simplejson-3.20.1.dist-info/WHEEL,sha256=_cnBs0VTJSy6TRwvMOZQ_5mpn0qxt2Jp1Y6Uq6s1G8k,110
simplejson-3.20.1.dist-info/METADATA,sha256=YrXCM4tahy43t5THZ6eJuaBJhmRoJlIOzyLaiqAcUb4,3328
simplejson-3.20.1.dist-info/top_level.txt,sha256=ohU816e0ltfT8aBFol4_XY1q9GBh9tEBbcPpNn49200,11
simplejson-3.20.1.dist-info/RECORD,,
simplejson-3.20.1.dist-info/LICENSE.txt,sha256=_KoeMTqZMEMi4uCDbqTufYOc6aSAQ485IqhT7f3eEp8,10375
simplejson/__init__.py,sha256=TVmnBn3yAe9XjEQTnxCa7BDZnjSfaKS06QR4y0sFcZg,23497
simplejson/_speedups.cpython-313-i386-linux-musl.so,sha256=yDiUSYStoJLoRMMLLITE90s1nZBG0X1Ix4GM4pcyG9Q,221344
simplejson/tests/test_dump.py,sha256=MV8NB24gSyhSseFFeRBzJMRNocnP0VC-PmfpHFJ8iVM,10570
