simplejson/_speedups.cpython-311-i386-linux-musl.so,sha256=ZUlqQpRQOx1gzXEF3mlEBQN3tyuDNm0fsAmGjYXhwJE,55572
simplejson/__init__.py,sha256=khSIRChhmeAMXtG7D6SPoHMvP3JE4CzKgT7rs7q2uMU,23497
simplejson/tests/test_dump.py,sha256=iD3z8E7MKCApU3bFsAdBeKHl_4hLIDrhPSIfpbGhjJc,10356
simplejson-3.19.2.dist-info/top_level.txt,sha256=ohU816e0ltfT8aBFol4_XY1q9GBh9tEBbcPpNn49200,11
simplejson-3.19.2.dist-info/WHEEL,sha256=SjCSZRKJh2LSX-OJufZLVltl5oH4aU0gLKzOBZHkJEc,111
simplejson-3.19.2.dist-info/RECORD,,
simplejson-3.19.2.dist-info/METADATA,sha256=BgskPGF7eMChcb2WCzjoA5jS7scA7xy-oc8NxFfX0L8,3102
simplejson-3.19.2.dist-info/LICENSE.txt,sha256=_KoeMTqZMEMi4uCDbqTufYOc6aSAQ485IqhT7f3eEp8,10375
