zope.interface-6.4-py3.12-nspkg.pth,sha256=SWEVH-jEWsKYrL0qoC6GBJaStx_iKxGoAY9PQycFVC4,529
zope/interface/_zope_interface_coptimizations.c,sha256=xq56Czru7kS4boskT3eXXxxIqlsVge87rzIR913AxW0,57205
zope/interface/interfaces.py,sha256=EAkcVWOBAEJ_1uxki5paMB2iiRuenhWhH9HTmtahIZI,50126
zope/interface/registry.py,sha256=KO-shRNDa3HV13dMfCzilMcrrO7499NnE-Y8OfBjFc0,25829
zope/interface/__init__.py,sha256=3ZfPUwE8FkswHxH57Po_PRJxyYYIYeUQ73Rexbn3KaI,3460
zope/interface/_zope_interface_coptimizations.cpython-312-aarch64-linux-musl.so,sha256=ivtevdFSI5PZp_3MN7fMheCEHUlmse498jNWh3I-1lI,72080
zope/interface/declarations.py,sha256=SmAZZ0-4AoLSCSp47DPbNl1v-rdN5I0-grxBWTd2aos,43007
zope/interface/document.py,sha256=ulz-aOQd1_4b7xUGNKz1dr1aERHGO0jLFMvNzl3h7Jg,4068
zope/interface/interface.py,sha256=33F_4-rmgww_mB1ZNt85k-Xj7YfcuP80hBGF75JFxbI,39409
zope/interface/advice.py,sha256=gHc81UfU8ysiRm4I9LooYR7W16aw3Si-xTh42jineCA,3892
zope/interface/adapter.py,sha256=rsHrDCyZ4QpV1Fl9o31Ty4LM0qTGGqHgPyPfdMY4tBk,36218
zope/interface/_compat.py,sha256=INsHdSwp4imu-1CL552I3S79YRSDCloB1J0x17PEHvw,4369
zope/interface/exceptions.py,sha256=fSv9yI6TMqWmgjaSX8cxt0Q2cASbmzphz_noyu0NnRM,8636
zope/interface/ro.py,sha256=4LkztZPdF642vW6ikghU6yTmhutPJj7VoXdlV6sQU1o,24157
zope/interface/_flatten.py,sha256=E4aomSQEN79yxAka9msyWOopv8i-dD4_4EfX9CXFXnI,1057
zope/interface/verify.py,sha256=-nBYCCz0fNqEIgYpzSJKljut7Yywor7QXT22hFafdcM,7226
zope/interface/common/interfaces.py,sha256=s_j3IaGwvWsabz5L2azjMzryDiuD2Gyi5f0L79Pov8Y,5368
zope/interface/common/__init__.py,sha256=Oip172bmZ16J8cKo5AWHsZ3l11k455zBZKzDxddOsZw,10462
zope/interface/common/sequence.py,sha256=ua0mLW_hCZmZnnhgaMYan9zoAfDjv6l5RAp_9YuZ9Uw,5526
zope/interface/common/io.py,sha256=if6Yzclu_T7qeUQNsXeIqREqgVTu-rjYB_VGZfYyz3Y,1242
zope/interface/common/collections.py,sha256=STe8TRe7qzhaLbAoZaJl8RK60x8thuBdyNJyb4P9dpQ,6792
zope/interface/common/idatetime.py,sha256=DUN8C0PeW1O1visJ9rbgjMiN_suaFMCcclyJnUlkK1Y,20964
zope/interface/common/numbers.py,sha256=D4kUnF5OgAk6CKcxaW86VH_OPLh1OXt_cF6WaOfvjLk,1682
zope/interface/common/builtins.py,sha256=in7YN1Rl9JSJMJin0SP7BfaL61dflKepORSMsJVDtSA,3027
zope/interface/common/mapping.py,sha256=CwSefWLXLIxQ08xAxyeB0NBTAmrVp90LjvIikwGHYoc,4678
zope/interface/common/tests/test_collections.py,sha256=XdaOzmt3HR5cbmwEGhENCTkhvELxkwECZH437Tthpu8,5718
zope/interface/common/tests/__init__.py,sha256=xXj2X_C0xZutCAtC8bdM4i5_JeAd-1NxaK_VkJXU1Qg,5476
zope/interface/common/tests/test_numbers.py,sha256=xp55tY7zeP-q6D6dJmlTsWicl-3mQ8dArwdfkhQDoNA,1394
zope/interface/common/tests/test_import_interfaces.py,sha256=wCFk-2kc7r-kAeOXZn5th5Qw_6k_-pMvdguk5b4NstM,813
zope/interface/common/tests/test_builtins.py,sha256=slmlaiZjaZJXjplCEaWXAaUFaWW6bcK3z8Je7al5mdE,1345
zope/interface/common/tests/test_idatetime.py,sha256=qGr8FDbiVuDZHjyDIKcz7Vz6qNfoFzd9eHejMTfIyAg,1923
zope/interface/common/tests/basemapping.py,sha256=bzeuZAg3tu-QeMHmLcgtT-fIkD3sxmk1x42YA66fwsg,3907
zope/interface/common/tests/test_io.py,sha256=AMLOSWmV7ZKCbHzcLwNqB06_R9zifohW_0qoSmC860w,1663
zope/interface/tests/test_verify.py,sha256=7mdkuW7xCSxB8Q3w50XF7ayB-qJTIhe7wgiJ5yDbjXE,19191
zope/interface/tests/test_ro.py,sha256=XFlt5AERciPTVR0zi6zvsPDCQWsF6zc6qFT0qn2vuTM,14124
zope/interface/tests/test_interface.py,sha256=8PnCmZdsHfxg-27nyfogCihp-o7-IFrZ_nMhg3kCoZw,92312
zope/interface/tests/__init__.py,sha256=2sMjAaqsnDB5aCcIIkz9lXeivO1Cpbo78GeV7qYfjgY,3961
zope/interface/tests/odd.py,sha256=DITySuFOf7f1ERI7qWGcosW98AO6-MvLoOAawsz07N8,3015
zope/interface/tests/test_registry.py,sha256=xHc0wGjkgy1sN_IaY-_tJ5qEHNut49UWOriRVz7v_40,112910
zope/interface/tests/test_advice.py,sha256=K_Scp5waHBPuzYnPMn00O1Q6Ap5u6t8xdRiFmfnGMQ0,6040
zope/interface/tests/dummy.py,sha256=8JydLumILxdOHKaAa_IfGIvSx9a5Agz8gcRwGNx4HNA,912
zope/interface/tests/test_sorting.py,sha256=6yeTd66j25xPfzqvmH6lAx2KZ2iblN7eNKoI342Cnuo,1934
zope/interface/tests/test_declarations.py,sha256=YEdPZw4XA-bCyMW1fUO43pAHiqPL3K-eSEW1jlLn91Q,82140
zope/interface/tests/test_element.py,sha256=z9Q2hYwPVzMX05NpA_IeiHoAb4qhTiHI57XQI38w4zQ,1120
zope/interface/tests/test_odd_declarations.py,sha256=WosR5hLjT8fd-S9Mu6u5xTZ55Dfee-nOvvNBF39KkXk,7566
zope/interface/tests/advisory_testing.py,sha256=XlSmWBnpFUjiUSFlXcfOUjGiTxUZRdoBoUCHuNboZzQ,898
zope/interface/tests/test_document.py,sha256=LE9ndrIrloJZIOxTPwj6GklGQTFW9zeRnFM5GiwvHfU,17164
zope/interface/tests/test_interfaces.py,sha256=l-V4hE52mL6DoMWJ6dAGKpJBkCiog8EBPH8oes7UCYI,4377
zope/interface/tests/test_exceptions.py,sha256=rNrW_HdJPmVbyjTN9TyO8ynZ7cxiL5c-UdZj9SNlF_4,6412
zope/interface/tests/test_compile_flags.py,sha256=wU3vtmqgzll6HMPbzFErMpORoVghrcZ5krIV4x6rfo4,1290
zope/interface/tests/test_adapter.py,sha256=w8Puu63ubnOQauKLpzJUVb3t7iBI3x7bPAm_eObhTcI,79479
zope/interface/tests/idummy.py,sha256=ESC_l4UqjCkiCeXWfcphVGtrP7PoNwwTTGzLpp6Doo4,890
zope/interface/tests/m1.py,sha256=JFuzE0pC2bSrXKyxm-VYYvoPt7F42wtFy-yxRPhmEdE,839
zope.interface-6.4.dist-info/WHEEL,sha256=KMQ9aHBqtW4VGUKzr4fc9IGC6E9Jx10rPRgVpL4vwyQ,114
zope.interface-6.4.dist-info/LICENSE.txt,sha256=PmcdsR32h1FswdtbPWXkqjg-rKPCDOo_r1Og9zNdCjw,2070
zope.interface-6.4.dist-info/top_level.txt,sha256=QpUHvpO4wIuZDeEgKY8qZCtD-tAukB0fn_f6utzlb98,5
zope.interface-6.4.dist-info/namespace_packages.txt,sha256=QpUHvpO4wIuZDeEgKY8qZCtD-tAukB0fn_f6utzlb98,5
zope.interface-6.4.dist-info/RECORD,,
zope.interface-6.4.dist-info/METADATA,sha256=62GQQB7pOmu51FH_Hj0hkOVorGTE-spEH1PA83hE7j0,42220
