zope.interface-7.0.3-py3.12-nspkg.pth,sha256=_l6EZJaefCi1yytmDbFQGX_jfS2gAtFyaDmlK1uFLec,457
zope/interface/advice.py,sha256=YftOBzbXuWQ3AuJImMtYv4SYbE7ubJrjodXzTgYR-dk,3918
zope/interface/interface.py,sha256=DlPPivtpgC3IOaeK9TdFoGBDAvJR4MjSLRERb018UNU,39684
zope/interface/registry.py,sha256=eDnfUtTFp1z9f-4F-4ZQ9EATLheAYuCP9_coZ3XLdVw,25812
zope/interface/document.py,sha256=mhSCJoxw7Whl-q-EMSkys--z3C7IyJ6TEsZ3psMqyJE,4139
zope/interface/_zope_interface_coptimizations.cpython-312-arm-linux-musleabihf.so,sha256=OzAdHNzLCITIxwYe30pPp8XdAyXWa5slIaoRR01BhH8,24124
zope/interface/_compat.py,sha256=yj7mY66LhNQFWEuWWz7AYnn6zEPavfgBryaIHjo0tVQ,4367
zope/interface/_flatten.py,sha256=NKviK4ZyLBCjxXvz5voI9pV_ui2SLqUhubbqZkvgEcg,1059
zope/interface/declarations.py,sha256=gQBm485BCDTgFoNPwB_oTQD-f4dDwl7DQn8rGLsG2Do,43442
zope/interface/exceptions.py,sha256=lW7SnsOT73LZI8w3aRdCRVUubfSy-CGztchnKqv1-5A,8566
zope/interface/__init__.py,sha256=9Euz0jFaHg3kT84m2HzikMt7s_JIAjM8BlVctyUfNTk,3475
zope/interface/interfaces.py,sha256=6_cBr3ft40B5oPMxYgux_3N9jV5YAkWJv2OFDdkXPVI,50267
zope/interface/ro.py,sha256=NeImEPsautGBC1VtQAQ1J1BGXmksw6hoSNWD7gVmEaQ,24577
zope/interface/_zope_interface_coptimizations.c,sha256=do6_3uhWWBwcNSLux72x2losxkXlVpoy8EoEwK_H-eI,71308
zope/interface/verify.py,sha256=cEaIWPcS6gT97RkQW2SQJxxuUP7wRrwYwsJtXqo8jdE,7333
zope/interface/adapter.py,sha256=XN9PD8OrRmP1ZJy2gPvAMXtiOnKcHL34doH0HaKHguQ,36647
zope/interface/tests/test_interface.py,sha256=6W5I5XunytWDHbhpE1R2NPmce1NARbiaLdg9MzzXtWY,92995
zope/interface/tests/advisory_testing.py,sha256=T2XF0DT8t9zi1JxnvR1u0WXpRtyOn5027VMyEcN7Ldc,900
zope/interface/tests/test_interfaces.py,sha256=UuNsfZHFlMCRL28dYGRcDG-hqGR8A1BqZMqsZz7sUaA,4399
zope/interface/tests/test_registry.py,sha256=2iS69j5Z9BzFkfEBR_CGReoiAuA_4Y1Lru2qlk5UWZs,113613
zope/interface/tests/test_advice.py,sha256=KyBjBDAF0HQam87yoUvoLdBf3O0c-Gcr3Nvj8KI-9ys,6062
zope/interface/tests/test_element.py,sha256=z9Q2hYwPVzMX05NpA_IeiHoAb4qhTiHI57XQI38w4zQ,1120
zope/interface/tests/test_odd_declarations.py,sha256=N5WmnKCrXE9YR1k4Baw27xQShvSgNrqDFB5NFE4zP2s,7710
zope/interface/tests/idummy.py,sha256=ESC_l4UqjCkiCeXWfcphVGtrP7PoNwwTTGzLpp6Doo4,890
zope/interface/tests/test_compile_flags.py,sha256=wU3vtmqgzll6HMPbzFErMpORoVghrcZ5krIV4x6rfo4,1290
zope/interface/tests/test_declarations.py,sha256=ZCD2x65wv3PmwhLVYbiSKhtv8j1-P-6zA5Bm41HkY80,83202
zope/interface/tests/__init__.py,sha256=Vu2CALgC5nADbRAZFb99LcDSXECcPCNdJDL-nv_6mZA,4242
zope/interface/tests/test_verify.py,sha256=JnVLFlHGgVn8fC6u-WPW-mDtfmSuDA2PC0sglWuVBjI,19200
zope/interface/tests/m1.py,sha256=clhSXmtaT8liCnM87Kp0bzAHfxIxr6gUBjXnVuxaUNI,850
zope/interface/tests/odd.py,sha256=nwjmxbHCFuI2UvY3Pwc7CfkmZWfXsn3oCb7r7C34DxU,2967
zope/interface/tests/test_sorting.py,sha256=I4P2jvStUzYrNOnIQgkZZs0sTn9BHe7g5RLQlFmTTW4,2051
zope/interface/tests/test_adapter.py,sha256=pB3Y_oXXtdtDsKf0BYlvpW281nT1yendxtzWgWp9o_0,80508
zope/interface/tests/test_document.py,sha256=0JIYe0GWvDPkr_IBACPw-8HsHNJyNNHBU_lUHYOXd9M,17220
zope/interface/tests/test_exceptions.py,sha256=hxceYZyLZghgpxm-ABg1k50-H1CYRSTUGMZyiTrElo8,6445
zope/interface/tests/test_ro.py,sha256=CvuZne2GdQu0JA4WQObKm8mG-F7__3T4VBINwoj3QQI,14465
zope/interface/tests/dummy.py,sha256=dd_cYIiPvYJDrEMQD0m2cl9SpkVMrQzMMu1yglSrnb8,913
zope/interface/common/mapping.py,sha256=XI9lO7Uwt_9sWDFyhDIk0Rjcr5nlu7SlD2KDyqdupdw,4687
zope/interface/common/sequence.py,sha256=SYvqSZpKRaX11vCADK6zGn0LqogPQ0u7INbqgTJ4sg8,5531
zope/interface/common/idatetime.py,sha256=sn5ccP9CiQAYzn6mptWf05uInZFp9o_DRu9_MaDXM5c,21039
zope/interface/common/builtins.py,sha256=P_QNQmCmieAuJFgiIgWeLLZbNyQ5Czz7riOmtIAPjX8,3030
zope/interface/common/numbers.py,sha256=D4kUnF5OgAk6CKcxaW86VH_OPLh1OXt_cF6WaOfvjLk,1682
zope/interface/common/io.py,sha256=if6Yzclu_T7qeUQNsXeIqREqgVTu-rjYB_VGZfYyz3Y,1242
zope/interface/common/__init__.py,sha256=ho-q_3jeKVq-jO-5xrN9_Q4PR0o8PDwja5NYsO7qTI0,10644
zope/interface/common/interfaces.py,sha256=VxYq0tje41VZiyFzeOFoXYq6CnLTwoJ2djV_y2-A1vs,5836
zope/interface/common/collections.py,sha256=oqH9d7BJ4Jv4IRzWhKOK74x_aBKBuNQquZWCuRqwYOw,6712
zope/interface/common/tests/test_idatetime.py,sha256=qGr8FDbiVuDZHjyDIKcz7Vz6qNfoFzd9eHejMTfIyAg,1923
zope/interface/common/tests/test_collections.py,sha256=rkMvw2YsjJ3HDfF4dYBGWyg56vR3kMAWK6zsjG36eNM,5721
zope/interface/common/tests/__init__.py,sha256=Am8tpD6HZQx6pfW7N22-dloC83-dKLA45NiM9Lx7Xss,5553
zope/interface/common/tests/test_numbers.py,sha256=tPrvkFVYa2kSSxf8_j7XYctupfS4BI-ee_jQ5yU8zRM,1395
zope/interface/common/tests/test_io.py,sha256=gYJnFT52De1JAJruKK6dzyQIdLgYdQME9Yn6QTn2QyI,1686
zope/interface/common/tests/test_builtins.py,sha256=slmlaiZjaZJXjplCEaWXAaUFaWW6bcK3z8Je7al5mdE,1345
zope/interface/common/tests/test_import_interfaces.py,sha256=wCFk-2kc7r-kAeOXZn5th5Qw_6k_-pMvdguk5b4NstM,813
zope/interface/common/tests/basemapping.py,sha256=02-jOZqVuqgHEtbQV5LXAJhvhnHnQKOJgZYMeR1RRUQ,3772
zope.interface-7.0.3.dist-info/RECORD,,
zope.interface-7.0.3.dist-info/WHEEL,sha256=KTe06964vBFO5K4Fo_4OscX0yn09nVL_R15wmIbrwbI,112
zope.interface-7.0.3.dist-info/top_level.txt,sha256=QpUHvpO4wIuZDeEgKY8qZCtD-tAukB0fn_f6utzlb98,5
zope.interface-7.0.3.dist-info/namespace_packages.txt,sha256=QpUHvpO4wIuZDeEgKY8qZCtD-tAukB0fn_f6utzlb98,5
zope.interface-7.0.3.dist-info/LICENSE.txt,sha256=PmcdsR32h1FswdtbPWXkqjg-rKPCDOo_r1Og9zNdCjw,2070
zope.interface-7.0.3.dist-info/METADATA,sha256=rAJsM92Ld3KbCvHvsevmVfFwM7YMNZY5E2xq3PZrkYA,43623
