup->chunks.chunks == NULL); if (unlikely(__pyx_t_1)) { /* … */ }
+0791: raise MemoryError()
PyErr_NoMemory(); __PYX_ERR(1, 791, __pyx_L1_error)
0792:
0793:
+0794: cdef void _dataframe_free_mapped_arrow(ArrowArray* arr) noexcept nogil:
static void __pyx_f_7questdb_7ingress__dataframe_free_mapped_arrow(struct ArrowArray *__pyx_v_arr) { /* … */ /* function exit code */ }
+0795: free(arr.buffers)
free(__pyx_v_arr->buffers);
+0796: arr.buffers = NULL
__pyx_v_arr->buffers = NULL;
+0797: arr.release = NULL
__pyx_v_arr->release = NULL;
0798:
0799:
+0800: cdef void_int _dataframe_series_as_pybuf(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(struct __pyx_obj_7questdb_7ingress_PandasCol *__pyx_v_pandas_col, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, struct __pyx_opt_args_7questdb_7ingress__dataframe_series_as_pybuf *__pyx_optional_args) { /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_1); __Pyx_XDECREF(__pyx_t_2); __Pyx_XDECREF(__pyx_t_3); __Pyx_XDECREF(__pyx_t_7); __Pyx_XDECREF(__pyx_t_12); __Pyx_XDECREF(__pyx_t_13); __Pyx_XDECREF(__pyx_t_14); __Pyx_XDECREF(__pyx_t_15); __Pyx_XDECREF(__pyx_t_25); __Pyx_XDECREF(__pyx_t_26); __Pyx_AddTraceback("questdb.ingress._dataframe_series_as_pybuf", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_XDECREF(__pyx_v_nparr); __Pyx_XDECREF(__pyx_v_ve); __Pyx_XDECREF(__pyx_v_be); __Pyx_RefNannyFinishContext(); return __pyx_r; } /* … */ struct __pyx_opt_args_7questdb_7ingress__dataframe_series_as_pybuf { int __pyx_n; PyObject *fallback_dtype; };
+0801: PandasCol pandas_col, col_t* col, str fallback_dtype=None) except -1:
PyObject *__pyx_v_fallback_dtype = ((PyObject*)Py_None); PyObject *__pyx_v_nparr = 0; struct ArrowArray *__pyx_v_mapped; CYTHON_UNUSED int __pyx_v_get_buf_ret; PyObject *__pyx_v_ve = NULL; PyObject *__pyx_v_be = NULL; __pyx_t_7questdb_7ingress_void_int __pyx_r; if (__pyx_optional_args) { if (__pyx_optional_args->__pyx_n > 0) { __pyx_v_fallback_dtype = __pyx_optional_args->fallback_dtype; } }
+0802: cdef object nparr = pandas_col.series.to_numpy(dtype=fallback_dtype)
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_pandas_col->series, __pyx_n_s_to_numpy); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 802, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = __Pyx_PyDict_NewPresized(1); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 802, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); if (PyDict_SetItem(__pyx_t_2, __pyx_n_s_dtype, __pyx_v_fallback_dtype) < 0) __PYX_ERR(1, 802, __pyx_L1_error) __pyx_t_3 = __Pyx_PyObject_Call(__pyx_t_1, __pyx_empty_tuple, __pyx_t_2); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 802, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __pyx_v_nparr = __pyx_t_3; __pyx_t_3 = 0;
0803: cdef ArrowArray* mapped
0804: cdef int get_buf_ret
+0805: if not PyObject_CheckBuffer(nparr):
__pyx_t_4 = (!PyObject_CheckBuffer(__pyx_v_nparr));
if (unlikely(__pyx_t_4)) {
+0806: raise TypeError(
__pyx_t_7 = __Pyx_PyObject_CallOneArg(__pyx_builtin_TypeError, __pyx_t_3); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 806, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __Pyx_Raise(__pyx_t_7, 0, 0, 0); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __PYX_ERR(1, 806, __pyx_L1_error)
+0807: f'Bad column {pandas_col.name!r}: Expected a buffer, got ' +
__pyx_t_3 = PyTuple_New(3); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 807, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __pyx_t_5 = 0; __pyx_t_6 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_column); __pyx_t_5 += 11; __Pyx_GIVEREF(__pyx_kp_u_Bad_column); PyTuple_SET_ITEM(__pyx_t_3, 0, __pyx_kp_u_Bad_column); __pyx_t_2 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_pandas_col->name), __pyx_empty_unicode); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 807, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_6 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_2) > __pyx_t_6) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_2) : __pyx_t_6; __pyx_t_5 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_2); __Pyx_GIVEREF(__pyx_t_2); PyTuple_SET_ITEM(__pyx_t_3, 1, __pyx_t_2); __pyx_t_2 = 0; __Pyx_INCREF(__pyx_kp_u_Expected_a_buffer_got); __pyx_t_5 += 25; __Pyx_GIVEREF(__pyx_kp_u_Expected_a_buffer_got); PyTuple_SET_ITEM(__pyx_t_3, 2, __pyx_kp_u_Expected_a_buffer_got); __pyx_t_2 = __Pyx_PyUnicode_Join(__pyx_t_3, 3, __pyx_t_5, __pyx_t_6); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 807, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; /* … */ __pyx_t_3 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_2, __pyx_t_7); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 807, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0;
+0808: f'{pandas_col.series!r} ({_fqn(type(pandas_col.series))})')
__pyx_t_3 = PyTuple_New(4); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 808, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __pyx_t_5 = 0; __pyx_t_6 = 127; __pyx_t_1 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_pandas_col->series), __pyx_empty_unicode); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 808, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_6 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_1) > __pyx_t_6) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_1) : __pyx_t_6; __pyx_t_5 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_1); __Pyx_GIVEREF(__pyx_t_1); PyTuple_SET_ITEM(__pyx_t_3, 0, __pyx_t_1); __pyx_t_1 = 0; __Pyx_INCREF(__pyx_kp_u__20); __pyx_t_5 += 2; __Pyx_GIVEREF(__pyx_kp_u__20); PyTuple_SET_ITEM(__pyx_t_3, 1, __pyx_kp_u__20); __pyx_t_1 = __pyx_f_7questdb_7ingress__fqn(((PyTypeObject*)((PyObject *)Py_TYPE(__pyx_v_pandas_col->series)))); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 808, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_7 = __Pyx_PyUnicode_Unicode(__pyx_t_1); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 808, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __pyx_t_6 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_7) > __pyx_t_6) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_7) : __pyx_t_6; __pyx_t_5 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_7); __Pyx_GIVEREF(__pyx_t_7); PyTuple_SET_ITEM(__pyx_t_3, 2, __pyx_t_7); __pyx_t_7 = 0; __Pyx_INCREF(__pyx_kp_u__12); __pyx_t_5 += 1; __Pyx_GIVEREF(__pyx_kp_u__12); PyTuple_SET_ITEM(__pyx_t_3, 3, __pyx_kp_u__12); __pyx_t_7 = __Pyx_PyUnicode_Join(__pyx_t_3, 4, __pyx_t_5, __pyx_t_6); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 808, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
+0809: try:
{ /*try:*/ { /* … */ } __Pyx_XDECREF(__pyx_t_8); __pyx_t_8 = 0; __Pyx_XDECREF(__pyx_t_9); __pyx_t_9 = 0; __Pyx_XDECREF(__pyx_t_10); __pyx_t_10 = 0; goto __pyx_L9_try_end; __pyx_L4_error:; __Pyx_XDECREF(__pyx_t_1); __pyx_t_1 = 0; __Pyx_XDECREF(__pyx_t_2); __pyx_t_2 = 0; __Pyx_XDECREF(__pyx_t_3); __pyx_t_3 = 0; __Pyx_XDECREF(__pyx_t_7); __pyx_t_7 = 0; /* … */ __pyx_L6_except_error:; __Pyx_XGIVEREF(__pyx_t_8); __Pyx_XGIVEREF(__pyx_t_9); __Pyx_XGIVEREF(__pyx_t_10); __Pyx_ExceptionReset(__pyx_t_8, __pyx_t_9, __pyx_t_10); goto __pyx_L1_error; __pyx_L9_try_end:; }
0810: # Note! We don't need to support numpy strides since Pandas doesn't.
0811: # Also note that this guarantees a 1D buffer.
+0812: get_buf_ret = PyObject_GetBuffer(nparr, &col.setup.pybuf, PyBUF_SIMPLE)
__pyx_t_11 = PyObject_GetBuffer(__pyx_v_nparr, (&__pyx_v_col->setup->pybuf), PyBUF_SIMPLE); if (unlikely(__pyx_t_11 == ((int)-1))) __PYX_ERR(1, 812, __pyx_L4_error) __pyx_v_get_buf_ret = __pyx_t_11;
+0813: except ValueError as ve:
__pyx_t_11 = __Pyx_PyErr_ExceptionMatches(__pyx_builtin_ValueError); if (__pyx_t_11) { __Pyx_AddTraceback("questdb.ingress._dataframe_series_as_pybuf", __pyx_clineno, __pyx_lineno, __pyx_filename); if (__Pyx_GetException(&__pyx_t_7, &__pyx_t_3, &__pyx_t_2) < 0) __PYX_ERR(1, 813, __pyx_L6_except_error) __Pyx_XGOTREF(__pyx_t_7); __Pyx_XGOTREF(__pyx_t_3); __Pyx_XGOTREF(__pyx_t_2); __Pyx_INCREF(__pyx_t_3); __pyx_v_ve = __pyx_t_3; /*try:*/ { /* … */ /*finally:*/ { __pyx_L15_error:; /*exception exit:*/{ __Pyx_PyThreadState_declare __Pyx_PyThreadState_assign __pyx_t_19 = 0; __pyx_t_20 = 0; __pyx_t_21 = 0; __pyx_t_22 = 0; __pyx_t_23 = 0; __pyx_t_24 = 0; __Pyx_XDECREF(__pyx_t_1); __pyx_t_1 = 0; __Pyx_XDECREF(__pyx_t_12); __pyx_t_12 = 0; __Pyx_XDECREF(__pyx_t_13); __pyx_t_13 = 0; __Pyx_XDECREF(__pyx_t_14); __pyx_t_14 = 0; __Pyx_XDECREF(__pyx_t_15); __pyx_t_15 = 0; if (PY_MAJOR_VERSION >= 3) __Pyx_ExceptionSwap(&__pyx_t_22, &__pyx_t_23, &__pyx_t_24); if ((PY_MAJOR_VERSION < 3) || unlikely(__Pyx_GetException(&__pyx_t_19, &__pyx_t_20, &__pyx_t_21) < 0)) __Pyx_ErrFetch(&__pyx_t_19, &__pyx_t_20, &__pyx_t_21); __Pyx_XGOTREF(__pyx_t_19); __Pyx_XGOTREF(__pyx_t_20); __Pyx_XGOTREF(__pyx_t_21); __Pyx_XGOTREF(__pyx_t_22); __Pyx_XGOTREF(__pyx_t_23); __Pyx_XGOTREF(__pyx_t_24); __pyx_t_11 = __pyx_lineno; __pyx_t_17 = __pyx_clineno; __pyx_t_18 = __pyx_filename; { __Pyx_DECREF(__pyx_v_ve); __pyx_v_ve = 0; } if (PY_MAJOR_VERSION >= 3) { __Pyx_XGIVEREF(__pyx_t_22); __Pyx_XGIVEREF(__pyx_t_23); __Pyx_XGIVEREF(__pyx_t_24); __Pyx_ExceptionReset(__pyx_t_22, __pyx_t_23, __pyx_t_24); } __Pyx_XGIVEREF(__pyx_t_19); __Pyx_XGIVEREF(__pyx_t_20); __Pyx_XGIVEREF(__pyx_t_21); __Pyx_ErrRestore(__pyx_t_19, __pyx_t_20, __pyx_t_21); __pyx_t_19 = 0; __pyx_t_20 = 0; __pyx_t_21 = 0; __pyx_t_22 = 0; __pyx_t_23 = 0; __pyx_t_24 = 0; __pyx_lineno = __pyx_t_11; __pyx_clineno = __pyx_t_17; __pyx_filename = __pyx_t_18; goto __pyx_L6_except_error; } } }
+0814: raise IngressError(
__Pyx_GetModuleGlobalName(__pyx_t_12, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 814, __pyx_L15_error) __Pyx_GOTREF(__pyx_t_12);
+0815: IngressErrorCode.BadDataFrame,
__Pyx_GetModuleGlobalName(__pyx_t_13, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_13)) __PYX_ERR(1, 815, __pyx_L15_error) __Pyx_GOTREF(__pyx_t_13); __pyx_t_14 = __Pyx_PyObject_GetAttrStr(__pyx_t_13, __pyx_n_s_BadDataFrame); if (unlikely(!__pyx_t_14)) __PYX_ERR(1, 815, __pyx_L15_error) __Pyx_GOTREF(__pyx_t_14); __Pyx_DECREF(__pyx_t_13); __pyx_t_13 = 0;
+0816: f'Bad column {pandas_col.name!r}: {ve}') from ve
__pyx_t_13 = PyTuple_New(4); if (unlikely(!__pyx_t_13)) __PYX_ERR(1, 816, __pyx_L15_error) __Pyx_GOTREF(__pyx_t_13); __pyx_t_5 = 0; __pyx_t_6 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_column); __pyx_t_5 += 11; __Pyx_GIVEREF(__pyx_kp_u_Bad_column); PyTuple_SET_ITEM(__pyx_t_13, 0, __pyx_kp_u_Bad_column); __pyx_t_15 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_pandas_col->name), __pyx_empty_unicode); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 816, __pyx_L15_error) __Pyx_GOTREF(__pyx_t_15); __pyx_t_6 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_15) > __pyx_t_6) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_15) : __pyx_t_6; __pyx_t_5 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_15); __Pyx_GIVEREF(__pyx_t_15); PyTuple_SET_ITEM(__pyx_t_13, 1, __pyx_t_15); __pyx_t_15 = 0; __Pyx_INCREF(__pyx_kp_u__21); __pyx_t_5 += 2; __Pyx_GIVEREF(__pyx_kp_u__21); PyTuple_SET_ITEM(__pyx_t_13, 2, __pyx_kp_u__21); __pyx_t_15 = __Pyx_PyObject_FormatSimple(__pyx_v_ve, __pyx_empty_unicode); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 816, __pyx_L15_error) __Pyx_GOTREF(__pyx_t_15); __pyx_t_6 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_15) > __pyx_t_6) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_15) : __pyx_t_6; __pyx_t_5 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_15); __Pyx_GIVEREF(__pyx_t_15); PyTuple_SET_ITEM(__pyx_t_13, 3, __pyx_t_15); __pyx_t_15 = 0; __pyx_t_15 = __Pyx_PyUnicode_Join(__pyx_t_13, 4, __pyx_t_5, __pyx_t_6); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 816, __pyx_L15_error) __Pyx_GOTREF(__pyx_t_15); __Pyx_DECREF(__pyx_t_13); __pyx_t_13 = 0; __pyx_t_13 = NULL; __pyx_t_16 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_12))) { __pyx_t_13 = PyMethod_GET_SELF(__pyx_t_12); if (likely(__pyx_t_13)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_12); __Pyx_INCREF(__pyx_t_13); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_12, function); __pyx_t_16 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_13, __pyx_t_14, __pyx_t_15}; __pyx_t_1 = __Pyx_PyObject_FastCall(__pyx_t_12, __pyx_callargs+1-__pyx_t_16, 2+__pyx_t_16); __Pyx_XDECREF(__pyx_t_13); __pyx_t_13 = 0; __Pyx_DECREF(__pyx_t_14); __pyx_t_14 = 0; __Pyx_DECREF(__pyx_t_15); __pyx_t_15 = 0; if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 814, __pyx_L15_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0; } __Pyx_Raise(__pyx_t_1, 0, 0, __pyx_v_ve); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 814, __pyx_L15_error) }
+0817: except BufferError as be:
__pyx_t_17 = __Pyx_PyErr_ExceptionMatches(__pyx_builtin_BufferError); if (__pyx_t_17) { __Pyx_AddTraceback("questdb.ingress._dataframe_series_as_pybuf", __pyx_clineno, __pyx_lineno, __pyx_filename); if (__Pyx_GetException(&__pyx_t_2, &__pyx_t_3, &__pyx_t_7) < 0) __PYX_ERR(1, 817, __pyx_L6_except_error) __Pyx_XGOTREF(__pyx_t_2); __Pyx_XGOTREF(__pyx_t_3); __Pyx_XGOTREF(__pyx_t_7); __Pyx_INCREF(__pyx_t_3); __pyx_v_be = __pyx_t_3; /*try:*/ { /* … */ /*finally:*/ { __pyx_L26_error:; /*exception exit:*/{ __Pyx_PyThreadState_declare __Pyx_PyThreadState_assign __pyx_t_24 = 0; __pyx_t_23 = 0; __pyx_t_22 = 0; __pyx_t_21 = 0; __pyx_t_20 = 0; __pyx_t_19 = 0; __Pyx_XDECREF(__pyx_t_1); __pyx_t_1 = 0; __Pyx_XDECREF(__pyx_t_12); __pyx_t_12 = 0; __Pyx_XDECREF(__pyx_t_13); __pyx_t_13 = 0; __Pyx_XDECREF(__pyx_t_14); __pyx_t_14 = 0; __Pyx_XDECREF(__pyx_t_15); __pyx_t_15 = 0; __Pyx_XDECREF(__pyx_t_25); __pyx_t_25 = 0; __Pyx_XDECREF(__pyx_t_26); __pyx_t_26 = 0; if (PY_MAJOR_VERSION >= 3) __Pyx_ExceptionSwap(&__pyx_t_21, &__pyx_t_20, &__pyx_t_19); if ((PY_MAJOR_VERSION < 3) || unlikely(__Pyx_GetException(&__pyx_t_24, &__pyx_t_23, &__pyx_t_22) < 0)) __Pyx_ErrFetch(&__pyx_t_24, &__pyx_t_23, &__pyx_t_22); __Pyx_XGOTREF(__pyx_t_24); __Pyx_XGOTREF(__pyx_t_23); __Pyx_XGOTREF(__pyx_t_22); __Pyx_XGOTREF(__pyx_t_21); __Pyx_XGOTREF(__pyx_t_20); __Pyx_XGOTREF(__pyx_t_19); __pyx_t_17 = __pyx_lineno; __pyx_t_11 = __pyx_clineno; __pyx_t_27 = __pyx_filename; { __Pyx_DECREF(__pyx_v_be); __pyx_v_be = 0; } if (PY_MAJOR_VERSION >= 3) { __Pyx_XGIVEREF(__pyx_t_21); __Pyx_XGIVEREF(__pyx_t_20); __Pyx_XGIVEREF(__pyx_t_19); __Pyx_ExceptionReset(__pyx_t_21, __pyx_t_20, __pyx_t_19); } __Pyx_XGIVEREF(__pyx_t_24); __Pyx_XGIVEREF(__pyx_t_23); __Pyx_XGIVEREF(__pyx_t_22); __Pyx_ErrRestore(__pyx_t_24, __pyx_t_23, __pyx_t_22); __pyx_t_24 = 0; __pyx_t_23 = 0; __pyx_t_22 = 0; __pyx_t_21 = 0; __pyx_t_20 = 0; __pyx_t_19 = 0; __pyx_lineno = __pyx_t_17; __pyx_clineno = __pyx_t_11; __pyx_filename = __pyx_t_27; goto __pyx_L6_except_error; } } } goto __pyx_L6_except_error;
+0818: raise IngressError(
__Pyx_GetModuleGlobalName(__pyx_t_12, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 818, __pyx_L26_error) __Pyx_GOTREF(__pyx_t_12);
+0819: IngressErrorCode.BadDataFrame,
__Pyx_GetModuleGlobalName(__pyx_t_15, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 819, __pyx_L26_error) __Pyx_GOTREF(__pyx_t_15); __pyx_t_14 = __Pyx_PyObject_GetAttrStr(__pyx_t_15, __pyx_n_s_BadDataFrame); if (unlikely(!__pyx_t_14)) __PYX_ERR(1, 819, __pyx_L26_error) __Pyx_GOTREF(__pyx_t_14); __Pyx_DECREF(__pyx_t_15); __pyx_t_15 = 0;
+0820: f'Bad column {pandas_col.name!r}: Expected a buffer, got ' +
__pyx_t_15 = PyTuple_New(3); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 820, __pyx_L26_error) __Pyx_GOTREF(__pyx_t_15); __pyx_t_5 = 0; __pyx_t_6 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_column); __pyx_t_5 += 11; __Pyx_GIVEREF(__pyx_kp_u_Bad_column); PyTuple_SET_ITEM(__pyx_t_15, 0, __pyx_kp_u_Bad_column); __pyx_t_13 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_pandas_col->name), __pyx_empty_unicode); if (unlikely(!__pyx_t_13)) __PYX_ERR(1, 820, __pyx_L26_error) __Pyx_GOTREF(__pyx_t_13); __pyx_t_6 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_13) > __pyx_t_6) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_13) : __pyx_t_6; __pyx_t_5 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_13); __Pyx_GIVEREF(__pyx_t_13); PyTuple_SET_ITEM(__pyx_t_15, 1, __pyx_t_13); __pyx_t_13 = 0; __Pyx_INCREF(__pyx_kp_u_Expected_a_buffer_got); __pyx_t_5 += 25; __Pyx_GIVEREF(__pyx_kp_u_Expected_a_buffer_got); PyTuple_SET_ITEM(__pyx_t_15, 2, __pyx_kp_u_Expected_a_buffer_got); __pyx_t_13 = __Pyx_PyUnicode_Join(__pyx_t_15, 3, __pyx_t_5, __pyx_t_6); if (unlikely(!__pyx_t_13)) __PYX_ERR(1, 820, __pyx_L26_error) __Pyx_GOTREF(__pyx_t_13); __Pyx_DECREF(__pyx_t_15); __pyx_t_15 = 0; /* … */ __pyx_t_15 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_13, __pyx_t_26); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 820, __pyx_L26_error) __Pyx_GOTREF(__pyx_t_15); __Pyx_DECREF(__pyx_t_13); __pyx_t_13 = 0; __Pyx_DECREF(__pyx_t_26); __pyx_t_26 = 0; __pyx_t_26 = NULL; __pyx_t_16 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_12))) { __pyx_t_26 = PyMethod_GET_SELF(__pyx_t_12); if (likely(__pyx_t_26)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_12); __Pyx_INCREF(__pyx_t_26); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_12, function); __pyx_t_16 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_26, __pyx_t_14, __pyx_t_15}; __pyx_t_1 = __Pyx_PyObject_FastCall(__pyx_t_12, __pyx_callargs+1-__pyx_t_16, 2+__pyx_t_16); __Pyx_XDECREF(__pyx_t_26); __pyx_t_26 = 0; __Pyx_DECREF(__pyx_t_14); __pyx_t_14 = 0; __Pyx_DECREF(__pyx_t_15); __pyx_t_15 = 0; if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 818, __pyx_L26_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0; }
+0821: f'{pandas_col.series!r} ({_fqn(type(pandas_col.series))})') from be
__pyx_t_15 = PyTuple_New(4); if (unlikely(!__pyx_t_15)) __PYX_ERR(1, 821, __pyx_L26_error) __Pyx_GOTREF(__pyx_t_15); __pyx_t_5 = 0; __pyx_t_6 = 127; __pyx_t_25 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_pandas_col->series), __pyx_empty_unicode); if (unlikely(!__pyx_t_25)) __PYX_ERR(1, 821, __pyx_L26_error) __Pyx_GOTREF(__pyx_t_25); __pyx_t_6 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_25) > __pyx_t_6) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_25) : __pyx_t_6; __pyx_t_5 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_25); __Pyx_GIVEREF(__pyx_t_25); PyTuple_SET_ITEM(__pyx_t_15, 0, __pyx_t_25); __pyx_t_25 = 0; __Pyx_INCREF(__pyx_kp_u__20); __pyx_t_5 += 2; __Pyx_GIVEREF(__pyx_kp_u__20); PyTuple_SET_ITEM(__pyx_t_15, 1, __pyx_kp_u__20); __pyx_t_25 = __pyx_f_7questdb_7ingress__fqn(((PyTypeObject*)((PyObject *)Py_TYPE(__pyx_v_pandas_col->series)))); if (unlikely(!__pyx_t_25)) __PYX_ERR(1, 821, __pyx_L26_error) __Pyx_GOTREF(__pyx_t_25); __pyx_t_26 = __Pyx_PyUnicode_Unicode(__pyx_t_25); if (unlikely(!__pyx_t_26)) __PYX_ERR(1, 821, __pyx_L26_error) __Pyx_GOTREF(__pyx_t_26); __Pyx_DECREF(__pyx_t_25); __pyx_t_25 = 0; __pyx_t_6 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_26) > __pyx_t_6) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_26) : __pyx_t_6; __pyx_t_5 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_26); __Pyx_GIVEREF(__pyx_t_26); PyTuple_SET_ITEM(__pyx_t_15, 2, __pyx_t_26); __pyx_t_26 = 0; __Pyx_INCREF(__pyx_kp_u__12); __pyx_t_5 += 1; __Pyx_GIVEREF(__pyx_kp_u__12); PyTuple_SET_ITEM(__pyx_t_15, 3, __pyx_kp_u__12); __pyx_t_26 = __Pyx_PyUnicode_Join(__pyx_t_15, 4, __pyx_t_5, __pyx_t_6); if (unlikely(!__pyx_t_26)) __PYX_ERR(1, 821, __pyx_L26_error) __Pyx_GOTREF(__pyx_t_26); __Pyx_DECREF(__pyx_t_15); __pyx_t_15 = 0; /* … */ __Pyx_Raise(__pyx_t_1, 0, 0, __pyx_v_be); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 818, __pyx_L26_error) }
+0822: _dataframe_alloc_chunks(1, col)
__pyx_t_28 = __pyx_f_7questdb_7ingress__dataframe_alloc_chunks(1, __pyx_v_col); if (unlikely(__pyx_t_28 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 822, __pyx_L1_error)
+0823: mapped = &col.setup.chunks.chunks[0]
__pyx_v_mapped = (&(__pyx_v_col->setup->chunks.chunks[0]));
0824:
0825: # Total number of elements.
+0826: mapped.length = (
__pyx_v_mapped->length = __Pyx_div_int64_t(((int64_t)__pyx_v_col->setup->pybuf.len), ((int64_t)__pyx_v_col->setup->pybuf.itemsize));
+0827: <int64_t>col.setup.pybuf.len // <int64_t>col.setup.pybuf.itemsize)
if (unlikely(((int64_t)__pyx_v_col->setup->pybuf.itemsize) == 0)) { PyErr_SetString(PyExc_ZeroDivisionError, "integer division or modulo by zero"); __PYX_ERR(1, 827, __pyx_L1_error) } else if (sizeof(int64_t) == sizeof(long) && (!(((int64_t)-1) > 0)) && unlikely(((int64_t)__pyx_v_col->setup->pybuf.itemsize) == (int64_t)-1) && unlikely(__Pyx_UNARY_NEG_WOULD_OVERFLOW(((int64_t)__pyx_v_col->setup->pybuf.len)))) { PyErr_SetString(PyExc_OverflowError, "value too large to perform division"); __PYX_ERR(1, 827, __pyx_L1_error) }
+0828: mapped.null_count = 0
__pyx_v_mapped->null_count = 0;
+0829: mapped.offset = 0
__pyx_v_mapped->offset = 0;
+0830: mapped.n_buffers = 2
__pyx_v_mapped->n_buffers = 2;
+0831: mapped.n_children = 0
__pyx_v_mapped->n_children = 0;
+0832: mapped.buffers = <const void**>calloc(2, sizeof(const void*))
__pyx_v_mapped->buffers = ((void const **)calloc(2, (sizeof(void const *))));
+0833: mapped.buffers[0] = NULL
(__pyx_v_mapped->buffers[0]) = NULL;
+0834: mapped.buffers[1] = <const void*>col.setup.pybuf.buf
(__pyx_v_mapped->buffers[1]) = ((void const *)__pyx_v_col->setup->pybuf.buf);
+0835: mapped.children = NULL
__pyx_v_mapped->children = NULL;
+0836: mapped.dictionary = NULL
__pyx_v_mapped->dictionary = NULL;
+0837: mapped.release = _dataframe_free_mapped_arrow # to cleanup allocated array.
__pyx_v_mapped->release = __pyx_f_7questdb_7ingress__dataframe_free_mapped_arrow;
0838:
+0839: cdef void_int _dataframe_series_as_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(struct __pyx_obj_7questdb_7ingress_PandasCol *__pyx_v_pandas_col, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { PyObject *__pyx_v_array = 0; PyObject *__pyx_v_chunks = 0; size_t __pyx_v_n_chunks; size_t __pyx_v_chunk_index; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_1); __Pyx_XDECREF(__pyx_t_2); __Pyx_XDECREF(__pyx_t_3); __Pyx_XDECREF(__pyx_t_11); __Pyx_XDECREF(__pyx_t_12); __Pyx_AddTraceback("questdb.ingress._dataframe_series_as_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_XDECREF(__pyx_v_array); __Pyx_XDECREF(__pyx_v_chunks); __Pyx_RefNannyFinishContext(); return __pyx_r; }
0840: PandasCol pandas_col,
0841: col_t* col) except -1:
0842: cdef object array
0843: cdef list chunks
0844: cdef size_t n_chunks
0845: cdef size_t chunk_index
+0846: array = _PYARROW.Array.from_pandas(pandas_col.series)
__pyx_t_2 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PYARROW, __pyx_n_s_Array); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 846, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_3 = __Pyx_PyObject_GetAttrStr(__pyx_t_2, __pyx_n_s_from_pandas); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 846, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __pyx_t_2 = NULL; __pyx_t_4 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_3))) { __pyx_t_2 = PyMethod_GET_SELF(__pyx_t_3); if (likely(__pyx_t_2)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_3); __Pyx_INCREF(__pyx_t_2); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_3, function); __pyx_t_4 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_2, __pyx_v_pandas_col->series}; __pyx_t_1 = __Pyx_PyObject_FastCall(__pyx_t_3, __pyx_callargs+1-__pyx_t_4, 1+__pyx_t_4); __Pyx_XDECREF(__pyx_t_2); __pyx_t_2 = 0; if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 846, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; } __pyx_v_array = __pyx_t_1; __pyx_t_1 = 0;
+0847: if isinstance(array, _PYARROW.ChunkedArray):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PYARROW, __pyx_n_s_ChunkedArray); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 847, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_5 = PyObject_IsInstance(__pyx_v_array, __pyx_t_1); if (unlikely(__pyx_t_5 == ((int)-1))) __PYX_ERR(1, 847, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_5) { /* … */ goto __pyx_L3; }
+0848: chunks = array.chunks
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_array, __pyx_n_s_chunks); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 848, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); if (!(likely(PyList_CheckExact(__pyx_t_1))||((__pyx_t_1) == Py_None) || __Pyx_RaiseUnexpectedTypeError("list", __pyx_t_1))) __PYX_ERR(1, 848, __pyx_L1_error) __pyx_v_chunks = ((PyObject*)__pyx_t_1); __pyx_t_1 = 0;
0849: else:
+0850: chunks = [array]
/*else*/ { __pyx_t_1 = PyList_New(1); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 850, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_INCREF(__pyx_v_array); __Pyx_GIVEREF(__pyx_v_array); if (__Pyx_PyList_SET_ITEM(__pyx_t_1, 0, __pyx_v_array)) __PYX_ERR(1, 850, __pyx_L1_error); __pyx_v_chunks = ((PyObject*)__pyx_t_1); __pyx_t_1 = 0; } __pyx_L3:;
0851:
+0852: n_chunks = len(chunks)
if (unlikely(__pyx_v_chunks == Py_None)) { PyErr_SetString(PyExc_TypeError, "object of type 'NoneType' has no len()"); __PYX_ERR(1, 852, __pyx_L1_error) } __pyx_t_6 = __Pyx_PyList_GET_SIZE(__pyx_v_chunks); if (unlikely(__pyx_t_6 == ((Py_ssize_t)-1))) __PYX_ERR(1, 852, __pyx_L1_error) __pyx_v_n_chunks = __pyx_t_6;
+0853: _dataframe_alloc_chunks(n_chunks, col)
__pyx_t_7 = __pyx_f_7questdb_7ingress__dataframe_alloc_chunks(__pyx_v_n_chunks, __pyx_v_col); if (unlikely(__pyx_t_7 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 853, __pyx_L1_error)
0854:
+0855: for chunk_index in range(n_chunks):
__pyx_t_8 = __pyx_v_n_chunks; __pyx_t_9 = __pyx_t_8; for (__pyx_t_10 = 0; __pyx_t_10 < __pyx_t_9; __pyx_t_10+=1) { __pyx_v_chunk_index = __pyx_t_10;
+0856: array = chunks[chunk_index]
if (unlikely(__pyx_v_chunks == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not subscriptable"); __PYX_ERR(1, 856, __pyx_L1_error) } __pyx_t_1 = __Pyx_GetItemInt_List(__pyx_v_chunks, __pyx_v_chunk_index, size_t, 0, __Pyx_PyInt_FromSize_t, 1, 0, 1); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 856, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF_SET(__pyx_v_array, __pyx_t_1); __pyx_t_1 = 0;
+0857: if chunk_index == 0:
__pyx_t_5 = (__pyx_v_chunk_index == 0); if (__pyx_t_5) { /* … */ goto __pyx_L6; }
+0858: chunks[chunk_index]._export_to_c(
if (unlikely(__pyx_v_chunks == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not subscriptable"); __PYX_ERR(1, 858, __pyx_L1_error) } __pyx_t_3 = __Pyx_GetItemInt_List(__pyx_v_chunks, __pyx_v_chunk_index, size_t, 0, __Pyx_PyInt_FromSize_t, 1, 0, 1); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 858, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __pyx_t_2 = __Pyx_PyObject_GetAttrStr(__pyx_t_3, __pyx_n_s_export_to_c); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 858, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
+0859: <uintptr_t>&col.setup.chunks.chunks[chunk_index],
__pyx_t_3 = __Pyx_PyInt_FromSize_t(((uintptr_t)(&(__pyx_v_col->setup->chunks.chunks[__pyx_v_chunk_index])))); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 859, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3);
+0860: <uintptr_t>&col.setup.arrow_schema)
__pyx_t_11 = __Pyx_PyInt_FromSize_t(((uintptr_t)(&__pyx_v_col->setup->arrow_schema))); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 860, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_11); __pyx_t_12 = NULL; __pyx_t_4 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_2))) { __pyx_t_12 = PyMethod_GET_SELF(__pyx_t_2); if (likely(__pyx_t_12)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_2); __Pyx_INCREF(__pyx_t_12); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_2, function); __pyx_t_4 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_12, __pyx_t_3, __pyx_t_11}; __pyx_t_1 = __Pyx_PyObject_FastCall(__pyx_t_2, __pyx_callargs+1-__pyx_t_4, 2+__pyx_t_4); __Pyx_XDECREF(__pyx_t_12); __pyx_t_12 = 0; __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __Pyx_DECREF(__pyx_t_11); __pyx_t_11 = 0; if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 858, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; } __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0;
0861: else:
+0862: chunks[chunk_index]._export_to_c(
/*else*/ { if (unlikely(__pyx_v_chunks == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not subscriptable"); __PYX_ERR(1, 862, __pyx_L1_error) } __pyx_t_2 = __Pyx_GetItemInt_List(__pyx_v_chunks, __pyx_v_chunk_index, size_t, 0, __Pyx_PyInt_FromSize_t, 1, 0, 1); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 862, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_11 = __Pyx_PyObject_GetAttrStr(__pyx_t_2, __pyx_n_s_export_to_c); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 862, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_11); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0;
+0863: <uintptr_t>&col.setup.chunks.chunks[chunk_index])
__pyx_t_2 = __Pyx_PyInt_FromSize_t(((uintptr_t)(&(__pyx_v_col->setup->chunks.chunks[__pyx_v_chunk_index])))); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 863, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_3 = NULL; __pyx_t_4 = 0; #if CYTHON_UNPACK_METHODS if (likely(PyMethod_Check(__pyx_t_11))) { __pyx_t_3 = PyMethod_GET_SELF(__pyx_t_11); if (likely(__pyx_t_3)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_11); __Pyx_INCREF(__pyx_t_3); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_11, function); __pyx_t_4 = 1; } } #endif { PyObject *__pyx_callargs[2] = {__pyx_t_3, __pyx_t_2}; __pyx_t_1 = __Pyx_PyObject_FastCall(__pyx_t_11, __pyx_callargs+1-__pyx_t_4, 1+__pyx_t_4); __Pyx_XDECREF(__pyx_t_3); __pyx_t_3 = 0; __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 862, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_11); __pyx_t_11 = 0; } __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; } __pyx_L6:; }
0864:
0865:
+0866: cdef const char* _ARROW_FMT_INT8 = "c"
__pyx_v_7questdb_7ingress__ARROW_FMT_INT8 = ((char const *)"c");
+0867: cdef const char* _ARROW_FMT_INT16 = "s"
__pyx_v_7questdb_7ingress__ARROW_FMT_INT16 = ((char const *)"s");
+0868: cdef const char* _ARROW_FMT_INT32 = "i"
__pyx_v_7questdb_7ingress__ARROW_FMT_INT32 = ((char const *)"i");
+0869: cdef const char* _ARROW_FMT_UTF8_STRING = 'u'
__pyx_v_7questdb_7ingress__ARROW_FMT_UTF8_STRING = ((char const *)"u");
+0870: cdef const char* _ARROW_FMT_LRG_UTF8_STRING = 'U'
__pyx_v_7questdb_7ingress__ARROW_FMT_LRG_UTF8_STRING = ((char const *)"U");
0871:
0872:
+0873: cdef void_int _dataframe_category_series_as_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_category_series_as_arrow(struct __pyx_obj_7questdb_7ingress_PandasCol *__pyx_v_pandas_col, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { char const *__pyx_v_format; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_4); __Pyx_XDECREF(__pyx_t_5); __Pyx_XDECREF(__pyx_t_6); __Pyx_XDECREF(__pyx_t_7); __Pyx_XDECREF(__pyx_t_10); __Pyx_XDECREF(__pyx_t_11); __Pyx_XDECREF(__pyx_t_12); __Pyx_AddTraceback("questdb.ingress._dataframe_category_series_as_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
0874: PandasCol pandas_col, col_t* col) except -1:
0875: cdef const char* format
+0876: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_1 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 876, __pyx_L1_error)
+0877: format = col.setup.arrow_schema.format
__pyx_t_2 = __pyx_v_col->setup->arrow_schema.format; __pyx_v_format = __pyx_t_2;
+0878: if strncmp(format, _ARROW_FMT_INT8, 1) == 0:
__pyx_t_3 = (strncmp(__pyx_v_format, __pyx_v_7questdb_7ingress__ARROW_FMT_INT8, 1) == 0); if (__pyx_t_3) { /* … */ goto __pyx_L3; }
+0879: col.setup.source = col_source_t.col_source_str_i8_cat
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_str_i8_cat;
+0880: elif strncmp(format, _ARROW_FMT_INT16, 1) == 0:
__pyx_t_3 = (strncmp(__pyx_v_format, __pyx_v_7questdb_7ingress__ARROW_FMT_INT16, 1) == 0); if (__pyx_t_3) { /* … */ goto __pyx_L3; }
+0881: col.setup.source = col_source_t.col_source_str_i16_cat
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_str_i16_cat;
+0882: elif strncmp(format, _ARROW_FMT_INT32, 1) == 0:
__pyx_t_3 = (strncmp(__pyx_v_format, __pyx_v_7questdb_7ingress__ARROW_FMT_INT32, 1) == 0); if (likely(__pyx_t_3)) { /* … */ goto __pyx_L3; }
+0883: col.setup.source = col_source_t.col_source_str_i32_cat
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_str_i32_cat;
0884: else:
+0885: raise IngressError(
/*else*/ { __Pyx_GetModuleGlobalName(__pyx_t_5, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 885, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5);
+0886: IngressErrorCode.BadDataFrame,
__Pyx_GetModuleGlobalName(__pyx_t_6, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 886, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_t_6, __pyx_n_s_BadDataFrame); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 886, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0;
+0887: f'Bad column {pandas_col.name!r}: ' +
__pyx_t_6 = PyTuple_New(3); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 887, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_8 = 0; __pyx_t_9 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_column); __pyx_t_8 += 11; __Pyx_GIVEREF(__pyx_kp_u_Bad_column); PyTuple_SET_ITEM(__pyx_t_6, 0, __pyx_kp_u_Bad_column); __pyx_t_10 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_pandas_col->name), __pyx_empty_unicode); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 887, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_9 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) > __pyx_t_9) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) : __pyx_t_9; __pyx_t_8 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_10); __Pyx_GIVEREF(__pyx_t_10); PyTuple_SET_ITEM(__pyx_t_6, 1, __pyx_t_10); __pyx_t_10 = 0; __Pyx_INCREF(__pyx_kp_u__21); __pyx_t_8 += 2; __Pyx_GIVEREF(__pyx_kp_u__21); PyTuple_SET_ITEM(__pyx_t_6, 2, __pyx_kp_u__21); __pyx_t_10 = __Pyx_PyUnicode_Join(__pyx_t_6, 3, __pyx_t_8, __pyx_t_9); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 887, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __pyx_t_6 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_10, __pyx_kp_u_Unsupported_arrow_category_index); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 887, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0;
+0888: 'Unsupported arrow category index type. ' +
__pyx_t_10 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_6, __pyx_t_11); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 888, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __Pyx_DECREF(__pyx_t_11); __pyx_t_11 = 0; __pyx_t_11 = NULL; __pyx_t_13 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_5))) { __pyx_t_11 = PyMethod_GET_SELF(__pyx_t_5); if (likely(__pyx_t_11)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_5); __Pyx_INCREF(__pyx_t_11); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_5, function); __pyx_t_13 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_11, __pyx_t_7, __pyx_t_10}; __pyx_t_4 = __Pyx_PyObject_FastCall(__pyx_t_5, __pyx_callargs+1-__pyx_t_13, 2+__pyx_t_13); __Pyx_XDECREF(__pyx_t_11); __pyx_t_11 = 0; __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 885, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; } __Pyx_Raise(__pyx_t_4, 0, 0, 0); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __PYX_ERR(1, 885, __pyx_L1_error) } __pyx_L3:;
+0889: f'Got {(<bytes>format).decode("utf-8")!r}.')
__pyx_t_10 = PyTuple_New(3); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 889, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_8 = 0; __pyx_t_9 = 127; __Pyx_INCREF(__pyx_kp_u_Got); __pyx_t_8 += 4; __Pyx_GIVEREF(__pyx_kp_u_Got); PyTuple_SET_ITEM(__pyx_t_10, 0, __pyx_kp_u_Got); __pyx_t_11 = __Pyx_PyBytes_FromString(__pyx_v_format); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 889, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_11); if (unlikely(__pyx_t_11 == Py_None)) { PyErr_Format(PyExc_AttributeError, "'NoneType' object has no attribute '%.30s'", "decode"); __PYX_ERR(1, 889, __pyx_L1_error) } __pyx_t_12 = __Pyx_decode_bytes(((PyObject*)__pyx_t_11), 0, PY_SSIZE_T_MAX, NULL, NULL, PyUnicode_DecodeUTF8); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 889, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __Pyx_DECREF(__pyx_t_11); __pyx_t_11 = 0; __pyx_t_11 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_t_12), __pyx_empty_unicode); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 889, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_11); __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0; __pyx_t_9 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_11) > __pyx_t_9) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_11) : __pyx_t_9; __pyx_t_8 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_11); __Pyx_GIVEREF(__pyx_t_11); PyTuple_SET_ITEM(__pyx_t_10, 1, __pyx_t_11); __pyx_t_11 = 0; __Pyx_INCREF(__pyx_kp_u__5); __pyx_t_8 += 1; __Pyx_GIVEREF(__pyx_kp_u__5); PyTuple_SET_ITEM(__pyx_t_10, 2, __pyx_kp_u__5); __pyx_t_11 = __Pyx_PyUnicode_Join(__pyx_t_10, 3, __pyx_t_8, __pyx_t_9); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 889, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_11); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0;
0890:
+0891: format = col.setup.arrow_schema.dictionary.format
__pyx_t_2 = __pyx_v_col->setup->arrow_schema.dictionary->format; __pyx_v_format = __pyx_t_2;
+0892: if (strncmp(format, _ARROW_FMT_UTF8_STRING, 1) != 0):
__pyx_t_3 = (strncmp(__pyx_v_format, __pyx_v_7questdb_7ingress__ARROW_FMT_UTF8_STRING, 1) != 0); if (unlikely(__pyx_t_3)) { /* … */ }
+0893: raise IngressError(
__Pyx_GetModuleGlobalName(__pyx_t_5, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 893, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5);
+0894: IngressErrorCode.BadDataFrame,
__Pyx_GetModuleGlobalName(__pyx_t_10, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 894, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_t_10, __pyx_n_s_BadDataFrame); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 894, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0;
+0895: f'Bad column {pandas_col.name!r}: ' +
__pyx_t_10 = PyTuple_New(3); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 895, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_8 = 0; __pyx_t_9 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_column); __pyx_t_8 += 11; __Pyx_GIVEREF(__pyx_kp_u_Bad_column); PyTuple_SET_ITEM(__pyx_t_10, 0, __pyx_kp_u_Bad_column); __pyx_t_11 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_pandas_col->name), __pyx_empty_unicode); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 895, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_11); __pyx_t_9 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_11) > __pyx_t_9) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_11) : __pyx_t_9; __pyx_t_8 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_11); __Pyx_GIVEREF(__pyx_t_11); PyTuple_SET_ITEM(__pyx_t_10, 1, __pyx_t_11); __pyx_t_11 = 0; __Pyx_INCREF(__pyx_kp_u__21); __pyx_t_8 += 2; __Pyx_GIVEREF(__pyx_kp_u__21); PyTuple_SET_ITEM(__pyx_t_10, 2, __pyx_kp_u__21); __pyx_t_11 = __Pyx_PyUnicode_Join(__pyx_t_10, 3, __pyx_t_8, __pyx_t_9); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 895, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_11); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; __pyx_t_10 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_11, __pyx_kp_u_Expected_a_category_of_strings); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 895, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_11); __pyx_t_11 = 0;
+0896: 'Expected a category of strings, ' +
__pyx_t_11 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_10, __pyx_t_12); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 896, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_11); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0; __pyx_t_12 = NULL; __pyx_t_13 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_5))) { __pyx_t_12 = PyMethod_GET_SELF(__pyx_t_5); if (likely(__pyx_t_12)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_5); __Pyx_INCREF(__pyx_t_12); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_5, function); __pyx_t_13 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_12, __pyx_t_7, __pyx_t_11}; __pyx_t_4 = __Pyx_PyObject_FastCall(__pyx_t_5, __pyx_callargs+1-__pyx_t_13, 2+__pyx_t_13); __Pyx_XDECREF(__pyx_t_12); __pyx_t_12 = 0; __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __Pyx_DECREF(__pyx_t_11); __pyx_t_11 = 0; if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 893, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; } __Pyx_Raise(__pyx_t_4, 0, 0, 0); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __PYX_ERR(1, 893, __pyx_L1_error)
+0897: f'got a category of {pandas_col.series.dtype.categories.dtype}.')
__pyx_t_11 = PyTuple_New(3); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 897, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_11); __pyx_t_8 = 0; __pyx_t_9 = 127; __Pyx_INCREF(__pyx_kp_u_got_a_category_of); __pyx_t_8 += 18; __Pyx_GIVEREF(__pyx_kp_u_got_a_category_of); PyTuple_SET_ITEM(__pyx_t_11, 0, __pyx_kp_u_got_a_category_of); __pyx_t_6 = __Pyx_PyObject_GetAttrStr(__pyx_v_pandas_col->series, __pyx_n_s_dtype); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 897, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_12 = __Pyx_PyObject_GetAttrStr(__pyx_t_6, __pyx_n_s_categories); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 897, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __pyx_t_6 = __Pyx_PyObject_GetAttrStr(__pyx_t_12, __pyx_n_s_dtype); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 897, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0; __pyx_t_12 = __Pyx_PyObject_FormatSimple(__pyx_t_6, __pyx_empty_unicode); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 897, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __pyx_t_9 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_12) > __pyx_t_9) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_12) : __pyx_t_9; __pyx_t_8 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_12); __Pyx_GIVEREF(__pyx_t_12); PyTuple_SET_ITEM(__pyx_t_11, 1, __pyx_t_12); __pyx_t_12 = 0; __Pyx_INCREF(__pyx_kp_u__5); __pyx_t_8 += 1; __Pyx_GIVEREF(__pyx_kp_u__5); PyTuple_SET_ITEM(__pyx_t_11, 2, __pyx_kp_u__5); __pyx_t_12 = __Pyx_PyUnicode_Join(__pyx_t_11, 3, __pyx_t_8, __pyx_t_9); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 897, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __Pyx_DECREF(__pyx_t_11); __pyx_t_11 = 0;
0898:
0899:
+0900: cdef inline bint _dataframe_is_float_nan(PyObject* obj) noexcept:
static CYTHON_INLINE int __pyx_f_7questdb_7ingress__dataframe_is_float_nan(PyObject *__pyx_v_obj) { int __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
+0901: return PyFloat_CheckExact(obj) and isnan(PyFloat_AS_DOUBLE(obj))
__pyx_t_2 = PyFloat_CheckExact(__pyx_v_obj); if (__pyx_t_2) { } else { __pyx_t_1 = __pyx_t_2; goto __pyx_L3_bool_binop_done; } __pyx_t_2 = isnan(PyFloat_AS_DOUBLE(__pyx_v_obj)); __pyx_t_1 = __pyx_t_2; __pyx_L3_bool_binop_done:; __pyx_r = __pyx_t_1; goto __pyx_L0;
0902:
0903:
+0904: cdef inline bint _dataframe_is_null_pyobj(PyObject* obj) noexcept:
static CYTHON_INLINE int __pyx_f_7questdb_7ingress__dataframe_is_null_pyobj(PyObject *__pyx_v_obj) { int __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
0905: return (
+0906: (obj == Py_None) or
__pyx_t_2 = (__pyx_v_obj == Py_None); if (!__pyx_t_2) { } else { __pyx_t_1 = __pyx_t_2; goto __pyx_L3_bool_binop_done; }
+0907: (obj == <PyObject*>_PANDAS_NA) or
__pyx_t_2 = (__pyx_v_obj == ((PyObject *)__pyx_v_7questdb_7ingress__PANDAS_NA)); if (!__pyx_t_2) { } else { __pyx_t_1 = __pyx_t_2; goto __pyx_L3_bool_binop_done; }
+0908: _dataframe_is_float_nan(obj))
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_is_float_nan(__pyx_v_obj); __pyx_t_1 = __pyx_t_2; __pyx_L3_bool_binop_done:; __pyx_r = __pyx_t_1; goto __pyx_L0;
0909:
0910: # noinspection PyUnreachableCode
+0911: cdef void_int _dataframe_series_sniff_pyobj(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_series_sniff_pyobj(struct __pyx_obj_7questdb_7ingress_PandasCol *__pyx_v_pandas_col, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { size_t __pyx_v_el_index; size_t __pyx_v_n_elements; PyObject **__pyx_v_obj_arr; PyObject *__pyx_v_obj; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_1); __Pyx_XDECREF(__pyx_t_8); __Pyx_XDECREF(__pyx_t_9); __Pyx_XDECREF(__pyx_t_10); __Pyx_XDECREF(__pyx_t_12); __Pyx_XDECREF(__pyx_t_14); __Pyx_AddTraceback("questdb.ingress._dataframe_series_sniff_pyobj", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
0912: PandasCol pandas_col, col_t* col) except -1:
0913: """
0914: Deduct the type of the object column.
0915: Object columns can contain pretty much anything, but they usually don't.
0916: We make an educated guess by finding the first non-null value in the column.
0917: """
0918: cdef size_t el_index
+0919: cdef size_t n_elements = len(pandas_col.series)
__pyx_t_1 = __pyx_v_pandas_col->series; __Pyx_INCREF(__pyx_t_1); __pyx_t_2 = PyObject_Length(__pyx_t_1); if (unlikely(__pyx_t_2 == ((Py_ssize_t)-1))) __PYX_ERR(1, 919, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __pyx_v_n_elements = __pyx_t_2;
0920: cdef PyObject** obj_arr
0921: cdef PyObject* obj
+0922: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 922, __pyx_L1_error)
+0923: obj_arr = <PyObject**>(col.setup.pybuf.buf)
__pyx_v_obj_arr = ((PyObject **)__pyx_v_col->setup->pybuf.buf);
+0924: for el_index in range(n_elements):
__pyx_t_4 = __pyx_v_n_elements; __pyx_t_5 = __pyx_t_4; for (__pyx_t_6 = 0; __pyx_t_6 < __pyx_t_5; __pyx_t_6+=1) { __pyx_v_el_index = __pyx_t_6;
+0925: obj = obj_arr[el_index]
__pyx_v_obj = (__pyx_v_obj_arr[__pyx_v_el_index]);
+0926: if not _dataframe_is_null_pyobj(obj):
__pyx_t_7 = (!__pyx_f_7questdb_7ingress__dataframe_is_null_pyobj(__pyx_v_obj)); if (__pyx_t_7) { /* … */ } }
+0927: if PyBool_Check(obj):
__pyx_t_7 = PyBool_Check(__pyx_v_obj);
if (__pyx_t_7) {
goto __pyx_L6;
+0928: col.setup.source = col_source_t.col_source_bool_pyobj
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_bool_pyobj;
+0929: elif PyLong_CheckExact(obj):
__pyx_t_7 = PyLong_CheckExact(__pyx_v_obj);
if (__pyx_t_7) {
goto __pyx_L6;
+0930: col.setup.source = col_source_t.col_source_int_pyobj
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_int_pyobj;
+0931: elif PyFloat_CheckExact(obj):
__pyx_t_7 = PyFloat_CheckExact(__pyx_v_obj);
if (__pyx_t_7) {
goto __pyx_L6;
+0932: col.setup.source = col_source_t.col_source_float_pyobj
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_float_pyobj;
+0933: elif PyUnicode_CheckExact(obj):
__pyx_t_7 = PyUnicode_CheckExact(__pyx_v_obj);
if (likely(__pyx_t_7)) {
goto __pyx_L6;
+0934: col.setup.source = col_source_t.col_source_str_pyobj
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_str_pyobj;
+0935: elif PyBytes_CheckExact(obj):
__pyx_t_7 = PyBytes_CheckExact(__pyx_v_obj);
if (unlikely(__pyx_t_7)) {
+0936: raise IngressError(
__Pyx_GetModuleGlobalName(__pyx_t_8, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 936, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8);
+0937: IngressErrorCode.BadDataFrame,
__Pyx_GetModuleGlobalName(__pyx_t_9, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 937, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_10 = __Pyx_PyObject_GetAttrStr(__pyx_t_9, __pyx_n_s_BadDataFrame); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 937, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0;
+0938: f'Bad column {pandas_col.name!r}: ' +
__pyx_t_9 = PyTuple_New(3); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 938, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_2 = 0; __pyx_t_11 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_column); __pyx_t_2 += 11; __Pyx_GIVEREF(__pyx_kp_u_Bad_column); PyTuple_SET_ITEM(__pyx_t_9, 0, __pyx_kp_u_Bad_column); __pyx_t_12 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_pandas_col->name), __pyx_empty_unicode); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 938, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __pyx_t_11 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_12) > __pyx_t_11) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_12) : __pyx_t_11; __pyx_t_2 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_12); __Pyx_GIVEREF(__pyx_t_12); PyTuple_SET_ITEM(__pyx_t_9, 1, __pyx_t_12); __pyx_t_12 = 0; __Pyx_INCREF(__pyx_kp_u__21); __pyx_t_2 += 2; __Pyx_GIVEREF(__pyx_kp_u__21); PyTuple_SET_ITEM(__pyx_t_9, 2, __pyx_kp_u__21); __pyx_t_12 = __Pyx_PyUnicode_Join(__pyx_t_9, 3, __pyx_t_2, __pyx_t_11); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 938, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __pyx_t_9 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_12, __pyx_kp_u_Unsupported_object_column_contai); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 938, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0;
+0939: 'Unsupported object column containing bytes.' +
__pyx_t_12 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_9, __pyx_kp_u_If_this_is_a_string_column_decod); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 939, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0;
+0940: 'If this is a string column, decode it first. ' +
__pyx_t_9 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_12, __pyx_kp_u_See_https_stackoverflow_com_ques); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 940, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0; __pyx_t_12 = NULL; __pyx_t_13 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_8))) { __pyx_t_12 = PyMethod_GET_SELF(__pyx_t_8); if (likely(__pyx_t_12)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_8); __Pyx_INCREF(__pyx_t_12); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_8, function); __pyx_t_13 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_12, __pyx_t_10, __pyx_t_9}; __pyx_t_1 = __Pyx_PyObject_FastCall(__pyx_t_8, __pyx_callargs+1-__pyx_t_13, 2+__pyx_t_13); __Pyx_XDECREF(__pyx_t_12); __pyx_t_12 = 0; __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 936, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0; } __Pyx_Raise(__pyx_t_1, 0, 0, 0); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 936, __pyx_L1_error)
0941: 'See: https://stackoverflow.com/questions/40389764/')
0942: else:
+0943: raise IngressError(
/*else*/ { __Pyx_GetModuleGlobalName(__pyx_t_8, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 943, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_8);
+0944: IngressErrorCode.BadDataFrame,
__Pyx_GetModuleGlobalName(__pyx_t_9, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 944, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_10 = __Pyx_PyObject_GetAttrStr(__pyx_t_9, __pyx_n_s_BadDataFrame); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 944, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0;
+0945: f'Bad column {pandas_col.name!r}: ' +
__pyx_t_9 = PyTuple_New(3); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 945, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_2 = 0; __pyx_t_11 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_column); __pyx_t_2 += 11; __Pyx_GIVEREF(__pyx_kp_u_Bad_column); PyTuple_SET_ITEM(__pyx_t_9, 0, __pyx_kp_u_Bad_column); __pyx_t_12 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_pandas_col->name), __pyx_empty_unicode); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 945, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __pyx_t_11 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_12) > __pyx_t_11) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_12) : __pyx_t_11; __pyx_t_2 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_12); __Pyx_GIVEREF(__pyx_t_12); PyTuple_SET_ITEM(__pyx_t_9, 1, __pyx_t_12); __pyx_t_12 = 0; __Pyx_INCREF(__pyx_kp_u__21); __pyx_t_2 += 2; __Pyx_GIVEREF(__pyx_kp_u__21); PyTuple_SET_ITEM(__pyx_t_9, 2, __pyx_kp_u__21); __pyx_t_12 = __Pyx_PyUnicode_Join(__pyx_t_9, 3, __pyx_t_2, __pyx_t_11); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 945, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __pyx_t_9 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_12, __pyx_kp_u_Unsupported_object_column_contai_2); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 945, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0;
+0946: f'Unsupported object column containing an object of type ' +
__pyx_t_14 = __Pyx_PyUnicode_ConcatInPlaceSafe(__pyx_t_9, __pyx_t_12); if (unlikely(!__pyx_t_14)) __PYX_ERR(1, 946, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_14); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0;
+0947: _fqn(type(<object>obj)) + '.')
__pyx_t_12 = __pyx_f_7questdb_7ingress__fqn(((PyTypeObject*)((PyObject *)Py_TYPE(((PyObject *)__pyx_v_obj))))); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 947, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); /* … */ __pyx_t_12 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_14, __pyx_kp_u__5); if (unlikely(!__pyx_t_12)) __PYX_ERR(1, 947, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_12); __Pyx_DECREF(__pyx_t_14); __pyx_t_14 = 0; __pyx_t_14 = NULL; __pyx_t_13 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_8))) { __pyx_t_14 = PyMethod_GET_SELF(__pyx_t_8); if (likely(__pyx_t_14)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_8); __Pyx_INCREF(__pyx_t_14); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_8, function); __pyx_t_13 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_14, __pyx_t_10, __pyx_t_12}; __pyx_t_1 = __Pyx_PyObject_FastCall(__pyx_t_8, __pyx_callargs+1-__pyx_t_13, 2+__pyx_t_13); __Pyx_XDECREF(__pyx_t_14); __pyx_t_14 = 0; __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; __Pyx_DECREF(__pyx_t_12); __pyx_t_12 = 0; if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 943, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0; } __Pyx_Raise(__pyx_t_1, 0, 0, 0); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 943, __pyx_L1_error) } __pyx_L6:;
+0948: return 0
0949:
0950: # We haven't returned yet, so we've hit an object column that
0951: # exclusively has null values. We will just skip this column.
+0952: col.setup.source = col_source_t.col_source_nulls
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_nulls;
0953:
0954:
+0955: cdef void_int _dataframe_resolve_source_and_buffers(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_resolve_source_and_buffers(struct __pyx_obj_7questdb_7ingress_PandasCol *__pyx_v_pandas_col, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { PyObject *__pyx_v_dtype = 0; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_1); __Pyx_XDECREF(__pyx_t_4); __Pyx_XDECREF(__pyx_t_5); __Pyx_XDECREF(__pyx_t_6); __Pyx_XDECREF(__pyx_t_9); __Pyx_XDECREF(__pyx_t_10); __Pyx_AddTraceback("questdb.ingress._dataframe_resolve_source_and_buffers", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_XDECREF(__pyx_v_dtype); __Pyx_RefNannyFinishContext(); return __pyx_r; }
0956: PandasCol pandas_col, col_t* col) except -1:
+0957: cdef object dtype = pandas_col.dtype
__pyx_t_1 = __pyx_v_pandas_col->dtype;
__pyx_v_dtype = __pyx_t_1;
__pyx_t_1 = 0;
+0958: if isinstance(dtype, _NUMPY_BOOL):
__pyx_t_1 = __pyx_v_7questdb_7ingress__NUMPY_BOOL; __Pyx_INCREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 958, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0959: col.setup.source = col_source_t.col_source_bool_numpy
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_bool_numpy;
+0960: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 960, __pyx_L1_error)
+0961: elif isinstance(dtype, _PANDAS.BooleanDtype):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_BooleanDtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 961, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 961, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0962: col.setup.source = col_source_t.col_source_bool_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_bool_arrow;
+0963: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 963, __pyx_L1_error)
+0964: elif isinstance(dtype, _NUMPY_UINT8):
__pyx_t_1 = __pyx_v_7questdb_7ingress__NUMPY_UINT8; __Pyx_INCREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 964, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0965: col.setup.source = col_source_t.col_source_u8_numpy
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_u8_numpy;
+0966: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 966, __pyx_L1_error)
+0967: elif isinstance(dtype, _NUMPY_INT8):
__pyx_t_1 = __pyx_v_7questdb_7ingress__NUMPY_INT8; __Pyx_INCREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 967, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0968: col.setup.source = col_source_t.col_source_i8_numpy
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_i8_numpy;
+0969: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 969, __pyx_L1_error)
+0970: elif isinstance(dtype, _NUMPY_UINT16):
__pyx_t_1 = __pyx_v_7questdb_7ingress__NUMPY_UINT16; __Pyx_INCREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 970, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0971: col.setup.source = col_source_t.col_source_u16_numpy
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_u16_numpy;
+0972: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 972, __pyx_L1_error)
+0973: elif isinstance(dtype, _NUMPY_INT16):
__pyx_t_1 = __pyx_v_7questdb_7ingress__NUMPY_INT16; __Pyx_INCREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 973, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0974: col.setup.source = col_source_t.col_source_i16_numpy
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_i16_numpy;
+0975: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 975, __pyx_L1_error)
+0976: elif isinstance(dtype, _NUMPY_UINT32):
__pyx_t_1 = __pyx_v_7questdb_7ingress__NUMPY_UINT32; __Pyx_INCREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 976, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0977: col.setup.source = col_source_t.col_source_u32_numpy
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_u32_numpy;
+0978: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 978, __pyx_L1_error)
+0979: elif isinstance(dtype, _NUMPY_INT32):
__pyx_t_1 = __pyx_v_7questdb_7ingress__NUMPY_INT32; __Pyx_INCREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 979, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0980: col.setup.source = col_source_t.col_source_i32_numpy
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_i32_numpy;
+0981: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 981, __pyx_L1_error)
+0982: elif isinstance(dtype, _NUMPY_UINT64):
__pyx_t_1 = __pyx_v_7questdb_7ingress__NUMPY_UINT64; __Pyx_INCREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 982, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0983: col.setup.source = col_source_t.col_source_u64_numpy
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_u64_numpy;
+0984: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 984, __pyx_L1_error)
+0985: elif isinstance(dtype, _NUMPY_INT64):
__pyx_t_1 = __pyx_v_7questdb_7ingress__NUMPY_INT64; __Pyx_INCREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 985, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0986: col.setup.source = col_source_t.col_source_i64_numpy
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_i64_numpy;
+0987: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 987, __pyx_L1_error)
+0988: elif isinstance(dtype, _PANDAS.UInt8Dtype):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_UInt8Dtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 988, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 988, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0989: col.setup.source = col_source_t.col_source_u8_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_u8_arrow;
+0990: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 990, __pyx_L1_error)
+0991: elif isinstance(dtype, _PANDAS.Int8Dtype):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_Int8Dtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 991, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 991, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0992: col.setup.source = col_source_t.col_source_i8_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_i8_arrow;
+0993: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 993, __pyx_L1_error)
+0994: elif isinstance(dtype, _PANDAS.UInt16Dtype):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_UInt16Dtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 994, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 994, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0995: col.setup.source = col_source_t.col_source_u16_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_u16_arrow;
+0996: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 996, __pyx_L1_error)
+0997: elif isinstance(dtype, _PANDAS.Int16Dtype):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_Int16Dtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 997, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 997, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+0998: col.setup.source = col_source_t.col_source_i16_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_i16_arrow;
+0999: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 999, __pyx_L1_error)
+1000: elif isinstance(dtype, _PANDAS.UInt32Dtype):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_UInt32Dtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1000, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 1000, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+1001: col.setup.source = col_source_t.col_source_u32_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_u32_arrow;
+1002: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1002, __pyx_L1_error)
+1003: elif isinstance(dtype, _PANDAS.Int32Dtype):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_Int32Dtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1003, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 1003, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+1004: col.setup.source = col_source_t.col_source_i32_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_i32_arrow;
+1005: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1005, __pyx_L1_error)
+1006: elif isinstance(dtype, _PANDAS.UInt64Dtype):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_UInt64Dtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1006, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 1006, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+1007: col.setup.source = col_source_t.col_source_u64_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_u64_arrow;
+1008: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1008, __pyx_L1_error)
+1009: elif isinstance(dtype, _PANDAS.Int64Dtype):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_Int64Dtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1009, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 1009, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+1010: col.setup.source = col_source_t.col_source_i64_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_i64_arrow;
+1011: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1011, __pyx_L1_error)
+1012: elif isinstance(dtype, _NUMPY_FLOAT32):
__pyx_t_1 = __pyx_v_7questdb_7ingress__NUMPY_FLOAT32; __Pyx_INCREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 1012, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+1013: col.setup.source = col_source_t.col_source_f32_numpy
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_f32_numpy;
+1014: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1014, __pyx_L1_error)
+1015: elif isinstance(dtype, _NUMPY_FLOAT64):
__pyx_t_1 = __pyx_v_7questdb_7ingress__NUMPY_FLOAT64; __Pyx_INCREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 1015, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+1016: col.setup.source = col_source_t.col_source_f64_numpy
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_f64_numpy;
+1017: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1017, __pyx_L1_error)
+1018: elif isinstance(dtype, _PANDAS.Float32Dtype):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_Float32Dtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1018, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 1018, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+1019: col.setup.source = col_source_t.col_source_f32_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_f32_arrow;
+1020: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1020, __pyx_L1_error)
+1021: elif isinstance(dtype, _PANDAS.Float64Dtype):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_Float64Dtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1021, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 1021, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+1022: col.setup.source = col_source_t.col_source_f64_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_f64_arrow;
+1023: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1023, __pyx_L1_error)
+1024: elif isinstance(dtype, _PANDAS.StringDtype):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_StringDtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1024, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 1024, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+1025: if dtype.storage == 'pyarrow':
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_dtype, __pyx_n_s_storage); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1025, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = (__Pyx_PyUnicode_Equals(__pyx_t_1, __pyx_n_u_pyarrow, Py_EQ)); if (unlikely((__pyx_t_2 < 0))) __PYX_ERR(1, 1025, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L4; }
+1026: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1026, __pyx_L1_error)
+1027: if strncmp(col.setup.arrow_schema.format, _ARROW_FMT_UTF8_STRING, 1) == 0:
__pyx_t_2 = (strncmp(__pyx_v_col->setup->arrow_schema.format, __pyx_v_7questdb_7ingress__ARROW_FMT_UTF8_STRING, 1) == 0); if (__pyx_t_2) { /* … */ goto __pyx_L5; }
+1028: col.setup.source = col_source_t.col_source_str_utf8_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_str_utf8_arrow;
+1029: elif strncmp(col.setup.arrow_schema.format, _ARROW_FMT_LRG_UTF8_STRING, 1) == 0:
__pyx_t_2 = (strncmp(__pyx_v_col->setup->arrow_schema.format, __pyx_v_7questdb_7ingress__ARROW_FMT_LRG_UTF8_STRING, 1) == 0); if (likely(__pyx_t_2)) { /* … */ goto __pyx_L5; }
+1030: col.setup.source = col_source_t.col_source_str_lrg_utf8_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_str_lrg_utf8_arrow;
1031: else:
+1032: raise IngressError(
/*else*/ { __Pyx_GetModuleGlobalName(__pyx_t_4, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1032, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4);
+1033: IngressErrorCode.BadDataFrame,
__Pyx_GetModuleGlobalName(__pyx_t_5, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1033, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_6 = __Pyx_PyObject_GetAttrStr(__pyx_t_5, __pyx_n_s_BadDataFrame); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1033, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0;
+1034: f'Unknown string dtype storage: {dtype.storage} ' +
__pyx_t_5 = PyTuple_New(3); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1034, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_7 = 0; __pyx_t_8 = 127; __Pyx_INCREF(__pyx_kp_u_Unknown_string_dtype_storage); __pyx_t_7 += 30; __Pyx_GIVEREF(__pyx_kp_u_Unknown_string_dtype_storage); PyTuple_SET_ITEM(__pyx_t_5, 0, __pyx_kp_u_Unknown_string_dtype_storage); __pyx_t_9 = __Pyx_PyObject_GetAttrStr(__pyx_v_dtype, __pyx_n_s_storage); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 1034, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_10 = __Pyx_PyObject_FormatSimple(__pyx_t_9, __pyx_empty_unicode); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1034, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __pyx_t_8 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) > __pyx_t_8) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) : __pyx_t_8; __pyx_t_7 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_10); __Pyx_GIVEREF(__pyx_t_10); PyTuple_SET_ITEM(__pyx_t_5, 1, __pyx_t_10); __pyx_t_10 = 0; __Pyx_INCREF(__pyx_kp_u__22); __pyx_t_7 += 1; __Pyx_GIVEREF(__pyx_kp_u__22); PyTuple_SET_ITEM(__pyx_t_5, 2, __pyx_kp_u__22); __pyx_t_10 = __Pyx_PyUnicode_Join(__pyx_t_5, 3, __pyx_t_7, __pyx_t_8); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1034, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; /* … */ __pyx_t_5 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_10, __pyx_t_9); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1034, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0;
+1035: f'for column {pandas_col.name} of dtype {dtype}. ' +
__pyx_t_5 = PyTuple_New(5); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1035, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_7 = 0; __pyx_t_8 = 127; __Pyx_INCREF(__pyx_kp_u_for_column); __pyx_t_7 += 11; __Pyx_GIVEREF(__pyx_kp_u_for_column); PyTuple_SET_ITEM(__pyx_t_5, 0, __pyx_kp_u_for_column); __pyx_t_9 = __Pyx_PyUnicode_Unicode(__pyx_v_pandas_col->name); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 1035, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_8 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_9) > __pyx_t_8) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_9) : __pyx_t_8; __pyx_t_7 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_9); __Pyx_GIVEREF(__pyx_t_9); PyTuple_SET_ITEM(__pyx_t_5, 1, __pyx_t_9); __pyx_t_9 = 0; __Pyx_INCREF(__pyx_kp_u_of_dtype); __pyx_t_7 += 10; __Pyx_GIVEREF(__pyx_kp_u_of_dtype); PyTuple_SET_ITEM(__pyx_t_5, 2, __pyx_kp_u_of_dtype); __pyx_t_9 = __Pyx_PyObject_FormatSimple(__pyx_v_dtype, __pyx_empty_unicode); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 1035, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_8 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_9) > __pyx_t_8) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_9) : __pyx_t_8; __pyx_t_7 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_9); __Pyx_GIVEREF(__pyx_t_9); PyTuple_SET_ITEM(__pyx_t_5, 3, __pyx_t_9); __pyx_t_9 = 0; __Pyx_INCREF(__pyx_kp_u__18); __pyx_t_7 += 2; __Pyx_GIVEREF(__pyx_kp_u__18); PyTuple_SET_ITEM(__pyx_t_5, 4, __pyx_kp_u__18); __pyx_t_9 = __Pyx_PyUnicode_Join(__pyx_t_5, 5, __pyx_t_7, __pyx_t_8); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 1035, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; /* … */ __pyx_t_9 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_5, __pyx_kp_u_Format_specifier); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 1035, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0;
+1036: f'Format specifier: ' + repr(bytes(col.setup.arrow_schema.format).decode('latin-1')))
__pyx_t_5 = __Pyx_PyBytes_FromString(__pyx_v_col->setup->arrow_schema.format); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1036, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_10 = __Pyx_PyObject_CallOneArg(((PyObject *)(&PyBytes_Type)), __pyx_t_5); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1036, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __pyx_t_5 = __Pyx_decode_bytes(__pyx_t_10, 0, PY_SSIZE_T_MAX, NULL, NULL, PyUnicode_DecodeLatin1); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1036, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; __pyx_t_10 = PyObject_Repr(__pyx_t_5); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1036, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __pyx_t_5 = PyNumber_Add(__pyx_t_9, __pyx_t_10); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1036, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; __pyx_t_10 = NULL; __pyx_t_11 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_4))) { __pyx_t_10 = PyMethod_GET_SELF(__pyx_t_4); if (likely(__pyx_t_10)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_4); __Pyx_INCREF(__pyx_t_10); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_4, function); __pyx_t_11 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_10, __pyx_t_6, __pyx_t_5}; __pyx_t_1 = __Pyx_PyObject_FastCall(__pyx_t_4, __pyx_callargs+1-__pyx_t_11, 2+__pyx_t_11); __Pyx_XDECREF(__pyx_t_10); __pyx_t_10 = 0; __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1032, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; } __Pyx_Raise(__pyx_t_1, 0, 0, 0); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 1032, __pyx_L1_error) } __pyx_L5:;
+1037: elif dtype.storage == 'python':
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_dtype, __pyx_n_s_storage); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1037, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = (__Pyx_PyUnicode_Equals(__pyx_t_1, __pyx_n_u_python, Py_EQ)); if (unlikely((__pyx_t_2 < 0))) __PYX_ERR(1, 1037, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (likely(__pyx_t_2)) { /* … */ goto __pyx_L4; }
+1038: col.setup.source = col_source_t.col_source_str_pyobj
+1039: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1039, __pyx_L1_error)
1040: else:
+1041: raise IngressError(
/*else*/ { __Pyx_GetModuleGlobalName(__pyx_t_4, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1041, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4);
+1042: IngressErrorCode.BadDataFrame,
__Pyx_GetModuleGlobalName(__pyx_t_5, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1042, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_6 = __Pyx_PyObject_GetAttrStr(__pyx_t_5, __pyx_n_s_BadDataFrame); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1042, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0;
+1043: f'Unknown string dtype storage: f{dtype.storage} ' +
__pyx_t_5 = PyTuple_New(3); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1043, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_7 = 0; __pyx_t_8 = 127; __Pyx_INCREF(__pyx_kp_u_Unknown_string_dtype_storage_f); __pyx_t_7 += 31; __Pyx_GIVEREF(__pyx_kp_u_Unknown_string_dtype_storage_f); PyTuple_SET_ITEM(__pyx_t_5, 0, __pyx_kp_u_Unknown_string_dtype_storage_f); __pyx_t_10 = __Pyx_PyObject_GetAttrStr(__pyx_v_dtype, __pyx_n_s_storage); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1043, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_9 = __Pyx_PyObject_FormatSimple(__pyx_t_10, __pyx_empty_unicode); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 1043, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; __pyx_t_8 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_9) > __pyx_t_8) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_9) : __pyx_t_8; __pyx_t_7 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_9); __Pyx_GIVEREF(__pyx_t_9); PyTuple_SET_ITEM(__pyx_t_5, 1, __pyx_t_9); __pyx_t_9 = 0; __Pyx_INCREF(__pyx_kp_u__22); __pyx_t_7 += 1; __Pyx_GIVEREF(__pyx_kp_u__22); PyTuple_SET_ITEM(__pyx_t_5, 2, __pyx_kp_u__22); __pyx_t_9 = __Pyx_PyUnicode_Join(__pyx_t_5, 3, __pyx_t_7, __pyx_t_8); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 1043, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; /* … */ __pyx_t_5 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_9, __pyx_t_10); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1043, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; __pyx_t_10 = NULL; __pyx_t_11 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_4))) { __pyx_t_10 = PyMethod_GET_SELF(__pyx_t_4); if (likely(__pyx_t_10)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_4); __Pyx_INCREF(__pyx_t_10); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_4, function); __pyx_t_11 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_10, __pyx_t_6, __pyx_t_5}; __pyx_t_1 = __Pyx_PyObject_FastCall(__pyx_t_4, __pyx_callargs+1-__pyx_t_11, 2+__pyx_t_11); __Pyx_XDECREF(__pyx_t_10); __pyx_t_10 = 0; __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1041, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; } __Pyx_Raise(__pyx_t_1, 0, 0, 0); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 1041, __pyx_L1_error) } __pyx_L4:;
+1044: f'for column {pandas_col.name} of dtype {dtype}.')
__pyx_t_5 = PyTuple_New(5); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1044, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_7 = 0; __pyx_t_8 = 127; __Pyx_INCREF(__pyx_kp_u_for_column); __pyx_t_7 += 11; __Pyx_GIVEREF(__pyx_kp_u_for_column); PyTuple_SET_ITEM(__pyx_t_5, 0, __pyx_kp_u_for_column); __pyx_t_10 = __Pyx_PyUnicode_Unicode(__pyx_v_pandas_col->name); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1044, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_8 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) > __pyx_t_8) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) : __pyx_t_8; __pyx_t_7 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_10); __Pyx_GIVEREF(__pyx_t_10); PyTuple_SET_ITEM(__pyx_t_5, 1, __pyx_t_10); __pyx_t_10 = 0; __Pyx_INCREF(__pyx_kp_u_of_dtype); __pyx_t_7 += 10; __Pyx_GIVEREF(__pyx_kp_u_of_dtype); PyTuple_SET_ITEM(__pyx_t_5, 2, __pyx_kp_u_of_dtype); __pyx_t_10 = __Pyx_PyObject_FormatSimple(__pyx_v_dtype, __pyx_empty_unicode); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1044, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_8 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) > __pyx_t_8) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) : __pyx_t_8; __pyx_t_7 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_10); __Pyx_GIVEREF(__pyx_t_10); PyTuple_SET_ITEM(__pyx_t_5, 3, __pyx_t_10); __pyx_t_10 = 0; __Pyx_INCREF(__pyx_kp_u__5); __pyx_t_7 += 1; __Pyx_GIVEREF(__pyx_kp_u__5); PyTuple_SET_ITEM(__pyx_t_5, 4, __pyx_kp_u__5); __pyx_t_10 = __Pyx_PyUnicode_Join(__pyx_t_5, 5, __pyx_t_7, __pyx_t_8); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1044, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0;
+1045: elif isinstance(dtype, _PANDAS.CategoricalDtype):
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_CategoricalDtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1045, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 1045, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+1046: _dataframe_category_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_category_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1046, __pyx_L1_error)
+1047: elif (isinstance(dtype, _NUMPY_DATETIME64_NS) and
__pyx_t_1 = __pyx_v_7questdb_7ingress__NUMPY_DATETIME64_NS; __Pyx_INCREF(__pyx_t_1); __pyx_t_12 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_12 == ((int)-1))) __PYX_ERR(1, 1047, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_12) { } else { __pyx_t_2 = __pyx_t_12; goto __pyx_L6_bool_binop_done; } /* … */ if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+1048: _dataframe_is_supported_datetime(dtype)):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_is_supported_datetime(__pyx_v_dtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1048, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_12 = __Pyx_PyObject_IsTrue(__pyx_t_1); if (unlikely((__pyx_t_12 < 0))) __PYX_ERR(1, 1048, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __pyx_t_2 = __pyx_t_12; __pyx_L6_bool_binop_done:;
+1049: col.setup.source = col_source_t.col_source_dt64ns_numpy
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_dt64ns_numpy;
+1050: _dataframe_series_as_pybuf(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_pybuf(__pyx_v_pandas_col, __pyx_v_col, NULL); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1050, __pyx_L1_error)
+1051: elif (isinstance(dtype, _PANDAS.DatetimeTZDtype) and
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_7questdb_7ingress__PANDAS, __pyx_n_s_DatetimeTZDtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1051, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_12 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_12 == ((int)-1))) __PYX_ERR(1, 1051, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_12) { } else { __pyx_t_2 = __pyx_t_12; goto __pyx_L8_bool_binop_done; } /* … */ if (__pyx_t_2) { /* … */ goto __pyx_L3; }
+1052: _dataframe_is_supported_datetime(dtype)):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_is_supported_datetime(__pyx_v_dtype); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1052, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_12 = __Pyx_PyObject_IsTrue(__pyx_t_1); if (unlikely((__pyx_t_12 < 0))) __PYX_ERR(1, 1052, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __pyx_t_2 = __pyx_t_12; __pyx_L8_bool_binop_done:;
+1053: col.setup.source = col_source_t.col_source_dt64ns_tz_arrow
__pyx_v_col->setup->source = __pyx_e_7questdb_7ingress_col_source_dt64ns_tz_arrow;
+1054: _dataframe_series_as_arrow(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_as_arrow(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1054, __pyx_L1_error)
+1055: elif isinstance(dtype, _NUMPY_OBJECT):
__pyx_t_1 = __pyx_v_7questdb_7ingress__NUMPY_OBJECT; __Pyx_INCREF(__pyx_t_1); __pyx_t_2 = PyObject_IsInstance(__pyx_v_dtype, __pyx_t_1); if (unlikely(__pyx_t_2 == ((int)-1))) __PYX_ERR(1, 1055, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (likely(__pyx_t_2)) { /* … */ goto __pyx_L3; }
+1056: _dataframe_series_sniff_pyobj(pandas_col, col)
__pyx_t_3 = __pyx_f_7questdb_7ingress__dataframe_series_sniff_pyobj(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_3 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1056, __pyx_L1_error)
1057: else:
+1058: raise IngressError(
/*else*/ { __Pyx_GetModuleGlobalName(__pyx_t_4, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1058, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4);
+1059: IngressErrorCode.BadDataFrame,
__Pyx_GetModuleGlobalName(__pyx_t_5, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1059, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_6 = __Pyx_PyObject_GetAttrStr(__pyx_t_5, __pyx_n_s_BadDataFrame); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1059, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0;
+1060: f'Unsupported dtype {dtype} for column {pandas_col.name!r}. ' +
__pyx_t_5 = PyTuple_New(5); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1060, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_7 = 0; __pyx_t_8 = 127; __Pyx_INCREF(__pyx_kp_u_Unsupported_dtype); __pyx_t_7 += 18; __Pyx_GIVEREF(__pyx_kp_u_Unsupported_dtype); PyTuple_SET_ITEM(__pyx_t_5, 0, __pyx_kp_u_Unsupported_dtype); __pyx_t_10 = __Pyx_PyObject_FormatSimple(__pyx_v_dtype, __pyx_empty_unicode); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1060, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_8 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) > __pyx_t_8) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) : __pyx_t_8; __pyx_t_7 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_10); __Pyx_GIVEREF(__pyx_t_10); PyTuple_SET_ITEM(__pyx_t_5, 1, __pyx_t_10); __pyx_t_10 = 0; __Pyx_INCREF(__pyx_kp_u_for_column_2); __pyx_t_7 += 12; __Pyx_GIVEREF(__pyx_kp_u_for_column_2); PyTuple_SET_ITEM(__pyx_t_5, 2, __pyx_kp_u_for_column_2); __pyx_t_10 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_pandas_col->name), __pyx_empty_unicode); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1060, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_8 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) > __pyx_t_8) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) : __pyx_t_8; __pyx_t_7 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_10); __Pyx_GIVEREF(__pyx_t_10); PyTuple_SET_ITEM(__pyx_t_5, 3, __pyx_t_10); __pyx_t_10 = 0; __Pyx_INCREF(__pyx_kp_u__18); __pyx_t_7 += 2; __Pyx_GIVEREF(__pyx_kp_u__18); PyTuple_SET_ITEM(__pyx_t_5, 4, __pyx_kp_u__18); __pyx_t_10 = __Pyx_PyUnicode_Join(__pyx_t_5, 5, __pyx_t_7, __pyx_t_8); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1060, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __pyx_t_5 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_10, __pyx_kp_u_Raise_an_issue_if_you_think_it_s); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1060, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0;
+1061: 'Raise an issue if you think it should be supported: ' +
__pyx_t_10 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_5, __pyx_kp_u_https_github_com_questdb_py_ques); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1061, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __pyx_t_5 = NULL; __pyx_t_11 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_4))) { __pyx_t_5 = PyMethod_GET_SELF(__pyx_t_4); if (likely(__pyx_t_5)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_4); __Pyx_INCREF(__pyx_t_5); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_4, function); __pyx_t_11 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_5, __pyx_t_6, __pyx_t_10}; __pyx_t_1 = __Pyx_PyObject_FastCall(__pyx_t_4, __pyx_callargs+1-__pyx_t_11, 2+__pyx_t_11); __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1058, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; } __Pyx_Raise(__pyx_t_1, 0, 0, 0); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 1058, __pyx_L1_error) } __pyx_L3:;
1062: 'https://github.com/questdb/py-questdb-client/issues.')
1063:
1064:
+1065: cdef void_int _dataframe_resolve_target(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_resolve_target(struct __pyx_obj_7questdb_7ingress_PandasCol *__pyx_v_pandas_col, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { enum __pyx_t_7questdb_7ingress_col_target_t __pyx_v_target; PyObject *__pyx_v_target_sources = 0; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_1); __Pyx_XDECREF(__pyx_t_4); __Pyx_XDECREF(__pyx_t_6); __Pyx_XDECREF(__pyx_t_7); __Pyx_XDECREF(__pyx_t_9); __Pyx_XDECREF(__pyx_t_10); __Pyx_AddTraceback("questdb.ingress._dataframe_resolve_target", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_XDECREF(__pyx_v_target_sources); __Pyx_RefNannyFinishContext(); return __pyx_r; }
1066: PandasCol pandas_col, col_t* col) except -1:
1067: cdef col_target_t target
1068: cdef set target_sources
+1069: if col.setup.meta_target in _DIRECT_META_TARGETS:
__pyx_t_1 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_meta_target_t(__pyx_v_col->setup->meta_target); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1069, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); if (unlikely(__pyx_v_7questdb_7ingress__DIRECT_META_TARGETS == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not iterable"); __PYX_ERR(1, 1069, __pyx_L1_error) } __pyx_t_2 = (__Pyx_PySet_ContainsTF(__pyx_t_1, __pyx_v_7questdb_7ingress__DIRECT_META_TARGETS, Py_EQ)); if (unlikely((__pyx_t_2 < 0))) __PYX_ERR(1, 1069, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; if (__pyx_t_2) { /* … */ }
+1070: col.setup.target = <col_target_t><int>col.setup.meta_target
__pyx_v_col->setup->target = ((enum __pyx_t_7questdb_7ingress_col_target_t)((int)__pyx_v_col->setup->meta_target));
+1071: return 0
+1072: for target in _FIELD_TARGETS:
if (unlikely(__pyx_v_7questdb_7ingress__FIELD_TARGETS == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not iterable"); __PYX_ERR(1, 1072, __pyx_L1_error) } __pyx_t_1 = __pyx_v_7questdb_7ingress__FIELD_TARGETS; __Pyx_INCREF(__pyx_t_1); __pyx_t_3 = 0; for (;;) { { Py_ssize_t __pyx_temp = __Pyx_PyTuple_GET_SIZE(__pyx_t_1); #if !CYTHON_ASSUME_SAFE_MACROS if (unlikely((__pyx_temp < 0))) __PYX_ERR(1, 1072, __pyx_L1_error) #endif if (__pyx_t_3 >= __pyx_temp) break; } #if CYTHON_ASSUME_SAFE_MACROS && !CYTHON_AVOID_BORROWED_REFS __pyx_t_4 = PyTuple_GET_ITEM(__pyx_t_1, __pyx_t_3); __Pyx_INCREF(__pyx_t_4); __pyx_t_3++; if (unlikely((0 < 0))) __PYX_ERR(1, 1072, __pyx_L1_error) #else __pyx_t_4 = __Pyx_PySequence_ITEM(__pyx_t_1, __pyx_t_3); __pyx_t_3++; if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1072, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); #endif __pyx_t_5 = ((enum __pyx_t_7questdb_7ingress_col_target_t)__Pyx_PyInt_As_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_t_4)); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1072, __pyx_L1_error) __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __pyx_v_target = __pyx_t_5; /* … */ } __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0;
+1073: target_sources = _TARGET_TO_SOURCES[target]
if (unlikely(__pyx_v_7questdb_7ingress__TARGET_TO_SOURCES == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not subscriptable"); __PYX_ERR(1, 1073, __pyx_L1_error) } __pyx_t_4 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_v_target); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1073, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __pyx_t_6 = __Pyx_PyDict_GetItem(__pyx_v_7questdb_7ingress__TARGET_TO_SOURCES, __pyx_t_4); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1073, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; if (!(likely(PySet_CheckExact(__pyx_t_6))||((__pyx_t_6) == Py_None) || __Pyx_RaiseUnexpectedTypeError("set", __pyx_t_6))) __PYX_ERR(1, 1073, __pyx_L1_error) __Pyx_XDECREF_SET(__pyx_v_target_sources, ((PyObject*)__pyx_t_6)); __pyx_t_6 = 0;
+1074: if col.setup.source in target_sources:
__pyx_t_6 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_v_col->setup->source); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1074, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); if (unlikely(__pyx_v_target_sources == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not iterable"); __PYX_ERR(1, 1074, __pyx_L1_error) } __pyx_t_2 = (__Pyx_PySet_ContainsTF(__pyx_t_6, __pyx_v_target_sources, Py_EQ)); if (unlikely((__pyx_t_2 < 0))) __PYX_ERR(1, 1074, __pyx_L1_error) __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; if (__pyx_t_2) { /* … */ }
+1075: col.setup.target = target
__pyx_v_col->setup->target = __pyx_v_target;
+1076: return 0
__pyx_r = 0;
goto __pyx_L0;
+1077: raise IngressError(
__Pyx_GetModuleGlobalName(__pyx_t_6, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1077, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6);
+1078: IngressErrorCode.BadDataFrame,
__Pyx_GetModuleGlobalName(__pyx_t_4, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1078, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_t_4, __pyx_n_s_BadDataFrame); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 1078, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0;
+1079: f'Could not map column source type (code {col.setup.source} for ' +
__pyx_t_4 = PyTuple_New(3); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1079, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __pyx_t_3 = 0; __pyx_t_8 = 127; __Pyx_INCREF(__pyx_kp_u_Could_not_map_column_source_type); __pyx_t_3 += 39; __Pyx_GIVEREF(__pyx_kp_u_Could_not_map_column_source_type); PyTuple_SET_ITEM(__pyx_t_4, 0, __pyx_kp_u_Could_not_map_column_source_type); __pyx_t_9 = __Pyx_PyUnicode_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_v_col->setup->source, 0, ' ', 'd'); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 1079, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_8 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_9) > __pyx_t_8) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_9) : __pyx_t_8; __pyx_t_3 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_9); __Pyx_GIVEREF(__pyx_t_9); PyTuple_SET_ITEM(__pyx_t_4, 1, __pyx_t_9); __pyx_t_9 = 0; __Pyx_INCREF(__pyx_kp_u_for); __pyx_t_3 += 5; __Pyx_GIVEREF(__pyx_kp_u_for); PyTuple_SET_ITEM(__pyx_t_4, 2, __pyx_kp_u_for); __pyx_t_9 = __Pyx_PyUnicode_Join(__pyx_t_4, 3, __pyx_t_3, __pyx_t_8); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 1079, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; /* … */ __pyx_t_4 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_9, __pyx_t_10); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1079, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0;
+1080: f'column {pandas_col.name!r} ' +
__pyx_t_4 = PyTuple_New(3); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1080, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __pyx_t_3 = 0; __pyx_t_8 = 127; __Pyx_INCREF(__pyx_kp_u_column_2); __pyx_t_3 += 7; __Pyx_GIVEREF(__pyx_kp_u_column_2); PyTuple_SET_ITEM(__pyx_t_4, 0, __pyx_kp_u_column_2); __pyx_t_10 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_pandas_col->name), __pyx_empty_unicode); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1080, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_8 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) > __pyx_t_8) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_10) : __pyx_t_8; __pyx_t_3 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_10); __Pyx_GIVEREF(__pyx_t_10); PyTuple_SET_ITEM(__pyx_t_4, 1, __pyx_t_10); __pyx_t_10 = 0; __Pyx_INCREF(__pyx_kp_u__22); __pyx_t_3 += 1; __Pyx_GIVEREF(__pyx_kp_u__22); PyTuple_SET_ITEM(__pyx_t_4, 2, __pyx_kp_u__22); __pyx_t_10 = __Pyx_PyUnicode_Join(__pyx_t_4, 3, __pyx_t_3, __pyx_t_8); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1080, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; /* … */ __pyx_t_10 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_4, __pyx_t_9); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1080, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __Pyx_DECREF(__pyx_t_9); __pyx_t_9 = 0; __pyx_t_9 = NULL; __pyx_t_11 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_6))) { __pyx_t_9 = PyMethod_GET_SELF(__pyx_t_6); if (likely(__pyx_t_9)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_6); __Pyx_INCREF(__pyx_t_9); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_6, function); __pyx_t_11 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_9, __pyx_t_7, __pyx_t_10}; __pyx_t_1 = __Pyx_PyObject_FastCall(__pyx_t_6, __pyx_callargs+1-__pyx_t_11, 2+__pyx_t_11); __Pyx_XDECREF(__pyx_t_9); __pyx_t_9 = 0; __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0; if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1077, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; } __Pyx_Raise(__pyx_t_1, 0, 0, 0); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 1077, __pyx_L1_error)
+1081: f' ({pandas_col.dtype}) to any ILP type.')
__pyx_t_10 = PyTuple_New(3); if (unlikely(!__pyx_t_10)) __PYX_ERR(1, 1081, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_10); __pyx_t_3 = 0; __pyx_t_8 = 127; __Pyx_INCREF(__pyx_kp_u__20); __pyx_t_3 += 2; __Pyx_GIVEREF(__pyx_kp_u__20); PyTuple_SET_ITEM(__pyx_t_10, 0, __pyx_kp_u__20); __pyx_t_9 = __Pyx_PyObject_FormatSimple(__pyx_v_pandas_col->dtype, __pyx_empty_unicode); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 1081, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __pyx_t_8 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_9) > __pyx_t_8) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_9) : __pyx_t_8; __pyx_t_3 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_9); __Pyx_GIVEREF(__pyx_t_9); PyTuple_SET_ITEM(__pyx_t_10, 1, __pyx_t_9); __pyx_t_9 = 0; __Pyx_INCREF(__pyx_kp_u_to_any_ILP_type); __pyx_t_3 += 18; __Pyx_GIVEREF(__pyx_kp_u_to_any_ILP_type); PyTuple_SET_ITEM(__pyx_t_10, 2, __pyx_kp_u_to_any_ILP_type); __pyx_t_9 = __Pyx_PyUnicode_Join(__pyx_t_10, 3, __pyx_t_3, __pyx_t_8); if (unlikely(!__pyx_t_9)) __PYX_ERR(1, 1081, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_9); __Pyx_DECREF(__pyx_t_10); __pyx_t_10 = 0;
1082:
1083:
+1084: cdef void _dataframe_init_cursor(col_t* col) noexcept nogil:
static void __pyx_f_7questdb_7ingress__dataframe_init_cursor(struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { /* … */ /* function exit code */ }
+1085: col.cursor.chunk = col.setup.chunks.chunks
__pyx_t_1 = __pyx_v_col->setup->chunks.chunks; __pyx_v_col->cursor.chunk = __pyx_t_1;
+1086: col.cursor.chunk_index = 0
__pyx_v_col->cursor.chunk_index = 0;
+1087: col.cursor.offset = col.cursor.chunk.offset
__pyx_t_2 = __pyx_v_col->cursor.chunk->offset; __pyx_v_col->cursor.offset = __pyx_t_2;
1088:
1089:
+1090: cdef void_int _dataframe_resolve_cols(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_resolve_cols(CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, PyObject *__pyx_v_pandas_cols, struct __pyx_t_7questdb_7ingress_col_t_arr *__pyx_v_cols, int *__pyx_v_any_cols_need_gil_out) { size_t __pyx_v_index; size_t __pyx_v_len_dataframe_cols; struct __pyx_obj_7questdb_7ingress_PandasCol *__pyx_v_pandas_col = 0; struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_5); __Pyx_AddTraceback("questdb.ingress._dataframe_resolve_cols", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_XDECREF((PyObject *)__pyx_v_pandas_col); __Pyx_RefNannyFinishContext(); return __pyx_r; }
1091: qdb_pystr_buf* b,
1092: list pandas_cols,
1093: col_t_arr* cols,
1094: bint* any_cols_need_gil_out) except -1:
1095: cdef size_t index
+1096: cdef size_t len_dataframe_cols = len(pandas_cols)
if (unlikely(__pyx_v_pandas_cols == Py_None)) { PyErr_SetString(PyExc_TypeError, "object of type 'NoneType' has no len()"); __PYX_ERR(1, 1096, __pyx_L1_error) } __pyx_t_1 = __Pyx_PyList_GET_SIZE(__pyx_v_pandas_cols); if (unlikely(__pyx_t_1 == ((Py_ssize_t)-1))) __PYX_ERR(1, 1096, __pyx_L1_error) __pyx_v_len_dataframe_cols = __pyx_t_1;
1097: cdef PandasCol pandas_col
1098: cdef col_t* col
+1099: any_cols_need_gil_out[0] = False
(__pyx_v_any_cols_need_gil_out[0]) = 0;
+1100: for index in range(len_dataframe_cols):
__pyx_t_2 = __pyx_v_len_dataframe_cols; __pyx_t_3 = __pyx_t_2; for (__pyx_t_4 = 0; __pyx_t_4 < __pyx_t_3; __pyx_t_4+=1) { __pyx_v_index = __pyx_t_4;
+1101: pandas_col = pandas_cols[index]
if (unlikely(__pyx_v_pandas_cols == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not subscriptable"); __PYX_ERR(1, 1101, __pyx_L1_error) } __pyx_t_5 = __Pyx_GetItemInt_List(__pyx_v_pandas_cols, __pyx_v_index, size_t, 0, __Pyx_PyInt_FromSize_t, 1, 0, 1); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1101, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); if (!(likely(((__pyx_t_5) == Py_None) || likely(__Pyx_TypeTest(__pyx_t_5, __pyx_ptype_7questdb_7ingress_PandasCol))))) __PYX_ERR(1, 1101, __pyx_L1_error) __Pyx_XDECREF_SET(__pyx_v_pandas_col, ((struct __pyx_obj_7questdb_7ingress_PandasCol *)__pyx_t_5)); __pyx_t_5 = 0;
+1102: col = &cols.d[index]
__pyx_v_col = (&(__pyx_v_cols->d[__pyx_v_index]));
1103:
1104: # The target is resolved in stages:
1105: # * We first assign all column `.meta_target`s to be fields.
1106: # * Then, depending on argument parsing some/none of the columns
1107: # obtain a meta-target of "table", "symbol" or "at".
1108: # * Finally, based on the source, any remaining "meta_target_field"
1109: # columns are converted to the appropriate target.
1110: # See: _dataframe_resolve_col_targets_and_dc(..).
+1111: col.setup.meta_target = meta_target_t.meta_target_field
__pyx_v_col->setup->meta_target = __pyx_e_7questdb_7ingress_meta_target_field;
1112:
1113: # We will sort columns later. The index will be used to achieve a stable
1114: # sort among columns with the same `.meta_target`.
+1115: col.setup.orig_index = index
__pyx_v_col->setup->orig_index = __pyx_v_index;
1116:
+1117: _dataframe_resolve_source_and_buffers(pandas_col, col)
__pyx_t_6 = __pyx_f_7questdb_7ingress__dataframe_resolve_source_and_buffers(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_6 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1117, __pyx_L1_error)
+1118: _dataframe_init_cursor(col)
__pyx_f_7questdb_7ingress__dataframe_init_cursor(__pyx_v_col);
+1119: if col_source_needs_gil(col.setup.source):
__pyx_t_7 = __pyx_f_7questdb_7ingress_col_source_needs_gil(__pyx_v_col->setup->source); if (__pyx_t_7) { /* … */ } }
+1120: any_cols_need_gil_out[0] = True
(__pyx_v_any_cols_need_gil_out[0]) = 1;
1121:
1122:
+1123: cdef void_int _dataframe_resolve_cols_target_name_and_dc(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_resolve_cols_target_name_and_dc(struct qdb_pystr_buf *__pyx_v_b, PyObject *__pyx_v_pandas_cols, struct __pyx_t_7questdb_7ingress_col_t_arr *__pyx_v_cols) { size_t __pyx_v_index; struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col; struct __pyx_obj_7questdb_7ingress_PandasCol *__pyx_v_pandas_col = 0; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_4); __Pyx_XDECREF(__pyx_t_6); __Pyx_XDECREF(__pyx_t_7); __Pyx_XDECREF(__pyx_t_11); __Pyx_AddTraceback("questdb.ingress._dataframe_resolve_cols_target_name_and_dc", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_XDECREF((PyObject *)__pyx_v_pandas_col); __Pyx_RefNannyFinishContext(); return __pyx_r; }
1124: qdb_pystr_buf* b,
1125: list pandas_cols,
1126: col_t_arr* cols) except -1:
1127: cdef size_t index
1128: cdef col_t* col
1129: cdef PandasCol pandas_col
+1130: for index in range(cols.size):
__pyx_t_1 = __pyx_v_cols->size; __pyx_t_2 = __pyx_t_1; for (__pyx_t_3 = 0; __pyx_t_3 < __pyx_t_2; __pyx_t_3+=1) { __pyx_v_index = __pyx_t_3;
+1131: col = &cols.d[index]
+1132: pandas_col = pandas_cols[index]
if (unlikely(__pyx_v_pandas_cols == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not subscriptable"); __PYX_ERR(1, 1132, __pyx_L1_error) } __pyx_t_4 = __Pyx_GetItemInt_List(__pyx_v_pandas_cols, __pyx_v_index, size_t, 0, __Pyx_PyInt_FromSize_t, 1, 0, 1); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1132, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); if (!(likely(((__pyx_t_4) == Py_None) || likely(__Pyx_TypeTest(__pyx_t_4, __pyx_ptype_7questdb_7ingress_PandasCol))))) __PYX_ERR(1, 1132, __pyx_L1_error) __Pyx_XDECREF_SET(__pyx_v_pandas_col, ((struct __pyx_obj_7questdb_7ingress_PandasCol *)__pyx_t_4)); __pyx_t_4 = 0;
+1133: _dataframe_resolve_target(pandas_col, col)
__pyx_t_5 = __pyx_f_7questdb_7ingress__dataframe_resolve_target(__pyx_v_pandas_col, __pyx_v_col); if (unlikely(__pyx_t_5 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1133, __pyx_L1_error)
+1134: if col.setup.source not in _TARGET_TO_SOURCES[col.setup.target]:
__pyx_t_4 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_source_t(__pyx_v_col->setup->source); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1134, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); if (unlikely(__pyx_v_7questdb_7ingress__TARGET_TO_SOURCES == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not subscriptable"); __PYX_ERR(1, 1134, __pyx_L1_error) } __pyx_t_6 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_v_col->setup->target); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1134, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_7 = __Pyx_PyDict_GetItem(__pyx_v_7questdb_7ingress__TARGET_TO_SOURCES, __pyx_t_6); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 1134, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __pyx_t_8 = (__Pyx_PySequence_ContainsTF(__pyx_t_4, __pyx_t_7, Py_NE)); if (unlikely((__pyx_t_8 < 0))) __PYX_ERR(1, 1134, __pyx_L1_error) __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; if (unlikely(__pyx_t_8)) { /* … */ }
+1135: raise ValueError(
__pyx_t_4 = __Pyx_PyObject_CallOneArg(__pyx_builtin_ValueError, __pyx_t_6); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1135, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __Pyx_Raise(__pyx_t_4, 0, 0, 0); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __PYX_ERR(1, 1135, __pyx_L1_error)
+1136: f'Bad value: Column {pandas_col.name!r} ' +
__pyx_t_7 = PyTuple_New(3); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 1136, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_9 = 0; __pyx_t_10 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_value_Column); __pyx_t_9 += 18; __Pyx_GIVEREF(__pyx_kp_u_Bad_value_Column); PyTuple_SET_ITEM(__pyx_t_7, 0, __pyx_kp_u_Bad_value_Column); __pyx_t_4 = __Pyx_PyObject_FormatSimpleAndDecref(PyObject_Repr(__pyx_v_pandas_col->name), __pyx_empty_unicode); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1136, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __pyx_t_10 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_4) > __pyx_t_10) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_4) : __pyx_t_10; __pyx_t_9 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_4); __Pyx_GIVEREF(__pyx_t_4); PyTuple_SET_ITEM(__pyx_t_7, 1, __pyx_t_4); __pyx_t_4 = 0; __Pyx_INCREF(__pyx_kp_u__22); __pyx_t_9 += 1; __Pyx_GIVEREF(__pyx_kp_u__22); PyTuple_SET_ITEM(__pyx_t_7, 2, __pyx_kp_u__22); __pyx_t_4 = __Pyx_PyUnicode_Join(__pyx_t_7, 3, __pyx_t_9, __pyx_t_10); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1136, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; /* … */ __pyx_t_7 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_4, __pyx_t_6); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 1136, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0;
+1137: f'({pandas_col.dtype}) is not ' +
__pyx_t_7 = PyTuple_New(3); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 1137, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __pyx_t_9 = 0; __pyx_t_10 = 127; __Pyx_INCREF(__pyx_kp_u__16); __pyx_t_9 += 1; __Pyx_GIVEREF(__pyx_kp_u__16); PyTuple_SET_ITEM(__pyx_t_7, 0, __pyx_kp_u__16); __pyx_t_6 = __Pyx_PyObject_FormatSimple(__pyx_v_pandas_col->dtype, __pyx_empty_unicode); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1137, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_10 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_6) > __pyx_t_10) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_6) : __pyx_t_10; __pyx_t_9 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_6); __Pyx_GIVEREF(__pyx_t_6); PyTuple_SET_ITEM(__pyx_t_7, 1, __pyx_t_6); __pyx_t_6 = 0; __Pyx_INCREF(__pyx_kp_u_is_not); __pyx_t_9 += 9; __Pyx_GIVEREF(__pyx_kp_u_is_not); PyTuple_SET_ITEM(__pyx_t_7, 2, __pyx_kp_u_is_not); __pyx_t_6 = __Pyx_PyUnicode_Join(__pyx_t_7, 3, __pyx_t_9, __pyx_t_10); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1137, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; /* … */ __pyx_t_6 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_7, __pyx_t_4); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1137, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0;
+1138: f'supported as a {_TARGET_NAMES[col.setup.target]} column.')
__pyx_t_6 = PyTuple_New(3); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1138, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_9 = 0; __pyx_t_10 = 127; __Pyx_INCREF(__pyx_kp_u_supported_as_a); __pyx_t_9 += 15; __Pyx_GIVEREF(__pyx_kp_u_supported_as_a); PyTuple_SET_ITEM(__pyx_t_6, 0, __pyx_kp_u_supported_as_a); if (unlikely(__pyx_v_7questdb_7ingress__TARGET_NAMES == Py_None)) { PyErr_SetString(PyExc_TypeError, "'NoneType' object is not subscriptable"); __PYX_ERR(1, 1138, __pyx_L1_error) } __pyx_t_4 = __Pyx_PyInt_From_enum____pyx_t_7questdb_7ingress_col_target_t(__pyx_v_col->setup->target); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1138, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __pyx_t_11 = __Pyx_PyDict_GetItem(__pyx_v_7questdb_7ingress__TARGET_NAMES, __pyx_t_4); if (unlikely(!__pyx_t_11)) __PYX_ERR(1, 1138, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_11); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __pyx_t_4 = __Pyx_PyObject_FormatSimple(__pyx_t_11, __pyx_empty_unicode); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1138, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_11); __pyx_t_11 = 0; __pyx_t_10 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_4) > __pyx_t_10) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_4) : __pyx_t_10; __pyx_t_9 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_4); __Pyx_GIVEREF(__pyx_t_4); PyTuple_SET_ITEM(__pyx_t_6, 1, __pyx_t_4); __pyx_t_4 = 0; __Pyx_INCREF(__pyx_kp_u_column); __pyx_t_9 += 8; __Pyx_GIVEREF(__pyx_kp_u_column); PyTuple_SET_ITEM(__pyx_t_6, 2, __pyx_kp_u_column); __pyx_t_4 = __Pyx_PyUnicode_Join(__pyx_t_6, 3, __pyx_t_9, __pyx_t_10); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1138, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0;
+1139: col.dispatch_code = <col_dispatch_code_t>(
__pyx_v_col->dispatch_code = ((enum __pyx_t_7questdb_7ingress_col_dispatch_code_t)(((int)__pyx_v_col->setup->source) + ((int)__pyx_v_col->setup->target)));
1140: <int>col.setup.source + <int>col.setup.target)
1141:
1142: # Since we don't need to send the column names for 'table' and
1143: # 'at' columns, we don't need to validate and encode them as
1144: # column names. This allows unsupported names for these columns.
+1145: if ((col.setup.meta_target != meta_target_t.meta_target_table) and
switch (__pyx_v_col->setup->meta_target) { case __pyx_e_7questdb_7ingress_meta_target_table: case __pyx_e_7questdb_7ingress_meta_target_at: /* … */ __pyx_t_8 = 0; /* … */ break; default: __pyx_t_8 = 1; break; } if (__pyx_t_8) { /* … */ } }
1146: (col.setup.meta_target != meta_target_t.meta_target_at)):
+1147: str_to_column_name_copy(b, pandas_col.name, &col.name)
__pyx_t_4 = __pyx_v_pandas_col->name; __Pyx_INCREF(__pyx_t_4); __pyx_t_5 = __pyx_f_7questdb_7ingress_str_to_column_name_copy(__pyx_v_b, ((PyObject*)__pyx_t_4), (&__pyx_v_col->name)); if (unlikely(__pyx_t_5 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1147, __pyx_L1_error) __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0;
1148:
1149:
+1150: cdef int _dataframe_compare_cols(const void* lhs, const void* rhs) noexcept nogil:
static int __pyx_f_7questdb_7ingress__dataframe_compare_cols(void const *__pyx_v_lhs, void const *__pyx_v_rhs) { struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_lhs_col; struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_rhs_col; int __pyx_v_source_diff; int __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
+1151: cdef col_t* lhs_col = <col_t*>lhs
__pyx_v_lhs_col = ((struct __pyx_t_7questdb_7ingress_col_t *)__pyx_v_lhs);
+1152: cdef col_t* rhs_col = <col_t*>rhs
__pyx_v_rhs_col = ((struct __pyx_t_7questdb_7ingress_col_t *)__pyx_v_rhs);
+1153: cdef int source_diff = lhs_col.setup.meta_target - rhs_col.setup.meta_target
__pyx_v_source_diff = (__pyx_v_lhs_col->setup->meta_target - __pyx_v_rhs_col->setup->meta_target);
+1154: if source_diff != 0:
__pyx_t_1 = (__pyx_v_source_diff != 0); if (__pyx_t_1) { /* … */ }
+1155: return source_diff
__pyx_r = __pyx_v_source_diff; goto __pyx_L0;
+1156: return <int>lhs_col.setup.orig_index - <int>rhs_col.setup.orig_index
__pyx_r = (((int)__pyx_v_lhs_col->setup->orig_index) - ((int)__pyx_v_rhs_col->setup->orig_index)); goto __pyx_L0;
1157:
1158: # noinspection PyUnreachableCode
+1159: cdef void_int _dataframe_resolve_args(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_resolve_args(PyObject *__pyx_v_df, PyObject *__pyx_v_table_name, PyObject *__pyx_v_table_name_col, PyObject *__pyx_v_symbols, PyObject *__pyx_v_at, struct qdb_pystr_buf *__pyx_v_b, size_t __pyx_v_col_count, struct line_sender_table_name *__pyx_v_c_table_name_out, int64_t *__pyx_v_at_value_out, struct __pyx_t_7questdb_7ingress_col_t_arr *__pyx_v_cols, int *__pyx_v_any_cols_need_gil_out) { Py_ssize_t __pyx_v_name_col; Py_ssize_t __pyx_v_at_col; PyObject *__pyx_v_pandas_cols = 0; PyObject *__pyx_7genexpr__pyx_v_index = NULL; PyObject *__pyx_7genexpr__pyx_v_name = NULL; PyObject *__pyx_7genexpr__pyx_v_series = NULL; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_1); __Pyx_XDECREF(__pyx_t_2); __Pyx_XDECREF(__pyx_t_3); __Pyx_XDECREF(__pyx_t_7); __Pyx_XDECREF(__pyx_t_8); __Pyx_AddTraceback("questdb.ingress._dataframe_resolve_args", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_XDECREF(__pyx_v_pandas_cols); __Pyx_XDECREF(__pyx_7genexpr__pyx_v_index); __Pyx_XDECREF(__pyx_7genexpr__pyx_v_name); __Pyx_XDECREF(__pyx_7genexpr__pyx_v_series); __Pyx_RefNannyFinishContext(); return __pyx_r; }
1160: object df,
1161: object table_name,
1162: object table_name_col,
1163: object symbols,
1164: object at,
1165: qdb_pystr_buf* b,
1166: size_t col_count,
1167: line_sender_table_name* c_table_name_out,
1168: int64_t* at_value_out,
1169: col_t_arr* cols,
1170: bint* any_cols_need_gil_out) except -1:
1171: cdef ssize_t name_col
1172: cdef ssize_t at_col
1173:
+1174: cdef list pandas_cols = [
{ /* enter inner scope */ __pyx_t_1 = PyList_New(0); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 1174, __pyx_L5_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_INCREF(__pyx_int_0); __pyx_t_2 = __pyx_int_0;
+1175: PandasCol(name, df.dtypes.iloc[index], series)
__pyx_t_8 = __Pyx_PyObject_GetAttrStr(__pyx_v_df, __pyx_n_s_dtypes); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 1175, __pyx_L5_error) __Pyx_GOTREF(__pyx_t_8); __pyx_t_7 = __Pyx_PyObject_GetAttrStr(__pyx_t_8, __pyx_n_s_iloc); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 1175, __pyx_L5_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0; __pyx_t_8 = __Pyx_PyObject_GetItem(__pyx_t_7, __pyx_7genexpr__pyx_v_index); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 1175, __pyx_L5_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __pyx_t_7 = PyTuple_New(3); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 1175, __pyx_L5_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_INCREF(__pyx_7genexpr__pyx_v_name); __Pyx_GIVEREF(__pyx_7genexpr__pyx_v_name); if (__Pyx_PyTuple_SET_ITEM(__pyx_t_7, 0, __pyx_7genexpr__pyx_v_name)) __PYX_ERR(1, 1175, __pyx_L5_error); __Pyx_GIVEREF(__pyx_t_8); if (__Pyx_PyTuple_SET_ITEM(__pyx_t_7, 1, __pyx_t_8)) __PYX_ERR(1, 1175, __pyx_L5_error); __Pyx_INCREF(__pyx_7genexpr__pyx_v_series); __Pyx_GIVEREF(__pyx_7genexpr__pyx_v_series); if (__Pyx_PyTuple_SET_ITEM(__pyx_t_7, 2, __pyx_7genexpr__pyx_v_series)) __PYX_ERR(1, 1175, __pyx_L5_error); __pyx_t_8 = 0; __pyx_t_8 = __Pyx_PyObject_Call(((PyObject *)__pyx_ptype_7questdb_7ingress_PandasCol), __pyx_t_7, NULL); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 1175, __pyx_L5_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; if (unlikely(__Pyx_ListComp_Append(__pyx_t_1, (PyObject*)__pyx_t_8))) __PYX_ERR(1, 1174, __pyx_L5_error) __Pyx_DECREF(__pyx_t_8); __pyx_t_8 = 0; } __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __Pyx_XDECREF(__pyx_7genexpr__pyx_v_index); __pyx_7genexpr__pyx_v_index = 0; __Pyx_XDECREF(__pyx_7genexpr__pyx_v_name); __pyx_7genexpr__pyx_v_name = 0; __Pyx_XDECREF(__pyx_7genexpr__pyx_v_series); __pyx_7genexpr__pyx_v_series = 0; goto __pyx_L8_exit_scope; __pyx_L5_error:; __Pyx_XDECREF(__pyx_7genexpr__pyx_v_index); __pyx_7genexpr__pyx_v_index = 0; __Pyx_XDECREF(__pyx_7genexpr__pyx_v_name); __pyx_7genexpr__pyx_v_name = 0; __Pyx_XDECREF(__pyx_7genexpr__pyx_v_series); __pyx_7genexpr__pyx_v_series = 0; goto __pyx_L1_error; __pyx_L8_exit_scope:; } /* exit inner scope */ __pyx_v_pandas_cols = ((PyObject*)__pyx_t_1); __pyx_t_1 = 0;
+1176: for index, (name, series) in enumerate(df.items())]
__pyx_t_4 = 0; if (unlikely(__pyx_v_df == Py_None)) { PyErr_Format(PyExc_AttributeError, "'NoneType' object has no attribute '%.30s'", "items"); __PYX_ERR(1, 1176, __pyx_L5_error) } __pyx_t_7 = __Pyx_dict_iterator(__pyx_v_df, 0, __pyx_n_s_items, (&__pyx_t_5), (&__pyx_t_6)); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 1176, __pyx_L5_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_XDECREF(__pyx_t_3); __pyx_t_3 = __pyx_t_7; __pyx_t_7 = 0; while (1) { __pyx_t_9 = __Pyx_dict_iter_next(__pyx_t_3, __pyx_t_5, &__pyx_t_4, &__pyx_t_7, &__pyx_t_8, NULL, __pyx_t_6); if (unlikely(__pyx_t_9 == 0)) break; if (unlikely(__pyx_t_9 == -1)) __PYX_ERR(1, 1176, __pyx_L5_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_GOTREF(__pyx_t_8); __Pyx_XDECREF_SET(__pyx_7genexpr__pyx_v_name, __pyx_t_7); __pyx_t_7 = 0; __Pyx_XDECREF_SET(__pyx_7genexpr__pyx_v_series, __pyx_t_8); __pyx_t_8 = 0; __Pyx_INCREF(__pyx_t_2); __Pyx_XDECREF_SET(__pyx_7genexpr__pyx_v_index, __pyx_t_2); __pyx_t_8 = __Pyx_PyInt_AddObjC(__pyx_t_2, __pyx_int_1, 1, 0, 0); if (unlikely(!__pyx_t_8)) __PYX_ERR(1, 1176, __pyx_L5_error) __Pyx_GOTREF(__pyx_t_8); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = __pyx_t_8; __pyx_t_8 = 0;
+1177: _dataframe_resolve_cols(b, pandas_cols, cols, any_cols_need_gil_out)
__pyx_t_10 = __pyx_f_7questdb_7ingress__dataframe_resolve_cols(__pyx_v_b, __pyx_v_pandas_cols, __pyx_v_cols, __pyx_v_any_cols_need_gil_out); if (unlikely(__pyx_t_10 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1177, __pyx_L1_error)
+1178: name_col = _dataframe_resolve_table_name(
__pyx_t_11 = __pyx_f_7questdb_7ingress__dataframe_resolve_table_name(__pyx_v_b, __pyx_v_df, __pyx_v_pandas_cols, __pyx_v_cols, __pyx_v_table_name, __pyx_v_table_name_col, __pyx_v_col_count, __pyx_v_c_table_name_out); if (unlikely(__pyx_t_11 == ((Py_ssize_t)-2L))) __PYX_ERR(1, 1178, __pyx_L1_error)
__pyx_v_name_col = __pyx_t_11;
1179: b,
1180: df,
1181: pandas_cols,
1182: cols,
1183: table_name,
1184: table_name_col,
1185: col_count,
1186: c_table_name_out)
+1187: at_col = _dataframe_resolve_at(df, cols, at, col_count, at_value_out)
__pyx_t_11 = __pyx_f_7questdb_7ingress__dataframe_resolve_at(__pyx_v_df, __pyx_v_cols, __pyx_v_at, __pyx_v_col_count, __pyx_v_at_value_out); if (unlikely(__pyx_t_11 == ((Py_ssize_t)-2L))) __PYX_ERR(1, 1187, __pyx_L1_error)
__pyx_v_at_col = __pyx_t_11;
+1188: _dataframe_resolve_symbols(df, pandas_cols, cols, name_col, at_col, symbols)
__pyx_t_10 = __pyx_f_7questdb_7ingress__dataframe_resolve_symbols(__pyx_v_df, __pyx_v_pandas_cols, __pyx_v_cols, __pyx_v_name_col, __pyx_v_at_col, __pyx_v_symbols); if (unlikely(__pyx_t_10 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1188, __pyx_L1_error)
+1189: _dataframe_resolve_cols_target_name_and_dc(b, pandas_cols, cols)
__pyx_t_10 = __pyx_f_7questdb_7ingress__dataframe_resolve_cols_target_name_and_dc(__pyx_v_b, __pyx_v_pandas_cols, __pyx_v_cols); if (unlikely(__pyx_t_10 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1189, __pyx_L1_error)
+1190: qsort(cols.d, col_count, sizeof(col_t), _dataframe_compare_cols)
qsort(__pyx_v_cols->d, __pyx_v_col_count, (sizeof(struct __pyx_t_7questdb_7ingress_col_t)), __pyx_f_7questdb_7ingress__dataframe_compare_cols);
1191:
1192:
+1193: cdef inline bint _dataframe_arrow_get_bool(col_cursor_t* cursor) noexcept nogil:
static CYTHON_INLINE int __pyx_f_7questdb_7ingress__dataframe_arrow_get_bool(struct __pyx_t_7questdb_7ingress_col_cursor_t *__pyx_v_cursor) { int __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
1194: return (
+1195: (<uint8_t*>cursor.chunk.buffers[1])[cursor.offset // 8] &
__pyx_r = ((((uint8_t *)(__pyx_v_cursor->chunk->buffers[1]))[(__pyx_v_cursor->offset / 8)]) & (1 << (__pyx_v_cursor->offset % 8))); goto __pyx_L0;
1196: (1 << (cursor.offset % 8)))
1197:
1198:
+1199: cdef inline bint _dataframe_arrow_is_valid(col_cursor_t* cursor) noexcept nogil:
static CYTHON_INLINE int __pyx_f_7questdb_7ingress__dataframe_arrow_is_valid(struct __pyx_t_7questdb_7ingress_col_cursor_t *__pyx_v_cursor) { int __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
1200: """Check if the value is set according to the validity bitmap."""
1201: return (
+1202: cursor.chunk.null_count == 0 or
__pyx_t_2 = (__pyx_v_cursor->chunk->null_count == 0); if (!__pyx_t_2) { } else { __pyx_t_1 = __pyx_t_2; goto __pyx_L3_bool_binop_done; }
1203: (
+1204: (<uint8_t*>cursor.chunk.buffers[0])[cursor.offset // 8] &
__pyx_t_2 = (((((uint8_t *)(__pyx_v_cursor->chunk->buffers[0]))[(__pyx_v_cursor->offset / 8)]) & (1 << (__pyx_v_cursor->offset % 8))) != 0); __pyx_t_1 = __pyx_t_2; __pyx_L3_bool_binop_done:; __pyx_r = __pyx_t_1; goto __pyx_L0;
1205: (1 << (cursor.offset % 8))))
1206:
1207:
+1208: cdef inline void _dataframe_arrow_get_cat_value(
static CYTHON_INLINE void __pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_value(struct __pyx_t_7questdb_7ingress_col_cursor_t *__pyx_v_cursor, size_t __pyx_v_key, size_t *__pyx_v_len_out, char const **__pyx_v_buf_out) { int32_t *__pyx_v_value_index_access; int32_t __pyx_v_value_begin; uint8_t *__pyx_v_value_char_access; /* … */ /* function exit code */ }
1209: col_cursor_t* cursor,
1210: size_t key,
1211: size_t* len_out,
1212: const char** buf_out) noexcept nogil:
1213: cdef int32_t* value_index_access
1214: cdef int32_t value_begin
1215: cdef uint8_t* value_char_access
+1216: value_index_access = <int32_t*>cursor.chunk.dictionary.buffers[1]
__pyx_v_value_index_access = ((int32_t *)(__pyx_v_cursor->chunk->dictionary->buffers[1]));
+1217: value_begin = value_index_access[key]
__pyx_v_value_begin = (__pyx_v_value_index_access[__pyx_v_key]);
+1218: len_out[0] = value_index_access[key + 1] - value_begin
(__pyx_v_len_out[0]) = ((__pyx_v_value_index_access[(__pyx_v_key + 1)]) - __pyx_v_value_begin);
+1219: value_char_access = <uint8_t*>cursor.chunk.dictionary.buffers[2]
__pyx_v_value_char_access = ((uint8_t *)(__pyx_v_cursor->chunk->dictionary->buffers[2]));
+1220: buf_out[0] = <const char*>&value_char_access[value_begin]
(__pyx_v_buf_out[0]) = ((char const *)(&(__pyx_v_value_char_access[__pyx_v_value_begin])));
1221:
1222:
+1223: cdef inline bint _dataframe_arrow_get_cat_i8(
static CYTHON_INLINE int __pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_i8(struct __pyx_t_7questdb_7ingress_col_cursor_t *__pyx_v_cursor, size_t *__pyx_v_len_out, char const **__pyx_v_buf_out) { int __pyx_v_valid; int8_t *__pyx_v_key_access; int8_t __pyx_v_key; int __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
1224: col_cursor_t* cursor, size_t* len_out, const char** buf_out) noexcept nogil:
+1225: cdef bint valid = _dataframe_arrow_is_valid(cursor)
__pyx_v_valid = __pyx_f_7questdb_7ingress__dataframe_arrow_is_valid(__pyx_v_cursor);
1226: cdef int8_t* key_access
1227: cdef int8_t key
+1228: if valid:
if (__pyx_v_valid) { /* … */ }
+1229: key_access = <int8_t*>cursor.chunk.buffers[1]
__pyx_v_key_access = ((int8_t *)(__pyx_v_cursor->chunk->buffers[1]));
+1230: key = key_access[cursor.offset]
__pyx_v_key = (__pyx_v_key_access[__pyx_v_cursor->offset]);
+1231: _dataframe_arrow_get_cat_value(cursor, <size_t>key, len_out, buf_out)
__pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_value(__pyx_v_cursor, ((size_t)__pyx_v_key), __pyx_v_len_out, __pyx_v_buf_out);
+1232: return valid
__pyx_r = __pyx_v_valid; goto __pyx_L0;
1233:
1234:
+1235: cdef inline bint _dataframe_arrow_get_cat_i16(
static CYTHON_INLINE int __pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_i16(struct __pyx_t_7questdb_7ingress_col_cursor_t *__pyx_v_cursor, size_t *__pyx_v_len_out, char const **__pyx_v_buf_out) { int __pyx_v_valid; int16_t *__pyx_v_key_access; int16_t __pyx_v_key; int __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
1236: col_cursor_t* cursor, size_t* len_out, const char** buf_out) noexcept nogil:
+1237: cdef bint valid = _dataframe_arrow_is_valid(cursor)
1238: cdef int16_t* key_access
1239: cdef int16_t key
+1240: if valid:
+1241: key_access = <int16_t*>cursor.chunk.buffers[1]
__pyx_v_key_access = ((int16_t *)(__pyx_v_cursor->chunk->buffers[1]));
+1242: key = key_access[cursor.offset]
+1243: _dataframe_arrow_get_cat_value(cursor, <size_t>key, len_out, buf_out)
+1244: return valid
1245:
1246:
+1247: cdef inline bint _dataframe_arrow_get_cat_i32(
static CYTHON_INLINE int __pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_i32(struct __pyx_t_7questdb_7ingress_col_cursor_t *__pyx_v_cursor, size_t *__pyx_v_len_out, char const **__pyx_v_buf_out) { int __pyx_v_valid; int32_t *__pyx_v_key_access; int32_t __pyx_v_key; int __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
1248: col_cursor_t* cursor, size_t* len_out, const char** buf_out) noexcept nogil:
+1249: cdef bint valid = _dataframe_arrow_is_valid(cursor)
1250: cdef int32_t* key_access
1251: cdef int32_t key
+1252: if valid:
+1253: key_access = <int32_t*>cursor.chunk.buffers[1]
__pyx_v_key_access = ((int32_t *)(__pyx_v_cursor->chunk->buffers[1]));
+1254: key = key_access[cursor.offset]
+1255: _dataframe_arrow_get_cat_value(cursor, <size_t>key, len_out, buf_out)
+1256: return valid
1257:
1258:
+1259: cdef inline bint _dataframe_arrow_str_utf8(
static CYTHON_INLINE int __pyx_f_7questdb_7ingress__dataframe_arrow_str_utf8(struct __pyx_t_7questdb_7ingress_col_cursor_t *__pyx_v_cursor, size_t *__pyx_v_len_out, char const **__pyx_v_buf_out) { int32_t *__pyx_v_index_access; uint8_t *__pyx_v_char_access; int32_t __pyx_v_begin; int __pyx_v_valid; int __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
1260: col_cursor_t* cursor,
1261: size_t* len_out,
1262: const char** buf_out) noexcept nogil:
1263: cdef int32_t* index_access
1264: cdef uint8_t* char_access
1265: cdef int32_t begin
+1266: cdef bint valid = _dataframe_arrow_is_valid(cursor)
+1267: if valid:
+1268: index_access = <int32_t*>cursor.chunk.buffers[1]
__pyx_v_index_access = ((int32_t *)(__pyx_v_cursor->chunk->buffers[1]));
+1269: char_access = <uint8_t*>cursor.chunk.buffers[2]
__pyx_v_char_access = ((uint8_t *)(__pyx_v_cursor->chunk->buffers[2]));
+1270: begin = index_access[cursor.offset]
__pyx_v_begin = (__pyx_v_index_access[__pyx_v_cursor->offset]);
+1271: len_out[0] = index_access[cursor.offset + 1] - begin
(__pyx_v_len_out[0]) = ((__pyx_v_index_access[(__pyx_v_cursor->offset + 1)]) - __pyx_v_begin);
+1272: buf_out[0] = <const char*>&char_access[begin]
(__pyx_v_buf_out[0]) = ((char const *)(&(__pyx_v_char_access[__pyx_v_begin])));
+1273: return valid
1274:
+1275: cdef inline bint _dataframe_arrow_str_utf8_lrg(
static CYTHON_INLINE int __pyx_f_7questdb_7ingress__dataframe_arrow_str_utf8_lrg(struct __pyx_t_7questdb_7ingress_col_cursor_t *__pyx_v_cursor, size_t *__pyx_v_len_out, char const **__pyx_v_buf_out) { int64_t *__pyx_v_index_access; uint8_t *__pyx_v_char_access; int64_t __pyx_v_begin; int __pyx_v_valid; int __pyx_r; /* … */ /* function exit code */ __pyx_L0:; return __pyx_r; }
1276: col_cursor_t* cursor,
1277: size_t* len_out,
1278: const char** buf_out) noexcept nogil:
1279: cdef int64_t* index_access
1280: cdef uint8_t* char_access
1281: cdef int64_t begin
+1282: cdef bint valid = _dataframe_arrow_is_valid(cursor)
+1283: if valid:
+1284: index_access = <int64_t*>cursor.chunk.buffers[1]
__pyx_v_index_access = ((int64_t *)(__pyx_v_cursor->chunk->buffers[1]));
+1285: char_access = <uint8_t*>cursor.chunk.buffers[2]
+1286: begin = index_access[cursor.offset]
+1287: len_out[0] = index_access[cursor.offset + 1] - begin
+1288: buf_out[0] = <const char*>&char_access[begin]
+1289: return valid
1290:
1291:
+1292: cdef inline void_int _dataframe_cell_str_pyobj_to_utf8(
static CYTHON_INLINE __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_cell_str_pyobj_to_utf8(struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_cursor_t *__pyx_v_cursor, int *__pyx_v_valid_out, struct line_sender_utf8 *__pyx_v_utf8_out) { PyObject **__pyx_v_access; PyObject *__pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_3); __Pyx_XDECREF(__pyx_t_6); __Pyx_XDECREF(__pyx_t_7); __Pyx_AddTraceback("questdb.ingress._dataframe_cell_str_pyobj_to_utf8", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1293: qdb_pystr_buf* b,
1294: col_cursor_t* cursor,
1295: bint* valid_out,
1296: line_sender_utf8* utf8_out) except -1:
+1297: cdef PyObject** access = <PyObject**>cursor.chunk.buffers[1]
__pyx_v_access = ((PyObject **)(__pyx_v_cursor->chunk->buffers[1]));
+1298: cdef PyObject* cell = access[cursor.offset]
__pyx_v_cell = (__pyx_v_access[__pyx_v_cursor->offset]);
+1299: if PyUnicode_CheckExact(cell):
__pyx_t_1 = PyUnicode_CheckExact(__pyx_v_cell);
if (__pyx_t_1) {
goto __pyx_L3;
+1300: str_to_utf8(b, cell, utf8_out)
__pyx_t_2 = __pyx_f_7questdb_7ingress_str_to_utf8(__pyx_v_b, __pyx_v_cell, __pyx_v_utf8_out); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1300, __pyx_L1_error)
+1301: valid_out[0] = True
(__pyx_v_valid_out[0]) = 1;
+1302: elif _dataframe_is_null_pyobj(cell):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_is_null_pyobj(__pyx_v_cell); if (likely(__pyx_t_1)) { /* … */ goto __pyx_L3; }
+1303: valid_out[0] = False
(__pyx_v_valid_out[0]) = 0;
1304: else:
+1305: raise ValueError(
/*else*/ { /* … */ __pyx_t_7 = __Pyx_PyObject_CallOneArg(__pyx_builtin_ValueError, __pyx_t_3); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 1305, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __Pyx_Raise(__pyx_t_7, 0, 0, 0); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0; __PYX_ERR(1, 1305, __pyx_L1_error) } __pyx_L3:;
+1306: 'Expected a string, ' +
__pyx_t_3 = __Pyx_PyUnicode_Concat(__pyx_kp_u_Expected_a_string, __pyx_t_7); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 1306, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __Pyx_DECREF(__pyx_t_7); __pyx_t_7 = 0;
+1307: f'got an object of type {_fqn(type(<object>cell))}.')
__pyx_t_3 = PyTuple_New(3); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 1307, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __pyx_t_4 = 0; __pyx_t_5 = 127; __Pyx_INCREF(__pyx_kp_u_got_an_object_of_type); __pyx_t_4 += 22; __Pyx_GIVEREF(__pyx_kp_u_got_an_object_of_type); PyTuple_SET_ITEM(__pyx_t_3, 0, __pyx_kp_u_got_an_object_of_type); __pyx_t_6 = __pyx_f_7questdb_7ingress__fqn(((PyTypeObject*)((PyObject *)Py_TYPE(((PyObject *)__pyx_v_cell))))); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1307, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __pyx_t_7 = __Pyx_PyUnicode_Unicode(__pyx_t_6); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 1307, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __pyx_t_5 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_7) > __pyx_t_5) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_7) : __pyx_t_5; __pyx_t_4 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_7); __Pyx_GIVEREF(__pyx_t_7); PyTuple_SET_ITEM(__pyx_t_3, 1, __pyx_t_7); __pyx_t_7 = 0; __Pyx_INCREF(__pyx_kp_u__5); __pyx_t_4 += 1; __Pyx_GIVEREF(__pyx_kp_u__5); PyTuple_SET_ITEM(__pyx_t_3, 2, __pyx_kp_u__5); __pyx_t_7 = __Pyx_PyUnicode_Join(__pyx_t_3, 3, __pyx_t_4, __pyx_t_5); if (unlikely(!__pyx_t_7)) __PYX_ERR(1, 1307, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_7); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
1308:
1309:
+1310: cdef void_int _dataframe_serialize_cell_table__str_pyobj(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_table__str_pyobj(struct line_sender_buffer *__pyx_v_ls_buf, struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { struct line_sender_error *__pyx_v_err; PyObject **__pyx_v_access; PyObject *__pyx_v_cell; struct line_sender_table_name __pyx_v_c_table_name; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_XDECREF(__pyx_t_5); __Pyx_XDECREF(__pyx_t_6); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_table__str_pyobj", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1311: line_sender_buffer* ls_buf,
1312: qdb_pystr_buf* b,
1313: col_t* col) except -1:
+1314: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1315: cdef PyObject** access = <PyObject**>col.cursor.chunk.buffers[1]
__pyx_v_access = ((PyObject **)(__pyx_v_col->cursor.chunk->buffers[1]));
+1316: cdef PyObject* cell = access[col.cursor.offset]
__pyx_v_cell = (__pyx_v_access[__pyx_v_col->cursor.offset]);
1317: cdef line_sender_table_name c_table_name
+1318: if not PyUnicode_CheckExact(cell):
__pyx_t_1 = (!PyUnicode_CheckExact(__pyx_v_cell));
if (__pyx_t_1) {
+1319: if _dataframe_is_null_pyobj(cell):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_is_null_pyobj(__pyx_v_cell); if (unlikely(__pyx_t_1)) { /* … */ }
+1320: raise ValueError('Expected a table name, got a null value')
__pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_ValueError, __pyx_tuple__23, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1320, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1320, __pyx_L1_error) /* … */ __pyx_tuple__23 = PyTuple_Pack(1, __pyx_kp_u_Expected_a_table_name_got_a_null); if (unlikely(!__pyx_tuple__23)) __PYX_ERR(1, 1320, __pyx_L1_error) __Pyx_GOTREF(__pyx_tuple__23); __Pyx_GIVEREF(__pyx_tuple__23);
1321: else:
+1322: raise ValueError(
/*else*/ { /* … */ __pyx_t_6 = __Pyx_PyObject_CallOneArg(__pyx_builtin_ValueError, __pyx_t_2); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1322, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __Pyx_Raise(__pyx_t_6, 0, 0, 0); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __PYX_ERR(1, 1322, __pyx_L1_error) }
+1323: 'Expected a table name (str object), ' +
__pyx_t_2 = __Pyx_PyUnicode_Concat(__pyx_kp_u_Expected_a_table_name_str_object, __pyx_t_6); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1323, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0;
+1324: f'got an object of type {_fqn(type(<object>cell))}.')
__pyx_t_2 = PyTuple_New(3); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1324, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __pyx_t_3 = 0; __pyx_t_4 = 127; __Pyx_INCREF(__pyx_kp_u_got_an_object_of_type); __pyx_t_3 += 22; __Pyx_GIVEREF(__pyx_kp_u_got_an_object_of_type); PyTuple_SET_ITEM(__pyx_t_2, 0, __pyx_kp_u_got_an_object_of_type); __pyx_t_5 = __pyx_f_7questdb_7ingress__fqn(((PyTypeObject*)((PyObject *)Py_TYPE(((PyObject *)__pyx_v_cell))))); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 1324, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __pyx_t_6 = __Pyx_PyUnicode_Unicode(__pyx_t_5); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1324, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __pyx_t_4 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_6) > __pyx_t_4) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_6) : __pyx_t_4; __pyx_t_3 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_6); __Pyx_GIVEREF(__pyx_t_6); PyTuple_SET_ITEM(__pyx_t_2, 1, __pyx_t_6); __pyx_t_6 = 0; __Pyx_INCREF(__pyx_kp_u__5); __pyx_t_3 += 1; __Pyx_GIVEREF(__pyx_kp_u__5); PyTuple_SET_ITEM(__pyx_t_2, 2, __pyx_kp_u__5); __pyx_t_6 = __Pyx_PyUnicode_Join(__pyx_t_2, 3, __pyx_t_3, __pyx_t_4); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1324, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0;
+1325: str_to_table_name(b, cell, &c_table_name)
__pyx_t_7 = __pyx_f_7questdb_7ingress_str_to_table_name(__pyx_v_b, __pyx_v_cell, (&__pyx_v_c_table_name)); if (unlikely(__pyx_t_7 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1325, __pyx_L1_error)
+1326: if not line_sender_buffer_table(ls_buf, c_table_name, &err):
__pyx_t_1 = (!line_sender_buffer_table(__pyx_v_ls_buf, __pyx_v_c_table_name, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+1327: raise c_err_to_py(err)
__pyx_t_6 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_6)) __PYX_ERR(1, 1327, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_6); __Pyx_Raise(__pyx_t_6, 0, 0, 0); __Pyx_DECREF(__pyx_t_6); __pyx_t_6 = 0; __PYX_ERR(1, 1327, __pyx_L1_error)
1328:
1329:
+1330: cdef void_int _dataframe_serialize_cell_table__str_utf8_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_table__str_utf8_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; size_t __pyx_v_c_len; char const *__pyx_v_buf; struct line_sender_table_name __pyx_v_c_table_name; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_table__str_utf8_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1331: line_sender_buffer* ls_buf,
1332: qdb_pystr_buf* b,
1333: col_t* col,
1334: PyThreadState** gs) except -1:
+1335: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1336: cdef size_t c_len
1337: cdef const char* buf
1338: cdef line_sender_table_name c_table_name
+1339: if _dataframe_arrow_str_utf8(&col.cursor, &c_len, &buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_str_utf8((&__pyx_v_col->cursor), (&__pyx_v_c_len), (&__pyx_v_buf)); if (likely(__pyx_t_1)) { /* … */ goto __pyx_L3; }
+1340: if not line_sender_table_name_init(&c_table_name, c_len, buf, &err):
__pyx_t_1 = (!line_sender_table_name_init((&__pyx_v_c_table_name), __pyx_v_c_len, __pyx_v_buf, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+1341: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1341, __pyx_L1_error)
+1342: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1342, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1342, __pyx_L1_error)
+1343: if not line_sender_buffer_table(ls_buf, c_table_name, &err):
+1344: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1344, __pyx_L1_error)
+1345: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1345, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1345, __pyx_L1_error)
1346: else:
+1347: _ensure_has_gil(gs)
/*else*/ {
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1347, __pyx_L1_error)
+1348: raise ValueError('Table name cannot be null')
__pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_ValueError, __pyx_tuple__24, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1348, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1348, __pyx_L1_error) } __pyx_L3:; /* … */ __pyx_tuple__24 = PyTuple_Pack(1, __pyx_kp_u_Table_name_cannot_be_null); if (unlikely(!__pyx_tuple__24)) __PYX_ERR(1, 1348, __pyx_L1_error) __Pyx_GOTREF(__pyx_tuple__24); __Pyx_GIVEREF(__pyx_tuple__24);
1349:
+1350: cdef void_int _dataframe_serialize_cell_table__str_lrg_utf8_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_table__str_lrg_utf8_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; size_t __pyx_v_c_len; char const *__pyx_v_buf; struct line_sender_table_name __pyx_v_c_table_name; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_table__str_lrg_utf8_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1351: line_sender_buffer* ls_buf,
1352: qdb_pystr_buf* b,
1353: col_t* col,
1354: PyThreadState** gs) except -1:
+1355: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1356: cdef size_t c_len
1357: cdef const char* buf
1358: cdef line_sender_table_name c_table_name
+1359: if _dataframe_arrow_str_utf8_lrg(&col.cursor, &c_len, &buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_str_utf8_lrg((&__pyx_v_col->cursor), (&__pyx_v_c_len), (&__pyx_v_buf)); if (likely(__pyx_t_1)) { /* … */ goto __pyx_L3; }
+1360: if not line_sender_table_name_init(&c_table_name, c_len, buf, &err):
+1361: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1361, __pyx_L1_error)
+1362: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1362, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1362, __pyx_L1_error)
+1363: if not line_sender_buffer_table(ls_buf, c_table_name, &err):
+1364: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1364, __pyx_L1_error)
+1365: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1365, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1365, __pyx_L1_error)
1366: else:
+1367: _ensure_has_gil(gs)
/*else*/ {
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1367, __pyx_L1_error)
+1368: raise ValueError('Table name cannot be null')
__pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_ValueError, __pyx_tuple__24, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1368, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1368, __pyx_L1_error) } __pyx_L3:;
1369:
1370:
+1371: cdef void_int _dataframe_serialize_cell_table__str_i8_cat(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_table__str_i8_cat(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; size_t __pyx_v_c_len; char const *__pyx_v_c_buf; struct line_sender_table_name __pyx_v_c_table_name; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_table__str_i8_cat", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1372: line_sender_buffer* ls_buf,
1373: qdb_pystr_buf* b,
1374: col_t* col,
1375: PyThreadState** gs) except -1:
+1376: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1377: cdef size_t c_len
1378: cdef const char* c_buf
1379: cdef line_sender_table_name c_table_name
+1380: if _dataframe_arrow_get_cat_i8(&col.cursor, &c_len, &c_buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_i8((&__pyx_v_col->cursor), (&__pyx_v_c_len), (&__pyx_v_c_buf)); if (likely(__pyx_t_1)) { /* … */ goto __pyx_L3; }
+1381: if not line_sender_table_name_init(&c_table_name, c_len, c_buf, &err):
__pyx_t_1 = (!line_sender_table_name_init((&__pyx_v_c_table_name), __pyx_v_c_len, __pyx_v_c_buf, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+1382: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1382, __pyx_L1_error)
+1383: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1383, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1383, __pyx_L1_error)
+1384: if not line_sender_buffer_table(ls_buf, c_table_name, &err):
+1385: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1385, __pyx_L1_error)
+1386: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1386, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1386, __pyx_L1_error)
1387: else:
+1388: _ensure_has_gil(gs)
/*else*/ {
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1388, __pyx_L1_error)
+1389: raise ValueError('Table name cannot be null')
__pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_ValueError, __pyx_tuple__24, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1389, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1389, __pyx_L1_error) } __pyx_L3:;
1390:
1391:
+1392: cdef void_int _dataframe_serialize_cell_table__str_i16_cat(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_table__str_i16_cat(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; size_t __pyx_v_c_len; char const *__pyx_v_c_buf; struct line_sender_table_name __pyx_v_c_table_name; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_table__str_i16_cat", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1393: line_sender_buffer* ls_buf,
1394: qdb_pystr_buf* b,
1395: col_t* col,
1396: PyThreadState** gs) except -1:
+1397: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1398: cdef size_t c_len
1399: cdef const char* c_buf
1400: cdef line_sender_table_name c_table_name
+1401: if _dataframe_arrow_get_cat_i16(&col.cursor, &c_len, &c_buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_i16((&__pyx_v_col->cursor), (&__pyx_v_c_len), (&__pyx_v_c_buf)); if (likely(__pyx_t_1)) { /* … */ goto __pyx_L3; }
+1402: if not line_sender_table_name_init(&c_table_name, c_len, c_buf, &err):
+1403: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1403, __pyx_L1_error)
+1404: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1404, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1404, __pyx_L1_error)
+1405: if not line_sender_buffer_table(ls_buf, c_table_name, &err):
+1406: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1406, __pyx_L1_error)
+1407: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1407, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1407, __pyx_L1_error)
1408: else:
+1409: _ensure_has_gil(gs)
/*else*/ {
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1409, __pyx_L1_error)
+1410: raise ValueError('Table name cannot be null')
__pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_ValueError, __pyx_tuple__24, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1410, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1410, __pyx_L1_error) } __pyx_L3:;
1411:
1412:
+1413: cdef void_int _dataframe_serialize_cell_table__str_i32_cat(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_table__str_i32_cat(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; size_t __pyx_v_c_len; char const *__pyx_v_c_buf; struct line_sender_table_name __pyx_v_c_table_name; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_table__str_i32_cat", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1414: line_sender_buffer* ls_buf,
1415: qdb_pystr_buf* b,
1416: col_t* col,
1417: PyThreadState** gs) except -1:
+1418: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1419: cdef size_t c_len
1420: cdef const char* c_buf
1421: cdef line_sender_table_name c_table_name
+1422: if _dataframe_arrow_get_cat_i32(&col.cursor, &c_len, &c_buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_i32((&__pyx_v_col->cursor), (&__pyx_v_c_len), (&__pyx_v_c_buf)); if (likely(__pyx_t_1)) { /* … */ goto __pyx_L3; }
+1423: if not line_sender_table_name_init(&c_table_name, c_len, c_buf, &err):
+1424: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1424, __pyx_L1_error)
+1425: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1425, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1425, __pyx_L1_error)
+1426: if not line_sender_buffer_table(ls_buf, c_table_name, &err):
+1427: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1427, __pyx_L1_error)
+1428: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1428, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1428, __pyx_L1_error)
1429: else:
+1430: _ensure_has_gil(gs)
/*else*/ {
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1430, __pyx_L1_error)
+1431: raise ValueError('Table name cannot be null')
__pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_ValueError, __pyx_tuple__24, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1431, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1431, __pyx_L1_error) } __pyx_L3:;
1432:
1433:
+1434: cdef void_int _dataframe_serialize_cell_symbol__str_pyobj(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_symbol__str_pyobj(struct line_sender_buffer *__pyx_v_ls_buf, struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; struct line_sender_utf8 __pyx_v_utf8; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_4); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_symbol__str_pyobj", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1435: line_sender_buffer* ls_buf,
1436: qdb_pystr_buf* b,
1437: col_t* col) except -1:
+1438: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1439: cdef bint valid = False
__pyx_v_valid = 0;
1440: cdef line_sender_utf8 utf8
+1441: _dataframe_cell_str_pyobj_to_utf8(b, &col.cursor, &valid, &utf8)
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_cell_str_pyobj_to_utf8(__pyx_v_b, (&__pyx_v_col->cursor), (&__pyx_v_valid), (&__pyx_v_utf8)); if (unlikely(__pyx_t_1 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1441, __pyx_L1_error)
+1442: if valid and not line_sender_buffer_symbol(ls_buf, col.name, utf8, &err):
if (__pyx_v_valid) { } else { __pyx_t_2 = __pyx_v_valid; goto __pyx_L4_bool_binop_done; } __pyx_t_3 = (!line_sender_buffer_symbol(__pyx_v_ls_buf, __pyx_v_col->name, __pyx_v_utf8, (&__pyx_v_err))); __pyx_t_2 = __pyx_t_3; __pyx_L4_bool_binop_done:; if (unlikely(__pyx_t_2)) { /* … */ }
+1443: raise c_err_to_py(err)
__pyx_t_4 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1443, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_Raise(__pyx_t_4, 0, 0, 0); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __PYX_ERR(1, 1443, __pyx_L1_error)
1444:
1445:
+1446: cdef void_int _dataframe_serialize_cell_symbol__str_utf8_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_symbol__str_utf8_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; struct line_sender_utf8 __pyx_v_utf8; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_symbol__str_utf8_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1447: line_sender_buffer* ls_buf,
1448: qdb_pystr_buf* b,
1449: col_t* col,
1450: PyThreadState** gs) except -1:
+1451: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1452: cdef line_sender_utf8 utf8
+1453: if _dataframe_arrow_str_utf8(&col.cursor, &utf8.len, &utf8.buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_str_utf8((&__pyx_v_col->cursor), (&__pyx_v_utf8.len), (&__pyx_v_utf8.buf)); if (__pyx_t_1) { /* … */ }
+1454: if not line_sender_buffer_symbol(ls_buf, col.name, utf8, &err):
__pyx_t_1 = (!line_sender_buffer_symbol(__pyx_v_ls_buf, __pyx_v_col->name, __pyx_v_utf8, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+1455: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1455, __pyx_L1_error)
+1456: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1456, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1456, __pyx_L1_error)
1457:
+1458: cdef void_int _dataframe_serialize_cell_symbol__str_lrg_utf8_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_symbol__str_lrg_utf8_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; struct line_sender_utf8 __pyx_v_utf8; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_symbol__str_lrg_utf8_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1459: line_sender_buffer* ls_buf,
1460: qdb_pystr_buf* b,
1461: col_t* col,
1462: PyThreadState** gs) except -1:
+1463: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1464: cdef line_sender_utf8 utf8
+1465: if _dataframe_arrow_str_utf8_lrg(&col.cursor, &utf8.len, &utf8.buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_str_utf8_lrg((&__pyx_v_col->cursor), (&__pyx_v_utf8.len), (&__pyx_v_utf8.buf)); if (__pyx_t_1) { /* … */ }
+1466: if not line_sender_buffer_symbol(ls_buf, col.name, utf8, &err):
+1467: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1467, __pyx_L1_error)
+1468: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1468, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1468, __pyx_L1_error)
1469:
1470:
+1471: cdef void_int _dataframe_serialize_cell_symbol__str_i8_cat(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_symbol__str_i8_cat(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; struct line_sender_utf8 __pyx_v_utf8; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_symbol__str_i8_cat", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1472: line_sender_buffer* ls_buf,
1473: qdb_pystr_buf* b,
1474: col_t* col,
1475: PyThreadState** gs) except -1:
+1476: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1477: cdef line_sender_utf8 utf8
+1478: if _dataframe_arrow_get_cat_i8(&col.cursor, &utf8.len, &utf8.buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_i8((&__pyx_v_col->cursor), (&__pyx_v_utf8.len), (&__pyx_v_utf8.buf)); if (__pyx_t_1) { /* … */ }
+1479: if not line_sender_buffer_symbol(ls_buf, col.name, utf8, &err):
+1480: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1480, __pyx_L1_error)
+1481: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1481, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1481, __pyx_L1_error)
1482:
1483:
+1484: cdef void_int _dataframe_serialize_cell_symbol__str_i16_cat(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_symbol__str_i16_cat(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; struct line_sender_utf8 __pyx_v_utf8; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_symbol__str_i16_cat", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1485: line_sender_buffer* ls_buf,
1486: qdb_pystr_buf* b,
1487: col_t* col,
1488: PyThreadState** gs) except -1:
+1489: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1490: cdef line_sender_utf8 utf8
+1491: if _dataframe_arrow_get_cat_i16(&col.cursor, &utf8.len, &utf8.buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_i16((&__pyx_v_col->cursor), (&__pyx_v_utf8.len), (&__pyx_v_utf8.buf)); if (__pyx_t_1) { /* … */ }
+1492: if not line_sender_buffer_symbol(ls_buf, col.name, utf8, &err):
+1493: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1493, __pyx_L1_error)
+1494: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1494, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1494, __pyx_L1_error)
1495:
1496:
+1497: cdef void_int _dataframe_serialize_cell_symbol__str_i32_cat(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_symbol__str_i32_cat(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; struct line_sender_utf8 __pyx_v_utf8; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_symbol__str_i32_cat", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1498: line_sender_buffer* ls_buf,
1499: qdb_pystr_buf* b,
1500: col_t* col,
1501: PyThreadState** gs) except -1:
+1502: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1503: cdef line_sender_utf8 utf8
+1504: if _dataframe_arrow_get_cat_i32(&col.cursor, &utf8.len, &utf8.buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_i32((&__pyx_v_col->cursor), (&__pyx_v_utf8.len), (&__pyx_v_utf8.buf)); if (__pyx_t_1) { /* … */ }
+1505: if not line_sender_buffer_symbol(ls_buf, col.name, utf8, &err):
+1506: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1506, __pyx_L1_error)
+1507: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1507, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1507, __pyx_L1_error)
1508:
1509:
+1510: cdef void_int _dataframe_serialize_cell_column_bool__bool_pyobj(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_bool__bool_pyobj(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { struct line_sender_error *__pyx_v_err; PyObject **__pyx_v_access; PyObject *__pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_XDECREF(__pyx_t_3); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_bool__bool_pyobj", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1511: line_sender_buffer* ls_buf,
1512: qdb_pystr_buf* b,
1513: col_t* col) except -1:
+1514: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1515: cdef PyObject** access = <PyObject**>col.cursor.chunk.buffers[1]
+1516: cdef PyObject* cell = access[col.cursor.offset]
+1517: if PyBool_Check(cell):
__pyx_t_1 = PyBool_Check(__pyx_v_cell);
goto __pyx_L3;
+1518: if not line_sender_buffer_column_bool(
__pyx_t_1 = (!line_sender_buffer_column_bool(__pyx_v_ls_buf, __pyx_v_col->name, (__pyx_v_cell == Py_True), (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
1519: ls_buf, col.name, cell == Py_True, &err):
+1520: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1520, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1520, __pyx_L1_error)
+1521: elif _dataframe_is_null_pyobj(cell):
+1522: raise ValueError('Cannot insert null values into a boolean column.')
__pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_ValueError, __pyx_tuple__25, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1522, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1522, __pyx_L1_error) /* … */ __pyx_tuple__25 = PyTuple_Pack(1, __pyx_kp_u_Cannot_insert_null_values_into_a); if (unlikely(!__pyx_tuple__25)) __PYX_ERR(1, 1522, __pyx_L1_error) __Pyx_GOTREF(__pyx_tuple__25); __Pyx_GIVEREF(__pyx_tuple__25);
1523: else:
+1524: raise ValueError(
/*else*/ { /* … */ __pyx_t_3 = __Pyx_PyObject_CallOneArg(__pyx_builtin_ValueError, __pyx_t_2); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 1524, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __Pyx_Raise(__pyx_t_3, 0, 0, 0); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __PYX_ERR(1, 1524, __pyx_L1_error) } __pyx_L3:;
+1525: 'Expected an object of type bool, got a ' +
__pyx_t_3 = __Pyx_PyUnicode_ConcatSafe(__pyx_kp_u_Expected_an_object_of_type_bool, __pyx_t_2); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 1525, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0;
+1526: _fqn(type(<object>cell)) + '.')
__pyx_t_2 = __pyx_f_7questdb_7ingress__fqn(((PyTypeObject*)((PyObject *)Py_TYPE(((PyObject *)__pyx_v_cell))))); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1526, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); /* … */ __pyx_t_2 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_3, __pyx_kp_u__5); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1526, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
1527:
1528:
+1529: cdef void_int _dataframe_serialize_cell_column_bool__bool_numpy(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_bool__bool_numpy(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; uint8_t *__pyx_v_access; uint8_t __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_bool__bool_numpy", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1530: line_sender_buffer* ls_buf,
1531: qdb_pystr_buf* b,
1532: col_t* col,
1533: PyThreadState** gs) except -1:
+1534: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1535: cdef uint8_t* access = <uint8_t*>col.cursor.chunk.buffers[1]
__pyx_v_access = ((uint8_t *)(__pyx_v_col->cursor.chunk->buffers[1]));
+1536: cdef uint8_t cell = access[col.cursor.offset]
+1537: if not line_sender_buffer_column_bool(ls_buf, col.name, not not cell, &err):
__pyx_t_1 = (!line_sender_buffer_column_bool(__pyx_v_ls_buf, __pyx_v_col->name, (!(!(__pyx_v_cell != 0))), (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+1538: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1538, __pyx_L1_error)
+1539: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1539, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1539, __pyx_L1_error)
1540:
1541:
+1542: cdef void_int _dataframe_serialize_cell_column_bool__bool_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_bool__bool_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; int __pyx_v_value; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_bool__bool_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1543: line_sender_buffer* ls_buf,
1544: qdb_pystr_buf* b,
1545: col_t* col,
1546: PyThreadState** gs) except -1:
+1547: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1548: cdef bint valid = _dataframe_arrow_is_valid(&col.cursor)
__pyx_v_valid = __pyx_f_7questdb_7ingress__dataframe_arrow_is_valid((&__pyx_v_col->cursor));
1549: cdef bint value
+1550: if valid:
if (likely(__pyx_v_valid)) { /* … */ goto __pyx_L3; }
+1551: value = _dataframe_arrow_get_bool(&col.cursor)
__pyx_v_value = __pyx_f_7questdb_7ingress__dataframe_arrow_get_bool((&__pyx_v_col->cursor));
+1552: if not line_sender_buffer_column_bool(ls_buf, col.name, value, &err):
__pyx_t_1 = (!line_sender_buffer_column_bool(__pyx_v_ls_buf, __pyx_v_col->name, __pyx_v_value, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+1553: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1553, __pyx_L1_error)
+1554: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1554, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1554, __pyx_L1_error)
1555: else:
+1556: _ensure_has_gil(gs)
/*else*/ {
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1556, __pyx_L1_error)
+1557: raise ValueError('Cannot insert null values into a boolean column.')
__pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_ValueError, __pyx_tuple__25, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1557, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1557, __pyx_L1_error) } __pyx_L3:;
1558:
1559:
+1560: cdef void_int _dataframe_serialize_cell_column_i64__int_pyobj(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__int_pyobj(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { struct line_sender_error *__pyx_v_err; PyObject **__pyx_v_access; PyObject *__pyx_v_cell; int64_t __pyx_v_value; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_3); __Pyx_XDECREF(__pyx_t_4); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__int_pyobj", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1561: line_sender_buffer* ls_buf,
1562: qdb_pystr_buf* b,
1563: col_t* col) except -1:
+1564: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1565: cdef PyObject** access = <PyObject**>col.cursor.chunk.buffers[1]
+1566: cdef PyObject* cell = access[col.cursor.offset]
1567: cdef int64_t value
+1568: if PyLong_CheckExact(cell):
__pyx_t_1 = PyLong_CheckExact(__pyx_v_cell);
if (__pyx_t_1) {
goto __pyx_L3;
+1569: value = PyLong_AsLongLong(cell)
__pyx_t_2 = PyLong_AsLongLong(__pyx_v_cell); if (unlikely(__pyx_t_2 == ((PY_LONG_LONG)-1LL) && PyErr_Occurred())) __PYX_ERR(1, 1569, __pyx_L1_error) __pyx_v_value = __pyx_t_2;
+1570: if not line_sender_buffer_column_i64(ls_buf, col.name, value, &err):
__pyx_t_1 = (!line_sender_buffer_column_i64(__pyx_v_ls_buf, __pyx_v_col->name, __pyx_v_value, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+1571: raise c_err_to_py(err)
__pyx_t_3 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 1571, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __Pyx_Raise(__pyx_t_3, 0, 0, 0); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __PYX_ERR(1, 1571, __pyx_L1_error)
+1572: elif _dataframe_is_null_pyobj(cell):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_is_null_pyobj(__pyx_v_cell); if (likely(__pyx_t_1)) { goto __pyx_L3; }
1573: pass
1574: else:
+1575: raise ValueError(
/*else*/ { /* … */ __pyx_t_4 = __Pyx_PyObject_CallOneArg(__pyx_builtin_ValueError, __pyx_t_3); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1575, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __Pyx_Raise(__pyx_t_4, 0, 0, 0); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __PYX_ERR(1, 1575, __pyx_L1_error) } __pyx_L3:;
+1576: 'Expected an object of type int, got an object of type ' +
__pyx_t_4 = __Pyx_PyUnicode_ConcatSafe(__pyx_kp_u_Expected_an_object_of_type_int_g, __pyx_t_3); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1576, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
+1577: _fqn(type(<object>cell)) + '.')
__pyx_t_3 = __pyx_f_7questdb_7ingress__fqn(((PyTypeObject*)((PyObject *)Py_TYPE(((PyObject *)__pyx_v_cell))))); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 1577, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); /* … */ __pyx_t_3 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_4, __pyx_kp_u__5); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 1577, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0;
1578:
1579:
+1580: cdef void_int _dataframe_serialize_cell_column_i64__u8_numpy(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u8_numpy(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; uint8_t *__pyx_v_access; uint8_t __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__u8_numpy", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1581: line_sender_buffer* ls_buf,
1582: qdb_pystr_buf* b,
1583: col_t* col,
1584: PyThreadState** gs) except -1:
+1585: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1586: cdef uint8_t* access = <uint8_t*>col.cursor.chunk.buffers[1]
+1587: cdef uint8_t cell = access[col.cursor.offset]
+1588: if not line_sender_buffer_column_i64(ls_buf, col.name, <int64_t>cell, &err):
__pyx_t_1 = (!line_sender_buffer_column_i64(__pyx_v_ls_buf, __pyx_v_col->name, ((int64_t)__pyx_v_cell), (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+1589: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1589, __pyx_L1_error)
+1590: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1590, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1590, __pyx_L1_error)
1591:
1592:
+1593: cdef void_int _dataframe_serialize_cell_column_i64__i8_numpy(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i8_numpy(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int8_t *__pyx_v_access; int8_t __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__i8_numpy", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1594: line_sender_buffer* ls_buf,
1595: qdb_pystr_buf* b,
1596: col_t* col,
1597: PyThreadState** gs) except -1:
+1598: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1599: cdef int8_t* access = <int8_t*>col.cursor.chunk.buffers[1]
__pyx_v_access = ((int8_t *)(__pyx_v_col->cursor.chunk->buffers[1]));
+1600: cdef int8_t cell = access[col.cursor.offset]
+1601: if not line_sender_buffer_column_i64(ls_buf, col.name, <int64_t>cell, &err):
+1602: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1602, __pyx_L1_error)
+1603: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1603, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1603, __pyx_L1_error)
1604:
1605:
+1606: cdef void_int _dataframe_serialize_cell_column_i64__u16_numpy(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u16_numpy(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; uint16_t *__pyx_v_access; uint16_t __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__u16_numpy", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1607: line_sender_buffer* ls_buf,
1608: qdb_pystr_buf* b,
1609: col_t* col,
1610: PyThreadState** gs) except -1:
+1611: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1612: cdef uint16_t* access = <uint16_t*>col.cursor.chunk.buffers[1]
__pyx_v_access = ((uint16_t *)(__pyx_v_col->cursor.chunk->buffers[1]));
+1613: cdef uint16_t cell = access[col.cursor.offset]
+1614: if not line_sender_buffer_column_i64(ls_buf, col.name, <int64_t>cell, &err):
+1615: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1615, __pyx_L1_error)
+1616: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1616, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1616, __pyx_L1_error)
1617:
1618:
+1619: cdef void_int _dataframe_serialize_cell_column_i64__i16_numpy(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i16_numpy(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int16_t *__pyx_v_access; int16_t __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__i16_numpy", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1620: line_sender_buffer* ls_buf,
1621: qdb_pystr_buf* b,
1622: col_t* col,
1623: PyThreadState** gs) except -1:
+1624: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1625: cdef int16_t* access = <int16_t*>col.cursor.chunk.buffers[1]
__pyx_v_access = ((int16_t *)(__pyx_v_col->cursor.chunk->buffers[1]));
+1626: cdef int16_t cell = access[col.cursor.offset]
+1627: if not line_sender_buffer_column_i64(ls_buf, col.name, <int64_t>cell, &err):
+1628: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1628, __pyx_L1_error)
+1629: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1629, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1629, __pyx_L1_error)
1630:
1631:
+1632: cdef void_int _dataframe_serialize_cell_column_i64__u32_numpy(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u32_numpy(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; uint32_t *__pyx_v_access; uint32_t __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__u32_numpy", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1633: line_sender_buffer* ls_buf,
1634: qdb_pystr_buf* b,
1635: col_t* col,
1636: PyThreadState** gs) except -1:
+1637: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1638: cdef uint32_t* access = <uint32_t*>col.cursor.chunk.buffers[1]
__pyx_v_access = ((uint32_t *)(__pyx_v_col->cursor.chunk->buffers[1]));
+1639: cdef uint32_t cell = access[col.cursor.offset]
+1640: if not line_sender_buffer_column_i64(ls_buf, col.name, <int64_t>cell, &err):
+1641: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1641, __pyx_L1_error)
+1642: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1642, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1642, __pyx_L1_error)
1643:
1644:
+1645: cdef void_int _dataframe_serialize_cell_column_i64__i32_numpy(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i32_numpy(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int32_t *__pyx_v_access; int32_t __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__i32_numpy", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1646: line_sender_buffer* ls_buf,
1647: qdb_pystr_buf* b,
1648: col_t* col,
1649: PyThreadState** gs) except -1:
+1650: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1651: cdef int32_t* access = <int32_t*>col.cursor.chunk.buffers[1]
__pyx_v_access = ((int32_t *)(__pyx_v_col->cursor.chunk->buffers[1]));
+1652: cdef int32_t cell = access[col.cursor.offset]
+1653: if not line_sender_buffer_column_i64(ls_buf, col.name, <int64_t>cell, &err):
+1654: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1654, __pyx_L1_error)
+1655: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1655, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1655, __pyx_L1_error)
1656:
1657:
+1658: cdef void_int _dataframe_serialize_cell_column_i64__u64_numpy(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u64_numpy(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; uint64_t *__pyx_v_access; uint64_t __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__u64_numpy", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1659: line_sender_buffer* ls_buf,
1660: qdb_pystr_buf* b,
1661: col_t* col,
1662: PyThreadState** gs) except -1:
+1663: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1664: cdef uint64_t* access = <uint64_t*>col.cursor.chunk.buffers[1]
__pyx_v_access = ((uint64_t *)(__pyx_v_col->cursor.chunk->buffers[1]));
+1665: cdef uint64_t cell = access[col.cursor.offset]
+1666: if cell > <uint64_t>INT64_MAX:
__pyx_t_1 = (__pyx_v_cell > ((uint64_t)INT64_MAX)); if (unlikely(__pyx_t_1)) { /* … */ }
+1667: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1667, __pyx_L1_error)
+1668: raise OverflowError('uint64 value too large for int64 column type.')
__pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_OverflowError, __pyx_tuple__26, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1668, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1668, __pyx_L1_error) /* … */ __pyx_tuple__26 = PyTuple_Pack(1, __pyx_kp_u_uint64_value_too_large_for_int64); if (unlikely(!__pyx_tuple__26)) __PYX_ERR(1, 1668, __pyx_L1_error) __Pyx_GOTREF(__pyx_tuple__26); __Pyx_GIVEREF(__pyx_tuple__26);
+1669: if not line_sender_buffer_column_i64(ls_buf, col.name, <int64_t>cell, &err):
+1670: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1670, __pyx_L1_error)
+1671: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1671, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1671, __pyx_L1_error)
1672:
1673:
+1674: cdef void_int _dataframe_serialize_cell_column_i64__i64_numpy(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i64_numpy(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int64_t *__pyx_v_access; int64_t __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__i64_numpy", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1675: line_sender_buffer* ls_buf,
1676: qdb_pystr_buf* b,
1677: col_t* col,
1678: PyThreadState** gs) except -1:
+1679: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1680: cdef int64_t* access = <int64_t*>col.cursor.chunk.buffers[1]
__pyx_v_access = ((int64_t *)(__pyx_v_col->cursor.chunk->buffers[1]));
+1681: cdef int64_t cell = access[col.cursor.offset]
+1682: if not line_sender_buffer_column_i64(ls_buf, col.name, cell, &err):
__pyx_t_1 = (!line_sender_buffer_column_i64(__pyx_v_ls_buf, __pyx_v_col->name, __pyx_v_cell, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+1683: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1683, __pyx_L1_error)
+1684: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1684, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1684, __pyx_L1_error)
1685:
1686:
+1687: cdef void_int _dataframe_serialize_cell_column_i64__u8_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u8_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; uint8_t *__pyx_v_access; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__u8_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1688: line_sender_buffer* ls_buf,
1689: qdb_pystr_buf* b,
1690: col_t* col,
1691: PyThreadState** gs) except -1:
+1692: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1693: cdef bint valid = _dataframe_arrow_is_valid(&col.cursor)
1694: cdef uint8_t* access
+1695: if valid:
if (__pyx_v_valid) { /* … */ }
+1696: access = <uint8_t*>col.cursor.chunk.buffers[1]
+1697: if not line_sender_buffer_column_i64(
__pyx_t_1 = (!line_sender_buffer_column_i64(__pyx_v_ls_buf, __pyx_v_col->name, ((int64_t)(__pyx_v_access[__pyx_v_col->cursor.offset])), (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
1698: ls_buf,
1699: col.name,
1700: <int64_t>access[col.cursor.offset],
1701: &err):
+1702: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1702, __pyx_L1_error)
+1703: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1703, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1703, __pyx_L1_error)
1704:
1705:
+1706: cdef void_int _dataframe_serialize_cell_column_i64__i8_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i8_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; int8_t *__pyx_v_access; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__i8_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1707: line_sender_buffer* ls_buf,
1708: qdb_pystr_buf* b,
1709: col_t* col,
1710: PyThreadState** gs) except -1:
+1711: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1712: cdef bint valid = _dataframe_arrow_is_valid(&col.cursor)
1713: cdef int8_t* access
+1714: if valid:
+1715: access = <int8_t*>col.cursor.chunk.buffers[1]
+1716: if not line_sender_buffer_column_i64(
1717: ls_buf,
1718: col.name,
1719: <int64_t>access[col.cursor.offset],
1720: &err):
+1721: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1721, __pyx_L1_error)
+1722: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1722, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1722, __pyx_L1_error)
1723:
1724:
+1725: cdef void_int _dataframe_serialize_cell_column_i64__u16_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u16_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; uint16_t *__pyx_v_access; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__u16_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1726: line_sender_buffer* ls_buf,
1727: qdb_pystr_buf* b,
1728: col_t* col,
1729: PyThreadState** gs) except -1:
+1730: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1731: cdef bint valid = _dataframe_arrow_is_valid(&col.cursor)
1732: cdef uint16_t* access
+1733: if valid:
+1734: access = <uint16_t*>col.cursor.chunk.buffers[1]
+1735: if not line_sender_buffer_column_i64(
1736: ls_buf,
1737: col.name,
1738: <int64_t>access[col.cursor.offset],
1739: &err):
+1740: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1740, __pyx_L1_error)
+1741: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1741, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1741, __pyx_L1_error)
1742:
1743:
+1744: cdef void_int _dataframe_serialize_cell_column_i64__i16_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i16_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; int16_t *__pyx_v_access; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__i16_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1745: line_sender_buffer* ls_buf,
1746: qdb_pystr_buf* b,
1747: col_t* col,
1748: PyThreadState** gs) except -1:
+1749: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1750: cdef bint valid = _dataframe_arrow_is_valid(&col.cursor)
1751: cdef int16_t* access
+1752: if valid:
+1753: access = <int16_t*>col.cursor.chunk.buffers[1]
+1754: if not line_sender_buffer_column_i64(
1755: ls_buf,
1756: col.name,
1757: <int64_t>access[col.cursor.offset],
1758: &err):
+1759: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1759, __pyx_L1_error)
+1760: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1760, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1760, __pyx_L1_error)
1761:
1762:
+1763: cdef void_int _dataframe_serialize_cell_column_i64__u32_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u32_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; uint32_t *__pyx_v_access; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__u32_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1764: line_sender_buffer* ls_buf,
1765: qdb_pystr_buf* b,
1766: col_t* col,
1767: PyThreadState** gs) except -1:
+1768: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1769: cdef bint valid = _dataframe_arrow_is_valid(&col.cursor)
1770: cdef uint32_t* access
+1771: if valid:
+1772: access = <uint32_t*>col.cursor.chunk.buffers[1]
+1773: if not line_sender_buffer_column_i64(
1774: ls_buf,
1775: col.name,
1776: <int64_t>access[col.cursor.offset],
1777: &err):
+1778: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1778, __pyx_L1_error)
+1779: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1779, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1779, __pyx_L1_error)
1780:
1781:
+1782: cdef void_int _dataframe_serialize_cell_column_i64__i32_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i32_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; int32_t *__pyx_v_access; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__i32_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1783: line_sender_buffer* ls_buf,
1784: qdb_pystr_buf* b,
1785: col_t* col,
1786: PyThreadState** gs) except -1:
+1787: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1788: cdef bint valid = _dataframe_arrow_is_valid(&col.cursor)
1789: cdef int32_t* access
+1790: if valid:
+1791: access = <int32_t*>col.cursor.chunk.buffers[1]
+1792: if not line_sender_buffer_column_i64(
1793: ls_buf,
1794: col.name,
1795: <int64_t>access[col.cursor.offset],
1796: &err):
+1797: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1797, __pyx_L1_error)
+1798: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1798, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1798, __pyx_L1_error)
1799:
1800:
+1801: cdef void_int _dataframe_serialize_cell_column_i64__u64_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u64_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; uint64_t *__pyx_v_access; uint64_t __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__u64_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1802: line_sender_buffer* ls_buf,
1803: qdb_pystr_buf* b,
1804: col_t* col,
1805: PyThreadState** gs) except -1:
+1806: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1807: cdef bint valid = _dataframe_arrow_is_valid(&col.cursor)
1808: cdef uint64_t* access
1809: cdef uint64_t cell
+1810: if valid:
+1811: access = <uint64_t*>col.cursor.chunk.buffers[1]
+1812: cell = access[col.cursor.offset]
__pyx_v_cell = (__pyx_v_access[__pyx_v_col->cursor.offset]);
+1813: if cell > <uint64_t>INT64_MAX:
+1814: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1814, __pyx_L1_error)
+1815: raise OverflowError('uint64 value too large for int64 column type.')
__pyx_t_2 = __Pyx_PyObject_Call(__pyx_builtin_OverflowError, __pyx_tuple__26, NULL); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1815, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1815, __pyx_L1_error)
+1816: if not line_sender_buffer_column_i64(
1817: ls_buf,
1818: col.name,
1819: <int64_t>cell,
1820: &err):
+1821: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1821, __pyx_L1_error)
+1822: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1822, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1822, __pyx_L1_error)
1823:
1824:
+1825: cdef void_int _dataframe_serialize_cell_column_i64__i64_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i64_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; int64_t *__pyx_v_access; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_i64__i64_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1826: line_sender_buffer* ls_buf,
1827: qdb_pystr_buf* b,
1828: col_t* col,
1829: PyThreadState** gs) except -1:
+1830: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1831: cdef bint valid = _dataframe_arrow_is_valid(&col.cursor)
1832: cdef int64_t* access
+1833: if valid:
+1834: access = <int64_t*>col.cursor.chunk.buffers[1]
+1835: if not line_sender_buffer_column_i64(
__pyx_t_1 = (!line_sender_buffer_column_i64(__pyx_v_ls_buf, __pyx_v_col->name, (__pyx_v_access[__pyx_v_col->cursor.offset]), (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
1836: ls_buf,
1837: col.name,
1838: access[col.cursor.offset],
1839: &err):
+1840: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1840, __pyx_L1_error)
+1841: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1841, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1841, __pyx_L1_error)
1842:
1843:
+1844: cdef void_int _dataframe_serialize_cell_column_f64__float_pyobj(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_f64__float_pyobj(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { struct line_sender_error *__pyx_v_err; PyObject **__pyx_v_access; PyObject *__pyx_v_cell; double __pyx_v_value; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_XDECREF(__pyx_t_3); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_f64__float_pyobj", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1845: line_sender_buffer* ls_buf,
1846: qdb_pystr_buf* b,
1847: col_t* col) except -1:
+1848: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1849: cdef PyObject** access = <PyObject**>col.cursor.chunk.buffers[1]
__pyx_v_access = ((PyObject **)(__pyx_v_col->cursor.chunk->buffers[1]));
+1850: cdef PyObject* cell = access[col.cursor.offset]
1851: cdef double value
+1852: if PyFloat_CheckExact(cell):
__pyx_t_1 = PyFloat_CheckExact(__pyx_v_cell);
if (__pyx_t_1) {
goto __pyx_L3;
+1853: value = PyFloat_AS_DOUBLE(cell)
__pyx_v_value = PyFloat_AS_DOUBLE(__pyx_v_cell);
+1854: if not line_sender_buffer_column_f64(ls_buf, col.name, value, &err):
__pyx_t_1 = (!line_sender_buffer_column_f64(__pyx_v_ls_buf, __pyx_v_col->name, __pyx_v_value, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+1855: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1855, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1855, __pyx_L1_error)
+1856: elif _dataframe_is_null_pyobj(cell):
1857: pass
1858: else:
+1859: raise ValueError(
/*else*/ { /* … */ __pyx_t_3 = __Pyx_PyObject_CallOneArg(__pyx_builtin_ValueError, __pyx_t_2); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 1859, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __Pyx_Raise(__pyx_t_3, 0, 0, 0); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __PYX_ERR(1, 1859, __pyx_L1_error) } __pyx_L3:;
+1860: 'Expected an object of type float, got an object of type ' +
__pyx_t_3 = __Pyx_PyUnicode_ConcatSafe(__pyx_kp_u_Expected_an_object_of_type_float, __pyx_t_2); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 1860, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0;
+1861: _fqn(type(<object>cell)) + '.')
__pyx_t_2 = __pyx_f_7questdb_7ingress__fqn(((PyTypeObject*)((PyObject *)Py_TYPE(((PyObject *)__pyx_v_cell))))); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1861, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); /* … */ __pyx_t_2 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_3, __pyx_kp_u__5); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1861, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0;
1862:
1863:
+1864: cdef void_int _dataframe_serialize_cell_column_f64__f32_numpy(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_f64__f32_numpy(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; float *__pyx_v_access; float __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_f64__f32_numpy", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1865: line_sender_buffer* ls_buf,
1866: qdb_pystr_buf* b,
1867: col_t* col,
1868: PyThreadState** gs) except -1:
+1869: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1870: # Note: This is the C `float` type, not the Python `float` type.
+1871: cdef float* access = <float*>col.cursor.chunk.buffers[1]
__pyx_v_access = ((float *)(__pyx_v_col->cursor.chunk->buffers[1]));
+1872: cdef float cell = access[col.cursor.offset]
+1873: if not line_sender_buffer_column_f64(ls_buf, col.name, <double>cell, &err):
__pyx_t_1 = (!line_sender_buffer_column_f64(__pyx_v_ls_buf, __pyx_v_col->name, ((double)__pyx_v_cell), (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+1874: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1874, __pyx_L1_error)
+1875: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1875, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1875, __pyx_L1_error)
1876:
1877:
+1878: cdef void_int _dataframe_serialize_cell_column_f64__f64_numpy(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_f64__f64_numpy(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; double *__pyx_v_access; double __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_f64__f64_numpy", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1879: line_sender_buffer* ls_buf,
1880: qdb_pystr_buf* b,
1881: col_t* col,
1882: PyThreadState** gs) except -1:
+1883: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1884: cdef double* access = <double*>col.cursor.chunk.buffers[1]
__pyx_v_access = ((double *)(__pyx_v_col->cursor.chunk->buffers[1]));
+1885: cdef double cell = access[col.cursor.offset]
+1886: if not line_sender_buffer_column_f64(ls_buf, col.name, cell, &err):
__pyx_t_1 = (!line_sender_buffer_column_f64(__pyx_v_ls_buf, __pyx_v_col->name, __pyx_v_cell, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+1887: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1887, __pyx_L1_error)
+1888: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1888, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1888, __pyx_L1_error)
1889:
1890:
+1891: cdef void_int _dataframe_serialize_cell_column_f64__f32_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_f64__f32_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; float *__pyx_v_access; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_f64__f32_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1892: line_sender_buffer* ls_buf,
1893: qdb_pystr_buf* b,
1894: col_t* col,
1895: PyThreadState** gs) except -1:
+1896: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1897: cdef bint valid = _dataframe_arrow_is_valid(&col.cursor)
1898: cdef float* access
+1899: if valid:
+1900: access = <float*>col.cursor.chunk.buffers[1]
+1901: if not line_sender_buffer_column_f64(
__pyx_t_1 = (!line_sender_buffer_column_f64(__pyx_v_ls_buf, __pyx_v_col->name, ((double)(__pyx_v_access[__pyx_v_col->cursor.offset])), (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
1902: ls_buf,
1903: col.name,
1904: <double>access[col.cursor.offset],
1905: &err):
+1906: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1906, __pyx_L1_error)
+1907: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1907, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1907, __pyx_L1_error)
1908:
1909:
+1910: cdef void_int _dataframe_serialize_cell_column_f64__f64_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_f64__f64_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; double *__pyx_v_access; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_f64__f64_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1911: line_sender_buffer* ls_buf,
1912: qdb_pystr_buf* b,
1913: col_t* col,
1914: PyThreadState** gs) except -1:
+1915: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1916: cdef bint valid = _dataframe_arrow_is_valid(&col.cursor)
1917: cdef double* access
+1918: if valid:
+1919: access = <double*>col.cursor.chunk.buffers[1]
+1920: if not line_sender_buffer_column_f64(
__pyx_t_1 = (!line_sender_buffer_column_f64(__pyx_v_ls_buf, __pyx_v_col->name, (__pyx_v_access[__pyx_v_col->cursor.offset]), (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
1921: ls_buf,
1922: col.name,
1923: access[col.cursor.offset],
1924: &err):
+1925: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1925, __pyx_L1_error)
+1926: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1926, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1926, __pyx_L1_error)
1927:
1928:
+1929: cdef void_int _dataframe_serialize_cell_column_str__str_pyobj(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_str__str_pyobj(struct line_sender_buffer *__pyx_v_ls_buf, struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; struct line_sender_utf8 __pyx_v_utf8; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_4); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_str__str_pyobj", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1930: line_sender_buffer* ls_buf,
1931: qdb_pystr_buf* b,
1932: col_t* col) except -1:
+1933: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+1934: cdef bint valid = False
__pyx_v_valid = 0;
1935: cdef line_sender_utf8 utf8
+1936: _dataframe_cell_str_pyobj_to_utf8(b, &col.cursor, &valid, &utf8)
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_cell_str_pyobj_to_utf8(__pyx_v_b, (&__pyx_v_col->cursor), (&__pyx_v_valid), (&__pyx_v_utf8)); if (unlikely(__pyx_t_1 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 1936, __pyx_L1_error)
+1937: if valid and not line_sender_buffer_column_str(
if (__pyx_v_valid) { } else { __pyx_t_2 = __pyx_v_valid; goto __pyx_L4_bool_binop_done; } /* … */ __pyx_t_3 = (!line_sender_buffer_column_str(__pyx_v_ls_buf, __pyx_v_col->name, __pyx_v_utf8, (&__pyx_v_err))); __pyx_t_2 = __pyx_t_3; __pyx_L4_bool_binop_done:; /* … */ if (unlikely(__pyx_t_2)) { /* … */ }
1938: ls_buf, col.name, utf8, &err):
+1939: raise c_err_to_py(err)
__pyx_t_4 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 1939, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_Raise(__pyx_t_4, 0, 0, 0); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __PYX_ERR(1, 1939, __pyx_L1_error)
1940:
1941:
+1942: cdef void_int _dataframe_serialize_cell_column_str__str_utf8_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_str__str_utf8_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; struct line_sender_utf8 __pyx_v_utf8; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_str__str_utf8_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1943: line_sender_buffer* ls_buf,
1944: qdb_pystr_buf* b,
1945: col_t* col,
1946: PyThreadState** gs) except -1:
+1947: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1948: cdef line_sender_utf8 utf8
+1949: if _dataframe_arrow_str_utf8(&col.cursor, &utf8.len, &utf8.buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_str_utf8((&__pyx_v_col->cursor), (&__pyx_v_utf8.len), (&__pyx_v_utf8.buf)); if (__pyx_t_1) { /* … */ }
+1950: if not line_sender_buffer_column_str(ls_buf, col.name, utf8, &err):
__pyx_t_1 = (!line_sender_buffer_column_str(__pyx_v_ls_buf, __pyx_v_col->name, __pyx_v_utf8, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+1951: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1951, __pyx_L1_error)
+1952: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1952, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1952, __pyx_L1_error)
1953:
+1954: cdef void_int _dataframe_serialize_cell_column_str__str_lrg_utf8_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_str__str_lrg_utf8_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; struct line_sender_utf8 __pyx_v_utf8; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_str__str_lrg_utf8_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1955: line_sender_buffer* ls_buf,
1956: qdb_pystr_buf* b,
1957: col_t* col,
1958: PyThreadState** gs) except -1:
+1959: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1960: cdef line_sender_utf8 utf8
+1961: if _dataframe_arrow_str_utf8_lrg(&col.cursor, &utf8.len, &utf8.buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_str_utf8_lrg((&__pyx_v_col->cursor), (&__pyx_v_utf8.len), (&__pyx_v_utf8.buf)); if (__pyx_t_1) { /* … */ }
+1962: if not line_sender_buffer_column_str(ls_buf, col.name, utf8, &err):
+1963: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1963, __pyx_L1_error)
+1964: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1964, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1964, __pyx_L1_error)
1965:
1966:
+1967: cdef void_int _dataframe_serialize_cell_column_str__str_i8_cat(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_str__str_i8_cat(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; struct line_sender_utf8 __pyx_v_utf8; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_str__str_i8_cat", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1968: line_sender_buffer* ls_buf,
1969: qdb_pystr_buf* b,
1970: col_t* col,
1971: PyThreadState** gs) except -1:
+1972: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1973: cdef line_sender_utf8 utf8
+1974: if _dataframe_arrow_get_cat_i8(&col.cursor, &utf8.len, &utf8.buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_i8((&__pyx_v_col->cursor), (&__pyx_v_utf8.len), (&__pyx_v_utf8.buf)); if (__pyx_t_1) { /* … */ }
+1975: if not line_sender_buffer_column_str(ls_buf, col.name, utf8, &err):
+1976: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1976, __pyx_L1_error)
+1977: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1977, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1977, __pyx_L1_error)
1978:
1979:
+1980: cdef void_int _dataframe_serialize_cell_column_str__str_i16_cat(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_str__str_i16_cat(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; struct line_sender_utf8 __pyx_v_utf8; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_str__str_i16_cat", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1981: line_sender_buffer* ls_buf,
1982: qdb_pystr_buf* b,
1983: col_t* col,
1984: PyThreadState** gs) except -1:
+1985: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1986: cdef line_sender_utf8 utf8
+1987: if _dataframe_arrow_get_cat_i16(&col.cursor, &utf8.len, &utf8.buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_i16((&__pyx_v_col->cursor), (&__pyx_v_utf8.len), (&__pyx_v_utf8.buf)); if (__pyx_t_1) { /* … */ }
+1988: if not line_sender_buffer_column_str(ls_buf, col.name, utf8, &err):
+1989: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 1989, __pyx_L1_error)
+1990: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 1990, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 1990, __pyx_L1_error)
1991:
1992:
+1993: cdef void_int _dataframe_serialize_cell_column_str__str_i32_cat(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_str__str_i32_cat(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; struct line_sender_utf8 __pyx_v_utf8; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_str__str_i32_cat", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
1994: line_sender_buffer* ls_buf,
1995: qdb_pystr_buf* b,
1996: col_t* col,
1997: PyThreadState** gs) except -1:
+1998: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
1999: cdef line_sender_utf8 utf8
+2000: if _dataframe_arrow_get_cat_i32(&col.cursor, &utf8.len, &utf8.buf):
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_arrow_get_cat_i32((&__pyx_v_col->cursor), (&__pyx_v_utf8.len), (&__pyx_v_utf8.buf)); if (__pyx_t_1) { /* … */ }
+2001: if not line_sender_buffer_column_str(ls_buf, col.name, utf8, &err):
+2002: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2002, __pyx_L1_error)
+2003: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 2003, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 2003, __pyx_L1_error)
2004:
2005:
+2006: cdef void_int _dataframe_serialize_cell_column_ts__dt64ns_numpy(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_ts__dt64ns_numpy(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int64_t *__pyx_v_access; int64_t __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_ts__dt64ns_numpy", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
2007: line_sender_buffer* ls_buf,
2008: qdb_pystr_buf* b,
2009: col_t* col,
2010: PyThreadState** gs) except -1:
+2011: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+2012: cdef int64_t* access = <int64_t*>col.cursor.chunk.buffers[1]
+2013: cdef int64_t cell = access[col.cursor.offset]
+2014: if cell != _NAT:
__pyx_t_1 = (__pyx_v_cell != __pyx_v_7questdb_7ingress__NAT); if (__pyx_t_1) { /* … */ }
+2015: if not line_sender_buffer_column_ts_nanos(ls_buf, col.name, cell, &err):
__pyx_t_1 = (!line_sender_buffer_column_ts_nanos(__pyx_v_ls_buf, __pyx_v_col->name, __pyx_v_cell, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+2016: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2016, __pyx_L1_error)
+2017: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 2017, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 2017, __pyx_L1_error)
2018:
2019:
+2020: cdef void_int _dataframe_serialize_cell_column_ts__dt64ns_tz_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_ts__dt64ns_tz_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; int64_t __pyx_v_cell; int64_t *__pyx_v_access; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_column_ts__dt64ns_tz_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
2021: line_sender_buffer* ls_buf,
2022: qdb_pystr_buf* b,
2023: col_t* col,
2024: PyThreadState** gs) except -1:
+2025: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+2026: cdef bint valid = _dataframe_arrow_is_valid(&col.cursor)
2027: cdef int64_t cell
2028: cdef int64_t* access
+2029: if valid:
+2030: access = <int64_t*>col.cursor.chunk.buffers[1]
+2031: cell = access[col.cursor.offset]
+2032: if not line_sender_buffer_column_ts_nanos(ls_buf, col.name, cell, &err):
+2033: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2033, __pyx_L1_error)
+2034: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 2034, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 2034, __pyx_L1_error)
2035:
2036:
+2037: cdef void_int _dataframe_serialize_cell_at_dt64ns_numpy(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_at_dt64ns_numpy(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int64_t *__pyx_v_access; int64_t __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_at_dt64ns_numpy", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
2038: line_sender_buffer* ls_buf,
2039: qdb_pystr_buf* b,
2040: col_t* col,
2041: PyThreadState** gs) except -1:
+2042: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+2043: cdef int64_t* access = <int64_t*>col.cursor.chunk.buffers[1]
+2044: cdef int64_t cell = access[col.cursor.offset]
+2045: if cell == _NAT:
__pyx_t_1 = (__pyx_v_cell == __pyx_v_7questdb_7ingress__NAT); if (__pyx_t_1) { /* … */ goto __pyx_L3; }
+2046: if not line_sender_buffer_at_now(ls_buf, &err):
__pyx_t_1 = (!line_sender_buffer_at_now(__pyx_v_ls_buf, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ }
+2047: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2047, __pyx_L1_error)
+2048: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 2048, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 2048, __pyx_L1_error)
2049: else:
2050: # Note: ls_buf will validate against negative numbers.
+2051: if not line_sender_buffer_at_nanos(ls_buf, cell, &err):
/*else*/ { __pyx_t_1 = (!line_sender_buffer_at_nanos(__pyx_v_ls_buf, __pyx_v_cell, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ } } __pyx_L3:;
+2052: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2052, __pyx_L1_error)
+2053: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 2053, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 2053, __pyx_L1_error)
2054:
2055:
+2056: cdef void_int _dataframe_serialize_cell_at_dt64ns_tz_arrow(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell_at_dt64ns_tz_arrow(struct line_sender_buffer *__pyx_v_ls_buf, CYTHON_UNUSED struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_err; int __pyx_v_valid; int64_t *__pyx_v_access; int64_t __pyx_v_cell; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_2); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell_at_dt64ns_tz_arrow", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
2057: line_sender_buffer* ls_buf,
2058: qdb_pystr_buf* b,
2059: col_t* col,
2060: PyThreadState** gs) except -1:
+2061: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
+2062: cdef bint valid = _dataframe_arrow_is_valid(&col.cursor)
__pyx_v_valid = __pyx_f_7questdb_7ingress__dataframe_arrow_is_valid((&__pyx_v_col->cursor));
2063: cdef int64_t* access
2064: cdef int64_t cell
+2065: if valid:
if (__pyx_v_valid) { /* … */ goto __pyx_L3; }
+2066: access = <int64_t*>col.cursor.chunk.buffers[1]
+2067: cell = access[col.cursor.offset]
2068: # Note: ls_buf will validate against negative numbers.
+2069: if not line_sender_buffer_at_nanos(ls_buf, cell, &err):
+2070: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2070, __pyx_L1_error)
+2071: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 2071, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 2071, __pyx_L1_error)
2072: else:
+2073: if not line_sender_buffer_at_now(ls_buf, &err):
/*else*/ { __pyx_t_1 = (!line_sender_buffer_at_now(__pyx_v_ls_buf, (&__pyx_v_err))); if (unlikely(__pyx_t_1)) { /* … */ } } __pyx_L3:;
+2074: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2074, __pyx_L1_error)
+2075: raise c_err_to_py(err)
__pyx_t_2 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_2)) __PYX_ERR(1, 2075, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_2); __Pyx_Raise(__pyx_t_2, 0, 0, 0); __Pyx_DECREF(__pyx_t_2); __pyx_t_2 = 0; __PYX_ERR(1, 2075, __pyx_L1_error)
2076:
2077:
+2078: cdef void_int _dataframe_serialize_cell(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_serialize_cell(struct line_sender_buffer *__pyx_v_ls_buf, struct qdb_pystr_buf *__pyx_v_b, struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col, PyThreadState **__pyx_v_gs) { enum __pyx_t_7questdb_7ingress_col_dispatch_code_t __pyx_v_dc; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_3); __Pyx_XDECREF(__pyx_t_4); __Pyx_AddTraceback("questdb.ingress._dataframe_serialize_cell", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
2079: line_sender_buffer* ls_buf,
2080: qdb_pystr_buf* b,
2081: col_t* col,
2082: PyThreadState** gs) except -1:
+2083: cdef col_dispatch_code_t dc = col.dispatch_code
__pyx_t_1 = __pyx_v_col->dispatch_code; __pyx_v_dc = __pyx_t_1;
2084: # Note!: Code below will generate a `switch` statement.
2085: # Ensure this happens! Don't break the `dc == ...` pattern.
+2086: if dc == col_dispatch_code_t.col_dispatch_code_skip_nulls:
switch (__pyx_v_dc) { case __pyx_e_7questdb_7ingress_col_dispatch_code_skip_nulls: break; case __pyx_e_7questdb_7ingress_col_dispatch_code_table__str_pyobj:
2087: pass # We skip a null column. Nothing to do.
+2088: elif dc == col_dispatch_code_t.col_dispatch_code_table__str_pyobj:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_table__str_utf8_arrow:
+2089: _dataframe_serialize_cell_table__str_pyobj(ls_buf, b, col)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_table__str_pyobj(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2089, __pyx_L1_error)
+2090: elif dc == col_dispatch_code_t.col_dispatch_code_table__str_utf8_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_table__str_lrg_utf8_arrow:
+2091: _dataframe_serialize_cell_table__str_utf8_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_table__str_utf8_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2091, __pyx_L1_error)
+2092: elif dc == col_dispatch_code_t.col_dispatch_code_table__str_lrg_utf8_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_table__str_i8_cat:
+2093: _dataframe_serialize_cell_table__str_lrg_utf8_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_table__str_lrg_utf8_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2093, __pyx_L1_error)
+2094: elif dc == col_dispatch_code_t.col_dispatch_code_table__str_i8_cat:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_table__str_i16_cat:
+2095: _dataframe_serialize_cell_table__str_i8_cat(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_table__str_i8_cat(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2095, __pyx_L1_error)
+2096: elif dc == col_dispatch_code_t.col_dispatch_code_table__str_i16_cat:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_table__str_i32_cat:
+2097: _dataframe_serialize_cell_table__str_i16_cat(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_table__str_i16_cat(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2097, __pyx_L1_error)
+2098: elif dc == col_dispatch_code_t.col_dispatch_code_table__str_i32_cat:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_symbol__str_pyobj:
+2099: _dataframe_serialize_cell_table__str_i32_cat(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_table__str_i32_cat(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2099, __pyx_L1_error)
+2100: elif dc == col_dispatch_code_t.col_dispatch_code_symbol__str_pyobj:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_symbol__str_utf8_arrow:
+2101: _dataframe_serialize_cell_symbol__str_pyobj(ls_buf, b, col)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_symbol__str_pyobj(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2101, __pyx_L1_error)
+2102: elif dc == col_dispatch_code_t.col_dispatch_code_symbol__str_utf8_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_symbol__str_lrg_utf8_arrow:
+2103: _dataframe_serialize_cell_symbol__str_utf8_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_symbol__str_utf8_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2103, __pyx_L1_error)
+2104: elif dc == col_dispatch_code_t.col_dispatch_code_symbol__str_lrg_utf8_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_symbol__str_i8_cat:
+2105: _dataframe_serialize_cell_symbol__str_lrg_utf8_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_symbol__str_lrg_utf8_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2105, __pyx_L1_error)
+2106: elif dc == col_dispatch_code_t.col_dispatch_code_symbol__str_i8_cat:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_symbol__str_i16_cat:
+2107: _dataframe_serialize_cell_symbol__str_i8_cat(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_symbol__str_i8_cat(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2107, __pyx_L1_error)
+2108: elif dc == col_dispatch_code_t.col_dispatch_code_symbol__str_i16_cat:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_symbol__str_i32_cat:
+2109: _dataframe_serialize_cell_symbol__str_i16_cat(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_symbol__str_i16_cat(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2109, __pyx_L1_error)
+2110: elif dc == col_dispatch_code_t.col_dispatch_code_symbol__str_i32_cat:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_bool__bool_pyobj:
+2111: _dataframe_serialize_cell_symbol__str_i32_cat(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_symbol__str_i32_cat(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2111, __pyx_L1_error)
+2112: elif dc == col_dispatch_code_t.col_dispatch_code_column_bool__bool_pyobj:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_bool__bool_numpy:
+2113: _dataframe_serialize_cell_column_bool__bool_pyobj(ls_buf, b, col)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_bool__bool_pyobj(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2113, __pyx_L1_error)
+2114: elif dc == col_dispatch_code_t.col_dispatch_code_column_bool__bool_numpy:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_bool__bool_arrow:
+2115: _dataframe_serialize_cell_column_bool__bool_numpy(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_bool__bool_numpy(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2115, __pyx_L1_error)
+2116: elif dc == col_dispatch_code_t.col_dispatch_code_column_bool__bool_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__int_pyobj:
+2117: _dataframe_serialize_cell_column_bool__bool_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_bool__bool_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2117, __pyx_L1_error)
+2118: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__int_pyobj:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u8_numpy:
+2119: _dataframe_serialize_cell_column_i64__int_pyobj(ls_buf, b, col)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__int_pyobj(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2119, __pyx_L1_error)
+2120: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__u8_numpy:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i8_numpy:
+2121: _dataframe_serialize_cell_column_i64__u8_numpy(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u8_numpy(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2121, __pyx_L1_error)
+2122: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__i8_numpy:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u16_numpy:
+2123: _dataframe_serialize_cell_column_i64__i8_numpy(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i8_numpy(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2123, __pyx_L1_error)
+2124: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__u16_numpy:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i16_numpy:
+2125: _dataframe_serialize_cell_column_i64__u16_numpy(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u16_numpy(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2125, __pyx_L1_error)
+2126: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__i16_numpy:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u32_numpy:
+2127: _dataframe_serialize_cell_column_i64__i16_numpy(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i16_numpy(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2127, __pyx_L1_error)
+2128: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__u32_numpy:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i32_numpy:
+2129: _dataframe_serialize_cell_column_i64__u32_numpy(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u32_numpy(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2129, __pyx_L1_error)
+2130: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__i32_numpy:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u64_numpy:
+2131: _dataframe_serialize_cell_column_i64__i32_numpy(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i32_numpy(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2131, __pyx_L1_error)
+2132: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__u64_numpy:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i64_numpy:
+2133: _dataframe_serialize_cell_column_i64__u64_numpy(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u64_numpy(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2133, __pyx_L1_error)
+2134: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__i64_numpy:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u8_arrow:
+2135: _dataframe_serialize_cell_column_i64__i64_numpy(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i64_numpy(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2135, __pyx_L1_error)
+2136: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__u8_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i8_arrow:
+2137: _dataframe_serialize_cell_column_i64__u8_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u8_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2137, __pyx_L1_error)
+2138: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__i8_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u16_arrow:
+2139: _dataframe_serialize_cell_column_i64__i8_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i8_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2139, __pyx_L1_error)
+2140: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__u16_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i16_arrow:
+2141: _dataframe_serialize_cell_column_i64__u16_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u16_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2141, __pyx_L1_error)
+2142: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__i16_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u32_arrow:
+2143: _dataframe_serialize_cell_column_i64__i16_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i16_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2143, __pyx_L1_error)
+2144: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__u32_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i32_arrow:
+2145: _dataframe_serialize_cell_column_i64__u32_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u32_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2145, __pyx_L1_error)
+2146: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__i32_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__u64_arrow:
+2147: _dataframe_serialize_cell_column_i64__i32_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i32_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2147, __pyx_L1_error)
+2148: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__u64_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_i64__i64_arrow:
+2149: _dataframe_serialize_cell_column_i64__u64_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__u64_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2149, __pyx_L1_error)
+2150: elif dc == col_dispatch_code_t.col_dispatch_code_column_i64__i64_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_f64__float_pyobj:
+2151: _dataframe_serialize_cell_column_i64__i64_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_i64__i64_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2151, __pyx_L1_error)
+2152: elif dc == col_dispatch_code_t.col_dispatch_code_column_f64__float_pyobj:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_f64__f32_numpy:
+2153: _dataframe_serialize_cell_column_f64__float_pyobj(ls_buf, b, col)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_f64__float_pyobj(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2153, __pyx_L1_error)
+2154: elif dc == col_dispatch_code_t.col_dispatch_code_column_f64__f32_numpy:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_f64__f64_numpy:
+2155: _dataframe_serialize_cell_column_f64__f32_numpy(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_f64__f32_numpy(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2155, __pyx_L1_error)
+2156: elif dc == col_dispatch_code_t.col_dispatch_code_column_f64__f64_numpy:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_f64__f32_arrow:
+2157: _dataframe_serialize_cell_column_f64__f64_numpy(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_f64__f64_numpy(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2157, __pyx_L1_error)
+2158: elif dc == col_dispatch_code_t.col_dispatch_code_column_f64__f32_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_f64__f64_arrow:
+2159: _dataframe_serialize_cell_column_f64__f32_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_f64__f32_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2159, __pyx_L1_error)
+2160: elif dc == col_dispatch_code_t.col_dispatch_code_column_f64__f64_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_str__str_pyobj:
+2161: _dataframe_serialize_cell_column_f64__f64_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_f64__f64_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2161, __pyx_L1_error)
+2162: elif dc == col_dispatch_code_t.col_dispatch_code_column_str__str_pyobj:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_str__str_utf8_arrow:
+2163: _dataframe_serialize_cell_column_str__str_pyobj(ls_buf, b, col)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_str__str_pyobj(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2163, __pyx_L1_error)
+2164: elif dc == col_dispatch_code_t.col_dispatch_code_column_str__str_utf8_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_str__str_lrg_utf8_arrow:
+2165: _dataframe_serialize_cell_column_str__str_utf8_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_str__str_utf8_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2165, __pyx_L1_error)
+2166: elif dc == col_dispatch_code_t.col_dispatch_code_column_str__str_lrg_utf8_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_str__str_i8_cat:
+2167: _dataframe_serialize_cell_column_str__str_lrg_utf8_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_str__str_lrg_utf8_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2167, __pyx_L1_error)
+2168: elif dc == col_dispatch_code_t.col_dispatch_code_column_str__str_i8_cat:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_str__str_i16_cat:
+2169: _dataframe_serialize_cell_column_str__str_i8_cat(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_str__str_i8_cat(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2169, __pyx_L1_error)
+2170: elif dc == col_dispatch_code_t.col_dispatch_code_column_str__str_i16_cat:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_str__str_i32_cat:
+2171: _dataframe_serialize_cell_column_str__str_i16_cat(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_str__str_i16_cat(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2171, __pyx_L1_error)
+2172: elif dc == col_dispatch_code_t.col_dispatch_code_column_str__str_i32_cat:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_ts__dt64ns_numpy:
+2173: _dataframe_serialize_cell_column_str__str_i32_cat(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_str__str_i32_cat(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2173, __pyx_L1_error)
+2174: elif dc == col_dispatch_code_t.col_dispatch_code_column_ts__dt64ns_numpy:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_column_ts__dt64ns_tz_arrow:
+2175: _dataframe_serialize_cell_column_ts__dt64ns_numpy(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_ts__dt64ns_numpy(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2175, __pyx_L1_error)
+2176: elif dc == col_dispatch_code_t.col_dispatch_code_column_ts__dt64ns_tz_arrow:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_at__dt64ns_numpy:
+2177: _dataframe_serialize_cell_column_ts__dt64ns_tz_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_column_ts__dt64ns_tz_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2177, __pyx_L1_error)
+2178: elif dc == col_dispatch_code_t.col_dispatch_code_at__dt64ns_numpy:
break; case __pyx_e_7questdb_7ingress_col_dispatch_code_at__dt64ns_tz_arrow:
+2179: _dataframe_serialize_cell_at_dt64ns_numpy(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_at_dt64ns_numpy(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2179, __pyx_L1_error)
+2180: elif dc == col_dispatch_code_t.col_dispatch_code_at__dt64ns_tz_arrow:
break; default:
+2181: _dataframe_serialize_cell_at_dt64ns_tz_arrow(ls_buf, b, col, gs)
__pyx_t_2 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell_at_dt64ns_tz_arrow(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, __pyx_v_gs); if (unlikely(__pyx_t_2 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2181, __pyx_L1_error)
2182: else:
+2183: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2183, __pyx_L1_error)
+2184: raise RuntimeError(f"Unknown column dispatch code: {dc}")
__pyx_t_3 = __Pyx_PyUnicode_From_enum____pyx_t_7questdb_7ingress_col_dispatch_code_t(__pyx_v_dc, 0, ' ', 'd'); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 2184, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __pyx_t_4 = __Pyx_PyUnicode_Concat(__pyx_kp_u_Unknown_column_dispatch_code, __pyx_t_3); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 2184, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __pyx_t_3 = __Pyx_PyObject_CallOneArg(__pyx_builtin_RuntimeError, __pyx_t_4); if (unlikely(!__pyx_t_3)) __PYX_ERR(1, 2184, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_3); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __Pyx_Raise(__pyx_t_3, 0, 0, 0); __Pyx_DECREF(__pyx_t_3); __pyx_t_3 = 0; __PYX_ERR(1, 2184, __pyx_L1_error) break; }
2185: # See earlier note about switch statement generation.
2186: # Don't add complex conditions above!
2187:
2188:
+2189: cdef void _dataframe_col_advance(col_t* col) noexcept nogil:
static void __pyx_f_7questdb_7ingress__dataframe_col_advance(struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col) { struct __pyx_t_7questdb_7ingress_col_cursor_t *__pyx_v_cursor; size_t __pyx_v_new_chunk; /* … */ /* function exit code */ }
2190: # Branchless version of:
2191: # cdef bint new_chunk = cursor.offset == <size_t>cursor.chunk.length
2192: # if new_chunk == 0:
2193: # cursor.chunk_index += 1
2194: # cursor.chunk += 1 # pointer advance
2195: #
2196: # if new_chunk:
2197: # cursor.offset = cursor.chunk.offset
2198: # else:
2199: # cursor.offset += 1
2200: #
2201: # (Checked with Godbolt, GCC -O3 code was rather "jumpy")
+2202: cdef col_cursor_t* cursor = &col.cursor
__pyx_v_cursor = (&__pyx_v_col->cursor);
2203: cdef size_t new_chunk # disguised bint. Either 0 or 1.
+2204: cursor.offset += 1
__pyx_v_cursor->offset = (__pyx_v_cursor->offset + 1);
+2205: new_chunk = cursor.offset == <size_t>cursor.chunk.length
__pyx_v_new_chunk = (__pyx_v_cursor->offset == ((size_t)__pyx_v_cursor->chunk->length));
+2206: cursor.chunk_index += new_chunk
__pyx_v_cursor->chunk_index = (__pyx_v_cursor->chunk_index + __pyx_v_new_chunk);
+2207: cursor.chunk += new_chunk
__pyx_v_cursor->chunk = (__pyx_v_cursor->chunk + __pyx_v_new_chunk);
2208: # Note: We get away with this because we've allocated one extra blank chunk.
2209: # This ensures that accessing `cursor.chunk.offset` doesn't segfault.
+2210: cursor.offset = (
__pyx_v_cursor->offset = ((__pyx_v_new_chunk * __pyx_v_cursor->chunk->offset) + ((!(__pyx_v_new_chunk != 0)) * __pyx_v_cursor->offset));
2211: (new_chunk * cursor.chunk.offset) +
2212: ((not new_chunk) * cursor.offset))
2213:
2214:
+2215: cdef void_int _dataframe_handle_auto_flush(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe_handle_auto_flush(struct __pyx_t_7questdb_7ingress_auto_flush_t const *__pyx_v_af, struct line_sender_buffer *__pyx_v_ls_buf, PyThreadState **__pyx_v_gs) { struct line_sender_error *__pyx_v_flush_err; struct line_sender_error *__pyx_v_marker_err; int __pyx_v_flush_ok; int __pyx_v_marker_ok; int __pyx_v_had_gil; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_4); __Pyx_XDECREF(__pyx_t_5); __Pyx_AddTraceback("questdb.ingress._dataframe_handle_auto_flush", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_RefNannyFinishContext(); return __pyx_r; }
2216: const auto_flush_t* af,
2217: line_sender_buffer* ls_buf,
2218: PyThreadState** gs) except -1:
2219: cdef line_sender_error* flush_err
2220: cdef line_sender_error* marker_err
2221: cdef bint flush_ok
2222: cdef bint marker_ok
+2223: if (af.sender == NULL) or (not should_auto_flush(&af.mode, ls_buf, af.last_flush_ms[0])):
__pyx_t_2 = (__pyx_v_af->sender == NULL); if (!__pyx_t_2) { } else { __pyx_t_1 = __pyx_t_2; goto __pyx_L4_bool_binop_done; } __pyx_t_2 = __pyx_f_7questdb_7ingress_should_auto_flush((&__pyx_v_af->mode), __pyx_v_ls_buf, (__pyx_v_af->last_flush_ms[0])); if (unlikely(__pyx_t_2 == ((int)-1) && PyErr_Occurred())) __PYX_ERR(1, 2223, __pyx_L1_error) __pyx_t_3 = (!__pyx_t_2); __pyx_t_1 = __pyx_t_3; __pyx_L4_bool_binop_done:; if (__pyx_t_1) { /* … */ }
+2224: return 0
2225:
2226: # Always temporarily release GIL during a flush.
+2227: had_gil = _ensure_doesnt_have_gil(gs)
__pyx_t_1 = __pyx_f_7questdb_7ingress__ensure_doesnt_have_gil(__pyx_v_gs); if (unlikely(__pyx_t_1 == ((int)-1) && PyErr_Occurred())) __PYX_ERR(1, 2227, __pyx_L1_error) __pyx_v_had_gil = __pyx_t_1;
+2228: flush_ok = line_sender_flush(af.sender, ls_buf, &flush_err)
__pyx_v_flush_ok = line_sender_flush(__pyx_v_af->sender, __pyx_v_ls_buf, (&__pyx_v_flush_err));
+2229: if flush_ok:
if (__pyx_v_flush_ok) { /* … */ goto __pyx_L6; }
+2230: af.last_flush_ms[0] = line_sender_now_micros() // 1000
(__pyx_v_af->last_flush_ms[0]) = __Pyx_div_int64_t(line_sender_now_micros(), 0x3E8);
2231: else:
2232: # To avoid flush reattempt on Sender.__exit__.
+2233: line_sender_buffer_clear(ls_buf)
/*else*/ { line_sender_buffer_clear(__pyx_v_ls_buf); } __pyx_L6:;
2234:
2235: # Flushing will have cleared the marker: We need to set it again
2236: # We need this also on error due to our error handling logic which will
2237: # try to rewind the buffer on error and fail if the marker is unset.
+2238: marker_ok = line_sender_buffer_set_marker(ls_buf, &marker_err)
__pyx_v_marker_ok = line_sender_buffer_set_marker(__pyx_v_ls_buf, (&__pyx_v_marker_err));
2239:
+2240: if had_gil or (not flush_ok) or (not marker_ok):
if (!__pyx_v_had_gil) { } else { __pyx_t_1 = __pyx_v_had_gil; goto __pyx_L8_bool_binop_done; } __pyx_t_3 = (!__pyx_v_flush_ok); if (!__pyx_t_3) { } else { __pyx_t_1 = __pyx_t_3; goto __pyx_L8_bool_binop_done; } __pyx_t_3 = (!__pyx_v_marker_ok); __pyx_t_1 = __pyx_t_3; __pyx_L8_bool_binop_done:; if (__pyx_t_1) { /* … */ }
+2241: _ensure_has_gil(gs)
__pyx_f_7questdb_7ingress__ensure_has_gil(__pyx_v_gs); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2241, __pyx_L1_error)
2242:
+2243: if not flush_ok:
__pyx_t_1 = (!__pyx_v_flush_ok); if (unlikely(__pyx_t_1)) { /* … */ }
+2244: raise c_err_to_py_fmt(flush_err, _FLUSH_FMT)
__Pyx_GetModuleGlobalName(__pyx_t_4, __pyx_n_s_FLUSH_FMT); if (unlikely(!__pyx_t_4)) __PYX_ERR(1, 2244, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_4); if (!(likely(PyUnicode_CheckExact(__pyx_t_4))||((__pyx_t_4) == Py_None) || __Pyx_RaiseUnexpectedTypeError("unicode", __pyx_t_4))) __PYX_ERR(1, 2244, __pyx_L1_error) __pyx_t_5 = __pyx_f_7questdb_7ingress_c_err_to_py_fmt(__pyx_v_flush_err, ((PyObject*)__pyx_t_4)); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 2244, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_DECREF(__pyx_t_4); __pyx_t_4 = 0; __Pyx_Raise(__pyx_t_5, 0, 0, 0); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __PYX_ERR(1, 2244, __pyx_L1_error)
2245:
2246: # The flush error takes precedence over the marker error.
+2247: if not marker_ok:
__pyx_t_1 = (!__pyx_v_marker_ok); if (unlikely(__pyx_t_1)) { /* … */ }
+2248: raise c_err_to_py(marker_err)
__pyx_t_5 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_marker_err); if (unlikely(!__pyx_t_5)) __PYX_ERR(1, 2248, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_5); __Pyx_Raise(__pyx_t_5, 0, 0, 0); __Pyx_DECREF(__pyx_t_5); __pyx_t_5 = 0; __PYX_ERR(1, 2248, __pyx_L1_error)
2249:
2250:
2251: # Every how many cells to release and re-acquire the Python GIL.
2252: #
2253: # We've done some perf testing with some mixed column dtypes.
2254: # On a modern CPU we're doing over 8 million pandas cells per second.
2255: # By default, `sys.getswitchinterval()` is 0.005 seconds.
2256: # To accomodate this, we'd need to release the GIL every 40,000 cells.
2257: # This will be divided by the column count to get the row gil blip interval.
+2258: cdef size_t _CELL_GIL_BLIP_INTERVAL = 40000
__pyx_v_7questdb_7ingress__CELL_GIL_BLIP_INTERVAL = 0x9C40;
2259:
2260:
+2261: cdef void_int _dataframe(
static __pyx_t_7questdb_7ingress_void_int __pyx_f_7questdb_7ingress__dataframe(struct __pyx_t_7questdb_7ingress_auto_flush_t __pyx_v_af, struct line_sender_buffer *__pyx_v_ls_buf, struct qdb_pystr_buf *__pyx_v_b, PyObject *__pyx_v_df, PyObject *__pyx_v_table_name, PyObject *__pyx_v_table_name_col, PyObject *__pyx_v_symbols, PyObject *__pyx_v_at) { size_t __pyx_v_col_count; struct line_sender_table_name __pyx_v_c_table_name; int64_t __pyx_v_at_value; struct __pyx_t_7questdb_7ingress_col_t_arr __pyx_v_cols; int __pyx_v_any_cols_need_gil; struct qdb_pystr_pos __pyx_v_str_buf_marker; size_t __pyx_v_row_count; struct line_sender_error *__pyx_v_err; size_t __pyx_v_row_index; size_t __pyx_v_col_index; struct __pyx_t_7questdb_7ingress_col_t *__pyx_v_col; size_t __pyx_v_row_gil_blip_interval; PyThreadState *__pyx_v_gs; int __pyx_v_was_serializing_cell; PyObject *__pyx_v_e = NULL; __pyx_t_7questdb_7ingress_void_int __pyx_r; /* … */ /* function exit code */ __pyx_r = 0; goto __pyx_L0; __pyx_L1_error:; __Pyx_XDECREF(__pyx_t_1); __Pyx_XDECREF(__pyx_t_19); __Pyx_XDECREF(__pyx_t_20); __Pyx_XDECREF(__pyx_t_21); __Pyx_XDECREF(__pyx_t_22); __Pyx_XDECREF(__pyx_t_23); __Pyx_XDECREF(__pyx_t_24); __Pyx_XDECREF(__pyx_t_26); __Pyx_XDECREF(__pyx_t_28); __Pyx_XDECREF(__pyx_t_29); __Pyx_XDECREF(__pyx_t_30); __Pyx_AddTraceback("questdb.ingress._dataframe", __pyx_clineno, __pyx_lineno, __pyx_filename); __pyx_r = -1; __pyx_L0:; __Pyx_XDECREF(__pyx_v_e); __Pyx_RefNannyFinishContext(); return __pyx_r; }
2262: auto_flush_t af,
2263: line_sender_buffer* ls_buf,
2264: qdb_pystr_buf* b,
2265: object df,
2266: object table_name,
2267: object table_name_col,
2268: object symbols,
2269: object at) except -1:
2270: cdef size_t col_count
2271: cdef line_sender_table_name c_table_name
+2272: cdef int64_t at_value = _AT_IS_SET_BY_COLUMN
__pyx_v_at_value = __pyx_v_7questdb_7ingress__AT_IS_SET_BY_COLUMN;
+2273: cdef col_t_arr cols = col_t_arr_blank()
__pyx_v_cols = __pyx_f_7questdb_7ingress_col_t_arr_blank();
+2274: cdef bint any_cols_need_gil = False
__pyx_v_any_cols_need_gil = 0;
2275: cdef qdb_pystr_pos str_buf_marker
2276: cdef size_t row_count
+2277: cdef line_sender_error* err = NULL
__pyx_v_err = NULL;
2278: cdef size_t row_index
2279: cdef size_t col_index
2280: cdef col_t* col
2281: cdef size_t row_gil_blip_interval
+2282: cdef PyThreadState* gs = NULL # GIL state. NULL means we have the GIL.
__pyx_v_gs = NULL;
2283: cdef bint had_gil
+2284: cdef bint was_serializing_cell = False
__pyx_v_was_serializing_cell = 0;
2285:
+2286: _dataframe_may_import_deps()
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_may_import_deps(); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 2286, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0;
+2287: _dataframe_check_is_dataframe(df)
__pyx_t_1 = __pyx_f_7questdb_7ingress__dataframe_check_is_dataframe(__pyx_v_df); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 2287, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0;
+2288: row_count = len(df)
__pyx_t_2 = PyObject_Length(__pyx_v_df); if (unlikely(__pyx_t_2 == ((Py_ssize_t)-1))) __PYX_ERR(1, 2288, __pyx_L1_error) __pyx_v_row_count = __pyx_t_2;
+2289: col_count = len(df.columns)
__pyx_t_1 = __Pyx_PyObject_GetAttrStr(__pyx_v_df, __pyx_n_s_columns); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 2289, __pyx_L1_error) __Pyx_GOTREF(__pyx_t_1); __pyx_t_2 = PyObject_Length(__pyx_t_1); if (unlikely(__pyx_t_2 == ((Py_ssize_t)-1))) __PYX_ERR(1, 2289, __pyx_L1_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __pyx_v_col_count = __pyx_t_2;
+2290: if (col_count == 0) or (row_count == 0):
__pyx_t_4 = (__pyx_v_col_count == 0); if (!__pyx_t_4) { } else { __pyx_t_3 = __pyx_t_4; goto __pyx_L4_bool_binop_done; } __pyx_t_4 = (__pyx_v_row_count == 0); __pyx_t_3 = __pyx_t_4; __pyx_L4_bool_binop_done:; if (__pyx_t_3) { /* … */ }
+2291: return 0 # Nothing to do.
2292:
+2293: try:
/*try:*/ { { /*try:*/ { /* … */ } __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; __Pyx_XDECREF(__pyx_t_6); __pyx_t_6 = 0; __Pyx_XDECREF(__pyx_t_7); __pyx_t_7 = 0; goto __pyx_L14_try_end; __pyx_L9_error:; __Pyx_XDECREF(__pyx_t_1); __pyx_t_1 = 0; __Pyx_XDECREF(__pyx_t_19); __pyx_t_19 = 0; __Pyx_XDECREF(__pyx_t_20); __pyx_t_20 = 0; __Pyx_XDECREF(__pyx_t_21); __pyx_t_21 = 0; __Pyx_XDECREF(__pyx_t_22); __pyx_t_22 = 0; __Pyx_XDECREF(__pyx_t_23); __pyx_t_23 = 0; __Pyx_XDECREF(__pyx_t_24); __pyx_t_24 = 0; __Pyx_XDECREF(__pyx_t_26); __pyx_t_26 = 0; __Pyx_XDECREF(__pyx_t_28); __pyx_t_28 = 0; __Pyx_XDECREF(__pyx_t_29); __pyx_t_29 = 0; __Pyx_XDECREF(__pyx_t_30); __pyx_t_30 = 0; /* … */ __pyx_L11_except_error:; __Pyx_XGIVEREF(__pyx_t_5); __Pyx_XGIVEREF(__pyx_t_6); __Pyx_XGIVEREF(__pyx_t_7); __Pyx_ExceptionReset(__pyx_t_5, __pyx_t_6, __pyx_t_7); goto __pyx_L7_error; __pyx_L14_try_end:; } }
+2294: qdb_pystr_buf_clear(b)
qdb_pystr_buf_clear(__pyx_v_b);
+2295: cols = col_t_arr_new(col_count)
__pyx_v_cols = __pyx_f_7questdb_7ingress_col_t_arr_new(__pyx_v_col_count);
+2296: _dataframe_resolve_args(
__pyx_t_8 = __pyx_f_7questdb_7ingress__dataframe_resolve_args(__pyx_v_df, __pyx_v_table_name, __pyx_v_table_name_col, __pyx_v_symbols, __pyx_t_1, __pyx_v_b, __pyx_v_col_count, (&__pyx_v_c_table_name), (&__pyx_v_at_value), (&__pyx_v_cols), (&__pyx_v_any_cols_need_gil)); if (unlikely(__pyx_t_8 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2296, __pyx_L9_error) __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0;
2297: df,
2298: table_name,
2299: table_name_col,
2300: symbols,
+2301: at if not isinstance(at, _ServerTimestamp) else None,
__pyx_t_3 = __Pyx_TypeCheck(__pyx_v_at, __pyx_ptype_7questdb_7ingress__ServerTimestamp); __pyx_t_4 = (!__pyx_t_3); if (__pyx_t_4) { __Pyx_INCREF(__pyx_v_at); __pyx_t_1 = __pyx_v_at; } else { __Pyx_INCREF(Py_None); __pyx_t_1 = Py_None; }
2302: b,
2303: col_count,
2304: &c_table_name,
2305: &at_value,
2306: &cols,
2307: &any_cols_need_gil)
2308:
2309: # We've used the str buffer up to a point for the headers.
2310: # Instead of clearing it (which would clear the headers' memory)
2311: # we will truncate (rewind) back to this position.
+2312: str_buf_marker = qdb_pystr_buf_tell(b)
__pyx_v_str_buf_marker = qdb_pystr_buf_tell(__pyx_v_b);
+2313: line_sender_buffer_clear_marker(ls_buf)
line_sender_buffer_clear_marker(__pyx_v_ls_buf);
2314:
2315: # On error, undo all added lines.
+2316: if not line_sender_buffer_set_marker(ls_buf, &err):
__pyx_t_4 = (!line_sender_buffer_set_marker(__pyx_v_ls_buf, (&__pyx_v_err))); if (unlikely(__pyx_t_4)) { /* … */ }
+2317: raise c_err_to_py(err)
__pyx_t_1 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 2317, __pyx_L9_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_Raise(__pyx_t_1, 0, 0, 0); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 2317, __pyx_L9_error)
2318:
+2319: row_gil_blip_interval = _CELL_GIL_BLIP_INTERVAL // col_count
if (unlikely(__pyx_v_col_count == 0)) { PyErr_SetString(PyExc_ZeroDivisionError, "integer division or modulo by zero"); __PYX_ERR(1, 2319, __pyx_L9_error) } __pyx_v_row_gil_blip_interval = (__pyx_v_7questdb_7ingress__CELL_GIL_BLIP_INTERVAL / __pyx_v_col_count);
+2320: if row_gil_blip_interval < 400: # ceiling reached at 100 columns
__pyx_t_4 = (__pyx_v_row_gil_blip_interval < 0x190); if (__pyx_t_4) { /* … */ }
+2321: row_gil_blip_interval = 400
__pyx_v_row_gil_blip_interval = 0x190;
+2322: try:
{ /*try:*/ { /* … */ } __Pyx_XDECREF(__pyx_t_9); __pyx_t_9 = 0; __Pyx_XDECREF(__pyx_t_10); __pyx_t_10 = 0; __Pyx_XDECREF(__pyx_t_11); __pyx_t_11 = 0; goto __pyx_L22_try_end; __pyx_L17_error:; __Pyx_XDECREF(__pyx_t_1); __pyx_t_1 = 0; /* … */ __pyx_L19_except_error:; __Pyx_XGIVEREF(__pyx_t_9); __Pyx_XGIVEREF(__pyx_t_10); __Pyx_XGIVEREF(__pyx_t_11); __Pyx_ExceptionReset(__pyx_t_9, __pyx_t_10, __pyx_t_11); goto __pyx_L9_error; __pyx_L22_try_end:; }
2323: # Don't move this logic up! We need the GIL to execute a `try`.
2324: # Also we can't have any other `try` blocks between here and the
2325: # `finally` block.
+2326: if not any_cols_need_gil:
__pyx_t_4 = (!__pyx_v_any_cols_need_gil); if (__pyx_t_4) { /* … */ }
+2327: _ensure_doesnt_have_gil(&gs)
__pyx_t_4 = __pyx_f_7questdb_7ingress__ensure_doesnt_have_gil((&__pyx_v_gs)); if (unlikely(__pyx_t_4 == ((int)-1) && PyErr_Occurred())) __PYX_ERR(1, 2327, __pyx_L17_error)
2328:
+2329: for row_index in range(row_count):
__pyx_t_12 = __pyx_v_row_count; __pyx_t_13 = __pyx_t_12; for (__pyx_t_14 = 0; __pyx_t_14 < __pyx_t_13; __pyx_t_14+=1) { __pyx_v_row_index = __pyx_t_14;
+2330: if (gs == NULL) and (row_index % row_gil_blip_interval == 0):
__pyx_t_3 = (__pyx_v_gs == NULL); if (__pyx_t_3) { } else { __pyx_t_4 = __pyx_t_3; goto __pyx_L27_bool_binop_done; } if (unlikely(__pyx_v_row_gil_blip_interval == 0)) { PyErr_SetString(PyExc_ZeroDivisionError, "integer division or modulo by zero"); __PYX_ERR(1, 2330, __pyx_L17_error) } __pyx_t_3 = ((__pyx_v_row_index % __pyx_v_row_gil_blip_interval) == 0); __pyx_t_4 = __pyx_t_3; __pyx_L27_bool_binop_done:; if (__pyx_t_4) { /* … */ }
2331: # Release and re-acquire the GIL every so often.
2332: # This is to allow other python threads to run.
2333: # If we hold the GIL for too long, we can starve other
2334: # threads, for example timing out network activity.
+2335: _ensure_doesnt_have_gil(&gs)
__pyx_t_4 = __pyx_f_7questdb_7ingress__ensure_doesnt_have_gil((&__pyx_v_gs)); if (unlikely(__pyx_t_4 == ((int)-1) && PyErr_Occurred())) __PYX_ERR(1, 2335, __pyx_L17_error)
+2336: _ensure_has_gil(&gs)
__pyx_f_7questdb_7ingress__ensure_has_gil((&__pyx_v_gs)); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2336, __pyx_L17_error)
2337:
+2338: qdb_pystr_buf_truncate(b, str_buf_marker)
qdb_pystr_buf_truncate(__pyx_v_b, __pyx_v_str_buf_marker);
2339:
2340: # Table-name from `table_name` arg in Python.
+2341: if c_table_name.buf != NULL:
__pyx_t_4 = (__pyx_v_c_table_name.buf != NULL); if (__pyx_t_4) { /* … */ }
+2342: if not line_sender_buffer_table(ls_buf, c_table_name, &err):
__pyx_t_4 = (!line_sender_buffer_table(__pyx_v_ls_buf, __pyx_v_c_table_name, (&__pyx_v_err))); if (unlikely(__pyx_t_4)) { /* … */ }
+2343: _ensure_has_gil(&gs)
__pyx_f_7questdb_7ingress__ensure_has_gil((&__pyx_v_gs)); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2343, __pyx_L17_error)
+2344: raise c_err_to_py(err)
__pyx_t_1 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 2344, __pyx_L17_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_Raise(__pyx_t_1, 0, 0, 0); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 2344, __pyx_L17_error)
2345:
2346: # Serialize columns cells.
2347: # Note: Columns are sorted: table name, symbols, fields, at.
+2348: was_serializing_cell = True
__pyx_v_was_serializing_cell = 1;
+2349: for col_index in range(col_count):
__pyx_t_15 = __pyx_v_col_count; __pyx_t_16 = __pyx_t_15; for (__pyx_t_17 = 0; __pyx_t_17 < __pyx_t_16; __pyx_t_17+=1) { __pyx_v_col_index = __pyx_t_17;
+2350: col = &cols.d[col_index]
__pyx_v_col = (&(__pyx_v_cols.d[__pyx_v_col_index]));
+2351: _dataframe_serialize_cell(ls_buf, b, col, &gs) # may raise
__pyx_t_8 = __pyx_f_7questdb_7ingress__dataframe_serialize_cell(__pyx_v_ls_buf, __pyx_v_b, __pyx_v_col, (&__pyx_v_gs)); if (unlikely(__pyx_t_8 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2351, __pyx_L17_error)
+2352: _dataframe_col_advance(col)
__pyx_f_7questdb_7ingress__dataframe_col_advance(__pyx_v_col); }
+2353: was_serializing_cell = False
2354:
2355: # Fixed "at" value (not from a column).
+2356: if at_value == _AT_IS_SERVER_NOW:
__pyx_t_4 = (__pyx_v_at_value == __pyx_v_7questdb_7ingress__AT_IS_SERVER_NOW); if (__pyx_t_4) { /* … */ goto __pyx_L33; }
+2357: if not line_sender_buffer_at_now(ls_buf, &err):
__pyx_t_4 = (!line_sender_buffer_at_now(__pyx_v_ls_buf, (&__pyx_v_err))); if (unlikely(__pyx_t_4)) { /* … */ }
+2358: _ensure_has_gil(&gs)
__pyx_f_7questdb_7ingress__ensure_has_gil((&__pyx_v_gs)); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2358, __pyx_L17_error)
+2359: raise c_err_to_py(err)
__pyx_t_1 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 2359, __pyx_L17_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_Raise(__pyx_t_1, 0, 0, 0); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 2359, __pyx_L17_error)
+2360: elif at_value >= 0:
__pyx_t_4 = (__pyx_v_at_value >= 0); if (__pyx_t_4) { /* … */ } __pyx_L33:;
+2361: if not line_sender_buffer_at_nanos(ls_buf, at_value, &err):
__pyx_t_4 = (!line_sender_buffer_at_nanos(__pyx_v_ls_buf, __pyx_v_at_value, (&__pyx_v_err))); if (unlikely(__pyx_t_4)) { /* … */ }
+2362: _ensure_has_gil(&gs)
__pyx_f_7questdb_7ingress__ensure_has_gil((&__pyx_v_gs)); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2362, __pyx_L17_error)
+2363: raise c_err_to_py(err)
__pyx_t_1 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_1)) __PYX_ERR(1, 2363, __pyx_L17_error) __Pyx_GOTREF(__pyx_t_1); __Pyx_Raise(__pyx_t_1, 0, 0, 0); __Pyx_DECREF(__pyx_t_1); __pyx_t_1 = 0; __PYX_ERR(1, 2363, __pyx_L17_error)
2364:
+2365: _dataframe_handle_auto_flush(&af, ls_buf, &gs)
__pyx_t_8 = __pyx_f_7questdb_7ingress__dataframe_handle_auto_flush((&__pyx_v_af), __pyx_v_ls_buf, (&__pyx_v_gs)); if (unlikely(__pyx_t_8 == ((__pyx_t_7questdb_7ingress_void_int)-1))) __PYX_ERR(1, 2365, __pyx_L17_error)
+2366: except Exception as e:
__pyx_t_18 = __Pyx_PyErr_ExceptionMatches(((PyObject *)(&((PyTypeObject*)PyExc_Exception)[0]))); if (__pyx_t_18) { __Pyx_AddTraceback("questdb.ingress._dataframe", __pyx_clineno, __pyx_lineno, __pyx_filename); if (__Pyx_GetException(&__pyx_t_1, &__pyx_t_19, &__pyx_t_20) < 0) __PYX_ERR(1, 2366, __pyx_L19_except_error) __Pyx_XGOTREF(__pyx_t_1); __Pyx_XGOTREF(__pyx_t_19); __Pyx_XGOTREF(__pyx_t_20); __Pyx_INCREF(__pyx_t_19); __pyx_v_e = __pyx_t_19; /*try:*/ { /* … */ /*finally:*/ { __pyx_L41_error:; /*exception exit:*/{ __Pyx_PyThreadState_declare __Pyx_PyThreadState_assign __pyx_t_33 = 0; __pyx_t_34 = 0; __pyx_t_35 = 0; __pyx_t_36 = 0; __pyx_t_37 = 0; __pyx_t_38 = 0; __Pyx_XDECREF(__pyx_t_21); __pyx_t_21 = 0; __Pyx_XDECREF(__pyx_t_22); __pyx_t_22 = 0; __Pyx_XDECREF(__pyx_t_23); __pyx_t_23 = 0; __Pyx_XDECREF(__pyx_t_24); __pyx_t_24 = 0; __Pyx_XDECREF(__pyx_t_26); __pyx_t_26 = 0; __Pyx_XDECREF(__pyx_t_28); __pyx_t_28 = 0; __Pyx_XDECREF(__pyx_t_29); __pyx_t_29 = 0; __Pyx_XDECREF(__pyx_t_30); __pyx_t_30 = 0; if (PY_MAJOR_VERSION >= 3) __Pyx_ExceptionSwap(&__pyx_t_36, &__pyx_t_37, &__pyx_t_38); if ((PY_MAJOR_VERSION < 3) || unlikely(__Pyx_GetException(&__pyx_t_33, &__pyx_t_34, &__pyx_t_35) < 0)) __Pyx_ErrFetch(&__pyx_t_33, &__pyx_t_34, &__pyx_t_35); __Pyx_XGOTREF(__pyx_t_33); __Pyx_XGOTREF(__pyx_t_34); __Pyx_XGOTREF(__pyx_t_35); __Pyx_XGOTREF(__pyx_t_36); __Pyx_XGOTREF(__pyx_t_37); __Pyx_XGOTREF(__pyx_t_38); __pyx_t_18 = __pyx_lineno; __pyx_t_31 = __pyx_clineno; __pyx_t_32 = __pyx_filename; { __Pyx_DECREF(__pyx_v_e); __pyx_v_e = 0; } if (PY_MAJOR_VERSION >= 3) { __Pyx_XGIVEREF(__pyx_t_36); __Pyx_XGIVEREF(__pyx_t_37); __Pyx_XGIVEREF(__pyx_t_38); __Pyx_ExceptionReset(__pyx_t_36, __pyx_t_37, __pyx_t_38); } __Pyx_XGIVEREF(__pyx_t_33); __Pyx_XGIVEREF(__pyx_t_34); __Pyx_XGIVEREF(__pyx_t_35); __Pyx_ErrRestore(__pyx_t_33, __pyx_t_34, __pyx_t_35); __pyx_t_33 = 0; __pyx_t_34 = 0; __pyx_t_35 = 0; __pyx_t_36 = 0; __pyx_t_37 = 0; __pyx_t_38 = 0; __pyx_lineno = __pyx_t_18; __pyx_clineno = __pyx_t_31; __pyx_filename = __pyx_t_32; goto __pyx_L19_except_error; } } } goto __pyx_L19_except_error;
2367: # It would be an internal bug for this to raise.
+2368: if not line_sender_buffer_rewind_to_marker(ls_buf, &err):
__pyx_t_4 = (!line_sender_buffer_rewind_to_marker(__pyx_v_ls_buf, (&__pyx_v_err))); if (unlikely(__pyx_t_4)) { /* … */ }
+2369: raise c_err_to_py(err)
__pyx_t_21 = __pyx_f_7questdb_7ingress_c_err_to_py(__pyx_v_err); if (unlikely(!__pyx_t_21)) __PYX_ERR(1, 2369, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_21); __Pyx_Raise(__pyx_t_21, 0, 0, 0); __Pyx_DECREF(__pyx_t_21); __pyx_t_21 = 0; __PYX_ERR(1, 2369, __pyx_L41_error)
2370:
+2371: if (isinstance(e, IngressError) and
__Pyx_GetModuleGlobalName(__pyx_t_21, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_21)) __PYX_ERR(1, 2371, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_21); __pyx_t_3 = PyObject_IsInstance(__pyx_v_e, __pyx_t_21); if (unlikely(__pyx_t_3 == ((int)-1))) __PYX_ERR(1, 2371, __pyx_L41_error) __Pyx_DECREF(__pyx_t_21); __pyx_t_21 = 0; if (__pyx_t_3) { } else { __pyx_t_4 = __pyx_t_3; goto __pyx_L45_bool_binop_done; } /* … */ if (unlikely(__pyx_t_4)) { /* … */ }
+2372: (e.code == IngressErrorCode.InvalidApiCall)):
__pyx_t_21 = __Pyx_PyObject_GetAttrStr(__pyx_v_e, __pyx_n_s_code); if (unlikely(!__pyx_t_21)) __PYX_ERR(1, 2372, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_21); __Pyx_GetModuleGlobalName(__pyx_t_22, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_22)) __PYX_ERR(1, 2372, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_22); __pyx_t_23 = __Pyx_PyObject_GetAttrStr(__pyx_t_22, __pyx_n_s_InvalidApiCall); if (unlikely(!__pyx_t_23)) __PYX_ERR(1, 2372, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_23); __Pyx_DECREF(__pyx_t_22); __pyx_t_22 = 0; __pyx_t_22 = PyObject_RichCompare(__pyx_t_21, __pyx_t_23, Py_EQ); __Pyx_XGOTREF(__pyx_t_22); if (unlikely(!__pyx_t_22)) __PYX_ERR(1, 2372, __pyx_L41_error) __Pyx_DECREF(__pyx_t_21); __pyx_t_21 = 0; __Pyx_DECREF(__pyx_t_23); __pyx_t_23 = 0; __pyx_t_3 = __Pyx_PyObject_IsTrue(__pyx_t_22); if (unlikely((__pyx_t_3 < 0))) __PYX_ERR(1, 2372, __pyx_L41_error) __Pyx_DECREF(__pyx_t_22); __pyx_t_22 = 0; __pyx_t_4 = __pyx_t_3; __pyx_L45_bool_binop_done:;
2373: # TODO: This should be allowed by the database.
2374: # It currently isn't so we have to raise an error.
+2375: raise IngressError(
__Pyx_GetModuleGlobalName(__pyx_t_23, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_23)) __PYX_ERR(1, 2375, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_23);
+2376: IngressErrorCode.BadDataFrame,
__Pyx_GetModuleGlobalName(__pyx_t_21, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_21)) __PYX_ERR(1, 2376, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_21); __pyx_t_24 = __Pyx_PyObject_GetAttrStr(__pyx_t_21, __pyx_n_s_BadDataFrame); if (unlikely(!__pyx_t_24)) __PYX_ERR(1, 2376, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_24); __Pyx_DECREF(__pyx_t_21); __pyx_t_21 = 0;
+2377: f'Bad dataframe row at index {row_index}: ' +
__pyx_t_21 = PyTuple_New(3); if (unlikely(!__pyx_t_21)) __PYX_ERR(1, 2377, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_21); __pyx_t_2 = 0; __pyx_t_25 = 127; __Pyx_INCREF(__pyx_kp_u_Bad_dataframe_row_at_index); __pyx_t_2 += 27; __Pyx_GIVEREF(__pyx_kp_u_Bad_dataframe_row_at_index); PyTuple_SET_ITEM(__pyx_t_21, 0, __pyx_kp_u_Bad_dataframe_row_at_index); __pyx_t_26 = __Pyx_PyUnicode_From_size_t(__pyx_v_row_index, 0, ' ', 'd'); if (unlikely(!__pyx_t_26)) __PYX_ERR(1, 2377, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_26); __pyx_t_2 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_26); __Pyx_GIVEREF(__pyx_t_26); PyTuple_SET_ITEM(__pyx_t_21, 1, __pyx_t_26); __pyx_t_26 = 0; __Pyx_INCREF(__pyx_kp_u__21); __pyx_t_2 += 2; __Pyx_GIVEREF(__pyx_kp_u__21); PyTuple_SET_ITEM(__pyx_t_21, 2, __pyx_kp_u__21); __pyx_t_26 = __Pyx_PyUnicode_Join(__pyx_t_21, 3, __pyx_t_2, __pyx_t_25); if (unlikely(!__pyx_t_26)) __PYX_ERR(1, 2377, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_26); __Pyx_DECREF(__pyx_t_21); __pyx_t_21 = 0; __pyx_t_21 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_26, __pyx_kp_u_All_values_are_nulls); if (unlikely(!__pyx_t_21)) __PYX_ERR(1, 2377, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_21); __Pyx_DECREF(__pyx_t_26); __pyx_t_26 = 0;
+2378: 'All values are nulls. '+
__pyx_t_26 = __Pyx_PyUnicode_ConcatInPlace(__pyx_t_21, __pyx_kp_u_Ensure_at_least_one_column_is_no); if (unlikely(!__pyx_t_26)) __PYX_ERR(1, 2378, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_26); __Pyx_DECREF(__pyx_t_21); __pyx_t_21 = 0; __pyx_t_21 = NULL; __pyx_t_27 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_23))) { __pyx_t_21 = PyMethod_GET_SELF(__pyx_t_23); if (likely(__pyx_t_21)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_23); __Pyx_INCREF(__pyx_t_21); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_23, function); __pyx_t_27 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_21, __pyx_t_24, __pyx_t_26}; __pyx_t_22 = __Pyx_PyObject_FastCall(__pyx_t_23, __pyx_callargs+1-__pyx_t_27, 2+__pyx_t_27); __Pyx_XDECREF(__pyx_t_21); __pyx_t_21 = 0; __Pyx_DECREF(__pyx_t_24); __pyx_t_24 = 0; __Pyx_DECREF(__pyx_t_26); __pyx_t_26 = 0; if (unlikely(!__pyx_t_22)) __PYX_ERR(1, 2375, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_22); __Pyx_DECREF(__pyx_t_23); __pyx_t_23 = 0; }
+2379: 'Ensure at least one column is not null.') from e
__Pyx_Raise(__pyx_t_22, 0, 0, __pyx_v_e); __Pyx_DECREF(__pyx_t_22); __pyx_t_22 = 0; __PYX_ERR(1, 2375, __pyx_L41_error)
+2380: elif was_serializing_cell:
if (unlikely(__pyx_v_was_serializing_cell)) { /* … */ }
+2381: raise IngressError(
__Pyx_GetModuleGlobalName(__pyx_t_23, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_23)) __PYX_ERR(1, 2381, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_23);
+2382: IngressErrorCode.BadDataFrame,
__Pyx_GetModuleGlobalName(__pyx_t_26, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_26)) __PYX_ERR(1, 2382, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_26); __pyx_t_24 = __Pyx_PyObject_GetAttrStr(__pyx_t_26, __pyx_n_s_BadDataFrame); if (unlikely(!__pyx_t_24)) __PYX_ERR(1, 2382, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_24); __Pyx_DECREF(__pyx_t_26); __pyx_t_26 = 0;
+2383: 'Failed to serialize value of column ' +
__pyx_t_21 = PyNumber_Add(__pyx_kp_u_Failed_to_serialize_value_of_col, __pyx_t_26); if (unlikely(!__pyx_t_21)) __PYX_ERR(1, 2383, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_21); __Pyx_DECREF(__pyx_t_26); __pyx_t_26 = 0;
+2384: repr(df.columns[col.setup.orig_index]) +
__pyx_t_26 = __Pyx_PyObject_GetAttrStr(__pyx_v_df, __pyx_n_s_columns); if (unlikely(!__pyx_t_26)) __PYX_ERR(1, 2384, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_26); __pyx_t_21 = __Pyx_GetItemInt(__pyx_t_26, __pyx_v_col->setup->orig_index, size_t, 0, __Pyx_PyInt_FromSize_t, 0, 0, 1); if (unlikely(!__pyx_t_21)) __PYX_ERR(1, 2384, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_21); __Pyx_DECREF(__pyx_t_26); __pyx_t_26 = 0; __pyx_t_26 = PyObject_Repr(__pyx_t_21); if (unlikely(!__pyx_t_26)) __PYX_ERR(1, 2384, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_26); __Pyx_DECREF(__pyx_t_21); __pyx_t_21 = 0; /* … */ __pyx_t_26 = PyNumber_Add(__pyx_t_21, __pyx_t_28); if (unlikely(!__pyx_t_26)) __PYX_ERR(1, 2384, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_26); __Pyx_DECREF(__pyx_t_21); __pyx_t_21 = 0; __Pyx_DECREF(__pyx_t_28); __pyx_t_28 = 0;
+2385: f' at row index {row_index} (' +
__pyx_t_26 = PyTuple_New(3); if (unlikely(!__pyx_t_26)) __PYX_ERR(1, 2385, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_26); __pyx_t_2 = 0; __pyx_t_25 = 127; __Pyx_INCREF(__pyx_kp_u_at_row_index); __pyx_t_2 += 14; __Pyx_GIVEREF(__pyx_kp_u_at_row_index); PyTuple_SET_ITEM(__pyx_t_26, 0, __pyx_kp_u_at_row_index); __pyx_t_28 = __Pyx_PyUnicode_From_size_t(__pyx_v_row_index, 0, ' ', 'd'); if (unlikely(!__pyx_t_28)) __PYX_ERR(1, 2385, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_28); __pyx_t_2 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_28); __Pyx_GIVEREF(__pyx_t_28); PyTuple_SET_ITEM(__pyx_t_26, 1, __pyx_t_28); __pyx_t_28 = 0; __Pyx_INCREF(__pyx_kp_u__20); __pyx_t_2 += 2; __Pyx_GIVEREF(__pyx_kp_u__20); PyTuple_SET_ITEM(__pyx_t_26, 2, __pyx_kp_u__20); __pyx_t_28 = __Pyx_PyUnicode_Join(__pyx_t_26, 3, __pyx_t_2, __pyx_t_25); if (unlikely(!__pyx_t_28)) __PYX_ERR(1, 2385, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_28); __Pyx_DECREF(__pyx_t_26); __pyx_t_26 = 0; /* … */ __pyx_t_29 = PyNumber_Add(__pyx_t_26, __pyx_t_30); if (unlikely(!__pyx_t_29)) __PYX_ERR(1, 2385, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_29); __Pyx_DECREF(__pyx_t_26); __pyx_t_26 = 0; __Pyx_DECREF(__pyx_t_30); __pyx_t_30 = 0;
+2386: repr(df.iloc[row_index, col.setup.orig_index]) +
__pyx_t_28 = __Pyx_PyObject_GetAttrStr(__pyx_v_df, __pyx_n_s_iloc); if (unlikely(!__pyx_t_28)) __PYX_ERR(1, 2386, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_28); __pyx_t_21 = __Pyx_PyInt_FromSize_t(__pyx_v_row_index); if (unlikely(!__pyx_t_21)) __PYX_ERR(1, 2386, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_21); __pyx_t_29 = __Pyx_PyInt_FromSize_t(__pyx_v_col->setup->orig_index); if (unlikely(!__pyx_t_29)) __PYX_ERR(1, 2386, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_29); __pyx_t_30 = PyTuple_New(2); if (unlikely(!__pyx_t_30)) __PYX_ERR(1, 2386, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_30); __Pyx_GIVEREF(__pyx_t_21); if (__Pyx_PyTuple_SET_ITEM(__pyx_t_30, 0, __pyx_t_21)) __PYX_ERR(1, 2386, __pyx_L41_error); __Pyx_GIVEREF(__pyx_t_29); if (__Pyx_PyTuple_SET_ITEM(__pyx_t_30, 1, __pyx_t_29)) __PYX_ERR(1, 2386, __pyx_L41_error); __pyx_t_21 = 0; __pyx_t_29 = 0; __pyx_t_29 = __Pyx_PyObject_GetItem(__pyx_t_28, __pyx_t_30); if (unlikely(!__pyx_t_29)) __PYX_ERR(1, 2386, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_29); __Pyx_DECREF(__pyx_t_28); __pyx_t_28 = 0; __Pyx_DECREF(__pyx_t_30); __pyx_t_30 = 0; __pyx_t_30 = PyObject_Repr(__pyx_t_29); if (unlikely(!__pyx_t_30)) __PYX_ERR(1, 2386, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_30); __Pyx_DECREF(__pyx_t_29); __pyx_t_29 = 0; /* … */ __pyx_t_30 = PyNumber_Add(__pyx_t_29, __pyx_t_26); if (unlikely(!__pyx_t_30)) __PYX_ERR(1, 2386, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_30); __Pyx_DECREF(__pyx_t_29); __pyx_t_29 = 0; __Pyx_DECREF(__pyx_t_26); __pyx_t_26 = 0; __pyx_t_26 = NULL; __pyx_t_27 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_23))) { __pyx_t_26 = PyMethod_GET_SELF(__pyx_t_23); if (likely(__pyx_t_26)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_23); __Pyx_INCREF(__pyx_t_26); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_23, function); __pyx_t_27 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_26, __pyx_t_24, __pyx_t_30}; __pyx_t_22 = __Pyx_PyObject_FastCall(__pyx_t_23, __pyx_callargs+1-__pyx_t_27, 2+__pyx_t_27); __Pyx_XDECREF(__pyx_t_26); __pyx_t_26 = 0; __Pyx_DECREF(__pyx_t_24); __pyx_t_24 = 0; __Pyx_DECREF(__pyx_t_30); __pyx_t_30 = 0; if (unlikely(!__pyx_t_22)) __PYX_ERR(1, 2381, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_22); __Pyx_DECREF(__pyx_t_23); __pyx_t_23 = 0; }
+2387: f'): {e} [dc={<int>col.dispatch_code}]') from e
__pyx_t_30 = PyTuple_New(5); if (unlikely(!__pyx_t_30)) __PYX_ERR(1, 2387, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_30); __pyx_t_2 = 0; __pyx_t_25 = 127; __Pyx_INCREF(__pyx_kp_u__27); __pyx_t_2 += 3; __Pyx_GIVEREF(__pyx_kp_u__27); PyTuple_SET_ITEM(__pyx_t_30, 0, __pyx_kp_u__27); __pyx_t_26 = __Pyx_PyObject_FormatSimple(__pyx_v_e, __pyx_empty_unicode); if (unlikely(!__pyx_t_26)) __PYX_ERR(1, 2387, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_26); __pyx_t_25 = (__Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_26) > __pyx_t_25) ? __Pyx_PyUnicode_MAX_CHAR_VALUE(__pyx_t_26) : __pyx_t_25; __pyx_t_2 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_26); __Pyx_GIVEREF(__pyx_t_26); PyTuple_SET_ITEM(__pyx_t_30, 1, __pyx_t_26); __pyx_t_26 = 0; __Pyx_INCREF(__pyx_kp_u_dc); __pyx_t_2 += 6; __Pyx_GIVEREF(__pyx_kp_u_dc); PyTuple_SET_ITEM(__pyx_t_30, 2, __pyx_kp_u_dc); __pyx_t_26 = __Pyx_PyUnicode_From_int(((int)__pyx_v_col->dispatch_code), 0, ' ', 'd'); if (unlikely(!__pyx_t_26)) __PYX_ERR(1, 2387, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_26); __pyx_t_2 += __Pyx_PyUnicode_GET_LENGTH(__pyx_t_26); __Pyx_GIVEREF(__pyx_t_26); PyTuple_SET_ITEM(__pyx_t_30, 3, __pyx_t_26); __pyx_t_26 = 0; __Pyx_INCREF(__pyx_kp_u__28); __pyx_t_2 += 1; __Pyx_GIVEREF(__pyx_kp_u__28); PyTuple_SET_ITEM(__pyx_t_30, 4, __pyx_kp_u__28); __pyx_t_26 = __Pyx_PyUnicode_Join(__pyx_t_30, 5, __pyx_t_2, __pyx_t_25); if (unlikely(!__pyx_t_26)) __PYX_ERR(1, 2387, __pyx_L41_error) __Pyx_GOTREF(__pyx_t_26); __Pyx_DECREF(__pyx_t_30); __pyx_t_30 = 0; /* … */ __Pyx_Raise(__pyx_t_22, 0, 0, __pyx_v_e); __Pyx_DECREF(__pyx_t_22); __pyx_t_22 = 0; __PYX_ERR(1, 2381, __pyx_L41_error)
2388: else:
+2389: raise
/*else*/ { __Pyx_GIVEREF(__pyx_t_1); __Pyx_GIVEREF(__pyx_t_19); __Pyx_XGIVEREF(__pyx_t_20); __Pyx_ErrRestoreWithState(__pyx_t_1, __pyx_t_19, __pyx_t_20); __pyx_t_1 = 0; __pyx_t_19 = 0; __pyx_t_20 = 0; __PYX_ERR(1, 2389, __pyx_L41_error) } }
+2390: except Exception as e:
__pyx_t_31 = __Pyx_PyErr_ExceptionMatches(((PyObject *)(&((PyTypeObject*)PyExc_Exception)[0]))); if (__pyx_t_31) { __Pyx_AddTraceback("questdb.ingress._dataframe", __pyx_clineno, __pyx_lineno, __pyx_filename); if (__Pyx_GetException(&__pyx_t_20, &__pyx_t_19, &__pyx_t_1) < 0) __PYX_ERR(1, 2390, __pyx_L11_except_error) __Pyx_XGOTREF(__pyx_t_20); __Pyx_XGOTREF(__pyx_t_19); __Pyx_XGOTREF(__pyx_t_1); __Pyx_INCREF(__pyx_t_19); __Pyx_XDECREF_SET(__pyx_v_e, __pyx_t_19); /*try:*/ { /* … */ /*finally:*/ { __pyx_L56_error:; /*exception exit:*/{ __Pyx_PyThreadState_declare __Pyx_PyThreadState_assign __pyx_t_11 = 0; __pyx_t_10 = 0; __pyx_t_9 = 0; __pyx_t_38 = 0; __pyx_t_37 = 0; __pyx_t_36 = 0; __Pyx_XDECREF(__pyx_t_21); __pyx_t_21 = 0; __Pyx_XDECREF(__pyx_t_22); __pyx_t_22 = 0; __Pyx_XDECREF(__pyx_t_23); __pyx_t_23 = 0; __Pyx_XDECREF(__pyx_t_24); __pyx_t_24 = 0; __Pyx_XDECREF(__pyx_t_26); __pyx_t_26 = 0; __Pyx_XDECREF(__pyx_t_28); __pyx_t_28 = 0; __Pyx_XDECREF(__pyx_t_29); __pyx_t_29 = 0; __Pyx_XDECREF(__pyx_t_30); __pyx_t_30 = 0; if (PY_MAJOR_VERSION >= 3) __Pyx_ExceptionSwap(&__pyx_t_38, &__pyx_t_37, &__pyx_t_36); if ((PY_MAJOR_VERSION < 3) || unlikely(__Pyx_GetException(&__pyx_t_11, &__pyx_t_10, &__pyx_t_9) < 0)) __Pyx_ErrFetch(&__pyx_t_11, &__pyx_t_10, &__pyx_t_9); __Pyx_XGOTREF(__pyx_t_11); __Pyx_XGOTREF(__pyx_t_10); __Pyx_XGOTREF(__pyx_t_9); __Pyx_XGOTREF(__pyx_t_38); __Pyx_XGOTREF(__pyx_t_37); __Pyx_XGOTREF(__pyx_t_36); __pyx_t_31 = __pyx_lineno; __pyx_t_18 = __pyx_clineno; __pyx_t_39 = __pyx_filename; { __Pyx_DECREF(__pyx_v_e); __pyx_v_e = 0; } if (PY_MAJOR_VERSION >= 3) { __Pyx_XGIVEREF(__pyx_t_38); __Pyx_XGIVEREF(__pyx_t_37); __Pyx_XGIVEREF(__pyx_t_36); __Pyx_ExceptionReset(__pyx_t_38, __pyx_t_37, __pyx_t_36); } __Pyx_XGIVEREF(__pyx_t_11); __Pyx_XGIVEREF(__pyx_t_10); __Pyx_XGIVEREF(__pyx_t_9); __Pyx_ErrRestore(__pyx_t_11, __pyx_t_10, __pyx_t_9); __pyx_t_11 = 0; __pyx_t_10 = 0; __pyx_t_9 = 0; __pyx_t_38 = 0; __pyx_t_37 = 0; __pyx_t_36 = 0; __pyx_lineno = __pyx_t_31; __pyx_clineno = __pyx_t_18; __pyx_filename = __pyx_t_39; goto __pyx_L11_except_error; } } } goto __pyx_L11_except_error;
+2391: if not isinstance(e, IngressError):
__Pyx_GetModuleGlobalName(__pyx_t_22, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_22)) __PYX_ERR(1, 2391, __pyx_L56_error) __Pyx_GOTREF(__pyx_t_22); __pyx_t_4 = PyObject_IsInstance(__pyx_v_e, __pyx_t_22); if (unlikely(__pyx_t_4 == ((int)-1))) __PYX_ERR(1, 2391, __pyx_L56_error) __Pyx_DECREF(__pyx_t_22); __pyx_t_22 = 0; __pyx_t_3 = (!__pyx_t_4); if (unlikely(__pyx_t_3)) { /* … */ }
+2392: raise IngressError(
__Pyx_GetModuleGlobalName(__pyx_t_23, __pyx_n_s_IngressError); if (unlikely(!__pyx_t_23)) __PYX_ERR(1, 2392, __pyx_L56_error) __Pyx_GOTREF(__pyx_t_23);
+2393: IngressErrorCode.InvalidApiCall,
__Pyx_GetModuleGlobalName(__pyx_t_30, __pyx_n_s_IngressErrorCode); if (unlikely(!__pyx_t_30)) __PYX_ERR(1, 2393, __pyx_L56_error) __Pyx_GOTREF(__pyx_t_30); __pyx_t_24 = __Pyx_PyObject_GetAttrStr(__pyx_t_30, __pyx_n_s_InvalidApiCall); if (unlikely(!__pyx_t_24)) __PYX_ERR(1, 2393, __pyx_L56_error) __Pyx_GOTREF(__pyx_t_24); __Pyx_DECREF(__pyx_t_30); __pyx_t_30 = 0;
+2394: str(e)) from e
__pyx_t_30 = __Pyx_PyObject_Unicode(__pyx_v_e); if (unlikely(!__pyx_t_30)) __PYX_ERR(1, 2394, __pyx_L56_error) __Pyx_GOTREF(__pyx_t_30); __pyx_t_26 = NULL; __pyx_t_27 = 0; #if CYTHON_UNPACK_METHODS if (unlikely(PyMethod_Check(__pyx_t_23))) { __pyx_t_26 = PyMethod_GET_SELF(__pyx_t_23); if (likely(__pyx_t_26)) { PyObject* function = PyMethod_GET_FUNCTION(__pyx_t_23); __Pyx_INCREF(__pyx_t_26); __Pyx_INCREF(function); __Pyx_DECREF_SET(__pyx_t_23, function); __pyx_t_27 = 1; } } #endif { PyObject *__pyx_callargs[3] = {__pyx_t_26, __pyx_t_24, __pyx_t_30}; __pyx_t_22 = __Pyx_PyObject_FastCall(__pyx_t_23, __pyx_callargs+1-__pyx_t_27, 2+__pyx_t_27); __Pyx_XDECREF(__pyx_t_26); __pyx_t_26 = 0; __Pyx_DECREF(__pyx_t_24); __pyx_t_24 = 0; __Pyx_DECREF(__pyx_t_30); __pyx_t_30 = 0; if (unlikely(!__pyx_t_22)) __PYX_ERR(1, 2392, __pyx_L56_error) __Pyx_GOTREF(__pyx_t_22); __Pyx_DECREF(__pyx_t_23); __pyx_t_23 = 0; } __Pyx_Raise(__pyx_t_22, 0, 0, __pyx_v_e); __Pyx_DECREF(__pyx_t_22); __pyx_t_22 = 0; __PYX_ERR(1, 2392, __pyx_L56_error)
2395: else:
+2396: raise
/*else*/ { __Pyx_GIVEREF(__pyx_t_20); __Pyx_GIVEREF(__pyx_t_19); __Pyx_XGIVEREF(__pyx_t_1); __Pyx_ErrRestoreWithState(__pyx_t_20, __pyx_t_19, __pyx_t_1); __pyx_t_20 = 0; __pyx_t_19 = 0; __pyx_t_1 = 0; __PYX_ERR(1, 2396, __pyx_L56_error) } }
2397: finally:
+2398: _ensure_has_gil(&gs) # Note: We need the GIL for cleanup.
/*finally:*/ { /*normal exit:*/{ __pyx_f_7questdb_7ingress__ensure_has_gil((&__pyx_v_gs)); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2398, __pyx_L1_error) /* … */ __pyx_f_7questdb_7ingress__ensure_has_gil((&__pyx_v_gs)); if (unlikely(PyErr_Occurred())) __PYX_ERR(1, 2398, __pyx_L64_error)
+2399: line_sender_buffer_clear_marker(ls_buf)
line_sender_buffer_clear_marker(__pyx_v_ls_buf); /* … */ line_sender_buffer_clear_marker(__pyx_v_ls_buf);
+2400: col_t_arr_release(&cols)
__pyx_f_7questdb_7ingress_col_t_arr_release((&__pyx_v_cols)); /* … */ __pyx_f_7questdb_7ingress_col_t_arr_release((&__pyx_v_cols));
+2401: qdb_pystr_buf_clear(b)
qdb_pystr_buf_clear(__pyx_v_b); goto __pyx_L8; } __pyx_L7_error:; /*exception exit:*/{ __Pyx_PyThreadState_declare __Pyx_PyThreadState_assign __pyx_t_7 = 0; __pyx_t_6 = 0; __pyx_t_5 = 0; __pyx_t_36 = 0; __pyx_t_37 = 0; __pyx_t_38 = 0; __Pyx_XDECREF(__pyx_t_1); __pyx_t_1 = 0; __Pyx_XDECREF(__pyx_t_19); __pyx_t_19 = 0; __Pyx_XDECREF(__pyx_t_20); __pyx_t_20 = 0; __Pyx_XDECREF(__pyx_t_21); __pyx_t_21 = 0; __Pyx_XDECREF(__pyx_t_22); __pyx_t_22 = 0; __Pyx_XDECREF(__pyx_t_23); __pyx_t_23 = 0; __Pyx_XDECREF(__pyx_t_24); __pyx_t_24 = 0; __Pyx_XDECREF(__pyx_t_26); __pyx_t_26 = 0; __Pyx_XDECREF(__pyx_t_28); __pyx_t_28 = 0; __Pyx_XDECREF(__pyx_t_29); __pyx_t_29 = 0; __Pyx_XDECREF(__pyx_t_30); __pyx_t_30 = 0; if (PY_MAJOR_VERSION >= 3) __Pyx_ExceptionSwap(&__pyx_t_36, &__pyx_t_37, &__pyx_t_38); if ((PY_MAJOR_VERSION < 3) || unlikely(__Pyx_GetException(&__pyx_t_7, &__pyx_t_6, &__pyx_t_5) < 0)) __Pyx_ErrFetch(&__pyx_t_7, &__pyx_t_6, &__pyx_t_5); __Pyx_XGOTREF(__pyx_t_7); __Pyx_XGOTREF(__pyx_t_6); __Pyx_XGOTREF(__pyx_t_5); __Pyx_XGOTREF(__pyx_t_36); __Pyx_XGOTREF(__pyx_t_37); __Pyx_XGOTREF(__pyx_t_38); __pyx_t_18 = __pyx_lineno; __pyx_t_31 = __pyx_clineno; __pyx_t_40 = __pyx_filename; { /* … */ qdb_pystr_buf_clear(__pyx_v_b); } if (PY_MAJOR_VERSION >= 3) { __Pyx_XGIVEREF(__pyx_t_36); __Pyx_XGIVEREF(__pyx_t_37); __Pyx_XGIVEREF(__pyx_t_38); __Pyx_ExceptionReset(__pyx_t_36, __pyx_t_37, __pyx_t_38); } __Pyx_XGIVEREF(__pyx_t_7); __Pyx_XGIVEREF(__pyx_t_6); __Pyx_XGIVEREF(__pyx_t_5); __Pyx_ErrRestore(__pyx_t_7, __pyx_t_6, __pyx_t_5); __pyx_t_7 = 0; __pyx_t_6 = 0; __pyx_t_5 = 0; __pyx_t_36 = 0; __pyx_t_37 = 0; __pyx_t_38 = 0; __pyx_lineno = __pyx_t_18; __pyx_clineno = __pyx_t_31; __pyx_filename = __pyx_t_40; goto __pyx_L1_error; __pyx_L64_error:; if (PY_MAJOR_VERSION >= 3) { __Pyx_XGIVEREF(__pyx_t_36); __Pyx_XGIVEREF(__pyx_t_37); __Pyx_XGIVEREF(__pyx_t_38); __Pyx_ExceptionReset(__pyx_t_36, __pyx_t_37, __pyx_t_38); } __Pyx_XDECREF(__pyx_t_7); __pyx_t_7 = 0; __Pyx_XDECREF(__pyx_t_6); __pyx_t_6 = 0; __Pyx_XDECREF(__pyx_t_5); __pyx_t_5 = 0; __pyx_t_36 = 0; __pyx_t_37 = 0; __pyx_t_38 = 0; goto __pyx_L1_error; } __pyx_L8:; }
