Metadata-Version: 2.4
Version: 0.6.13
Summary: Bosch Smart Home Controller API Python Library
Home-page: https://github.com/tschamm/boschshcpy
Author: Clemens-Alexander Brust, Thomas Schamm
Author-email: cabrust@pm.me, thomas@tschamm.de
License: bsd-3-clause
Project-URL: Bug Reports, https://github.com/tschamm/boschshcpy/issues
Project-URL: Source, https://github.com/tschamm/boschshcpy
Keywords: boschshcpy
Classifier: Operating System :: OS Independent
Classifier: Programming Language :: Python
Classifier: License :: OSI Approved :: BSD License
Requires-Python: >=3.10, <4
License-File: LICENSE
Requires-Dist: cryptography>=41
Requires-Dist: getmac<1,>=0.8.2
Requires-Dist: requests>=2.22
Requires-Dist: zeroconf>=0.28.0
Dynamic: author
Dynamic: author-email
Dynamic: classifier
Dynamic: description
Dynamic: description-content-type
Dynamic: home-page
Dynamic: keywords
Dynamic: license
Dynamic: license-file
Dynamic: project-url
Dynamic: requires-dist
Dynamic: requires-python
Dynamic: summary
# Bosch Smart Home Controller API Python Library
[![PyPI version](https://img.shields.io/pypi/v/boschshcpy.svg)](https://pypi.org/project/boschshcpy/)
[![Tests](https://github.com/tschamm/boschshcpy/actions/workflows/tests.yml/badge.svg)](https://github.com/tschamm/boschshcpy/actions/workflows/tests.yml)
[![BuyMeCoffee][buymecoffeebadge-tschamm]][buymecoffee-tschamm]
[![BuyMeCoffee][buymecoffeebadge-mosandlts]][buymecoffee-mosandlts]
Python client library for the Bosch Smart Home Controller (SHC) local REST API.
Communicates directly with the controller over mutual-TLS on the local network — no cloud, no Bosch account required.
The official API documentation is available at [github.com/BoschSmartHome/bosch-shc-api-docs](https://github.com/BoschSmartHome/bosch-shc-api-docs).
Beyond the documented OpenAPI surface, this library also models several endpoints that Bosch's own Android
app uses but never published a spec for (firmware updates, the local automation-rule engine, hydraulic
balancing, ...) — these were traced by decompiling the official app and/or capturing live traffic against a
real controller. Anything not confirmed against real hardware is called out explicitly below and in the
relevant docstrings.
## Contents
- [Quick start](#quick-start)
- [Architecture](#architecture)
- [Install](#install)
- [Supported device services](#supported-device-services)
- [Supported device models](#supported-device-models)
- [Capabilities](#capabilities)
- [Usage](#usage)
- [Rawscans](#rawscans-command-line)
- [Maintainers & support](#maintainers--support)
## Quick start
**1 — Install**
```bash
pip install boschshcpy
**2 — Register a client certificate**
Press and hold the SHC front button until the LED flashes (registration mode, ~10 s), then:
```bash
boschshc_registerclient -ip 192.168.x.x -pw YOUR_SHC_PASSWORD
This writes `cert.pem` and `key.pem` to the working directory.
**3 — Use the session**
```python
import boschshcpy
session = boschshcpy.SHCSession("192.168.x.x", "cert.pem", "key.pem")
session.information.summary()
session.start_polling()          # starts long-poll thread; callbacks fire on state change
# ... your code ...
session.stop_polling()
> For asyncio / Home Assistant usage see the [async example](#python-api-async--aiohttp) below.
## Architecture
```mermaid
graph TD
    APP("Your code / Home Assistant\nSHCSession or SHCSessionAsync")
    DH("SHCDeviceHelper\ntyped per-category device accessors")
    DOM("Domains\nSHCIntrusionSystem, SHCWaterAlarmSystem,\nSHCAutomationRule, SHCEmma")
    DS("SHCDeviceService\nservice state + event/callback dispatch")
    RA("SHCAPI / SHCAPIAsync\nHTTP + mTLS client, retry-on-drop")
    POLL("SHCPollingThread\n(sync client only)")
    SHC("Bosch Smart Home Controller")
    DEV("Zigbee / HomeMaticIP / Bluetooth\ndevices, LEDVANCE & Hue lights, cameras")
    APP --> DH
    APP --> DOM
    DH --> DS
    DOM --> RA
    DS --> RA
    APP -.->|start_polling / async context manager| POLL
    POLL -->|long-poll GET, port 8446| RA
    RA -->|"REST, port 8444/8446\nclient-cert mTLS"| SHC
    SHC <-->|Zigbee / HmIP / vendor bridges| DEV
**Sync path** (`SHCSession` + `SHCAPI`): blocking `requests`/`urllib3` calls. A dedicated
`SHCPollingThread` owns the long-poll subscription; state-change callbacks fire from that thread, so any
UI/event-loop consumer must marshal back onto its own thread. Suitable for scripts and simple consumers.
**Async path** (`SHCSessionAsync` + `SHCAPIAsync`): fully `asyncio`-native, built on `aiohttp`. This is
what the [boschshc-hass](https://github.com/tschamm/boschshc-hass) Home Assistant integration uses in
production. Every write method has an `async def async_*` coroutine counterpart; the long-poll loop runs as
a plain asyncio task, no separate thread needed. Both clients retry once on a dropped connection
(`SHCConnectionError`), and both tolerate partial/malformed long-poll messages without stalling the poll
loop.
### Domain model
```mermaid
graph LR
    S["SHCSession /\nSHCSessionAsync"]
    S --> D["devices\n(SHCDevice subclasses,\nvia device_helper buckets)"]
    S --> R["rooms\n(SHCRoom)"]
    S --> SC["scenarios\n(SHCScenario)"]
    S --> AR["automation_rules\n(SHCAutomationRule)"]
    S --> UDS["userdefinedstates\n(SHCUserDefinedState)"]
    S --> MSG["messages\n(SHCMessage)"]
    S --> INFO["information\n(SHCInformation)"]
    S --> IDS["intrusion_system\n(SHCIntrusionSystem)"]
    S --> WA["water_alarm_system\n(SHCWaterAlarmSystem, optional)"]
    S --> E["emma\n(SHCEmma, grid power)"]
    D --> SVC["device_service(name)\n(SHCDeviceService)"]
    SVC -->|state changes, events| CB["subscribe_callback()"]
Every device, room, domain and service tracks its own raw JSON state and refreshes itself either from a
targeted `short_poll()`/`refresh()` call or from the long-poll callback dispatch — nothing here does a
blind full re-enumeration on every update.
## Install
Requires Python ≥ 3.10.
```bash
Current PyPI version: **0.6.1**
## Supported device services
TemperatureLevel, HumidityLevel, RoomClimateControl, ShutterContact,
ValveTappet, PowerSwitch, PowerMeter, Routing, PowerSwitchProgram,
PresenceSimulationConfiguration, BinarySwitch, SmokeDetectorCheck, Alarm,
ShutterControl, CameraLight, PrivacyMode, CameraNotification,
IntrusionDetectionControl, Keypad, LatestMotion, AirQualityLevel,
SurveillanceAlarm, BatteryLevel, Thermostat, WaterLeakageSensor,
WaterLeakageSensorTilt, HeatingCircuit, PirSensorConfiguration,
SmartSensitivityControl, DetectionTest, WalkTest, LatestTamper, PollControl,
PetImmunity, OccupancyDetection, MultiLevelSwitch, ChildProtection,
SwitchConfiguration, DimmerConfiguration, Bypass, OutdoorSiren,
CommunicationQuality, BoilerHeating, and more
## Supported device models
| Model key | Description |
| `SWD` / `SWD2` / `SWD2_PLUS` / `SWD2_DUAL` | Shutter Contact Gen 1 + Gen 2 (incl. 2 Plus, Dual) |
| `BBL` | Shutter Control |
| `MICROMODULE_SHUTTER` / `MICROMODULE_AWNING` | Micromodule Shutter / Awning |
| `MICROMODULE_BLINDS` | Micromodule Blinds (with tilt) |
| `PSM` | Smart Plug |
| `PLUG_COMPACT` / `PLUG_COMPACT_DUAL` | Smart Plug Compact |
| `BSM` | Light Switch BSM |
| `MICROMODULE_LIGHT_CONTROL` / `MICROMODULE_LIGHT_ATTACHED` | Micromodule Light Control / Attached |
| `MICROMODULE_RELAY` | Micromodule Relay (switch and impulse types) |
| `MICROMODULE_DIMMER` | Micromodule Dimmer |
| `SD` / `SMOKE_DETECTOR2` | Smoke Detector Gen 1 + Gen 2 |
| `SMOKE_DETECTION_SYSTEM` | Smoke Detection System |
| `CAMERA_EYES` | Camera Eyes |
| `CAMERA_360` | Camera 360 |
| `CAMERA_OUTDOOR_GEN2` | Camera Outdoor Gen 2 |
| `ROOM_CLIMATE_CONTROL` | Room Climate Control (thermostat group) |
| `HEATING_CIRCUIT` | Heating Circuit |
| `BOILER` | Multiroom Boiler Control (room-linked heat-demand device — spec-only, **not live-tested**, no owned hardware) |
| `TRV` / `TRV_GEN2` / `TRV_GEN2_DUAL` | Thermostat (Radiator Valve) Gen 1 + Gen 2 |
| `THB` / `BWTH` / `BWTH24` | Wall Thermostat |
| `RTH2_BAT` / `RTH2_230` | Room Thermostat 2 |
| `WRC2` / `SWITCH2` | Universal Switch |
| `MD` / `MD2` | Motion Detector Gen 1 + Gen 2 [+M] |
| `PRESENCE_SIMULATION_SERVICE` | Presence Simulation System |
| `TWINGUARD` | Twinguard (smoke + air quality) |
| `WLS` | Water Leakage Sensor |
| `OUTDOOR_SIREN` | Outdoor Siren (test-alarm trigger, power-supply diagnostics) |
| `LEDVANCE_LIGHT` / `HUE_LIGHT` | LEDVANCE / Hue lights (via SHC) |
## Capabilities
Beyond straightforward device-service read/write, the library covers a number of controller-wide and
cross-device features. Everything here is additive on top of the per-device services above.
### Firmware updates
Two independent, device-agnostic surfaces (APK-traced, not in the official OpenAPI spec):
- **Controller firmware**: `SHCInformation.start_software_update()` /
  `async_start_software_update()` triggers the SHC's own firmware install (`POST
  rootdevices/startSoftwareUpdate`). Controller-wide update status is available via `SHCInformation`
  fields such as `available_version`, `last_update_result`, `update_activation_timeout`, `api_versions`,
  and `shc_generation`.
- **Per-device firmware**: `SHCDevice.firmware_update_state()` / `async_firmware_update_state()` probes
  a device's own firmware lifecycle (`GET devicemanagement/firmware/{deviceId}`) independent of which
  services that device advertises — returns one of `Fetching`, `UpToDate`, `UpdateRunning`,
  `TransferringUpdate`, `AwaitingUserInteraction`, `AwaitingActivation`, `AwaitingActivationTimeout`,
  `UpdatePending`, `UpdateAvailable`, `UpToDateAwaitingUserInteraction`, `Failed`, `Unknown`, or `None` if
  the device has no firmware capability at all (e.g. virtual devices, the controller's own root device).
  `SHCDevice.activate_firmware_update()` / `async_activate_firmware_update()` (`PUT
  devicemanagement/firmware/{deviceId}/activate`) then triggers the actual install.
Both the state probe and the install action have been confirmed end-to-end against real hardware: a
TRV_GEN2 radiator thermostat correctly reported `AwaitingActivation`, matching the Bosch app at the same
moment, and triggering the install walked the real device through
`AwaitingActivation → UpdatePending → Unknown → UpToDateAwaitingUserInteraction` over roughly 90 seconds,
staying fully functional throughout.
### Local automation-rule engine
`SHCAutomationRule` models the native "if this then that" rules the Bosch app's own automation editor
manages (arm/disarm state, keypad presses, astro time, shutter contacts, user-defined states, ... driving
plug/light/climate/camera/notification actions) — an entirely separate system from Home Assistant's own
automations, undocumented in the official spec, APK-traced and confirmed live against a real SHC with 23
real user-configured rules.
```python
for rule in session.automation_rules:
    rule.summary()               # id, name, enabled, trigger/condition/action counts
rule = session.automation_rule("some-rule-id")
rule.set_enabled(False)          # or await rule.async_set_enabled(False)
rule.trigger()                   # or await rule.async_trigger() — fire it manually, right now
rule.refresh()                   # re-fetch just this rule
Deleting a rule is available at the API layer (`session.api.delete_automation_rule(rule_id)`); it isn't
(yet) wrapped as an `SHCAutomationRule` instance method.
### Whole-home water-leak alarm system
`session.water_alarm_system` (an `SHCWaterAlarmSystem`, documented in the official
`WaterDetectionSystem` OpenAPI spec) mirrors the whole-installation alarm state the Bosch app shows,
**separate from** the individual per-device `WaterLeakageSensor`/`WaterLeakageSensorTilt` services exposed
on each `SHCWaterLeakageSensor` (`session.device_helper.water_leakage_detectors`) — the domain aggregates
across all water sensors in the installation, while each device still reports its own local leak/tilt
state independently.
```python
if session.water_alarm_system is not None:      # None on installs with no water sensors at all
    wa = session.water_alarm_system
    print(wa.available, wa.alarm_state)          # AlarmState.ALARM_OFF / WATER_ALARM / ALARM_MUTED
    print(wa.first_incident_device_id, wa.first_incident_room_name, wa.first_incident_timestamp)
    wa.mute()                                    # or await wa.async_mute()
The domain degrades gracefully (simply absent, `session.water_alarm_system is None`) on installations
without any water-leak sensors.
### Intrusion detection (arm/disarm + read-only discovery)
`session.intrusion_system` (`SHCIntrusionSystem`) covers the interactive controls:
```python
session.intrusion_system.arm()                       # default profile
session.intrusion_system.arm_full_protection()        # profile 0
session.intrusion_system.arm_partial_protection()     # profile 1
session.intrusion_system.arm_individual_protection()  # profile 2 (custom)
session.intrusion_system.disarm()
session.intrusion_system.mute()                       # silence an active alarm
print(session.intrusion_system.arming_state, session.intrusion_system.alarm_state)
print(session.intrusion_system.active_configuration_profile)   # Profile.UNKNOWN if unrecognized
print(session.intrusion_system.security_gaps)
On top of that, the API layer exposes read-only discovery endpoints for the intrusion system's own
configuration surface — profiles, per-profile states, and endpoint actuator/trigger listings — laying the
groundwork for exposing intrusion-system *configuration* (not just arm/disarm) to consumers in future:
```python
session.api.get_intrusion_profiles()
session.api.get_intrusion_profile(profile_id)
session.api.get_intrusion_profile_states()
session.api.get_intrusion_endpoint_alarm_actuators()
session.api.get_intrusion_endpoint_alarm_triggers()
session.api.get_intrusion_endpoint_reminder_actuators()
### Thermostat regulation, per-room temperature drop, and related climate surfaces
- **Regulation algorithm** (per thermostat device): `SHCDevice.thermostat_regulation_algorithm()` /
  `async_thermostat_regulation_algorithm()` to read, `set_thermostat_regulation_algorithm()` /
  `async_set_thermostat_regulation_algorithm()` to write — returns `None` (rather than raising) on devices
  without this capability. Confirmed live.
- **Per-room temperature drop** (`SHCRoom`, the anti-frost/window-open compensation setting from the
  app's room-detail screen): `room.temperature_drop_service` / `async_temperature_drop_service`,
  `set_temperature_drop_enabled()` / `async_set_temperature_drop_enabled()`,
  `set_temperature_drop_value()` / `async_set_temperature_drop_value()`. Confirmed live across 12 real
  rooms.
- **Hydraulic balancing configuration** — `SHCAPI`/`SHCAPIAsync`
  `get_hydraulic_balancing_configurations()` / `get_hydraulic_balancing_configuration(config_id)` /
  `put_hydraulic_balancing_configuration(config_id, config)`. **Not in the official OpenAPI spec, APK
  ground-truth, and NOT live-confirmed** — no hydraulic-balancing-capable device is available to test
  against; treat as provisional.
- **Comfort-zone templates** — `SHCAPI`/`SHCAPIAsync` `get_comfort_zone_templates(sensor_id)` /
  `put_comfort_zone_template(sensor_id, comfort_zone)`. Same caveat as hydraulic balancing: APK-derived,
  **not live-confirmed**.
- **Multiroom Boiler Control** (`SHCBoiler` device, `BoilerHeatingService`) — a device family plus a
  room-linking API: `SHCAPI`/`SHCAPIAsync` `get_boiler_capable_rooms()`, `get_boiler_linked_rooms(boiler_id)`
  / `put_boiler_linked_rooms(boiler_id, room_ids)`, `put_boiler_add_room(boiler_id, room_id)`. Fully
  documented in the official spec but was never implemented until 0.6.0. **Not live-tested** — no owned
  Boiler hardware; implemented carefully and directly from the spec, flagged as such in every relevant
  docstring. `SHCBoiler` devices show up through normal enumeration (`session.devices`,
  `session.device(device_id)`) like any other device.
### Whole-home open-doors/open-windows summary
`SHCAPI.get_open_windows()` / `SHCAPIAsync.get_open_windows()` — a single controller-wide summary of which
doors/windows are currently open, live-confirmed against a real installation. The real response is a
strict superset of the documented `Windows` schema — it also includes `bypassedDoors`, `bypassedWindows`,
`openOthers`, `bypassedOthers`, and `unknownOthers` beyond what the official spec documents (reported
upstream).
### Zigbee routing diagnostics
`SHCAPI`/`SHCAPIAsync`/`SHCSession`/`SHCSessionAsync` `get_zigbee_routing_info(device_id)` — an
APK-discovered endpoint (`GET /smarthome/zigbee/routinginfo/{deviceId}`, not in the official docs),
confirmed working against real hardware. Returns an `SHCZigbeeRoutingInfo` (`device_id`,
`aggregated_quality`, and an ordered `route` of `ZigbeeRoutingHop(device_id, quality)` entries) describing
the mesh path back to the controller — useful for diagnosing a flaky Zigbee end device.
### EMMA grid power
`session.emma` (`SHCEmma`) exposes the EMMA energy-management/grid-power domain, when present on the
installation.
## Usage
### Register a new client
Press and hold the button on the SHC controller until the LED starts flashing (registration mode).
Then run:
```bash
boschshc_registerclient -ip YOUR_SHC_IP -pw YOUR_SHC_PASSWORD
This writes a certificate/key pair (`cert.pem` / `key.pem`) to the working directory. The CLI prompts for
the SHC password via a hidden `getpass` prompt if `-pw` is omitted, and writes the private key with `0600`
permissions — neither the password nor the key material is ever printed to stdout or left in shell
history.
More details: [Bosch API docs — register a client](https://github.com/BoschSmartHome/bosch-shc-api-docs/tree/master/postman#register-a-new-client-to-the-bosch-smart-home-controller)
### Python API (sync)
```python
import boschshcpy
# Create session (lazy=False enumerates all devices on connect)
    controller_ip="192.168.25.51",
    certificate="cert.pem",
    key="key.pem",
# Access a device and service
device = session.device("roomClimateControl_hz_5")
service = device.device_service("TemperatureLevel")
print(service.temperature)
# Short-poll a single service
service.short_poll()
# Writing to a service — every writable service field has a setter.
# Sync property setter, or an async_set_* coroutine for the event loop:
device.multi_level_switch = 50              # sync write (PUT to the service)
await device.async_set_multi_level_switch(50)
# Motion Detector II examples (services the SHC exposes for the MD2 [+M]):
from boschshcpy.services_impl import DetectionTestService, PollControlService
md2 = session.device_helper.motion_detectors2[0]
md2.set_detection_state_request(                 # start a walk/detection test
    DetectionTestService.DetectionStateRequest.DETECTION_STATE_START)
md2.tamper_protection_enabled = True             # toggle tamper protection
md2.reset_tampered_state()                       # POST resetTamperedState
md2.long_poll_interval = PollControlService.PollControlState.SHORT  # orientation-light response
print(md2.profile, md2.supported_profiles)       # installation profile (read-only unless writable, see below)
md2.set_profile("OUTDOOR")                       # write the installation profile (validated against supported_profiles)
# Start long-poll thread (non-blocking)
# ... do work, handle callbacks ...
# Stop polling
# Arm the intrusion detection system
# Trigger the controller's own firmware update
session.information.start_software_update()
# Fire a local automation rule manually
session.automation_rules[0].trigger()
# Raw API dump
scan_result = session.rawscan(command="devices")
### Python API (async / aiohttp)
```python
import asyncio
import boschshcpy
async def main():
    session = boschshcpy.SHCSessionAsync(
        key="key.pem",
    async with session:
        for device in session.device_helper.smart_plugs:
            await device.async_set_state(True)  # turn on
            print(session.water_alarm_system.alarm_state)
asyncio.run(main())
### Device helper accessors (`SHCSession.device_helper`)
`SHCDeviceHelper` exposes typed properties for each device category:
shutter_contacts, shutter_contacts2, shutter_controls,
micromodule_shutter_controls, micromodule_blinds, micromodule_relays,
micromodule_impulse_relays, micromodule_light_controls,
micromodule_light_attached, micromodule_dimmers, light_switches_bsm,
smart_plugs, smart_plugs_compact, smoke_detectors, smoke_detection_system,
climate_controls, heating_circuits, thermostats, wallthermostats,
roomthermostats, motion_detectors, motion_detectors2, twinguards,
universal_switches, camera_eyes, camera_360, camera_outdoor_gen2,
ledvance_lights, hue_lights, water_leakage_detectors,
presence_simulation_system, outdoor_sirens
`SHCBoiler` devices aren't (yet) exposed via a dedicated `device_helper` bucket — access them through
normal device enumeration (`session.devices`, `session.device(device_id)`).
Other session attributes: `session.scenarios`, `session.rooms`, `session.automation_rules`,
`session.userdefinedstates`, `session.messages`, `session.intrusion_system`,
`session.water_alarm_system` (`None` if the installation has no water sensors), `session.emma` (EMMA grid
power), `session.information` (`SHCInformation` — firmware/version/network details).
## Rawscans (command-line)
### Public information
```bash
boschshc_rawscan -ip YOUR_SHC_IP -cert cert.pem -key key.pem public_information
### All devices
```bash
boschshc_rawscan -ip YOUR_SHC_IP -cert cert.pem -key key.pem devices
### Single device
```bash
boschshc_rawscan -ip YOUR_SHC_IP -cert cert.pem -key key.pem device YOUR_DEVICE_ID
### Services of a device
```bash
boschshc_rawscan -ip YOUR_SHC_IP -cert cert.pem -key key.pem device_services YOUR_DEVICE_ID
### Single service of a device
```bash
boschshc_rawscan -ip YOUR_SHC_IP -cert cert.pem -key key.pem device_service YOUR_DEVICE_ID YOUR_SERVICE_ID
### All scenarios
```bash
boschshc_rawscan -ip YOUR_SHC_IP -cert cert.pem -key key.pem scenarios
### All rooms
```bash
boschshc_rawscan -ip YOUR_SHC_IP -cert cert.pem -key key.pem rooms
Example device output:
```json
    "@type": "device",
    "rootDeviceId": "xx-xx-xx-xx-xx-xx",
    "id": "hdm:HomeMaticIP:30xxx",
    "deviceServiceIds": [
        "Thermostat", "BatteryLevel", "ValveTappet",
        "SilentMode", "TemperatureLevel", "Linking", "TemperatureOffset"
    "manufacturer": "BOSCH",
    "roomId": "hz_8",
    "deviceModel": "TRV",
    "serial": "30xxx",
    "name": "Test Thermostat",
    "status": "AVAILABLE"
## Maintainers / support
| Role | |
| Original authors | Clemens-Alexander Brust ([@cabrust](https://github.com/cabrust)), Thomas Schamm ([@tschamm](https://github.com/tschamm)) |
| Co-maintainer | Thomas Mosandl ([@mosandlt](https://github.com/mosandlt)) |
[![Buy tschamm a coffee][buymecoffeebadge-tschamm]][buymecoffee-tschamm]
[![Buy mosandlts a coffee][buymecoffeebadge-mosandlts]][buymecoffee-mosandlts]
Bug reports and feature requests: [github.com/tschamm/boschshcpy/issues](https://github.com/tschamm/boschshcpy/issues)
[buymecoffee-tschamm]: https://www.buymeacoffee.com/tschamm
[buymecoffeebadge-tschamm]: https://img.shields.io/badge/buy%20tschamm%20a%20double%20espresso-donate-yellow.svg
[buymecoffee-mosandlts]: https://buymeacoffee.com/mosandlts
[buymecoffeebadge-mosandlts]: https://img.shields.io/badge/buy%20mosandlts%20a%20coffee-donate-yellow.svg
