Metadata-Version: 2.4
Version: 6.11.1
Summary: Control your Midea M-Smart appliances via local area network
Home-page: https://github.com/midea-lan/midea-local
Author: rokam
Author-email: lucas@mindello.com.br
License: MIT
Classifier: Operating System :: OS Independent
Requires-Python: >=3.12
License-File: LICENSE
Requires-Dist: aiofiles
Requires-Dist: aiohttp
Requires-Dist: colorlog
Requires-Dist: defusedxml
Requires-Dist: deprecated
Requires-Dist: ifaddr
Requires-Dist: pycryptodome
Requires-Dist: platformdirs
Dynamic: author
Dynamic: author-email
Dynamic: classifier
Dynamic: description
Dynamic: description-content-type
Dynamic: home-page
Dynamic: license
Dynamic: license-file
Dynamic: requires-dist
Dynamic: requires-python
Dynamic: summary
# Midea-local python lib
[![Python build](https://github.com/midea-lan/midea-local/actions/workflows/python-build.yml/badge.svg)](https://github.com/midea-lan/midea-local/actions/workflows/python-build.yml)
[![codecov](https://codecov.io/github/midea-lan/midea-local/graph/badge.svg?token=8V0C1T2GJA)](https://codecov.io/github/midea-lan/midea-local)
> [中文版 / Chinese README](./README_hans.md)
Control your Midea M-Smart appliances via local area network.
This library is part of https://github.com/georgezhao2010/midea_ac_lan code. It was separated to segregate responsibilities.
⭐If this component is helpful for you, please star it, it encourages me a lot.
## Getting started
### Finding your device
```python3
from midealocal.discover import discover
# Without knowing the ip address
discover()
# If you know the ip address
discover(ip_address="203.0.113.11")
# The device type is in hexadecimal as in midealocal/devices/TYPE
type_code = hex(list(discover().values())[0]['type'])[2:]
### Getting data from device
```python3
from midealocal.devices import device_selector
token = '...'
key = '...'
# Get the first device
d = list(discover().values())[0]
# Select the device
ac = device_selector(
  name="AC",
  device_id=d['device_id'],
  device_type=d['type'],
  ip_address=d['ip_address'],
  port=d['port'],
  token=token,
  key=key,
  device_protocol=d['protocol'],
  model=d['model'],
  subtype=0,
  customize="",
# Connect and authenticate
ac.connect()
# Getting the attributes
print(ac.attributes)
# Setting the temperature
ac.set_target_temperature(23.0, None)
# Setting the swing
ac.set_swing(False, False)
### command line tool
```python3
python3 -m midealocal.cli -h
## Development
This project uses [uv](https://docs.astral.sh/uv/) for its development environment.
After [installing uv](https://docs.astral.sh/uv/getting-started/installation/):
```bash
git clone https://github.com/midea-lan/midea-local.git
cd midea-local
./scripts/setup.sh          # Linux / macOS / WSL2  (Windows: scripts\setup.ps1)
This creates a `.venv`, installs all dependencies, and sets up the pre-commit hooks.
Run tools with `uv run`, e.g. `uv run python -m pytest ./tests/`. See the contributing
guide for the full workflow and per-OS uv install instructions.
## Contributing Guide
[CONTRIBUTING](.github/CONTRIBUTING.md)
[中文版CONTRIBUTING](.github/CONTRIBUTING.zh.md)
