shapely-2.0.4.dist-info/LICENSE.txt,sha256=SiB-rJvyV-0obhxvD84lPRq_2xNPxh7IVeN_VpKj91Q,1583
shapely-2.0.4.dist-info/METADATA,sha256=GZcIzn8I4IQWChqLYywEjfIkNNScR-2oOWJAiOgzeoM,6974
shapely-2.0.4.dist-info/RECORD,,
shapely-2.0.4.dist-info/top_level.txt,sha256=fxc5UIKKldpKP3lx2dvM5R3hWeKwlmVW6-nfikr3iU0,8
shapely-2.0.4.dist-info/WHEEL,sha256=Sa4OebvWGIz03phE-3tlNSEM7V5kQFFXPkWHL0MWa9c,113
shapely.libs/libgeos_c-86a0d5d7.so.1.18.1,sha256=D5HYpEQoluzv4lm7Kd8hBsh5wjSCQOqxPL26_KK-no8,456433
shapely.libs/libstdc++-496613c0.so.6.0.32,sha256=To9BbuuzmIGKI1dYHbGC_ytU3wDCOB6CUOTObaaUK7g,3494361
shapely.libs/libgeos-bf79f795.so.3.12.1,sha256=dided5BWlTVoSKZKFQK1xwydQmP9SpRtfuqTzTfJtwU,4449761
shapely.libs/libgcc_s-a3a07607.so.1,sha256=h5FeDoMYh2d4ARIwq0s__--fFtmMolN-GV5SnHuYOMQ,148041
shapely/strtree.py,sha256=m7gTvKZ03a6eZ5UNw3QUqEVWGIBLZmLofBtTFccyZvk,20390
shapely/_geometry_helpers.cpython-312-x86_64-linux-musl.so,sha256=GM4GPxKw0iX3N7aCVG0JxYuLN3xMZDASd-Ja7W7fyXY,315385
shapely/lib.cpython-312-x86_64-linux-musl.so,sha256=AmonQMd-4REklNQibAtcqE03mWh2K4OgCpnrn3-9-tg,178705
shapely/plotting.py,sha256=DeIWQD_8sKg_fmMb1vSlXjcXhRRhfb5w1zN93MNmh_Y,6165
shapely/_geometry.py,sha256=irSMc7zqjN-tyDKz8NpBkb97NurUrjBuub1feIYPow0,23925
shapely/coordinates.py,sha256=vU6HRO9tuSuX60WwLPTv9ey2qC5LkIJ1_AArWROSnqc,7220
shapely/errors.py,sha256=w77yN5CcXLcy0jZmYBK0YZ_4f0hX-A7qqRoGRKks1Xc,2455
shapely/measurement.py,sha256=W10XJnoPG9msghnoA3QS-qxiCP40u6wS-UvhhG8lQEg,9727
shapely/_geos.cpython-312-x86_64-linux-musl.so,sha256=Kv5VEMj9IhT_fceqEw4VLNGFGWEJujQMIgOsWzwdJT8,72449
shapely/prepared.py,sha256=kcE28dEU3RayHycEH6NNp02nGq6tVPRK2KMsErCL8Fk,2402
shapely/ops.py,sha256=1-OuJRfoSM0tuO0blDeCkuszwOYvli6hlpKEVDJ3ff4,26182
shapely/_enum.py,sha256=SLuvOs440tV8yDRGbiR8l0AE2WLms1Ri8Z666hDZEOU,713
shapely/decorators.py,sha256=VoRvPWKnEmbHGToGElEfF5f75NPGDagm_kES4N_Cl18,2555
shapely/wkt.py,sha256=kDPrPUtQnTrfsEdLi7APqBAkIoqcUSccrK1mmkWXOks,1947
shapely/speedups.py,sha256=V7olKLqaE_F5iJ-cSMWfymQFrLsKj4zUx5u_qGzUvxU,948
shapely/_ragged_array.py,sha256=QlAl7SIToSLzeAOM_pAm3BOBg78ajBTnyu02anE7bfU,16570
shapely/affinity.py,sha256=Up9mCMItVGFJQM5CzTXN8DZfDRmXDp4HDL1rusFMRhg,7644
shapely/io.py,sha256=3-DCnk4aMGfMLnH4zwPBMv8aFR_3jlGoS_I76yaIL4w,13344
shapely/__init__.py,sha256=JYPRTL-BInpJIzaS2JSpUB2X-O8FAQxYEWJIhYQ5yRY,1049
shapely/constructive.py,sha256=1MvS-c92hnZozIuoAqFNbQlodNnQU6rFsqUdvRhmH7I,38056
shapely/validation.py,sha256=gRJpmvX2JLELktQT_qr6O2tlcrCf7SJNy0bgDSIvafA,1433
shapely/_pygeos_api.pxd,sha256=jP7i6JBN2HpOn-bybe-2HNBshQq4qmxOmS04T0yA3bo,1518
shapely/predicates.py,sha256=_jA6vKax_N83Ott7AnVgZkflebg9axOaQeSWjKafsF4,32944
shapely/creation.py,sha256=gU5XcIbGGGgiWWk64Il99wAujvpWcAyU_w8DEs1WJWM,20245
shapely/linear.py,sha256=C_us0k6iJ9RC2HWR5oBQRCDU7Xzm219Hexd5CcDXf38,7297
shapely/wkb.py,sha256=BuuJm9NDUiLtPWMu1pl8dVpx4AN0MW6cCyN1hvyDrPA,1912
shapely/geos.py,sha256=xL5Tejiyjw1t7y51pZBNtcrxYZn4m8G1q39qthxi2Rk,222
shapely/_version.py,sha256=TKnmWyGM-1wfkxZvyGs2cW7XlJt_3VaapfE9Hdl0sb4,497
shapely/coords.py,sha256=g8WtiMBRrvl8mpqmeWGHZBJ5YkOKjWKT5tZnPXl-x6o,1570
shapely/set_operations.py,sha256=AanuLUvUy6_JunPilBkfd9-zlnjbNGIH7kydaPaqMZ0,17507
shapely/testing.py,sha256=o5pTV_kcBha0xDi8w_UvFkdSNDkr2e8Nk73jyZ9KYn8,6313
shapely/_geos.pxd,sha256=zj448O8W73mHcjjOa3N5NAHOz5ujtdq-f9zwaF9Vxzw,2889
shapely/geometry/base.py,sha256=lDo7ODukTpw-N4zelu0dZ-4UKhWYL8WDG2kkx6lAPFo,34131
shapely/geometry/polygon.py,sha256=jrBDmu7ZM1KzccVShZxehS_CIk5xeWSNgeX9LvR17DI,11376
shapely/geometry/point.py,sha256=Npik3CUzvbxnfRF7BxZbBBc77g_R41rsG74JGj1whho,4183
shapely/geometry/multilinestring.py,sha256=uI6CP6ds_efY9Dy_a6QLkyiZNAIiMdNpJ2Y7IZJ5hVo,2796
shapely/geometry/__init__.py,sha256=Nlqw8usKbsZUt-PRO02a_zRoyZifJYvUzbUnQrVnaKo,763
shapely/geometry/geo.py,sha256=qQtXCdGpzif-NOu7KT7bN1guP8ceYEjwmhahB5bTOvk,4098
shapely/geometry/multipoint.py,sha256=7Jrxb69a5zlAEFmyUfmCRiIxED8T8ghyhKhLsSZNjRM,2683
shapely/geometry/multipolygon.py,sha256=9LS73gtyOKs22N8Btz4WzGxFlljy1obtOgb0u80lhos,3843
shapely/geometry/collection.py,sha256=tOMe2tLl_w3Xl3pHXmMiTEczY9BCltLQYmfkOdBj_r4,1599
shapely/geometry/linestring.py,sha256=Wl1yMKmSL0ziAX-QJgybl2ekg_1o1sYCDOlI7ZsC7ck,6786
shapely/geometry/conftest.py,sha256=QkHIGaq9zHRWmHu1Z5Wu1AMJHSKQZCP7U73rADWXkTM,224
shapely/algorithms/_oriented_envelope.py,sha256=rETyzVRYKaGqPeY6xils_QUp22vwjrpfB3uElMS3NFo,1975
shapely/algorithms/cga.py,sha256=GHQBLFI1Epq-Zj92RO3K8yYRado1xNBsrS4djawo068,625
shapely/algorithms/__init__.py,sha256=47DEQpj8HBSa-_TImW-5JCeuQeRkm5NMpJWZG3hSuFU,0
shapely/algorithms/polylabel.py,sha256=vH904OcVSlV-UKIsctp54VBkUBy8_-NuMiyLvRNPclc,4692
shapely/vectorized/__init__.py,sha256=j4d9L0I23M84KXkHuDqKhQCEYsgY7DjtPznJuTbFVs8,2249
shapely/tests/test_io.py,sha256=U76hnAfGvz1xO-150FtzmQNiGgXa-LLRat9PGSrEriA,25273
shapely/tests/test_creation_indices.py,sha256=9t1T5SSoaiPHJ3u69iCdPMKVWgVmSA44yeICREIGlQs,13398
shapely/tests/test_coordinates.py,sha256=aQXGOa-HWT-Un8RyWzzkJz62IsSqMwE63J4DxrwsAH0,9068
shapely/tests/test_measurement.py,sha256=ptv26_VDRgQTb9Z-Bi0GonnsvQpVTPfnUieSVUhZoRY,10773
shapely/tests/test_constructive.py,sha256=UuxFFAiccRa2NuFrkfOL_IydR7nHv_9ac8FBud2Y0vA,33026
shapely/tests/test_linear.py,sha256=YZ4v203qdpbt82xf9sSrkpqBmTYT_Bt0_0Y1m62BYRY,7440
shapely/tests/test_creation.py,sha256=ubGQEp9o-tbpflqlmr7PLkYUlU_2DapPHusGG1abYYE,17868
shapely/tests/common.py,sha256=YR84dak4frQH_XDDAfSwKQrTxuX5Mm9FBFC0VZcly5A,3592
shapely/tests/test_geometry.py,sha256=XS6lymPKmmPRadEJs1YGYB9DqUmjsBAmw__Lzys9Niw,24453
shapely/tests/__init__.py,sha256=47DEQpj8HBSa-_TImW-5JCeuQeRkm5NMpJWZG3hSuFU,0
shapely/tests/test_predicates.py,sha256=xYHpThB0djln_FhLnK9c2mEifDv8lfUxap9IFrC1mwY,10980
shapely/tests/test_plotting.py,sha256=jQX209kK6Nbs5YyF4kdpCJXDzPXqWnUznKXKQBd3o2A,3615
shapely/tests/test_strtree.py,sha256=vozZeGN13_fsKQxUEmZkrLGRm52dq9L3fuFZY4Q3fi8,74066
shapely/tests/test_ragged_array.py,sha256=f2tDJXJs438g0nTCueNoxwKN5Y6-SL4k4Gv4QmXyM7g,11953
shapely/tests/test_misc.py,sha256=DMSIqnKr9LY6qeF8CSRd4TxtLc-RLLE164NvawvzwxI,5602
shapely/tests/test_set_operations.py,sha256=ON0uIZMAum_awQxeG27xq3LsxgynS_Kp0nAr01vPXoU,16931
shapely/tests/test_testing.py,sha256=fLGSiETvPPrvdDRvqxZUx63s3HohJG0d0FaOmsyMJR4,3072
shapely/tests/legacy/test_create_inconsistent_dimensionality.py,sha256=RXTo4yMWv15pWEyERPYdJhZ-nCqyz1WiTMOxZ2Q40Fo,10644
shapely/tests/legacy/test_wkb.py,sha256=iEHmD47yLbdnoetgMhzy-K202FTpAwO5uB64NEJWOf4,6121
shapely/tests/legacy/test_affinity.py,sha256=Q03K9atdQa5r-c4fVxvmuQDbAb1B4-EGZb6-Sx4SPtY,12531
shapely/tests/legacy/test_validation.py,sha256=L33s2pjag9R_HoDa-mUG1oEOZcK-pexhnQHX4xlZu6I,238
shapely/tests/legacy/test_snap.py,sha256=4KkXVxpZV38wTgxYZuGTVou1F9Co7qCPMixGouMZUqI,764
shapely/tests/legacy/test_polylabel.py,sha256=GHgr9HcJ9kLHZIiv1UE99ut3TfjjRhr7MrCNVsnMjlQ,3225
shapely/tests/legacy/test_polygonize.py,sha256=m9euuuzwqS7mfT-nxtfoheIzrvoSXlhMaL0phXo_HZk,1389
shapely/tests/legacy/test_buffer.py,sha256=LqeEwKb4irvmorGOYwbSqhB3hHFF6Ag2bnfZoULyTlg,6521
shapely/tests/legacy/test_parallel_offset.py,sha256=GRiJa48w2-z7NXDVgjyh5wPTCt_lQZg5l_b1bExDZ4U,2332
shapely/tests/legacy/test_operations.py,sha256=2KbOgN48Y8YLYrdff7M9TTMrX8AgQuFcDNeiEnzI8Sk,4074
shapely/tests/legacy/test_minimum_clearance.py,sha256=jaV8heru7YwU1xWo8QO30qIcE4wR7B8tLz8DMtdZnfQ,916
shapely/tests/legacy/test_ndarrays.py,sha256=5_sHeWOJ49rt41pLl5j41IbWFDDcSW0kAFqtC45jKkU,1244
shapely/tests/legacy/test_cga.py,sha256=FmLoEAfyWO9fvdrYLuxiDn4pk7fi60RN14eMBv1VXU8,1509
shapely/tests/legacy/test_empty_polygons.py,sha256=pNjl0EVWuphek4TPHHqydPq10JqImQC0y963erL5K7E,683
shapely/tests/legacy/threading_test.py,sha256=ZVGj2PC-wEZ0Pr2VJgYPAM2iqd5LOs3Bepj6qWK_sz8,1032
shapely/tests/legacy/test_geointerface.py,sha256=dAsuOZSaVTZjWXquLlC0bA7MufQ8-Rr67J7FWQCfj4o,3648
shapely/tests/legacy/test_voronoi_diagram.py,sha256=ceWf2YmgUhwwLWfZWZxbVSftF2u3RYwD-fiPeAIcgts,4444
shapely/tests/legacy/test_equality.py,sha256=Q0lUt_1MbXrzUwnLSW6w4U1ThRvYNaUkO6NgdTxL0xI,931
shapely/tests/legacy/test_singularity.py,sha256=GI-_673c18SIAq1UQZT3ZOnfeSbhBEuGAYgCuzPldho,381
shapely/tests/legacy/test_linear_referencing.py,sha256=CBHU1SXOHor7WKGww1ZmoSgLqa0QsuhfVPK21aiNv0Y,2914
shapely/tests/legacy/test_products_z.py,sha256=CrN95z-8sl3J76YZE05E5tYvMLrhGDTp_Rivbblbq5g,388
shapely/tests/legacy/test_persist.py,sha256=SrwIiAOOQ1PrmXEeOO4t3dOswkSQhXvcdGnlM4yyvkI,1713
shapely/tests/legacy/test_svg.py,sha256=xIXhkL44w1PJl3suxvDjXKd9nPO7ljkYMTz3qoD7DG0,8253
shapely/tests/legacy/test_linemerge.py,sha256=AfoJ-20T6t3aw6EBCAG8VAYBJqWjDdaq6m3laxLAxlM,1330
shapely/tests/legacy/test_transform.py,sha256=s5GWsu9EeW__D0QHT4L9ivr1lygeiSxRNLEyGgmdksk,2705
shapely/tests/legacy/test_nearest.py,sha256=eXHfHQA0k1cUYNcn9WvL9SpnwhCjFb2CeN2NAMHQ0M0,476
shapely/tests/legacy/test_union.py,sha256=LHatZT6dgMhQLEZJ4pOUaDSoD0UqPnbjAefHbWsvxkU,2319
shapely/tests/legacy/test_vectorized.py,sha256=I5haar26ma34Cs7WgQPRuxmTnEM2Di8HlALy5S-xh6o,3583
shapely/tests/legacy/test_wkt.py,sha256=2RCgxa5SH7-kVotkEy1_WBb8eiN8S1Ji-dwdflsCMng,1610
shapely/tests/legacy/__init__.py,sha256=Jhb3gRBggyQeAgQVpobtcJAuqaVlFptXkTR9t3z48Ik,275
shapely/tests/legacy/test_substring.py,sha256=E-Rnm0tOqjUnRZtSEgCUPyknYlnraYIWpQaozeAT0OQ,21148
shapely/tests/legacy/test_predicates.py,sha256=LjSM-3xdFVYriDqZ9bedL7WbxRiOjMx5-vuyh-BQPbM,2712
shapely/tests/legacy/test_locale.py,sha256=zlaz6tM71Do_2xyCbfzQEMREzfbFQYzscSrvKl1dEqc,1436
shapely/tests/legacy/test_operators.py,sha256=aWjGgHOmLm6Jx21BiR9APBFokL4hxOrC1IRY8YHo0QU,1948
shapely/tests/legacy/test_orient.py,sha256=dVmRd2O2j_bO4UOjVq1lr6prijUTeIWXtDUVR4gZ_BA,2400
shapely/tests/legacy/test_delaunay.py,sha256=TubjNzbTxij9N9VDRX9Po_3MpxytonkCoAExq5aVaRs,838
shapely/tests/legacy/test_make_valid.py,sha256=6s-sf6RrcVUxwAFcG1fkmBnCtv4wHQXVD6FuA61YrD4,574
shapely/tests/legacy/test_prepared.py,sha256=NbuyzVwY3taqrnn6swX4HIfSQtV8rpFO__dpwZLhoUQ,2347
shapely/tests/legacy/test_pickle.py,sha256=LvyCTWS3hkwG7hM-Y71iQ9KEcP9jfoPA2ji3QYN64h0,2481
shapely/tests/legacy/test_box.py,sha256=dWUFGKq_ItxQNw613IPqkAJu0vAbCKDSiXNtXfaU7yI,599
shapely/tests/legacy/test_mapping.py,sha256=5CiH3Ab0BMkxbluE5T1A0lDYXWqbfpEESLkFcIKmr6I,395
shapely/tests/legacy/test_split.py,sha256=YgGUaiPtbq1SFSj5nGcj_gp1l3wYbRsXxSIdk0D_g3s,9714
shapely/tests/legacy/test_shared_paths.py,sha256=KZ1FM6s2O315voIw1XOEluwMnfzhyLd91yXnpNmnt7Y,1434
shapely/tests/legacy/test_clip_by_rect.py,sha256=zBID16XD31PYB0Ojls9x-8UTzhjBEL-9CqFYSszz5Vg,4180
shapely/tests/legacy/conftest.py,sha256=dve1hOGWMjaOk58k_RUbU1RvnLCPLopnwGvUSMAmqrk,588
shapely/tests/legacy/test_shape.py,sha256=3F3YHrtDBcl-BtjdMhbXGNaFs5KrCL5r4nB_kZoYilE,1404
shapely/tests/legacy/test_invalid_geometries.py,sha256=K-lRgzKTXcjRoXhfaNOILD6DzR2DO3XJfsNXjbrlpfs,907
shapely/tests/geometry/test_multipoint.py,sha256=y0ewZ0y85HayrjpLPfsrhAXySPz-rcC2KuGrOro2dTg,2435
shapely/tests/geometry/test_collection.py,sha256=j3SPQwuw-L14UvtR3-ZFD7VDckesPPoL7eqRNZcZ5II,2230
shapely/tests/geometry/test_polygon.py,sha256=9__zIzfXrqOBkgAmpR_FHa1uMkTP9FDfv4I3yrjXw1k,15293
shapely/tests/geometry/test_decimal.py,sha256=xGPoBZ7kR6dzoXQeVufZv3pA-DE9sA3O4TbuFPsVWdg,2750
shapely/tests/geometry/test_equality.py,sha256=KiwjrFOhueS7-emfTgEfPj0m2BtBX-8FQT7UolgGRGQ,7982
shapely/tests/geometry/test_format.py,sha256=Q3iiOjRz3UpvPrhc6_TFQXFDKxgf5pbbJ8gvHCLM7MU,4556
shapely/tests/geometry/test_multipolygon.py,sha256=WTNTrkEUNhgokvYuIA6oblF1wkAnvYskS5417865AIs,4074
shapely/tests/geometry/__init__.py,sha256=47DEQpj8HBSa-_TImW-5JCeuQeRkm5NMpJWZG3hSuFU,0
shapely/tests/geometry/test_geometry_base.py,sha256=Y9VFkUA9cHhfWsRSigeorH8yue6tTmtyrBrp2UjuFGs,7030
shapely/tests/geometry/test_hash.py,sha256=EtQyaRUtTUIL8AiCjyvVC4KRJQ_E3uqr-4Wn_oaW-Ac,673
shapely/tests/geometry/test_point.py,sha256=UstZcumfejqgdueP4xyhNaVRGGnwUZfFC5bUX3cvBX0,4676
shapely/tests/geometry/test_multi.py,sha256=SejfKyNSH27bxQnLwouRHnxgrlQV6egaxLADR4G9ZBY,304
shapely/tests/geometry/test_linestring.py,sha256=e_81lvGmqWm7GT_0OvzDcoldoBPju-7g-01zbUpSGBE,6339
shapely/tests/geometry/test_multilinestring.py,sha256=yFW5ctDIVvzrsPm8v9tnQByho6fs3ngR8nV31l6F1EU,2835
shapely/tests/geometry/test_coords.py,sha256=RI0mScQ-mLtVuQQsNfvPfMwPLgATcD6Kj3l9-PhXP80,2687
shapely/tests/geometry/test_emptiness.py,sha256=FIPHsZWLgRoehKpvoezAsqjjzJnosL7y08a-AbHlbA4,2362
