Metadata-Version: 2.4
Version: 0.1.6
Summary: Async Python client for energieleser devices (stromleser, gasleser, wasserleser, wärmeleser).
License: MIT
License-File: LICENSE
Keywords: energieleser,stromleser,gasleser,wasserleser,waermeleser,home-assistant,smart-meter
Author: nineti GmbH
Author-email: info@energieleser.de
Maintainer: Ajinkya Gokhale
Maintainer-email: ajinkya.gokhale@nineti.de
Requires-Python: >=3.11,<4.0
Classifier: Development Status :: 4 - Beta
Classifier: Framework :: AsyncIO
Classifier: Operating System :: OS Independent
Classifier: Programming Language :: Python :: 3.11
Classifier: Programming Language :: Python :: 3.14
Classifier: Programming Language :: Python :: 3 :: Only
Classifier: Topic :: Home Automation
Classifier: Typing :: Typed
Requires-Dist: aiohttp (>=3.14)
Project-URL: Bug Tracker, https://github.com/nineti-GmbH/energieleser.py/issues
Project-URL: Homepage, https://energieleser.de
Project-URL: Maintainer, https://github.com/AjinkyaGokhale
Project-URL: Repository, https://github.com/nineti-GmbH/energieleser.py
# energieleser.py
[![PyPI](https://img.shields.io/pypi/v/energieleser.svg)](https://pypi.org/project/energieleser/)
[![Python](https://img.shields.io/pypi/pyversions/energieleser.svg)](https://pypi.org/project/energieleser/)
[![License: MIT](https://img.shields.io/badge/license-MIT-green.svg)](https://github.com/nineti-GmbH/energieleser.py/blob/main/LICENSE)
> Async Python client for energieleser smart meter devices.
Talks to the device's local HTTP API and returns typed dataclasses for **stromleser.one**, **gasleser**, **gasleser.pulse**, **wasserleser** and **wärmeleser**. Powers the Home Assistant integration.
## Installing / Getting started
```shell
pip install energieleser
```python
import asyncio
from energieleser import EnergieleserClient
async def main() -> None:
    async with EnergieleserClient("192.168.1.100") as client:
        device = await client.get_device()
        print(device.device_id, device.device_type)
asyncio.run(main())
More examples in [docs/usage.md](https://github.com/nineti-GmbH/energieleser.py/blob/main/docs/usage.md).
## Features
- Async HTTP client built on `aiohttp`.
- Typed, frozen, slotted dataclasses per device family.
- Automatic device-type detection from `device_id` prefix.
- Optional `Measurement(value, unit)` fields — missing readings stay `None` instead of raising.
- Bring-your-own `aiohttp.ClientSession`, or let the client manage one.
- Structured exception hierarchy for clean error handling.
## Configuration
`EnergieleserClient(host, port=80, *, session=None, request_timeout=10.0)`
| Argument          | Type                          | Default | Description        |
| `host`            | `str`                         | —       | Device IP address or hostname.                                             |
| `port`            | `int`                         | `80`    | Device HTTP port.                                                          |
| `session`         | `aiohttp.ClientSession\|None` | `None`  | Reuse an existing session. If `None`, the client creates and owns its own. |
| `request_timeout` | `float`                       | `10.0`  | Per-request timeout in seconds.                                            |
## Documentation
- [Usage](https://github.com/nineti-GmbH/energieleser.py/blob/main/docs/usage.md) — examples, shared sessions
- [Supported devices](https://github.com/nineti-GmbH/energieleser.py/blob/main/docs/devices.md) — device families, fields
- [Exceptions](https://github.com/nineti-GmbH/energieleser.py/blob/main/docs/exceptions.md) — exception hierarchy
- [Development](https://github.com/nineti-GmbH/energieleser.py/blob/main/docs/development.md) — local setup, lint, tests
- [Publishing](https://github.com/nineti-GmbH/energieleser.py/blob/main/docs/publishing.md) — release workflow
- [Contributing](https://github.com/nineti-GmbH/energieleser.py/blob/main/docs/contributing.md) — how to contribute
## Links
- PyPI: https://pypi.org/project/energieleser/
- Repository: https://github.com/nineti-GmbH/energieleser.py
- Issue tracker: https://github.com/nineti-GmbH/energieleser.py/issues
- Homepage: https://energieleser.de
## Licensing
The code in this project is licensed under the MIT license — see [LICENSE](https://github.com/nineti-GmbH/energieleser.py/blob/main/LICENSE).
© [nineti GmbH](https://energieleser.de)
