Metadata-Version: 2.5
Version: 0.7.0
Summary: Python API for interacting with the Stiebel Eltron ISG web gateway via Modbus for controlling integral ventilation units and heat pumps.
Project-URL: Homepage, https://github.com/ThyMYthOS/python-stiebel-eltron
Project-URL: Issues, https://github.com/ThyMYthOS/python-stiebel-eltron/issues
Author: Manuel Stahl, Martin Fuchs
License-Expression: MIT
License-File: LICENSE
Keywords: modbus,stiebel-eltron,tecalor
Classifier: Programming Language :: Python :: 3.14
Classifier: Typing :: Typed
Requires-Python: <4,>=3.12
Requires-Dist: modbus-connection[pymodbus]<5,>=4.5.1
Requires-Dist: pymodbus<4,>=3.10.0
<p align=center>
    <img src="https://www.stiebel-eltron.de/content/dam/ste/logo-stiebel-eltron.svg"/>
</p>
<p align=center>
    <a href="https://pypi.org/project/pystiebeleltron/"><img src="https://img.shields.io/pypi/v/pystiebeleltron.svg"/></a>
    <a href="https://github.com/ThyMYthOS/python-stiebel-eltron/actions/workflows/test-python-package.yml"><img src="https://github.com/ThyMYthOS/python-stiebel-eltron/actions/workflows/test-python-package.yml/badge.svg"/></a>
    <!--a href='https://coveralls.io/github/fucm/python-stiebel-eltron?branch=master'><img src='https://coveralls.io/repos/github/fucm/python-stiebel-eltron/badge.svg?branch=master' alt='Coverage Status' /></a>
  <img src="https://img.shields.io/github/license/ThyMYthOS/python-stiebel-eltron.svg"/></a Maybe use https://github.com/marketplace/actions/coverage-badge-->
</p>
# python-stiebel-eltron
Python API for interacting with the STIEBEL ELTRON ISG web gateway via modbus for controlling integral ventilation units and heat pumps.
This module is based on the STIEBEL ELTRON [modbus user manual](https://www.stiebel-eltron.ch/content/dam/ste/ch/de/downloads/kundenservice/smart-home/Modbus/Modbus%20Bedienungsanleitung.pdf), but is not official, developed, supported or endorsed by Stiebel Eltron GmbH & Co. KG. For questions and other inquiries, use the issue tracker in this repo please.
## Requirements
You need to have [Python](https://www.python.org) installed.
* STIEBEL ELTRON Internet-Service Gateway [ISG WEB](https://www.stiebel-eltron.com/en/home/products-solutions/renewables/controller_energymanagement/internet_servicegateway/isg_web.html) with enabled [modbus module](https://www.stiebel-eltron.ch/de/home/service/smart-home/modbus.html)
  * You can call the STIEBEL ELTRON support, if your ISG does not have the modbus module enabled. They upgraded mine for free.
* STIEBEL ELTRON heatpumpt (compatible). Successfully used devices:
  * LWZ504e
  * LWZ304
* Network connection to the ISG WEB
## Installation
The package is available in the [Python Package Index](https://pypi.python.org/).
```bash
    $ pip install pystiebeleltron
## Example usage of the module
The sample below shows how to use this Python module (api for wpm heat pumps).
The API takes a [`ModbusUnit`](https://github.com/home-assistant-libs/modbus-connection). You own the connection: build it, hand a unit to the API, and close it when done. Building it performs no I/O — the first read establishes the link, and a link that drops later is re-established on the next request, over the same unit handle. Each register block is a component exposed on the API, and values are read as typed attributes (`None` when the register is unavailable).
```python
    import asyncio
    from modbus_connection import ModbusTcpParams
    from modbus_connection.pymodbus import ModbusConnection
    from pystiebeleltron.wpm import WpmStiebelEltronAPI
    async def main():
      connection = ModbusConnection(ModbusTcpParams(host='IP_ADDRESS_ISG', port=502))
      api = WpmStiebelEltronAPI(connection.for_unit(1))
      await api.async_update()
      print(f"outside temperature: {api.system_values.outside_temperature}")
      print(f"water comfort target temperature: {api.system_parameters.comfort_temperature}")
      # Writing a register:
      await api.system_parameters.write("comfort_temperature", 50)
      await connection.close()
    asyncio.run(main())
## License
``python-stiebel-eltron`` is licensed under MIT, for more details check LICENSE.
