simplejson-3.19.3.dist-info/RECORD,,
simplejson-3.19.3.dist-info/WHEEL,sha256=IiBzv0eL-WQm1cvozrTnDizrOh226FgGsB33uR2ppag,113
simplejson-3.19.3.dist-info/top_level.txt,sha256=ohU816e0ltfT8aBFol4_XY1q9GBh9tEBbcPpNn49200,11
simplejson-3.19.3.dist-info/LICENSE.txt,sha256=_KoeMTqZMEMi4uCDbqTufYOc6aSAQ485IqhT7f3eEp8,10375
simplejson-3.19.3.dist-info/METADATA,sha256=CLwgaPjfXxGsIy4YnOr5Gvw4u4tJ-WUYKNMGNAyL0AM,3153
simplejson/_speedups.cpython-313-aarch64-linux-musl.so,sha256=_L_WJuGztE5JdK80gAWYzBF_nx_e3ybP0bCzQx2dBs8,241456
simplejson/__init__.py,sha256=vgozbo7UnLXw2dtr53tMAA4PkYu01IX9ZGJ_Vexmmpo,23497
simplejson/tests/test_dump.py,sha256=iD3z8E7MKCApU3bFsAdBeKHl_4hLIDrhPSIfpbGhjJc,10356
