simplejson-3.19.3.dist-info/RECORD,,
simplejson-3.19.3.dist-info/WHEEL,sha256=_AGXwykbnxpJoqcCtBlsZzWB12ny_KIGhqICRNQUWmY,112
simplejson-3.19.3.dist-info/top_level.txt,sha256=ohU816e0ltfT8aBFol4_XY1q9GBh9tEBbcPpNn49200,11
simplejson-3.19.3.dist-info/LICENSE.txt,sha256=_KoeMTqZMEMi4uCDbqTufYOc6aSAQ485IqhT7f3eEp8,10375
simplejson-3.19.3.dist-info/METADATA,sha256=CLwgaPjfXxGsIy4YnOr5Gvw4u4tJ-WUYKNMGNAyL0AM,3153
simplejson/_speedups.cpython-312-x86_64-linux-musl.so,sha256=2EIp1JLoI4rHAe_CPwuiax3t7hhMivlHjHVM95NbfFo,232376
simplejson/__init__.py,sha256=vgozbo7UnLXw2dtr53tMAA4PkYu01IX9ZGJ_Vexmmpo,23497
simplejson/tests/test_dump.py,sha256=iD3z8E7MKCApU3bFsAdBeKHl_4hLIDrhPSIfpbGhjJc,10356
