Metadata-Version: 2.4
Version: 1.5.2
Summary: Monarch Money API for Python
Home-page: https://github.com/bradleyseanf/monarchmoneycommunity
Author: bradleyseanf
Author-email: bradleyseanf@users.noreply.github.com
License: MIT
Keywords: monarch money,financial,money,personal finance
Platform: any
Classifier: Development Status :: 4 - Beta
Classifier: Intended Audience :: Financial and Insurance Industry
Classifier: Topic :: Office/Business :: Financial
Requires-Dist: aiohttp>=3.14.3
Requires-Dist: gql==4.0
Requires-Dist: oathtool>=2.4.0
Dynamic: author
Dynamic: author-email
Dynamic: classifier
Dynamic: description
Dynamic: description-content-type
Dynamic: home-page
Dynamic: keywords
Dynamic: license
Dynamic: platform
Dynamic: requires-dist
Dynamic: summary
<p align="center">
  <img src=".github/assets/monarch-logo.svg" alt="Monarch Money Community logo" />
</p>
[![Maintenance](https://img.shields.io/maintenance/yes/2026)](https://github.com/bradleyseanf/monarchmoneycommunity/graphs/commit-activity)
[![Issues](https://img.shields.io/github/issues/bradleyseanf/monarchmoneycommunity)](https://github.com/bradleyseanf/monarchmoneycommunity/issues)
[![Pull Requests](https://img.shields.io/github/issues-pr/bradleyseanf/monarchmoneycommunity)](https://github.com/bradleyseanf/monarchmoneycommunity/pulls)
[![Contributors](https://img.shields.io/github/contributors/bradleyseanf/monarchmoneycommunity)](https://github.com/bradleyseanf/monarchmoneycommunity/graphs/contributors)
> [!WARNING]
> This project was forked from https://github.com/hammem/monarchmoney and would not be possible without it.
> The upstream fork is no longer maintained. This fork fixes issues that prevent the library from working today, including the Monarch Money domain change to `api.monarch.com`, auth persistence, and the `get_budget()` GraphQL query.
> Moving forward, please report issues here.
# Monarch Money Community
Python library for accessing [Monarch Money](https://www.monarchmoney.com) data.
# Installation
## From Source Code
Clone this repository from Git
`git clone https://github.com/bradleyseanf/monarchmoneycommunity.git`
## Via `pip`
`pip install monarchmoneycommunity`
Import the library as `monarchmoney` after installation.
This package pins `gql` to `4.0`.
# Instantiate & Login
There are two ways to use this library: interactive and non-interactive.
## Interactive
If you're using this library in something like iPython or Jupyter, you can run an interactive-login which supports multi-factor authentication:
```python
from monarchmoney import MonarchMoney
mm = MonarchMoney()
await mm.interactive_login()
This will prompt you for the email, password and, if needed, the multi-factor token.
## Non-interactive
For a non-interactive session, you'll need to create an instance and login:
```python
mm = MonarchMoney()
await mm.login(email, password)
This may throw a `RequireMFAException`.  If it does, you'll need to get a multi-factor token and call the following method:
```python
from monarchmoney import MonarchMoney, RequireMFAException
mm = MonarchMoney()
try:
except RequireMFAException:
        await mm.multi_factor_authenticate(email, password, multi_factor_code)
Alternatively, you can provide the MFA Secret Key. The MFA Secret Key is found when setting up the MFA in Monarch Money by going to Settings -> Security -> Enable MFA -> and copy the `Two-factor text code`. Then provide it in the login() method:
```python
mm = MonarchMoney()
await mm.login(
        email=email,
        password=password,
        save_session=False,
        use_saved_session=False,
        mfa_secret_key=mfa_secret_key,
# Use a Saved Session
You can easily save your session for use later on.  While we don't know precisely how long a session lasts, authors of this library have found it can last several months.
```python
mm = MonarchMoney()
# Save it for later, no more need to login!
mm.save_session()
Once you've logged in, you can simply load the saved session to pick up where you left off.
```python
mm = MonarchMoney()
mm.load_session()
# Then, start accessing data!
await mm.get_accounts()
# Accessing Data
As of writing this README, the following methods are supported:
## Non-Mutating Methods
<table>
  <thead>
    <tr>
      <th width="280">Method</th>
      <th>Description</th>
    </tr>
  </thead>
  <tbody>
    <tr>
      <td><code>get_accounts</code></td>
      <td>gets all the accounts linked to Monarch Money</td>
    </tr>
    <tr>
      <td><code>get_account_holdings</code></td>
      <td>gets all of the securities in a brokerage or similar type of account</td>
    </tr>
    <tr>
      <td><code>get_account_type_options</code></td>
      <td>all account types and their subtypes available in Monarch Money</td>
    </tr>
    <tr>
      <td><code>get_account_history</code></td>
      <td>gets all daily account history for the specified account</td>
    </tr>
    <tr>
      <td><code>get_institutions</code></td>
      <td>gets institutions linked to Monarch Money</td>
    </tr>
    <tr>
      <td><code>get_budgets</code></td>
      <td>all the budgets and the corresponding actual amounts</td>
    </tr>
    <tr>
      <td><code>get_credit_history</code></td>
      <td>gets credit score snapshots and Spinwheel user details</td>
    </tr>
    <tr>
      <td><code>get_subscription_details</code></td>
      <td>gets the Monarch Money account's status (e.g. paid or trial)</td>
    </tr>
    <tr>
      <td><code>get_recurring_transactions</code></td>
      <td>gets the future recurring transactions, including merchant and account details</td>
    </tr>
    <tr>
      <td><code>get_transactions_summary</code></td>
      <td>gets the transaction summary data from the transactions page</td>
    </tr>
    <tr>
      <td><code>get_transactions</code></td>
      <td>gets transaction data, defaults to returning the last 100 transactions; can also be searched by date range</td>
    </tr>
    <tr>
      <td><code>find_duplicate_transactions</code></td>
      <td>finds duplicate transaction groups using Plaid-reported fields</td>
    </tr>
      <tr>
        <td><code>get_transaction_categories</code></td>
        <td>gets all of the categories configured in the account</td>
      </tr>
    <tr>
      <td><code>get_transaction_category_groups</code></td>
      <td>all category groups configured in the account</td>
    </tr>
    <tr>
      <td><code>get_transaction_details</code></td>
      <td>gets detailed transaction data for a single transaction</td>
    </tr>
    <tr>
      <td><code>get_transaction_splits</code></td>
      <td>gets transaction splits for a single transaction</td>
    </tr>
    <tr>
      <td><code>get_transaction_tags</code></td>
      <td>gets all of the tags configured in the account</td>
    </tr>
    <tr>
      <td><code>get_cashflow</code></td>
      <td>gets cashflow data (by category, category group, merchant and a summary)</td>
    </tr>
    <tr>
      <td><code>get_cashflow_summary</code></td>
      <td>gets cashflow summary (income, expense, savings, savings rate)</td>
    </tr>
    <tr>
      <td><code>is_accounts_refresh_complete</code></td>
      <td>gets the status of a running account refresh</td>
    </tr>
  </tbody>
</table>
## Mutating Methods
<table>
  <thead>
    <tr>
    </tr>
  </thead>
  <tbody>
    <tr>
      <td><code>delete_transaction_category</code></td>
      <td>deletes a category for transactions</td>
    </tr>
    <tr>
      <td><code>delete_transaction_categories</code></td>
      <td>deletes a list of transaction categories for transactions</td>
    </tr>
    <tr>
      <td><code>create_transaction_category</code></td>
      <td>creates a category for transactions</td>
    </tr>
    <tr>
      <td><code>request_accounts_refresh</code></td>
      <td>requests a synchronization / refresh of all accounts linked to Monarch Money. This is a <strong>non-blocking call</strong>. If the user wants to check on the status afterwards, they must call <code>is_accounts_refresh_complete</code>.</td>
    </tr>
    <tr>
      <td><code>request_accounts_refresh_and_wait</code></td>
      <td>requests a synchronization / refresh of all accounts linked to Monarch Money. This is a <strong>blocking call</strong> and will not return until the refresh is complete or no longer running.</td>
    </tr>
    <tr>
      <td><code>create_transaction</code></td>
      <td>creates a transaction with the given attributes</td>
    </tr>
    <tr>
      <td><code>update_transaction</code></td>
      <td>modifies one or more attributes for an existing transaction</td>
    </tr>
    <tr>
      <td><code>update_reoccuring</code></td>
      <td>updates recurring merchant settings (frequency, amount, date, active status)</td>
    </tr>
    <tr>
      <td><code>delete_transaction</code></td>
      <td>deletes a given transaction by the provided transaction id</td>
    </tr>
    <tr>
      <td><code>update_transaction_splits</code></td>
      <td>modifies how a transaction is split (or not)</td>
    </tr>
    <tr>
      <td><code>create_transaction_tag</code></td>
      <td>creates a tag for transactions</td>
    </tr>
    <tr>
      <td><code>set_transaction_tags</code></td>
      <td>sets the tags on a transaction</td>
    </tr>
    <tr>
      <td><code>set_budget_amount</code></td>
      <td>sets a budget's value to the given amount (date allowed, will only apply to month specified by default). A zero amount value will <code>unset</code> or <code>clear</code> the budget for the given category.</td>
    </tr>
    <tr>
      <td><code>update_flexible_budget</code></td>
      <td>updates the Flexible budget bucket amount for a month</td>
    </tr>
    <tr>
      <td><code>update_flex_rollover_settings</code></td>
      <td>updates the Flex rollover settings, including the start month and starting balance</td>
    </tr>
    <tr>
      <td><code>reset_budget</code></td>
      <td>resets the budget for a month back to its defaults</td>
    </tr>
      <tr>
        <td><code>create_manual_account</code></td>
        <td>creates a new manual account</td>
      </tr>
    <tr>
      <td><code>delete_account</code></td>
      <td>deletes an account by the provided account id</td>
    </tr>
    <tr>
      <td><code>update_account</code></td>
      <td>updates settings and/or balance of the provided account id</td>
    </tr>
    <tr>
      <td><code>upload_account_balance_history</code></td>
      <td>uploads account history csv file for a given account</td>
    </tr>
    <tr>
      <td><code>upload_attachment</code></td>
      <td>uploads a binary file for a given transaction by the provided transaction id</td>
    </tr>
    <tr>
      <td><code>upload_receipt_to_inbox(file_content, filename)</code></td>
      <td>uploads a receipt image to the Monarch general receipt inbox (not attached to a specific transaction), triggering Monarch's AI to auto-categorize and match it</td>
    </tr>
  </tbody>
</table>
## Typed Client
If you want typed account, subscription, and holdings models, import the typed client:
```python
from typedmonarchmoney import TypedMonarchMoney
mm = TypedMonarchMoney()
accounts = await mm.get_accounts()
The typed client returns `MonarchAccount`, `MonarchSubscription`, `MonarchCashflowSummary`, and `MonarchHoldings` objects instead of raw dictionaries.
# Contributing
Any and all contributions - code, documentation, feature requests, feedback - are welcome!
If you plan to submit up a pull request, you can expect a timely review.  There aren't any strict requirements around the environment you'll need.
# FAQ
**How do I use this API if I login to Monarch via Google?**
If you currently use Google or 'Continue with Google' to access your Monarch account, you'll need to set a password to leverage this API.  You can set a password on your Monarch account by going to your [security settings](https://app.monarchmoney.com/settings/security).
Don't forget to use a password unique to your Monarch account and to enable multi-factor authentication!
# Projects Using This Library
*Open a PR adjusting the README if you would like to be added to this list*
*Disclaimer: These projects are neither affiliated nor endorsed by Monarch Money.*
- [mmoney-cli](https://github.com/theFong/mmoney-cli) - Access your MonarchMoney data via CLI
- [monarchmoney-typed](https://github.com/jeeftor/monarchmoney-typed) - MonarchMoney Home Assistant Integration
- [monarch-mcp-server](https://github.com/robcerda/monarch-mcp-server) - Model Context Protocol (MCP) server for integrating with Monarch Money.
