guppy3-3.1.5.dist-info/METADATA,sha256=YCtVwF6qFcCbpBoRwu1UnKTza9YS_WZ3awQirbtnvwQ,6593
guppy3-3.1.5.dist-info/RECORD,,
guppy3-3.1.5.dist-info/top_level.txt,sha256=7Ndk4OvW39B2jGI117WIYQcH-us34KGvyw6zqGL3Ux8,6
guppy3-3.1.5.dist-info/WHEEL,sha256=YnLCwhzAibpPa4I2wVby4cQOpj8-JkNAXziWbX6BFBk,110
guppy3-3.1.5.dist-info/LICENSE,sha256=aSwiGjYUjJ0uF1k2Rs0F6riy5j4MF5RppFUL1wo594k,1175
guppy/_version.py,sha256=mJYMSuyIO1XLlqliQBPP2ZXiCh0I_4jEqY_Jb1EZKCM,22
guppy/heapy/heapyc.cpython-313-i386-linux-musl.so,sha256=kyCFa-rJQtluFlb9-HNU4ahCHtbTkHtxIVEdt8-vlLM,577872
guppy/heapy/test/test_Path.py,sha256=nq6fZhI7XK6w_oESPjurgaoJ4pioKveYWkUING7VevM,28959
guppy/sets/setsc.cpython-313-i386-linux-musl.so,sha256=keqmbryO_8HIMiK20Scrho0pZOr4swlPi_qGCb4Yl_Q,399556
