Metadata-Version: 2.4
Version: 14.1.0
Summary: Python iCalendar implementation (rfc 5545) with built-in recurring event support
Author-email: Allen Porter <allen.porter@gmail.com>
License-Expression: Apache-2.0
Project-URL: Source, https://github.com/allenporter/ical
Project-URL: Documentation, https://allenporter.github.io/ical/
Project-URL: Bug Tracker, https://github.com/allenporter/ical/issues
Project-URL: Changelog, https://github.com/allenporter/ical/releases
Keywords: icalendar,ics,calendar,recurring,rfc5545,vcalendar,rrule,vcard,caldav
Classifier: Development Status :: 5 - Production/Stable
Classifier: Operating System :: OS Independent
Classifier: Programming Language :: Python :: 3.11
Classifier: Topic :: Office/Business :: Scheduling
Classifier: Topic :: Software Development :: Libraries :: Python Modules
Classifier: Typing :: Typed
Requires-Python: >=3.11
License-File: LICENSE
Requires-Dist: python-dateutil>=2.8.2
Requires-Dist: tzdata>=2023.3
Requires-Dist: pydantic>=2.10.4
Provides-Extra: async
Requires-Dist: aiohttp>=3.10.0; extra == "async"
Dynamic: license-file
# ical
[![PyPI version](https://img.shields.io/pypi/v/ical.svg)](https://pypi.org/project/ical/)
[![CI](https://github.com/allenporter/ical/actions/workflows/test.yaml/badge.svg)](https://github.com/allenporter/ical/actions/workflows/test.yaml)
[![Documentation](https://img.shields.io/badge/docs-allenporter.github.io%2Fical-blue)](https://allenporter.github.io/ical/)
A modern Python [RFC 5545](https://datatracker.ietf.org/doc/html/rfc5545) iCalendar library with **built-in recurring event support** — no companion libraries needed.
```python
from ical.calendar_stream import IcsCalendarStream
cal = IcsCalendarStream.calendar_from_ics(ics_content)
# Recurring events are automatically expanded — just iterate
for event in cal.timeline:
    print(event.start, event.summary)
## Why ical?
Most Python iCalendar libraries require two separate packages to handle recurring events:
```python
# The typical ecosystem approach — two libraries, two APIs
import icalendar
import recurring_ical_events
cal = icalendar.Calendar.from_ical(ics_content)
events = recurring_ical_events.of(cal).between(start, end)
`ical` handles this natively with a single, unified [`Timeline`](https://allenporter.github.io/ical/) interface, with a Pythonic API and validated inputs.
| Feature | `ical` | `icalendar` | `ics.py` |
| Built-in recurrence expansion | ✅ | ❌ needs `recurring-ical-events` | ❌ |
| Pythonic attribute access (`event.start`, `event.summary`) | ✅ | ❌ (`event.get('DTSTART').dt`) | ✅ |
| Input validation with clear error messages | ✅ | ❌ | ❌ |
| Full type annotations (`py.typed`) | ✅ strict `ty` | ✅ v7+ | ❌ |
| Application-level store API | ✅ | ❌ | ❌ |
| RFC 7986 / RFC 6868 / RFC 8536 | ✅ | partial | ❌ |
| Active maintenance | ✅ | ✅ | ⚠️ stalled |
## Used By
- [**Home Assistant**](https://www.home-assistant.io/) — powers the [Local Calendar](https://www.home-assistant.io/integrations/local_calendar/), [Remote Calendar](https://www.home-assistant.io/integrations/remote_calendar/), and [Google Calendar](https://www.home-assistant.io/integrations/google/) integrations (including serving locally-synced calendars for performance)
## Installation
```bash
uv add ical
Or with pip:
```bash
pip install ical
Requires Python 3.11+.
Fetching calendars from a url asynchronously (see below) requires the optional `async` extra, which pulls in [`aiohttp`](https://docs.aiohttp.org/):
```bash
pip install ical[async]
## Quickstart
### Reading an .ics file
Parse a calendar file and iterate over events in chronological order, with recurring events automatically expanded:
```python
from pathlib import Path
from ical.exceptions import CalendarParseError
filename = Path("calendar.ics")
with filename.open() as ics_file:
    try:
        cal = IcsCalendarStream.calendar_from_ics(ics_file.read())
    except CalendarParseError as err:
        print(f"Failed to parse '{filename}': {err}")
    else:
### Fetching a remote .ics url
Fetching a remote calendar over HTTP without blocking the event loop requires the optional `ical[async]` extra:
```python
cal = await IcsCalendarStream.calendar_from_url("https://example.com/calendar.ics")
An existing `aiohttp.ClientSession` can be passed in via the `session` argument to reuse connection pooling; otherwise a session is created and closed automatically for the request.
### Creating a calendar
```python
from datetime import date
from ical.calendar import Calendar
from ical.event import Event
cal = Calendar()
cal.events.append(
    Event(summary="Team standup", start=date(2024, 1, 15), end=date(2024, 1, 16)),
    print(event.summary)
### Writing an .ics file
```python
with Path("output.ics").open("w") as f:
    f.write(IcsCalendarStream.calendar_to_ics(cal))
### Recurring events
Recurring events are stored once in the calendar but automatically expanded by the `Timeline`:
```python
from ical.types.recur import Recur
cal = Calendar()
cal.events.append(
    Event(
        summary="Weekly standup",
        end=date(2024, 1, 16),
        rrule=Recur.from_rrule("FREQ=WEEKLY;COUNT=10"),
# All 10 occurrences are expanded automatically
### Application-level API
For managing calendar state in an application (ensuring timezones are set correctly, editing individual instances of recurring events, etc.), use `ical.store`:
```python
from ical.store import EventStore
from datetime import datetime, timezone
store = EventStore()
store.add(Event(summary="Meeting", start=datetime(2024, 1, 15, 9, tzinfo=timezone.utc)))
See the [full documentation](https://allenporter.github.io/ical/) for the complete API reference.
## Technical Guides
We publish detailed technical guides exploring the library's design:
- [Timezones & Custom TzInfo](https://allenporter.github.io/ical/ical/guides/timezone.html)
- [Recurrence Rules & Event Generation](https://allenporter.github.io/ical/ical/guides/recurrence.html)
- [Calendar Compatibility Layer](https://allenporter.github.io/ical/ical/guides/compatibility.html)
## Supported RFCs
- [RFC 5545](https://datatracker.ietf.org/doc/html/rfc5545) — Internet Calendaring and Scheduling Core Object Specification (iCalendar)
- [RFC 6868](https://datatracker.ietf.org/doc/html/rfc6868) — Parameter Value Encoding in iCalendar and vCard
- [RFC 7986](https://datatracker.ietf.org/doc/html/rfc7986) — New Properties for iCalendar
- [RFC 8536](https://datatracker.ietf.org/doc/html/rfc8536) — The Time Zone Information Format (TZif)
## Comparison with other libraries
`ical` is designed for applications that need a complete, modern solution. You may prefer an alternative if:
- **[`icalendar`](https://github.com/collective/icalendar)** — You need low-level control over raw iCalendar components, jCal (JSON) support, or maximum ecosystem compatibility. You prefer to expand recurring events manually and don't mind a second library ([`recurring-ical-events`](https://github.com/niccokunzmann/python-recurring-ical-events)). You need to support legacy Python versions (3.8+) that `ical` does not target.
- **[`ics.py`](https://github.com/ics-py/ics-py)** — You need a simple read-only script and do not require recurrence support. Note: no stable release since 0.7.2 (August 2021).
## Contributing
See [CONTRIBUTING.md](CONTRIBUTING.md) for setup and development instructions.
