Metadata-Version: 2.4
Version: 3.4.1
Summary: Powerview blinds API wrapper
Home-page: https://github.com/sander76/aio-powerview-api
Author: Sander Teunissen
License: MIT
Classifier: Programming Language :: Python
Classifier: Programming Language :: Python :: 3.7
Classifier: Programming Language :: Python :: 3.8
Classifier: Programming Language :: Python :: 3.9
Classifier: Programming Language :: Python :: Implementation :: CPython
Classifier: Programming Language :: Python :: Implementation :: PyPy
Requires-Python: >=3.5.0
License-File: LICENSE
Requires-Dist: aiohttp<4,>=3.7.4
Dynamic: author
Dynamic: classifier
Dynamic: description
Dynamic: description-content-type
Dynamic: home-page
Dynamic: license
Dynamic: license-file
Dynamic: requires-dist
Dynamic: requires-python
Dynamic: summary
AioPvApi
A python asyncio API for PowerView blinds.
Written for Home-Assistant. Adding features as I go...
Have a look at the examples folder for some guidance how to use it.
Links
- https://home-assistant.io/
- https://www.hunterdouglas.com/operating-systems/powerview-motorization
Changelog
**v3.4.1**
- Correct erroneous naming in function naming
- Handle empty responses from gen 1 hubs
- Handle scenemembers api endpoint case sensitive
- Update automation primary key to eventid
**v3.4.0**
- BREAKING CHANGE: Update SceneMembers api to use Scene ID as index over Shade ID
- Patch bad logging of errornous warning message
- Update scene tests to use fixtures
**v3.3.0**
- Limit battery max to 100%
- Move co-ordinator of shades from HA to API Core
- Remove shade limiter causing issues with tilt shades
**v3.2.1**
- Add type 57 (Carole Roman Shades)
**v3.2.0**
- Bug fix for gen1 shades with bad data
- Fix bad close position on tilt shades
- Add hub registration capability
- Revert gen 1/2 shades to previous power type mapping
- Add retry logic to battery status requests
**v3.1.2**
- Add type 72 (Silhoutte)
**v3.1.1**
- Fix missed timeout blocks and handle in websession
**v3.1.0**
- General docstring updates
- Handle kwargs in websessions for management of timeout internally
- Update error handling in tools
- Handle empty values and zeros better
- Add type 53 (Sonnette) and type 95 (Aura Illuminated, Roller). Note: *Type 95 do not support light control*
- Handle PowerType 11 + 12. Both are fixed and cannot be edited
**v3.0.2**
- Add type 19 (Provenance Woven Wood)
- Fix Positioning for ShadeVerticalTiltAnywhere + ShadeTiltOnly (Mid only)
- Fix logging regression on initial setup
- Fixes for ShadeVerticalTiltAnywhere + ShadeTiltOnly
- Fix tests
- Remove unneeded declerations
- Fix shade position reporting for v2 shades
- Handle empty hub data being returned
**v3.0.1**
- Raw hub data updates made via defined function (`request_raw_data`, `request_home_data`, `request_raw_firware`, `detect_api_version`)
- Parse Gen 3 hub name based on serial + mac
- Find API version based on firmware revision
- Remove async_timeout and move to asyncio
**v3.0.0**
- Major overhaul to incorporate gateway version 3 API.  Version can be automatically detected or manually specified.
- UserData class is deprecated and replaced with Hub.
- ShadePosition class now replaces the raw json management of shades in support of cross generational management.
- Schedules / Automations are now supported by the API
- New get_*objecttype* methods available to returned structured data objects for consistent management
**v2.0.4**
- Add Type 10 - SkyLift
- Handle calls to update shade position during maintenance
- Raise error directly on hub calls instead of logger
**v2.0.3**
- Add Type 26, 27 & 28 - Skyline Panels
- Force capability 1 for Type 44 - Twist
- Align class name standard
**v2.0.2**
- Bug Fix to handle shades with unexpected json responses
**v2.0.1**
- Invert type 3 & 4 to match api documentation from hunter douglas
- Add type 10
**v2.0.0**
- Add support for all known shade types
- Fallback to shade recognition based on capability
- Clamping to prevent MIN_POSITION or MAX_POSITION being exceeded
- Code refactoring
**v1.6.19**
- Add endpoints and handle 423 response
- Remove loop as argument
