ephem-4.1.2.dist-info/LICENSE,sha256=ae8hz349Ca4u6W1nC2rInr0nB7BHi38Os7aNI80aj9k,1307
ephem-4.1.2.dist-info/WHEEL,sha256=wfQ2JplaiAGNsImR_TCpfsd6u4nR_5UG1l3fd4C2Gwo,114
ephem-4.1.2.dist-info/top_level.txt,sha256=a4VcrJBvMRDa8lfZHPytad3r-KyBBWsRABWGRqfmQIQ,6
ephem-4.1.2.dist-info/RECORD,,
ephem-4.1.2.dist-info/METADATA,sha256=auC-CdiuTLg8h9C1f25nPMxbDzkofhgkRakhUGqXVMI,5760
ephem/_libastro.cpython-311-aarch64-linux-musl.so,sha256=93aTdYkA7Y9BqRc3BUt_otWU6n6tFvYEOjFwoT9Q3Wg,2010904
ephem/cities.py,sha256=ZXk6Xt-5jBGJSTuTg8MDqidfGeto3mte3nf3E54UzuE,10672
ephem/stars.py,sha256=hkuwlKIDPfyHTrc2n7aWmuABpnjCYjJgiUUakKC1ElQ,9246
ephem/__init__.py,sha256=kMKCoAvMaiB_nSkJxk3IobtGFL5TVKFqOPSXb6af8GY,24312
ephem/doc/tutorial.rst,sha256=nTA93DUuH98I6299bm3-gBJdl2sf2SYkDsRb1B5iBRo,29098
ephem/doc/rise-set.rst,sha256=4jdtO2Xz331OfRT0lWHHBFD5Ia_mANdOS0RmcvbU624,4433
ephem/doc/index.rst,sha256=485MNqi6o44V2MA8vrrQhrxE922PUlEU4AGKUzqMAN8,5819
ephem/doc/date.rst,sha256=Zv40eYNAJh3o_lBf2tuQxQ3SJOeNlqavYHLShfO-gn8,7854
ephem/doc/CHANGELOG.rst,sha256=LMGPfS3XRuMTU7T_jrMyGz34tIXO-IAM1664wSu0D-A,20661
ephem/doc/newton.rst,sha256=icIdwrWXtRi3bY8kykEx6By4hi3HBVn_9lIvvaHjuJs,3306
ephem/doc/examples.rst,sha256=DnrMV8TOrNzgL1Sh124a5W54t5tIOwfbrokh7-67ZRk,4130
ephem/doc/toc.rst,sha256=UNZWoTPlMUADK3bdFRqfMo8PVRHmXwlScqhf_0_f2Vc,220
ephem/doc/coordinates.rst,sha256=W51vaUTQpkS1Bg_OvVDG8L3CxusTQpn7OTkyhVXNAls,5715
ephem/doc/catalogs.rst,sha256=wXMxPWcnVcwzdUOEHuOGNPzwXnXQKWL0FUdSwhP2lMY,1607
ephem/doc/radec.rst,sha256=SQIoUAvELFlicL6yLh_BsjLDaJzarH6vdF9bfC4DvEA,8615
ephem/doc/angle.rst,sha256=fin6_CiQ5V5q6KO0Kw7wqxyfWR1tSw8V4CRXcugWZF8,3893
ephem/doc/quick.rst,sha256=NyilLwvlYYq8p1XsPTZ5asyfW4c-gYYQa7B4cEAIMb4,31217
ephem/tests/test_observers.py,sha256=igrupoz3c8S4d_z_I33YQnw6PWPcOk-yuBmf2eBAfpU,1412
ephem/tests/test_locales.py,sha256=2qPa9-q0RrUF79Fhju4qgMBYMtnK8tDJJ-sVJ4FNE_M,1307
ephem/tests/test_jpl.py,sha256=67Uc1aFw89FS2knKulEzP78BPczLIMMqBBDdHzZ6x9s,3026
ephem/tests/test_bodies.py,sha256=7W87mbKBVCkvOvyL3Ok9ahhB_mdjdb9TOAkJrkm2qoU,12776
ephem/tests/test_usno.py,sha256=0BWR-zchhIy1VIzVdpqBxh3o2ogLBGSz9mU94SxVelc,17293
ephem/tests/test_usno_equinoxes.py,sha256=6l7QgT7mRdXp8RzkCt-owNrbUEaOLmGCr97CsdojScw,6856
ephem/tests/test_angles.py,sha256=5TFWhR94_BE15yCLP4JNmjyW56gSqhu8bR0z3Oks2mc,2482
ephem/tests/test_github_issues.py,sha256=DgjnBA8HZvgzTIySxDKj0yxbqmTK4ignWzKVTmqrOX0,4344
ephem/tests/test_rise_set.py,sha256=7RCeBF4WCo8yilMUL9v2hkY46zuGjCO2cXhvf4FfNME,6075
ephem/tests/__init__.py,sha256=47DEQpj8HBSa-_TImW-5JCeuQeRkm5NMpJWZG3hSuFU,0
ephem/tests/test_stars.py,sha256=kE4XgugBZVDMpPrvvJ1MyP5Rdm__4JLDnNSFnorZQx8,9026
ephem/tests/test_launchpad_244811.py,sha256=yquODvnuGd4lkVvg0A_Cb0E5WFwrXgRe0590KSbm-5g,801
ephem/tests/test_dates.py,sha256=IpuvcQTfbeOJSvoyW6qf5EI1lSKa5_sdMNtL7ksEOWU,4843
ephem/tests/test_cities.py,sha256=CkR-Qyf_TnrbGTPPL47PgU2rZrTzxE4vJmhnlEYJPAk,284
ephem/tests/test_satellite.py,sha256=aZnQeSINb-_KV__I4t3Ia--5OOvbFCPZrKF-jFwYrsU,4628
ephem/tests/test_rst.py,sha256=WVhWOCHlpA-FJ6ABfeH_KX3t-xxvjPUJwBv833YzGCM,1113
ephem/tests/test_constants.py,sha256=dnSHpbSVNzvJpwEBb8oHAwbbn-HPoUJFOdDjBEom4LU,434
ephem/tests/test_launchpad_236872.py,sha256=yqI2rNGlvl3E-7omQhghmYI9hxz3JJdmDmGBclHA1m0,371
ephem/tests/usno/astrom_antares.txt,sha256=HY0wBydAY3xHCEDAkugw5eqpmS37DDqqGrFDHNjjioQ,1182
ephem/tests/usno/appgeo_sun.txt,sha256=0nrG8Goi7c6uyvguD14qc0kG04wk3fI6tdqOyO4wg9s,1422
ephem/tests/usno/appgeo_moon.txt,sha256=aO001m6IrVEL_ClZPrzvwKpFDCiVmYvVo1ZQ9npGU7U,1285
ephem/tests/usno/astrom_neptune.txt,sha256=NoCw76dIiS__QGycfalPzUay3CGFC126F6y3DivY5T8,1297
ephem/tests/usno/moon_phases.txt,sha256=xXewmqE9e5swQBBymewbqKD78T46shjqIZ_y_cczXEI,1072
ephem/tests/usno/risettran_rigel.txt,sha256=bnTPdAXfjqi3PAwgiHh4Z2Kk9QkscpkQBZfDLuDnr08,2481
ephem/tests/usno/astrom_mercury.txt,sha256=BDjKHLnhZvHTVZvwldm2GohGObVQmdpIuu1reFhk41c,1297
ephem/tests/usno/apptopo_deneb.txt,sha256=ahSVrMGpKgoQXdA6KjXZd--GLFEa18DALSbYlRD7sUs,1394
ephem/tests/usno/riset_moon.txt,sha256=B5aiWnmYY0ZL5EgYA6WwIDcrPQeIUGreZzVuLK4bukc,5498
ephem/tests/usno/apptopo_moon.txt,sha256=4ZOohYig4RFNGp776sr1zB8fDGlNXFoknSHucWlyaTE,1518
ephem/tests/usno/apptopo_sun.txt,sha256=T1lp6DIvLjINnRBvhhmo_5rzzdt3okxJO_uykzRu5UI,1530
ephem/tests/usno/riset_sun.txt,sha256=7T0HI7EIfZn12OPH9zKS6qWn1TjWXTFIYpTp1FwZoEc,5498
ephem/tests/usno/risettran_moon.txt,sha256=p1H2SKLJaRxBdf5VuLkVEIezH8tbnkjuyB0LoikKtNQ,2042
ephem/tests/usno/appgeo_jupiter.txt,sha256=BsxUUtXf1pJ81fB35tJvnkl5BFKdv_TIK9SCZK1pWyw,1297
ephem/tests/usno/appgeo_deneb.txt,sha256=JYvP718mTL7wUruEZSk9djcd6e8oR1m5y7Y2HvzLe04,1182
ephem/tests/jpl/europa.txt,sha256=sjpMha2yk0vGvRn3T9JNKjOjmdn0c2ziGENmsRMPeAQ,7951
ephem/tests/jpl/hyperion.txt,sha256=2NuqRBkPKC3sjCZooVECUjYy86zkYHTNzIcuqaQjXwY,5683
ephem/tests/jpl/saturn.txt,sha256=6tM6nsXpuBGPYctNKtsNQQxTehSPk5yj8Q012pjeNZo,5721
ephem/tests/jpl/phobos.txt,sha256=UipMa74di2aNeNj1xyN4Tzg3yNHJ-sLEMCRWO9oK_Hk,7957
ephem/tests/jpl/neptune.txt,sha256=HW2Lv2C3xw8Op5e-IfMBSmQO15M9W0X2xwkuf0AZcq4,5239
ephem/tests/jpl/mars.txt,sha256=nKtERJtI2PLAnD3SOhT00xL4gtOBqkH7R-ycikzQyms,7956
ephem/tests/jpl/oberon.txt,sha256=MxqTMs2kNhJW4sTSNxSRIoALO4qciABkEteKWsQSzWY,5233
ephem/tests/jpl/jupiter.txt,sha256=u9HyW4u-u03jJuu4VEeZp2-XC5Rq3UTKoA44ZnN7eBU,6519
ephem/tests/jpl/uranus.txt,sha256=0PZIKfEJZZsEMJTds3OumV3x5g0Jqy-TdV8Vre7qYuo,5239
