simplejson/__init__.py,sha256=YwgBOU5VCaSXh0jKvTarr5qz7rcR0tqmVcvwcKyVUmY,23497
simplejson/_speedups.cpython-311-aarch64-linux-musl.so,sha256=MjXb0bbuN8gdfPZsw_ngx0N_2ZiRGmEPkGKaSfp_Ajw,69264
simplejson/tests/test_dump.py,sha256=iD3z8E7MKCApU3bFsAdBeKHl_4hLIDrhPSIfpbGhjJc,10356
simplejson-3.19.1.dist-info/WHEEL,sha256=wfQ2JplaiAGNsImR_TCpfsd6u4nR_5UG1l3fd4C2Gwo,114
simplejson-3.19.1.dist-info/top_level.txt,sha256=ohU816e0ltfT8aBFol4_XY1q9GBh9tEBbcPpNn49200,11
simplejson-3.19.1.dist-info/LICENSE.txt,sha256=_KoeMTqZMEMi4uCDbqTufYOc6aSAQ485IqhT7f3eEp8,10375
simplejson-3.19.1.dist-info/RECORD,,
simplejson-3.19.1.dist-info/METADATA,sha256=5PrVnele4BEIBA9-VlPjFJtYCG23K27LS9jIZ6YUOOY,3051
