imageio/__init__.py,sha256=sNTBhCbAmhCt2d4Lsax29o2wUUhYfS_F1tolZUvnT2k,3355
imageio/__main__.py,sha256=ML406biyXilwpd81xaoG7-eC32DkJi3jW3oSkWf_SC0,5266
imageio/freeze.py,sha256=hi9MNZz-ridgQBWcAqnd92sULek2lgmBSTmuott5lus,170
imageio/py.typed,sha256=47DEQpj8HBSa-_TImW-5JCeuQeRkm5NMpJWZG3hSuFU,0
imageio/testing.py,sha256=iBs_EccxQQ2Zm6Hk-wbA49ISBbvn8H7sWWTu4j6rDes,1595
imageio/typing.py,sha256=qrvyFrVIs21bZCE0x802l1R-xCV4DlCNaTzPiJEZbzc,349
imageio/v2.py,sha256=1KJ5z8Ji2nnAdy_K3vIpysG2Kg7rIcPiadNG1pwKx-E,21563
imageio/v2.pyi,sha256=JFaA8K8Ao9IQNBtNbnOpXLaOxQ2s6gzA3VFcdvPDFjA,2430
imageio/v3.py,sha256=its_COjJawMbIQcLbHoEy4KyKzNewoISt_1obtBWXdE,9446
imageio/v3.pyi,sha256=pGHIL0BX4IN-xlmhRXnbNIjuMPqmSw8aamc5M-gHbRA,1350
imageio/config/__init__.py,sha256=8NOpL5ePrkiioJb9hRBw3rydc4iNZkMwp7VdQlP4jDc,307
imageio/config/extensions.py,sha256=-C0ogWErxWxUlOpEBHfQfFf3moECTo-ZrRMj9GLfddc,47078
imageio/config/extensions.pyi,sha256=X9d4plQJc8zFsHRzIl6kcdgmN-x9ldEtQ9iVxepkRHI,606
imageio/config/plugins.py,sha256=soMiQHl_nyHIc14hoCBGtzgmsxviNPdRd-Nqd1Vh9e8,20406
imageio/config/plugins.pyi,sha256=pzH8pacqU5uldsvYOee_nhd2Hkk3mR8VQBtjeVnkkHY,706
imageio/core/__init__.py,sha256=ka3YhBNXYqsnu9n1Db60DhHTn5tylYzfED_RYXgMz8U,638
imageio/core/fetching.py,sha256=OobljhXSiDlBb7fPVTIpMlMe9rgTEUWyDZjH1c9krcM,9148
imageio/core/findlib.py,sha256=EENvtyMBlZpIbrsS2dcE9koiBX-vLGjdcBziXA0kTJE,5549
imageio/core/format.py,sha256=-OXKaezyyYM6Srs5rht8oD2-POO99qh45A_Uz9byIKU,30916
imageio/core/format.pyi,sha256=5BZF-xwp5BmG8C5ahfL48z_a2MITN0509Uf6f1phZRw,3336
imageio/core/imopen.py,sha256=0E-bsNGAVwHXBO4XMAnEZPcYU2ckkUhXSQ9j-ehEaNo,9544
imageio/core/imopen.pyi,sha256=8jLI2tKUTqFe79mccw95fRAIanJPHi6gQmzB2ClESlk,2215
imageio/core/legacy_plugin_wrapper.py,sha256=DcbIfcjWH4P5w48RaWRutkpy1gNYU18bcKEoq61hcok,12136
imageio/core/legacy_plugin_wrapper.pyi,sha256=X1ksqM_V4KJkUhQ69PfIc44vf26GMo3j0L8ofj5Tu-g,1065
imageio/core/request.py,sha256=sd9XKIln32HH_2xEBhU5DG9zo6xRge65TEQmMy6On9g,28230
imageio/core/request.pyi,sha256=etw3vjIRdE73Zqu6S35acooQOUODi6ittHKGJlVFnj0,2369
imageio/core/util.py,sha256=GuofrpeemzA0zj9AnDnwH3G6cpG3IgxjkxdmToPEBlk,17997
imageio/core/v3_plugin_api.py,sha256=w8wUjlT7_N6aU76DYGF3ubYYfUHTyfStvK5_xosZLPQ,15560
imageio/plugins/__init__.py,sha256=xpEfuiMIAkKoqeqdw21dW6UuInL-pnJG3fCIhx1QpIs,3468
imageio/plugins/_bsdf.py,sha256=eElZIqDchs_p5rj9nyquUYegysJvKW34yUaRAnkQH7Y,32758
imageio/plugins/_dicom.py,sha256=wLJi8XI9BlM5nSy3u1e-AHM_jBA4awF6TlrPgyfgIpM,34071
imageio/plugins/_freeimage.py,sha256=6_pL4HMax82KMLaOwaedfQBuJ5LI2JT4KEjF0SsdVH0,51757
imageio/plugins/_swf.py,sha256=FTbXLPVT6bJQYzsmK15ToiU9EeutcpNldu_MiZeLT3g,25769
imageio/plugins/_tifffile.py,sha256=sRf_JXVA7vvSPxvuzdL_bl9PXs03q5eXbrOEu66ISqs,371578
imageio/plugins/bsdf.py,sha256=F85Urav6qkr-GPOoL3Vk9aIvfwPewxxWU0uBqXIIaTg,12865
imageio/plugins/dicom.py,sha256=RCTbtu85NYyW19DX6-jBdm5lSq3k55lCUoWB0P2NUog,13016
imageio/plugins/example.py,sha256=8t2GZGoecuf4PRonqdjrS2BZq-LsHy4BVFcH3JMf2s4,5499
imageio/plugins/feisem.py,sha256=2hpTRJzwt71HB_g671WuBRp0MahnF7uXhe-XjiphpG0,3359
imageio/plugins/ffmpeg.py,sha256=piW75hVO32K9AuvSpBRClI3QhC3bwDgwC8Wxj6P2qnk,30141
imageio/plugins/fits.py,sha256=XnlmeC79sIiIPd_7IDx05-p3-b2unO4CVR0nWAA4ph0,4531
imageio/plugins/freeimage.py,sha256=SuzYuGvCtZIiXIr51dWRTl5CATzRUqb8pNCSIg9YZv8,14645
imageio/plugins/freeimagemulti.py,sha256=VGsN52E9_mxpI-KY0mT9ui46oKFiFQBnhXKepRkdm3Q,11295
imageio/plugins/gdal.py,sha256=3to_O_Jeo5CHdlHmkN398B_i9pi5YAKUbM1mD5Zm_jc,1652
imageio/plugins/grab.py,sha256=g6KbKVQUquHro_BW6He7NNmivVV-UtcsCJoDt3rdly0,2776
imageio/plugins/lytro.py,sha256=QSR79bTw1rop2LjcHCr6KGdXo3tzlWPOrGPLuAyf1uA,25314
imageio/plugins/npz.py,sha256=7ZQr-4lQEKbfjaF6rOmpq9pQgDTUHvkZa_NHZkJWBQo,2670
imageio/plugins/opencv.py,sha256=C2nBQQFDXuz6LOyJ1P3-S6e_7h-pJgLow7h7w4Si2tg,11629
imageio/plugins/pillow.py,sha256=VHSk-ExnO_nDs5rq9Ij-Qp63KFo2vYofoGBlJ3kviQI,23060
imageio/plugins/pillow_info.py,sha256=Bt5iJtQnAh6mGViPIxhxRQPNidqay9-6BleAJZkhN1w,36624
imageio/plugins/pillow_legacy.py,sha256=VHRTSgHUTLfFOFRp2LvzEYRq6FPWbO3-fXu4Nfzxa4A,32234
imageio/plugins/pillowmulti.py,sha256=uHLbYZ5lYDMuV52KAp9nvrJ8VKRF9Jc754zndWRZUfY,11808
imageio/plugins/pyav.py,sha256=WBvpTmDbcK7hO2p9q9TeVJAC0HPDnLqsptE9ogJU1T4,47638
imageio/plugins/pydicom.py,sha256=8gGCq6IaFtI2vxDTkuv0vDnQE3avqyssyGMY0UZhzfY,36762
imageio/plugins/rawpy.py,sha256=TiKGLyipJNfwbVk3qhoWFAPKQMMYrPjVgxXv7Fnrv1o,5947
imageio/plugins/simpleitk.py,sha256=1A5fSg_75nfOmHtSBwF588yxyDt4KTNcYDrwPA0T1-I,4106
imageio/plugins/spe.py,sha256=o71wpXKAV8jrMhMQ_6MEuo_HrSJ9vpDSW54tjTML3l4,32170
imageio/plugins/swf.py,sha256=Xw3KTcH4HFb7ImnySZGbTBACW30w4gD2uo78SDg8-D8,11754
imageio/plugins/tifffile.py,sha256=Ba9i3La5BrQnWZHk48KB-5xAnvInJT8mn0BqKJ8JHxc,20663
imageio/plugins/tifffile_v3.py,sha256=f0WjaoLUZPoqXUyWg_nwUVBTbIRm4gxywP3mNaR2W-0,15371
imageio-2.38.2.dist-info/licenses/LICENSE,sha256=xFPPE2i7ngCeTX5TNPx4UR5mUxamEu9U7k_hJFZ4_iw,1307
imageio-2.38.2.dist-info/METADATA,sha256=dJkcJEJEN5QEHNWXo0ygs-DKex858BsoBF_92q5M0_c,9697
imageio-2.38.2.dist-info/WHEEL,sha256=mOdXR9C3wMVov7cSY8PY-XCzo3SmmWCHvGQr5csJoao,91
imageio-2.38.2.dist-info/entry_points.txt,sha256=0-yB6XGfrx1OMPw_xigPramTcwi5M4jX6L5Edrz0OoU,130
imageio-2.38.2.dist-info/top_level.txt,sha256=iSUjc-wEw-xbMTvMOSKg85n0-E7Ms--Mo4FLMC-J2YM,8
imageio-2.38.2.dist-info/RECORD,,
