jsonschema/__init__.py,sha256=h0l2RPVM9kimU7-jTSKoEnguV3QGvrrQvlnJN3F6UPk,1561
jsonschema/__main__.py,sha256=Sfz1ZNeogymj_KZxq6JXY3F6O_1v28sLIiskusifQ5s,40
jsonschema/_format.py,sha256=xYMOH4Y5b9xtUV-Ol34QdtD412iHetTYJpiswIP-HY4,14091
jsonschema/_legacy_validators.py,sha256=vpxM-RSGLiEGUBcQq6867bOL2YpHB2ocMQANuFzinUY,7343
jsonschema/_types.py,sha256=_NDm3OxdPPWAqBSpfo4QVEA_oqfKMACg1QslVx0S900,5364
jsonschema/_utils.py,sha256=xrdrhbf611Cpkv-GKVtY_lXfDwwuKg-FDswibvRVIeg,10437
jsonschema/_validators.py,sha256=qmoubuJKRguYnJoG-_G-s4WnE1B8KFvxiacnmLAITCM,15563
jsonschema/cli.py,sha256=c2yQYyhTkBOgaa_s9e2gQ8clHmE6n3OZQ9a8Etcy6Pw,8239
jsonschema/exceptions.py,sha256=MBG9buP0C_8Z6fIZ2ob3KdgP7Nx4tIV9cX9S5SfR06Y,11267
jsonschema/protocols.py,sha256=WgzzOvm0Vnu39FHPQxjhEs4d2ctq-U3vFMnAchQ3Vbg,6598
jsonschema/validators.py,sha256=jbevK3aOsGVLPaQE4eO8H4bOQPTKUOqahbPMskRL0ko,36262
jsonschema/benchmarks/__init__.py,sha256=A0sQrxDBVHSyQ-8ru3L11hMXf3q9gVuB9x_YgHb4R9M,70
jsonschema/benchmarks/issue232.py,sha256=GKQBwm03sf-pPSxBxc4YDvBBnMYknOk6m-WtTntN5VE,506
jsonschema/benchmarks/json_schema_test_suite.py,sha256=PvfabpUYcF4_7csYDTcTauED8rnFEGYbdY5RqTXD08s,320
jsonschema/benchmarks/issue232/issue.json,sha256=eaPOZjMRu5u8RpKrsA9uk7ucPZS5tkKG4D_hkOTQ3Hk,117105
jsonschema/schemas/draft2019-09.json,sha256=e3YbPhIfCgyh6ioLjizIVrz4AWBLgmjXG6yqICvAwTs,1785
jsonschema/schemas/draft2020-12.json,sha256=Qdp29a-3zgYtJI92JGOpL3ykfk4PkFsiS6av7vkd7Q8,2452
jsonschema/schemas/draft3.json,sha256=2LanCgvBrUT8Eyk37KszzCjFxuOw0UBFOeS-ahb5Crg,2699
jsonschema/schemas/draft4.json,sha256=d-VZ-zmogXIypnObMGPT_e88TPZ9Zb40jd2-Fuvs9j4,4355
jsonschema/schemas/draft6.json,sha256=wp386fVINcOgbAOzxdXsDtp3cGVo-cTffPvHVmpRAG0,4437
jsonschema/schemas/draft7.json,sha256=PVOSCIJhYGxVm2A_OFMpyfGrRbXWZ-uZBodFOwVdQF4,4819
jsonschema/schemas/vocabularies.json,sha256=SW7oOta6bhkEdVDPBKgvrosztMW_UyKs-s04pgpgXqs,12845
jsonschema/tests/__init__.py,sha256=47DEQpj8HBSa-_TImW-5JCeuQeRkm5NMpJWZG3hSuFU,0
jsonschema/tests/_helpers.py,sha256=yoWpWVYq4auuTPPd1_8FXV77RlczQtiyutSh6c191ZM,618
jsonschema/tests/_suite.py,sha256=r9QUEFsH-s8tClyw_b1zU4tmmC71-CLSWw-zfw4BxVk,7153
jsonschema/tests/fuzz_validate.py,sha256=fUA7yTJIihaCwJplkUehZeyB84HcXEcqtY5oPJXIO7I,1114
jsonschema/tests/test_cli.py,sha256=Pxes9nmTU_7-U4iKIbaNg4Lj3CpgirC_bxujrxcNqeo,28738
jsonschema/tests/test_deprecations.py,sha256=paMq3Hd33zDfVsJpTd95MAOzI6y7IoUQ5brgp9qqVdU,3901
jsonschema/tests/test_exceptions.py,sha256=NXbsKfRYoaCYQvI1Er1ld_NNL4Xuun4Tw2b4VIsNfSA,19190
jsonschema/tests/test_format.py,sha256=-J0Em4cx5mPx87MuTAkt4yGMTp8Hn32QTG3jZ_P8yKg,3755
jsonschema/tests/test_jsonschema_test_suite.py,sha256=GjHoqkl1E1scfMccoLgxiCqMxl0GZL96EXaowj_DNlI,21201
jsonschema/tests/test_types.py,sha256=DyvSKPtuaIu93Lkde80PkJkNOKgvCbaDYAfHz0yxyL0,6803
jsonschema/tests/test_utils.py,sha256=lJRVYyQeZQTUCTU_M3BhlkxPMgjsc8KQCd7U_Qkook8,3749
jsonschema/tests/test_validators.py,sha256=1iONAWZFKJ9VmW2V9K3SPqDvLN7y9zbIX9pX08WjXws,74030
jsonschema-4.10.0.dist-info/METADATA,sha256=oqJIOlik3CgABEotcdfBHr5rUinBp-Ahe1w5XsJQQ90,7964
jsonschema-4.10.0.dist-info/WHEEL,sha256=3DSmSyYE1SDERO2-rI3qUbMVovBs7--ggc7mubOemsc,86
jsonschema-4.10.0.dist-info/entry_points.txt,sha256=vO7rX4Fs_xIVJy2pnAtKgTSxfpnozAVQ0DjCmpMxnWE,51
jsonschema-4.10.0.dist-info/licenses/COPYING,sha256=T5KgFaE8TRoEC-8BiqE0MLTxvHO0Gxa7hGw0Z2bedDk,1057
jsonschema-4.10.0.dist-info/RECORD,,
