Metadata-Version: 2.5
Version: 1.9.7
Import-Name: python_discovery
Summary: Python interpreter discovery
Project-URL: Changelog, https://github.com/tox-dev/python-discovery/blob/main/docs/changelog.rst
Project-URL: Documentation, https://python-discovery.readthedocs.io
Project-URL: Homepage, https://github.com/tox-dev/python-discovery
Project-URL: Source, https://github.com/tox-dev/python-discovery
Project-URL: Tracker, https://github.com/tox-dev/python-discovery/issues
Maintainer-email: Bernát Gábor <gaborjbernat@gmail.com>
License-Expression: MIT
License-File: LICENSE
Keywords: discovery,interpreter,python
Classifier: Development Status :: 5 - Production/Stable
Classifier: Operating System :: MacOS :: MacOS X
Classifier: Operating System :: Microsoft :: Windows
Classifier: Operating System :: POSIX
Classifier: Programming Language :: Python :: 3 :: Only
Classifier: Programming Language :: Python :: 3.9
Classifier: Programming Language :: Python :: 3.10
Classifier: Programming Language :: Python :: 3.11
Classifier: Programming Language :: Python :: 3.14
Classifier: Programming Language :: Python :: 3.15
Classifier: Programming Language :: Python :: Implementation :: CPython
Classifier: Topic :: Software Development :: Libraries
Classifier: Topic :: Utilities
Requires-Python: >=3.9
Requires-Dist: filelock>=3.16.1
# [`python-discovery`](https://python-discovery.readthedocs.io/en/latest/)
[![PyPI](https://img.shields.io/pypi/v/python-discovery?style=flat-square)](https://pypi.org/project/python-discovery/)
[![Supported Python versions](https://img.shields.io/pypi/pyversions/python-discovery.svg)](https://pypi.org/project/python-discovery/)
[![Downloads](https://static.pepy.tech/badge/python-discovery/month)](https://pepy.tech/project/python-discovery)
[![check](https://github.com/tox-dev/python-discovery/actions/workflows/check.yaml/badge.svg)](https://github.com/tox-dev/python-discovery/actions/workflows/check.yaml)
[![Documentation Status](https://readthedocs.org/projects/python-discovery/badge/?version=latest)](https://python-discovery.readthedocs.io/en/latest/?badge=latest)
[![OpenSSF Scorecard](https://api.scorecard.dev/projects/github.com/tox-dev/python-discovery/badge)](https://scorecard.dev/viewer/?uri=github.com/tox-dev/python-discovery)
[![OpenSSF Best Practices](https://www.bestpractices.dev/projects/16262/badge)](https://www.bestpractices.dev/projects/16262)
## What is python-discovery?
`python-discovery` is a library for discovering Python interpreters installed on your machine. You may have multiple
Python versions from system packages, [pyenv](https://github.com/pyenv/pyenv), [mise](https://mise.jdx.dev/),
[asdf](https://asdf-vm.com/), [uv](https://docs.astral.sh/uv/), or the Windows registry (PEP 514). This library finds
the right one for you.
Give it a requirement like `python3.12` or `>=3.11,<3.13`, and it searches all known locations, verifies each candidate,
and returns detailed metadata about the match. Results are cached to disk so repeated lookups are fast.
The library runs on Python 3.9+ and discovers interpreters as old as Python 3.6; anything older is skipped with a
warning naming the version it found.
## Usage
```python
from pathlib import Path
from python_discovery import DiskCache, get_interpreter
cache = DiskCache(root=Path("~/.cache/python-discovery").expanduser())
result = get_interpreter("python3.12", cache=cache)
if result is not None:
    print(result.executable)  # /usr/bin/python3.12
    print(result.implementation)  # CPython
    print(result.version_info[:3])  # (3, 12, 1)
The `get_interpreter()` function accepts various specification formats:
- Absolute path: `/usr/bin/python3.12`
- Version: `3.12`
- Implementation prefix: `cpython3.12`
- [Version specifier](https://packaging.python.org/en/latest/specifications/version-specifiers/): `>=3.10`,
  `>=3.11,<3.13`
## Documentation
Full documentation is available at [python-discovery.readthedocs.io](https://python-discovery.readthedocs.io/en/latest/)
