Metadata-Version: 2.5
Version: 0.4.0
Summary: Asynchronous client for the Trimlight V3 local HTTP API
Project-URL: Homepage, https://github.com/spdevpro/trimlight-ha-api
Project-URL: Source, https://github.com/spdevpro/trimlight-ha-api
Project-URL: Issues, https://github.com/spdevpro/trimlight-ha-api/issues
License-Expression: MIT
License-File: LICENSE
Classifier: Development Status :: 3 - Alpha
Classifier: Framework :: AsyncIO
Classifier: Programming Language :: Python :: 3.14
Classifier: Typing :: Typed
Requires-Python: >=3.14
Requires-Dist: aiohttp>=3.13.0
Requires-Dist: yarl>=1.20.0
# aiotrimlight
[![CI](https://github.com/spdevpro/trimlight-ha-api/actions/workflows/ci.yml/badge.svg)](https://github.com/spdevpro/trimlight-ha-api/actions/workflows/ci.yml)
`aiotrimlight` is an asynchronous Python client for the Trimlight Edge Pro local HTTP API. It provides device metadata, runtime light state, high-level power, brightness and static color control, and saved scene queries and playback.
## Requirements
- Python 3.14 or newer.
- A Trimlight controller with the V3 local HTTP API.
- The client and controller must be reachable on the same local network.
## Installation
```shell
python -m pip install aiotrimlight
For source development:
```shell
git clone https://github.com/spdevpro/trimlight-ha-api.git
cd trimlight-ha-api
uv sync --locked --group test --python 3.14
## Usage
```python
import asyncio
from aiohttp import ClientSession
from aiotrimlight import TrimlightClient
async def main() -> None:
    async with ClientSession(trust_env=False) as session:
        client = TrimlightClient("192.0.2.10", session)
        device = await client.get_device_info()
        state = await client.get_light_state()
        print(device, state)
        await client.set_light_state(
            on=True,
            brightness=64,
            red=255,
            green=255,
            blue=255,
            warm_white=0,
            cold_white=0,
        print(state)
asyncio.run(main())
Replace the example address with the controller's LAN IP address.
`trust_env=False` prevents system proxy settings from routing local controller traffic through an HTTP proxy.
Discovery metadata exposes both the normalized DID and the full MAC address encoded
by the firmware:
```python
from aiotrimlight import parse_discovery_properties
discovery = parse_discovery_properties({"did": "544c0003020000000001"})
print(discovery.did)  # 544c0003020000000001
print(discovery.mac_address)  # 02:00:00:00:00:01
## Development
```shell
uv run --no-sync pytest --cov=aiotrimlight --cov-branch --cov-report=term-missing
uv run --no-sync ruff check .
uv run --no-sync ruff format --check .
uv run --no-sync mypy src tests
uv build --no-sources --clear
uv run --no-sync twine check dist/*
> [!WARNING]
> `examples/turn_on.py` sends commands to real Trimlight hardware. Review the configured host and output values before running it.
## Releases
Stable releases are built and published through GitHub Actions using PyPI
Trusted Publishing.
## License
`aiotrimlight` is distributed under the MIT License. See [LICENSE](LICENSE).
