simplejson-3.20.1.dist-info/WHEEL,sha256=XPgYmeBC_Rg0MCVBgXqO165pafrAlEvfR4FBK_d_Vdw,112
simplejson-3.20.1.dist-info/METADATA,sha256=YrXCM4tahy43t5THZ6eJuaBJhmRoJlIOzyLaiqAcUb4,3328
simplejson-3.20.1.dist-info/top_level.txt,sha256=ohU816e0ltfT8aBFol4_XY1q9GBh9tEBbcPpNn49200,11
simplejson-3.20.1.dist-info/RECORD,,
simplejson-3.20.1.dist-info/LICENSE.txt,sha256=_KoeMTqZMEMi4uCDbqTufYOc6aSAQ485IqhT7f3eEp8,10375
simplejson/_speedups.cpython-313-x86_64-linux-musl.so,sha256=v9lxeNYIWlmVJRN4gmP2qj-KwLqqJk8oC9gG-PRaWN0,232520
simplejson/__init__.py,sha256=TVmnBn3yAe9XjEQTnxCa7BDZnjSfaKS06QR4y0sFcZg,23497
simplejson/tests/test_dump.py,sha256=MV8NB24gSyhSseFFeRBzJMRNocnP0VC-PmfpHFJ8iVM,10570
