Metadata-Version: 2.4
Version: 1.10.0
Summary: Tesla Fleet API library for Python
Author-email: Brett Adams <hello@teslemetry.com>
License-Expression: Apache-2.0
Project-URL: Homepage, https://github.com/Teslemetry/python-tesla-fleet-api
Classifier: Development Status :: 5 - Production/Stable
Classifier: Operating System :: OS Independent
Requires-Python: >=3.13
License-File: LICENSE
Requires-Dist: aiohttp>=3
Requires-Dist: aiofiles>=24
Requires-Dist: aiolimiter>=1
Requires-Dist: cryptography>=43
Requires-Dist: protobuf>=6.32.0
Requires-Dist: tesla-protocol>=0.5.0
Requires-Dist: bleak>=0.22
Requires-Dist: bleak-retry-connector>=3.9
Dynamic: license-file
# Tesla Fleet API
Tesla Fleet API is a Python library that provides an interface to interact with Tesla's Fleet API, including signed commands and encrypted local Bluetooth (BLE) communication. It also supports interactions with Teslemetry and Tessie services.
## Features
- Fleet API for vehicles
- Fleet API for energy sites
- Fleet API with signed vehicle commands
- Bluetooth for vehicles
- Routing and failover across backends for vehicles and energy sites (e.g. Bluetooth/local primary, cloud fallback)
- Teslemetry integration
- Tessie integration
## Installation
You can install the library using pip:
```bash
pip install tesla-fleet-api
## Usage
### Authentication
The `TeslaFleetOAuth` class provides methods that help with authenticating to the Tesla Fleet API. Here's a basic example:
```python
import asyncio
import aiohttp
from tesla_fleet_api import TeslaFleetOAuth
async def main():
    async with aiohttp.ClientSession() as session:
        oauth = TeslaFleetOAuth(
            session=session,
            client_id="<client_id>",
            client_secret="<client_secret>",
            redirect_uri="<redirect_uri>",
        # Get the login URL and navigate the user to it
        login_url = oauth.get_login_url(scopes=["openid", "email", "offline_access"])
        print(f"Please go to {login_url} and authorize access.")
        # After the user authorizes access, they will be redirected to the redirect_uri with a code
        code = input("Enter the code you received: ")
        # Exchange the code for a refresh token
        await oauth.get_refresh_token(code)
        print(f"Access token: {oauth.access_token}")
        print(f"Refresh token: {oauth.refresh_token}")
        # Dont forget to store the refresh token so you can use it again later
asyncio.run(main())
### Fleet API for Vehicles
The `TeslaFleetApi` class provides methods to interact with the Fleet API for vehicles. Here's a basic example:
```python
import asyncio
import aiohttp
from tesla_fleet_api import TeslaFleetApi
from tesla_fleet_api.exceptions import TeslaFleetError
async def main():
        api = TeslaFleetApi(
            access_token="<access_token>",
            session=session,
            region="na",
        try:
            data = await api.vehicles.list()
            print(data)
        except TeslaFleetError as e:
            print(e)
asyncio.run(main())
For more detailed examples, see [Fleet API for Vehicles](docs/fleet_api_vehicles.md).
### Fleet API for Energy Sites
The `EnergySites` class provides methods to interact with the Fleet API for energy sites. Here's a basic example:
```python
import asyncio
import aiohttp
async def main():
            session=session,
            region="na",
        try:
            energy_sites = await api.energySites.list()
            print(energy_sites)
            print(e)
asyncio.run(main())
For more detailed examples, see [Fleet API for Energy Sites](docs/fleet_api_energy_sites.md).
To pair an energy gateway's RSA key over the cloud and compose the resulting
signed local LAN control (via the sibling `aiopowerwall` library) with a
cloud fallback through `EnergySiteRouter`, see [Energy: Local
Control](docs/energy_local_control.md).
### Fleet API with Signed Vehicle Commands
The `VehicleSigned` class provides methods to interact with the Fleet API using signed vehicle commands. Here's a basic example:
```python
import asyncio
import aiohttp
from tesla_fleet_api.tesla.vehicle.signed import VehicleSigned
async def main():
            session=session,
            region="na",
        try:
            vehicle = VehicleSigned(api, "<vin>")
            data = await vehicle.wake_up()
            print(data)
            print(e)
asyncio.run(main())
For more detailed examples, see [Fleet API with Signed Vehicle Commands](docs/fleet_api_signed_commands.md).
### Bluetooth for Vehicles
The `TeslaBluetooth` class provides methods to interact with Tesla vehicles using Bluetooth. Here's a basic example:
```python
import asyncio
from bleak import BleakScanner
from tesla_fleet_api import TeslaBluetooth
async def main():
    scanner = BleakScanner()
    devices = await scanner.discover()
    for device in devices:
        if TeslaBluetooth().valid_name(device.name):
            print(f"Found Tesla vehicle: {device.name}")
asyncio.run(main())
For more detailed examples, see [Bluetooth for Vehicles](docs/bluetooth_vehicles.md).
`get_private_key(path)` loads an existing EC private key or creates a new
unencrypted PEM key file. Newly created key files are created owner-readable
and owner-writable only (`0600`) from the start, with no write-then-chmod
window, and concurrent creators fall back to reading the file that won the
create race.
`VehicleBluetooth` keeps a held BLE connection alive during idle periods by
default with a passive GATT read about every 20 seconds. Pass
`keepalive_interval=None` (or `0`) when creating the vehicle to disable it;
leaving it enabled can keep an already-awake car awake longer, so disconnect or
disable keepalive when vehicle sleep is preferred.
BLE connect/notify failures, and GATT writes rejected before backend I/O, raise
`BluetoothTransportError`, a `TeslaFleetError` subclass, with the original
transport exception chained as `__cause__` when available. A GATT write that
entered backend I/O and then failed or timed out is delivery-ambiguous and
raises `BluetoothTimeout`/`BluetoothUnconfirmedCommand` instead. Mutating BLE
commands use a confirmation ladder controlled by `confirmation` (`"ack"` by
default) and `raise_unconfirmed` (`False` by default): an inconclusive lost
acknowledgement resolves as best-effort success unless you opt in to
`BluetoothUnconfirmedCommand`, while a command proven not to have applied raises
`BluetoothCommandFailed`. See [Bluetooth for Vehicles](docs/bluetooth_vehicles.md)
for the full ladder. Catch `TeslaFleetError` to handle Bluetooth transport
failures (including `bleak.exc.BleakError` and builtin `TimeoutError` from
ESPHome proxies) and response-wait timeouts through the same library error
hierarchy.
`VehicleBluetooth` can also register persistent BLE broadcast listeners for
unsolicited VCSEC `VehicleStatus` updates. Use typed `listen_*` helpers for the
decoded vehicle-status fields, or `listen_broadcast(domain, callback)` for raw
per-domain broadcast messages. Use `listen_connection_status(callback)` for
`True`/`False` BLE session transition notifications. See
[Bluetooth for Vehicles](docs/bluetooth_vehicles.md#connection-status-events)
for the connection-event contract.
### Routing and Failover
The `Router` class composes an ordered list of two-or-more backends that share a common method surface and dispatches each method call down the chain, automatically failing over on most errors. `VehicleRouter` and `EnergySiteRouter` are thin entity-specific subclasses. A common setup is a local `VehicleBluetooth` primary with a cloud fallback (e.g. a `TeslemetryVehicle`), so commands go over Bluetooth when the vehicle is reachable and route to the cloud otherwise:
```python
import asyncio
import aiohttp
from tesla_fleet_api import TeslaBluetooth, Teslemetry
from tesla_fleet_api.router import VehicleRouter
async def main():
        # Primary: local Bluetooth
        tesla_bluetooth = TeslaBluetooth()
        await tesla_bluetooth.get_private_key("path/to/private_key.pem")
        primary = tesla_bluetooth.vehicles.create("<vin>", confirmation="verify")
        # Secondary (fallback): Teslemetry cloud
        teslemetry = Teslemetry(access_token="<access_token>", session=session)
        secondary = teslemetry.vehicles.create("<vin>")
        vehicle = VehicleRouter(primary, secondary)
        try:
            print(e)
asyncio.run(main())
The constructor is `Router(primary, secondary, *more_backends, health=None)`; the two-argument form shown above is fully backward compatible, and any number of extra backends may follow to extend the chain. Each call is tried on the first backend that has the method and, on any exception except `BluetoothUnconfirmedCommand`, retried on the next backend that has it, returning the first success (raising the last error only if every applicable backend fails). Non-callable attributes (e.g. `vin`) resolve to the first backend that has them.
By default the router attempts the primary and fails over on any error, with no up-front probe. You can also pass an explicit `health` check — a `bool`, a sync callable, or an async callable returning `bool` — to decide up front whether to route to the primary or skip straight to the rest of the chain. The health check gates **only the primary** (the first backend); later backends are reached purely through per-command failover.
`EnergySiteRouter` follows the same pattern for energy sites, pairing a duck-typed local `EnergySite`-shaped object (e.g. aiopowerwall's `PowerwallEnergySite`, no dependency added) with a cloud `TeslemetryEnergySite` fallback:
```python
from tesla_fleet_api.router import EnergySiteRouter
router = EnergySiteRouter(local_energysite, teslemetry_energysite)
await router.operation(...)  # local first, cloud on failure
`Router`, `VehicleRouter`, and `EnergySiteRouter` are all importable from `tesla_fleet_api.router` (and, for backward compatibility, from `tesla_fleet_api.tesla`).
Enable `DEBUG` logging for `tesla_fleet_api` to see which backend served a routed call and why failover happened.
> **Warning:** Because a failed call is replayed on the next backend, a non-idempotent command (e.g. `honk_horn`, `actuate_trunk`, `door_unlock`, `charge_start`) that fails _mid-flight_ — after a backend may have already partially applied it — can be **double-executed** (or executed more than once across a longer chain) when it is retried on the next backend. This is a deliberate tradeoff of per-command failover. `BluetoothUnconfirmedCommand` is the exception: it propagates without failover because the BLE command may already have executed. When the primary is `VehicleBluetooth`, pass `confirmation="verify"` to resolve supported mutating command timeouts by state before they reach the router, and set `raise_unconfirmed=True` when callers must see still-ambiguous outcomes instead of the default best-effort success; callers needing exactly-once semantics for other commands should gate dispatch with an explicit `health` check or call the underlying backends directly.
> Dispatch is implemented via `__getattr__`, which does not proxy dunder methods, so `async with Router(...)` does **not** manage a backend's BLE connection lifecycle (`__aenter__`/`__aexit__`). Commands still auto-connect on send; for explicit connect/disconnect reach through `router.primary` (or `router.backends`).
### Debug Logging
Enable the `tesla_fleet_api` logger at `DEBUG` to see each command's command
name, transport/backend, and result. In standalone scripts, configure a handler
first:
```python
import logging
logging.basicConfig(level=logging.DEBUG)
logging.getLogger("tesla_fleet_api").setLevel(logging.DEBUG)
Command log lines use `transport=bluetooth`, `fleet`, `teslemetry`, or `tessie`.
Routers also emit `backend=<ClassName>` lines for each backend tried. See
[Bluetooth for Vehicles](docs/bluetooth_vehicles.md#troubleshooting-enable-debug-logging)
for examples and the signed-command naming details.
REST responses that are valid JSON but not objects, such as `null`, lists, or
scalars, are returned unchanged and log as `result=success`.
### Teslemetry
The `Teslemetry` class provides methods to interact with the Teslemetry service. Here's a basic example:
```python
import asyncio
import aiohttp
from tesla_fleet_api import Teslemetry
async def main():
        api = Teslemetry(
            session=session,
        try:
            print(data)
            print(e)
asyncio.run(main())
For more detailed examples, see [Teslemetry](docs/teslemetry.md).
### Tessie
The `Tessie` class provides methods to interact with the Tessie service. Here's a basic example:
```python
import asyncio
import aiohttp
from tesla_fleet_api import Tessie
async def main():
        api = Tessie(
            session=session,
        try:
            print(data)
            print(e)
asyncio.run(main())
For more detailed examples, see [Tessie](docs/tessie.md).
